@DV52 Hi
Thanks for the reply. You may not agree with
@Uwe but I do remember reading your very informative posts about '
lighting channels' over last few months as I was fitting ambient light kit in my A3 8V Sportback.
I don't understand what's being said; simply because there are "free pins" on the doesn't mean that you can allocate "free light channels" to those pins.
Firstly sorry for not being clear enough.
By free pins I did mean
lighting channels in Adaptations in
Module 09 that have
Lasttyp set as 'Not Active' and then I checked on socket C of and those numbers did not have any wires going into.
Correct - except for T73c /34 which according to my , is the pin for the Drive mode selection button ( I assume this switch is not fitted to your car)
My mistake,
pin#34 on T73 socket C is
not free. I have
pin#35,#36, #37 and #61 on socket C and
pin#44 on socket B that are free.
Leuchte32AMBL 2C35, Leuchte33AMBL 3C36, Leuchte34AMBL 4C37, Leuchte31AMBL 1C61 and
Leuchte15AL RB44 have
Lasttyp as 'not active'. See
channel map below.
So, the reason I started exploring light channels was because of the way this kit was behaving that I bought off
AliExpress. It is a mobile App controlled kit, that has a master controller with some lights wired to it and multiple subcontrollers with lights that need power only and the lights on/off and color change is controlled by bluetooth connections to the master controller. I activated pin
#3, #9 and #72 on socket C and started testing the kit with it. I had menu activated so I could control them as Front, and Footwell.
#3, #9 and #72 are the correct pins for cupholder, ambient and footwell, respectively, for my car model.
I noticed the power up/power down pattern, where
#9 was getting powered first, then
#3, then
#72. Anyway, the standard supply has a
dimming up/dimming down effect on these pins. So, the master controller that worked perfectly when powered through power socket/cigaretter lighter power supply, did not behave the same when powered through
#9. Then I realised same issue with
#3 and #72. With cigarette lighter/power socket, that would power on ignition, I could control through App for the light kit, set a color and then when I got into car
next time, the controller would remember that color. But with
#3, #9, #72, the controller would go back to flashing sequence of
red>
green>
blue and would not remember the color selection. I tested this multiple times, to confirm that it has to be
dimming up/dimming down effect causing this 'color memory' loss on the controller.
I managed to confirm my assumption, or so do I believe, when I changed
Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 from
Ambientelicht 1 to
Klemme 30G. The maincontroller then on
#9 behaved as it did with power socket supply.
Klemme 30G was brilliant but that meant I cannot control the lights through
#9, on under
Front.
#3 still responded when I powered up/down through . So, I wanted to explore, if I could use another pin or two from to power up the maincontroller with
Lichtfunktion as
Klemme 30G and have rest of lights through subcontrollers through
pin #9, #3 and #72 on socket C, so I don't have the 'color memory' problem and I have control over the lights in the car.
I'm not sure about the door button light - but once you energize a previously factory disable Leuchte-set, you also activate the inherent protection facilities for the load on the respective pin. platform cars generally don't have in-line fuses for exterior lighting and instead, this surveillance activity is undertaken by the . So, an active Leuchte-set expects to see a minimum electrical current the value of which is determined by the Lasttyp channel setting. If this electrical load doesn't appear - the will flag an error message on the dash because it signifies that the lamp is faulty (i.e. open-circuit)
I tested with
#37 and #61, added terminal pins and then for associated
Leuchte34AMBL 4C37 and
Leuchte31AMBL 1C61, I changed
Lasttyp to
40 - allgemeine LED and changed their
Lichtfunktion to Ambient 1, to Footwell, interior lights, Klemme 15 and Klemme 30G but same problem. I did get 'Circuit Open' fault on vagcom for each of the pins but the problem for me was seeing the yellow warning triangle on dashboard with message of
light fault. I did not notice anything other than that initially, but in the evening I realied that all button/switches on dashboard and central console have the red background light On
but not the doors. Then I checked again by stepping out, locking and unlocking, and I noticed the door button lights flashed On once on ignition and then went off. I tried to switch through light switch and tried clearning errors with vagcom but the issue stayed there. I tried with other free
pins #35 and #36 as well, by changing their
Lasttyp from 'not active' to something else, with only one pin On, with multiple pins On etc. but same problem. So, I gave up on this idea of utilising free lighting channels but I would like to know if those free pins can be used and how they end up upsetting the door switch background lights. I compared Module 09 map before and after to see if anything else has changed by me powering up those free pins but I did not notice anything out of place at all.
