2004 Audi A8 Energy Management problems?? Please help
Yup WD = Wire Diagrams in repair manual.
Also what do you meen by battery from fast recharges kaput? What is part is kaput? Thanks
The incorrect battery and charging format for BDM.
I believe this:
explains you're getting a "Request Out of Range" error. How about a picture of the BEM code sticker from your replacement battery and one of exactly what you're typing into the Battery Coding Assistant?
BostonSlaya
Rhode Island, USA
C?ID=240768
I believe this:
I cannot seam to find the sticker for some reason. I can tell you I put it in correctly. I even called VCDS tech support and they walked me threw it and they said there not sure why it's not accepting it. They also said even though it says rejected its saving the changes so I should be fine. Come to find out I'm not. I even changed the last number in the serial as I seen on forums and no luck same error. I also put in other BEM and serial numbers from forums that was also a verta battery. I wish I still had the sticker to show you. I'll keep looking.
   #26
BostonSlaya
Rhode Island, USA
C?ID=240768
I believe this:
Ok I have an update! So for battery coding I finally figured it out. Battery code is rejected every time I have the key turned all the way to the right. The battery codes every time correctly if all you do is put the key in and not turn it.
2nd thing is I found out after setting my alarm I go check on it about 1/2 hour later giving it more than enough time to go to sleep. I noticed that my hazard button is still lite up, the shifter letters are lite up, the two small leds on the rear view mirror are lite up and the overhead cluster LEDs are all lite up(dome light) area. Now the main lights are not on just the buttons where the writing are.
Any ideas on how to fix this? Does this mean the car isn't going to sleep? Or could this be the reason my battery is getting drained all the time? I'm trying to take care of this. Thanks
I'm trying to recall what a 2004 A8 ignition lock is like. But this is certainly something we should make a note of of other A8 owners.
Yep, sure does sound like something has insomnia. The question is what and why.
BostonSlaya
Rhode Island, USA
C?ID=240768
Well I ordered a cd changer to update my Mmi but it can defective. So I purchased another one and will be here soon. I'll update my MMI and see if anything changes. I don't know if this is going to work but I have my car locked and alarm set I'll wait about 45 mins and do a autoscan to see what modules its reading. Maybe this will tell me what's not falling asleep? I have VCDS on and going out my drivers window so the door stays shut. Think this would help?
   #29
Terminal 15 relay energized or failure to release so that ecu can go night nights.
Maybe relay3 J329 but could in fact have a back feed I have seen from a bad Kessy taking on water.
   #30
BostonSlaya
Rhode Island, USA
C?ID=240768
Terminal 15? What's this and why the speculation?
Ok so do you recommend replacing the relay3? J329 module should be replaced? What steps do you think I should take? Also do you think updating my Mmi would help these problems? I'm still on 0.0.6 I think that's the software from when the car was manufactured. I will be updating to 3360 then to 4260 I think is the new one.
I have to say Jack your very informative and know what your doing thanks so much for the help
   #31
Me no........ I'm retarded........Feels good to help though.
Could be a lot of things......... trace out using WD .....this way you will see what I see.
Updates are always advised in addition to reading why the update was done.
Get WD! then lets talk test tracks........ making tracks of the problem.
   #32
BostonSlaya
Rhode Island, USA
C?ID=240768
I have alldata I'm assuming the WD is on there.
I'll reach back out once I look at it.
   #35
BostonSlaya
Rhode Island, USA
C?ID=240768
Or 'Some Data' or 'Wrong Data'. :cool:
So I recived the CD player installed it and first updated to Mmi version 3360 twice to make sure it was properly installed. Then I installed the newest version 4610 twice. All went well so far the car has been sitting for a couple hours and still have 100% battery without any issues!!! The true test will be in the morning but notice the lights inside are not on anymore! 😃. Now the bad news for some reason after the update it now reads a code that there is component protection on my sound system!!!! Great!! Everything works accept my sound for all media. Nav works over the speaks and so on but no sound for cd, or radio. Looks like I have a trip to the stealer to get it off. 😰
   #36
BostonSlaya
Rhode Island, USA
C?ID=240768
Real question is why would it do that after an update??
   #37
So I recived the CD player installed it and first updated to Mmi version 3360 twice to make sure it was properly installed. Then I installed the newest version 4610 twice. All went well so far the car has been sitting for a couple hours and still have 100% battery without any issues!!! The true test will be in the morning but notice the lights inside are not on anymore! ��. Now the bad news for some reason after the update it now reads a code that there is component protection on my sound system!!!! Great!! Everything works accept my sound for all media. Nav works over the speaks and so on but no sound for cd, or radio. Looks like I have a trip to the stealer to get it off. ��
Ah because an update defaults a baseline similar to other eeprom settings grabbing baseline upon wake from re-flash mode, with defaulted eeprom like when recoded, or ADP clear.
The update itself could also have a corrective measure.
It is possible it defaulted it as such by doing double flashes and sparked the CP to be active or the CP for the new CD player requires a marry.
What's the new auto-scan say? Please post it.
