Hi,
I have added a removable towing hook on my Audi A4 B9.
After adding the control module 69 and adapting the other modules there is still the error on 74-Chassis Control -- Status: Malfunction 0010.
Does anyone see what I've done wrong? Maybe I made a mistake in coding the other modules.....
This is after the towing hook control module is installed but without the adaptation/programming part.
With the adaptation/programming part.
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Chassis Type: F4-AU49 (4M2)
Scan: 01 02 03 08 09 15 16 17 19 29 39 3C 42 44 46 47 52 5F 6D 74
81 A5 AC BB BC CA CF D6 D7
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AD HW: 04L 907 309 L
Component: R4 2.0l TDI H34 1970
Revision: B1H34---
Coding: 0A254032232405083428
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
ROD: EV_ECM20TDI01104L906026AD_001.rod
VCID: 6C81C5D35600369B43B-8038
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 G HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0008
Revision: --H03--- Serial number: 0000000112
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU49.rod
VCID: 43D34E6F1B1E19E3D21-8016
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160292001624
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding: 0CAA489910AB0A9711A3489800835292E6A59A301208508812004A4967A559
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49CF5C473932C3B318D-801C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0071
Coding: 241808295544400D02000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B2ABF5FC645437E9-8062
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001095629
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: E709435800PAG0MUFU02
Rear A/C control head:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07501143E17900CD01458715582E00B9110B31080000000000000000200016810A450123025701
VCID: 025D8B6B4484D0EB997-8056
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 160821 043 0813
Serial number: 89435300301623402844
Coding: 5BC7F7
Serial number: 20092060X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 28 06 2016 00474918
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE110081611910398
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 AT HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10277693
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000125376001
65568 - Terminal 30-5
U1415 00 [009] - Open circuit
Reset counter: 240
Mileage: 67403 km
Date: 2021.05.28
Time: 20:23:49
average_Voltage_terminals: 14.50 V
Outside air temperature sensor-Outside air temperature on CAN: 19.50 °C
interior_temperature: 24.50 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 HW: 8W0 959 655
Component: Airbag10.44 H72 0086
Serial number: 003M6007N9XH
Coding: AACCF0C00C800000585400F3C00C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 0655977B68ACECCBB5F-8052
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705A0286Q00278
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706A0286Q01047
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 060 310 16
Serial number: 3577Y00BD204C33492F5
Subsystem 4 - Part No SW: ----------- HW: 442 060 310 16
Serial number: 3587Y00BD204C332F1D7
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 609 16
Serial number: 3517700B721590A4320Y
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 609 16
Serial number: 3527700B321590A1236Y
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 210 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500BF21F10C2E34J
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 210 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BF21F10C30303
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 809 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B121F10C2A1B+
Subsystem 10 - Part No SW: ----------- HW: 442 430 809 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00A71FBD72324CT
Subsystem 11 - Part No SW: ----------- HW: 442 430 809 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00A71FBD72222BQ
Part No SW: 4M0 907 129 JD HW: 4M0 907 129 JD
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7BA3F68F236EA123DA1-802E
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H15 0307
Coding: 04A468C078880008002069601000400000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU73.rod
VCID: 42DD4B6B040410EBD97-8016
16777024 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
[BCME_0x23 communication error bap_error_timeout heartbeat]
Reset counter: 54
Mileage: 67999 km
Date: 2021.06.19
Time: 16:58:57
Part No SW: 4M2 907 468 C HW: 4M2 907 468 A
Component: Gateway H15 0098
Revision: 4S040002 Serial number: 0244S00B616923
Coding: 0301000100000E4041070000005900124C900007000000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002060
ROD: EV_GatewCONTIAU736_002_AU49.rod
VCID: 3829298352D84A3B773-806C
Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
Component: J453 MFL H04 0002
Serial number: 20160907052133 20608
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 5982361004
16646149 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 58
Mileage: 68210 km
Date: 2021.06.22
Time: 08:00:05
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A9E98312588A3BB73-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