From my search I could not work out if there is a lighting channel for those switch button lights anywhere but surely powering up the spare pins was affecting background light for door buttons. By door button switches light I am referring to 'red' glow in the button for door lock, window control, central locking buttons. The same effect can be seen in buttons of central console, dashboard buttons, steering buttons and light switch. The problem was only happening with the door buttons, all other buttons were glowing as normal and all external lights were behaving as expected.
I assume you mean the lights on the door. There can be multiple "door lights", but in general, they are controlled by the respective left/right, front/left door modules. On other version models like the Golf mk7, lights within the door cards are controlled via Leuchte30FR LC72 which is the footwell lighting facility - but according to my , this doesn't happen on Audi A3 8V and the Leuchte-set is disabled on the .
My other query, is linked to ambient lighting again but mainly
the doors. When I activated
door ambient pins and door handle pins, and
#3, #9 and #72, their default behaviour was that, they are Off when car is locked, then when I unlock with key remote, they are still Off, but when I open door they all power On and then when I get into car and close the door, they power Off. I could turn them On manually by turning light switch to 'parking lights' On or they turn On when its dark outside, so when headlights turn On with light switch on Auto. The lights would power Off when I step out of car, lock door and press lock button on key remote.
The only part I did not like with that behaviour was, the lights turning On when opening the door, specially in the day when it is bright and those lights would stay on for so long if the door has been kept open. Maybe the trigger was with driver's door only. So, I wondered if there is a lighting channel type approach that can be used to control their behaviour, if you know a hidden channel somewhere maybe. There is nothing in individual door controllers that I could see.
I spent so much time with lighting kit and getting it right, couldn't wait any longer that I went ahead and
locked
pin #9 onto
Klemme 30G, put main controller on there with maincontroller powered cupholder and armRest light, and 2xsubcontrollers with light source for optic/glow fibre on front dashboard and 2xsubcontrollers with optic fibre for sides of central console.
I left
pin #3 as
Ambientelicht 1 , and that powers up 4 subcontrollers with 2 light sources each, 4 light sources light up another glow fibre on dashboard as well as light in each vent at the front.
#72 has another main controller, that directly powers up the footwell lights but same 'color memory' problem if I left
Lichtfunktion as footwell, or interior lights. So, I have put that on Klemme 15.
Through , I can only control lights under
#3 (
Front) and on
Door. The rest of control is obviously through
Klemme 30G and Klemme 15 and after that I have control through the mobile App.
I had to change
Lasttyp for each of pin
#3, #9 and #72 from 'LED Kleinleistung' to 'allgemeine LED', I tested with 'allgemeine LED bis 6W' and 'allgemeine LED bis 12W' but those pins were certainly not getting 12W or even 6W as the subcontroller with one light source draws no more than 2W. I had even reduced that using voltage divider circuit approach by adding some resistors (
I had to do that in doors for subcontrollers to work as power kept tripping otherwise) to it as kit seemed to work well with 9V battery.
In total I have added 26 lights sources as part of this ambient kit.
I am very curious now about these 'free' lighting channels that did not let me make use of them. I appreciate your response and sorry for this big essay. I tried to format it better but I need bit more experience to make it as easy to read as you did.
I have attached Module 09 data below and I added some photos of the lights that I have fitted in the link
A3 8V Ambient Lighting https://www.dropbox.com/sh/2jjmifzk5vhr5si/AAB8S9ELv33dsUF4LnMsEmiLa?dl=0.
I have to say it was a very big task for me, and not easy if anyone wants to give it a go, but I am happy to talk through if someone is keen.