   #38
BostonSlaya
Rhode Island, USA
C?ID=240768
New AutoScan below
Friday,12,June,2015,20:22:50:14758
VCDS Version: 15.6.0.0 (x64)
Data version: 20150604
VIN: WAUML44E74N017518   License Plate:
Mileage: 80250km-49865mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 65 72 76
VIN: WAUML44E74N017518   Mileage: 80250km-49865miles
Address 01: Engine        Labels: 077-910-560-BFM.lbl
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0CD531019
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F4DDD45CE847AC7EA-804A
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0027237
   VCID: 2447D2A9E7E2591FB7-8071
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0007597
   Shop #: WSC 23435 000 00000
   VCID: 224BD4B1FDF6572FC5-8077
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0CD531019
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58BFB659EB2ACDFFEB-800D
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 S    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 346IP047514325
   Coding: 0000103
   Shop #: WSC 00000 000 08192
   VCID: 326B24F1AD16C7AF35-8067
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000097794
   Subsystem 3 - Serial number: 0113.11.130000000100010015ÿ
   Subsystem 4 - Serial number: 010015ÿ
            000 -  -
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2015.06.12
                    Time: 20:18:09
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000033347
   Coding: 1151313
   VCID: 5ABBAC519526DFEFDD-800F
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO15122003065A000000000168ÿ†89
   Subsystem 5 - Serial number: 000168ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO18122003065A00000000
   Subsystem 7 - Serial number: 65A000000000072ÿ
00066 - Rear Right Footwell Heater (Z43)
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2015.06.12
                    Time: 20:16:13
                    Voltage: 12.30 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A5B3C9185C68F6F8D-807F
   Subsystem 1 - Part No: 4E1 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 02313
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Serial number: AUZ5ZBC1016260
   VCID: 1C37EA49DF9261DF0F-8049
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E2009013
   VCID: 285FC6999BCABD7F9B-807D
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 65C18FADAC58601760-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3CD006664
   Coding: 0000232
   Shop #: WSC 65537 000 00032
   VCID: 5CB7AA499F1221DFCF-8009
Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C0111AE
   Coding: FCFE7FCD1B2904
   Shop #: WSC 07228 444 53694
   VCID: 2643C8A191DEAB0FA9-8073
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0210
   Revision: 00000014    Serial number: 00000000013996
   Coding: 0000000
   VCID: 61C99BBDB8700C379C-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   Shop #: WSC 22145 444 54027
   VCID: 2541CFADECD8A017A0-8070
00776 - Level Control System Sensor; Left Front (G78)
                    Fault Status: 11101100
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2015.06.12
                    Time: 20:18:09
   VCID: 55A1BF6DBC38F097F0-FFFF
No Faults Found
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H42 1100
   Revision: 00000000    Serial number: 355LL037514310
   VCID: 387F16D94B6A2DFF0B-806D
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000332500063
   Coding: 0004021
   VCID: 1D31E74DC48868D7F8-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0000541
   VCID: 5EB3A041890E33CFA1-800B
02110 - Window Regulator Switch
                    Reset counter: 236
                    Mileage: 80240 km
                    Date: 2015.06.12
                    Time: 20:11:60
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312110112
   Coding: 0065086
   VCID: 275DC5A596D4B20792-8072
   Subsystem 1 - Component:  HDSG keine Antwort
   Component: Neigungssensor  H02 0020
02107 - Trunk or Luggage Compartment Opening Motor (V254)
                    Fault Frequency: 88
                    Reset counter: 196
                    Mileage: 80036 km
                    Date: 2003.10.08
                    Time: 00:02:16
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2015.06.12
                    Time: 20:05:49
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 196
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 224 C    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0470
   Revision: Dev_D01     Serial number: 00000000655399
   Coding: 0000018
   VCID: 1E33E041C98E73CFE1-804B
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 196
                    Mileage: 80251 km
                    Date: 2003.10.08
                    Time: 03:26:43
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000030051
   Coding: 0010111
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T078WE
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM005 0110
   Coding: 0000541
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 23435 444 58960
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 46
                    Voltage: 6.21 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 62CB94B1BD76172F85-8037
01539 - Headlights Not Adjusted
                    Fault Status: 11100101
                    Reset counter: 196
                    Mileage: 80248 km
                    Date: 2015.06.12
                    Time: 20:18:14
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0630
   Revision: 00000000    Serial number: 304CE047583230
   Shop #: WSC 06802 176 59446
   VCID: 31692BFDA810FCB74C-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 A    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0230
   Revision: 00000000    Serial number: 00000004980755
   Shop #: WSC 07212 444 82777
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  341010A32A
   Coding: 303030393135313035444C56413033343130313041333241
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0032845
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   Shop #: WSC 65762 132 574529
   VCID: 5FCD9D458E043AC7AA-800A
01467 - Front Left Tire Pressure Sensor (G222)
                    Fault Status: 11100100
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2003.10.08
                    Time: 06:39:46
                    Voltage: 11.40 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2003.10.08
                    Time: 06:39:47
                    Voltage: 11.40 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2003.10.08
                    Time: 06:39:47
                    Voltage: 11.40 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2003.10.08
                    Time: 06:39:47
                    Voltage: 11.40 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01477 - System Switched Off
            000 -  -
                    Reset counter: 196
                    Mileage: 80252 km
                    Date: 2003.10.08
                    Time: 00:02:57
                    Temperature: 48.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0000013
   VCID: 5DB1A74D840828D7B8-8008
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000335600021
   Coding: 0001208
   VCID: 2149DBBDF8F04C37DC-8074
End-------------------------(Elapsed Time: 03:27)--------------------------
this car is driving me crazy lol