VCID: 34311DB34EB0AE5B5BB-8060
Part No SW: 4M0 959 793 G HW: 4M0 959 793 C
Component: TSG FS 009 0052
Serial number: 0000222046492
Coding: 005F0B2050000080000110B0
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 09008380008000
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X_002.rod
VCID: 40D941630A0802FBCF3-8014
Part No SW: 8W0 907 064 BB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0328
Coding: 01340000000000E0630980006600080031000000004B02502F04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 011012
ROD: EV_BCM2HellaAU736_011.rod
VCID: 7DA7F8973D7AAF13E45-8028
ID - sensor:
Subsystem 1 - Part No SW: 4M0 959 754 T HW: 4M0 959 754 T
Component: ID-Geber H40 0105
Serial number: 3616000198847009
647169 - Bulb for Left Tail Light
B12BE 13 [009] - Open Circuit
Reset counter: 32
Mileage: 68597 km
Date: 2021.07.18
Time: 14:42:08
Supply voltages-Terminal 30 power supply: 12.093 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.120 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 12 04 38
light_freeze_frame: 00000000 00000000 00000000 00000000
647425 - Bulb for Right Tail Light
B12BF 13 [009] - Open Circuit
Reset counter: 32
Mileage: 68597 km
Date: 2021.07.18
Time: 14:42:08
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA00NUEP
Coding: 0194020800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76B5E7BB184CFC4BA5F-8022
Part No SW: 4M0 959 792 G HW: 4M0 959 792 C
Component: TSG BFS 009 0052
Serial number: 0000221438570
Coding: 005F0B205C000080000110B0
VCID: 41DF446701020BF3C0D-8014
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W0 035 036 C HW: 8W0 035 036 A
Component: MU-P-LN-EU 052 0678
Serial number: A792J0G2511524
Coding: 019402010000000013110002000A00332F000165017001009E
VCID: 33331EAF4BBEA963421-8066
Subsystem 1 - Part No SW: V03 959 802 DE HW: -----------
Component: ECE 2019 --- 0172
Multimedia System 1:
Subsystem 2 - Part No SW: 8W0 919 605 HW: 8W0 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9GBJ0212P
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK122091600030032
Compact disc data bank:
Component: Gracenote2--- --- 1013
3077 - Telephone baseplate
B1051 13 [008] - Open Circuit
[Bracket for mobile phone holder - open circuit]
Reset counter: 72
Mileage: 67785 km
Date: 2021.06.17
Time: 23:10:54
Voltage terminal 30: 12.2 V
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31002228400000
Coding: 0550
VCID: 323D1BABB4A4A06B497-8066
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 E HW: 8W0 907 777 C
Component: Fahrwerk-SG H34 1213
Serial number: 0110160189
Coding: 1000483958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 J HW: 8W1 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161018000615
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3A2D338B6CD4582B817-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090200000402022023A2AD0000FC90F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3B23368F63EE61239A1-806E
1123600 - predictive route data
Reset counter: 71
Mileage: 67549 km
Date: 2021.06.01
Time: 22:10:34
Control Module temperature: 31 °C
Voltage terminal 15: 14.40 V
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 303911A3BAA8927B3F3-8064
Part No SW: 4M0 959 795 G HW: 4M0 959 795 C
Component: TSG HFS 009 0052
Serial number: 0000222673174
Coding: 000F092000000080000010A0
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 44D14D731E101EDBEBB-8010
Component: TSG HBFS 009 0052
Serial number: 0000222673173
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4M0 907 594 HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 608000049202
VCID: 73B3DEAF0B3EE963821-8026
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 B HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001015
VCID: 313F14A7B1A29B7330D-8064
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C73B380C5C4B45F-8042
Component: LED1R H09 0003
End----(Elapsed Time: 02:02, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
Scan: 01 02 03 08 09 15 16 17 19 29 39 3C 42 44 46 47 52 5F 69 6D
74 81 A5 AC BB BC CA CF D6 D7
Revision: B1H34---
Coding: 0A254032233405083428
MTF pump:
Coding: 07501143E17900CD01458715583E00B9110B31080000000000000000200016810A450123025701
Coding: 5BC7F7
Coding: 02005D
Reset counter: 32
Mileage: 68596 km
Date: 2021.07.18
Time: 18:45:01
average_Voltage_terminals: 11.60 V
Outside air temperature sensor-Outside air temperature on CAN: 26.50 �C
interior_temperature: 26.00 �C
Coding: 88001B
Coding: 88001B
Coding: 08A468C078880008012079601000600000000000
Revision: --------
Coding: 0EC002
Coding: 01340000000000E0630980006600480031000000004B02502F04000000040030001F0001000000
ID - sensor:
H40
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anheanger H21 0203
Serial number: 00006789,.+00(
Coding: 0100000202000000
Coding: 05D0
Coding: 9000503958
327793 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Incorrectly_coded_mounting_coding_trailer]
Reset counter: 34
Mileage: 68683 km
Date: 2021.07.20
Time: 21:47:44
Coding: 0404090200000402022023A3AD0000FC90F0C020C020
Revision: --------
Coding: 0EC002
End----(Elapsed Time: 02:14, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