IDE00002-Transport mode active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA active 9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 8 9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf not active 9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer active 9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel active 9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 1000 ms 9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 1000 ms 9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 1000 ms 9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 1000 ms 9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 1000 ms 9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status active 9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube active 9
IDE01550-Service position 133.197670 ° 2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking DELAY 2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln Yes 2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn active 2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln Yes 2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn normal 2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung active 2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte active 2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen not active 2
IDE02332-Deactivate production mode 0 3
IDE02488-Anti-theft system interior monitoring 100% 1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen not active 3
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf not active 3
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken not active 3
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck active 3
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 3 s 3
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 1 s 3
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 5 s 3
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 5 s 3
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW active 3
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck active 3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel not enabled 4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 100% 4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 100% 4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 100% 4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel installed 4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 4
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset -0.25 ° 13
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit 50.0 %/s 13
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt both sides 13
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold 0.0 km/h 13
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur 100.0 °C 13
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur 95.0 °C 13
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel 90 ° 13
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur 80.0 °C 13
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel 30 ° 13
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold 32.0 km/h 13
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift ECE R48 13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separate 3
IDE04923-ENG115774-Turn signal control-Komfortblinken active 3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 5 3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker SMLS 3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.25% 3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 1.00% 3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht separate 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 60 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren not active 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Fog lamp 5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus automatic 5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 16 5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 2 5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 20 seconds 5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 1 Minute 5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 5
IDE04927-IDE01446-Window heater-Running time of heated front window 600 s 8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung 35.0 °C 8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung 35.0 °C 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH Default 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active 8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn not active 1
IDE04928-ENG115864-Anti-theft protection-Alarmsignal frequency modulated 1
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung driver door contact thatcham 1
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus not active 1
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl 10 Alarme 1
IDE04928-ENG148904-Anti-theft protection-Überwachung Innenentriegelungshebel not active 1
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm keine verzoegerung 1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 4
IDE05142-ENG116621-Access control-automatisches Entriegeln active 4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit active 4
IDE05142-ENG116706-Access control-Autounlock NAR not active 4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 4
IDE05142-ENG115722-Access control-Electrical rear lid not active 4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt active 4
IDE05142-ENG115755-Access control-Notschließfunktion not active 4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 4
IDE05142-ENG115758-Access control-Valet Parking not active 4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash active 4
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 0 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 0 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 35 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 11 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 21 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 3F 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 37 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 41 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 minimize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 minimize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 0 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 0 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 100 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 100 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 100 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 27 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 27 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 100 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 100 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 100 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 100 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 100 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 100 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 100 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 100 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 100 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 100 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 100 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 100 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 100 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 100 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 100 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 100 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 100 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 100 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 0 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 25 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 25 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 100 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 0 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 0 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 0 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 0 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 0 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 25 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 25 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 13 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 13 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 0 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 0 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 3 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 4 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 26 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2E 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2F 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 27 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 3 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 4 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 5 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 6 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 20 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 21 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 1C 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 1D 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 not active 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 not active 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 23 - allgemeine Scheinwerfer 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 23 - allgemeine Scheinwerfer 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 43 - allgemeine LED 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 40 - allgemeine LED 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 12 - Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 12 - Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 8 - allgemeine Glühlampe 12W 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 13 - Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 8 - allgemeine Glühlampe 12W 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 8 - allgemeine Glühlampe 12W 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 8 - allgemeine Glühlampe 12W 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 40 - allgemeine LED 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 11 - Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 11 - Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 23 - allgemeine Scheinwerfer 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 23 - allgemeine Scheinwerfer 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 Always 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 Always 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 Always 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 Always 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 41 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 30 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 0 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 0 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 37 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 45 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 8 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 26 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 26 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 8 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 40 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 45 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 46 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 47 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 48 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 13 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 14 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 0 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 0 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 22 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 23 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 9 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 30 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 30 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 30 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 10 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 0 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 0 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 15 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 15 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 3 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 5 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 30 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 3 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 5 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 0 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 25 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 0 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 0 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 0 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 0 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 0 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 0 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 30 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 0 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 0 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 0 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 30 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 30 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 8 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 8 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 15 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 15 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 30 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 30 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-Anti-theft alarm system vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 09 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 FF F6 06 00 0F 1E 00 85 0F 32 F7 64 23 45 21 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 FF F6 56 00 0F 1E 00 86 28 32 F7 65 0F 43 21 57 1B 03 32 3F 3A 69 58 93 0D 09 A3 03 F5 F6 26 00 0F 19 00 88 0F 2D F7 68 1E 45 21 57 1B 03 22 3F 3A 69 58 93 0C 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 66 23 45 21 57 9B 23 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 20 24 2B 3F 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 20.00 °C 14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 19.00 °C 14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 28.00 °C 14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 27.50 °C 14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 41.00 °C 14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 40.50 °C 14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 50.00 °C 14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 49.00 °C 14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 63.00 °C 14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 62.50 °C 14
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten not active 6
IDE06096-ENG116597-Interior lights-KL30G ohne PWM not active 6
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe not active 6
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten active 6
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung active 6
IDE06096-ENG116595-Interior lights-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung not active 6
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert 50% 6
IDE06425-Dynamometer mode: functional not active 1
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag Daytime running lamps 2
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht active 2
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 2
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 2
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten active 2
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO active 2
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 2
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte not active 2
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 2
IDE07007-ENG148891-Air conditioning/heating function via remote control-Anzahl zulaessiger Remotestarts 2 2
IDE07007-ENG148876-Air conditioning/heating function via remote control-RemoteStart Betrieb Dauer 10 min 2
IDE07356-Position during interval mode 21.197781 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 5
IDE08542-IDE02021-Access control 2-Comfort closing active 6
IDE08542-IDE02022-Access control 2-Comfort opening not active 6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen not active 6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen not active 6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen not active 6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen Yes 6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen Yes 6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung Yes 6
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 6
IDE08542-ENG115671-Access control 2-Regenschließen Permanent 6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen active 6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen active 6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen active 6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen active 6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron not active 6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 500 ms 4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset active 4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 800 ms 4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent not installed 4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung not installed 4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner active 1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 not active 1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
MAS01471-lower stop 26.197776 ° 2
MAS01472-upper stop 166.197637 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 18.197784 ° 2
MAS05056-upper turn position 21.197781 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 3
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -3 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 100.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 95.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 80.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 40.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 20.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 10.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 5.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 3.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 1.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 lx 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 lx 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 lx 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16.00% 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16.00% 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100.00% 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100.00% 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100.00% 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6.00% 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6.00% 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100.00% 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100.00% 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100.00% 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 100 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 150 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 6.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 6.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 16.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 30.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 60.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100.00% 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100.00% 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100.00% 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100.00% 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100.00% 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100.00% 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100.00% 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100.00% 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6.00% 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6.00% 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100.00% 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100.00% 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 2000 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 3000 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 4000 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 5100 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 40 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0 0 lx 8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1 8 lx 8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2 50 lx 8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3 500 lx 8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0 6.00% 8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1 6.00% 8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2 100.00% 8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3 100.00% 8
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 Blinken links Dunkelphase 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 100 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 100 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 23 - allgemeine Scheinwerfer 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 Abbiegelicht links 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 Coming Home oder Leaving Home aktiv 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 100 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 100 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 23 - allgemeine Scheinwerfer 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 Abbiegelicht rechts 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 Coming Home oder Leaving Home aktiv 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 100 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 100 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 3 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 43 - allgemeine LED 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Klemme 30G 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 4 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 40 - allgemeine LED 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Ambientelicht 1 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 Interior lighting 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 12 - Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 Blinken links Dunkelphase 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 12 - Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 Blinken rechts Dunkelphase 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 Blinken rechts Dunkelphase 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 25 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 25 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 13 - Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake lamp 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 Coming Home oder Leaving Home aktiv 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 25 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 25 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 13 - Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake lamp 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 Coming Home oder Leaving Home aktiv 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 100 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake lamp 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 Rueckfahrlicht 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 Coming Home oder Leaving Home aktiv 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 27 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 0 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Coming Home oder Leaving Home aktiv 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 not active 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 27 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 0 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Coming Home oder Leaving Home aktiv 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 not active 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 100 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 Coming Home oder Leaving Home aktiv 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 13 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2E 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 11 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 Coming Home oder Leaving Home aktiv 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 100 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 13 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2F 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 21 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Nebelschlusslicht wenn kein Anhaenger gesteckt 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 Coming Home oder Leaving Home aktiv 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 8 - allgemeine Glühlampe 12W 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 Always 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 8 - allgemeine Glühlampe 12W 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 Always 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 26 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 35 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 8 - allgemeine Glühlampe 12W 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 100 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 40 - allgemeine LED 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Klemme 15 mit Nachlauf bis Fahrzeugstillstand 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 100 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 3 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 Ambientelicht 1 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 100 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 4 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 Ambientelicht 2 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 100 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 5 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 Ambientelicht 3 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 100 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 6 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 Ambientelicht 4 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 0 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 27 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 3F 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 8 - allgemeine Glühlampe 12W 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 Parking light right 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 not active 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 minimize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 100 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 20 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lamps 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 not active 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 Lichthupe generell 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 minimize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 100 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 21 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lamps 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 not active 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 Lichthupe generell 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 100 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 11 - Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 not active 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 100 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 11 - Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 not active 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 100 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 1C 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 37 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 23 - allgemeine Scheinwerfer 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Left high beam 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Lichthupe generell 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 100 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 1D 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 41 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 23 - allgemeine Scheinwerfer 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Right high beam 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Lichthupe generell 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 10 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 100 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 150 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 220 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 253 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
