Phil200tdi
Hi
I've recently bought a 2016 Audi S8 4.0T which is Stock. I'm entirely new to VAG/Audi.
I have a MIL on the dash for Rear Sport Differential Fault. Upon reading the codes it looks like it may be electrical failure in one of the diff oil pressure sensors (Black and Brown plugs). I'm keen to know which it is / Part number. I've run some logs and one (IDE02035-ENG98502) is registering 0.5Bar Pressure engine off and IDE02036-ENG98502 is 0.0 Bar - both have 5V. I've sprayed contact cleaner into the plugs (more in hope than anticipation)... I cant get a response from the module to run pressure tests etc in Basic Settings. I gather that I shouldn't replace more than one at a time and that they need coding to the car...
Any advice on diagnosis and repair would be appreciated:
Saturday,13,February,2021,16:56:24:08840
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUZZZ4H1GN014646 License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 15 16 17 19 1B 22 30 34 36 3B 42 44
46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 A9 BA
VIN: WAUZZZ4H1GN014646 Mileage: 63962km-39744miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (------CTFA) Labels:. 079-907-560-CFS2.clb
Part No SW: 4H0 907 557 C HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0004
Revision: NCH63---
Coding: 022A00326526010B3800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0907557C 001005
ROD: EV_ECM40TFS0114H0907557C.rod
VCID: 30391B446AA17B0BC32-8064
Part No SW: 4H1 927 158 CE HW: 0BK 927 156 AD
Component: 0BK 40TFSIRdW H19 1004
Revision: --H19---
VCID: 75B7EA50D5431E23504-8020
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 T HW: 4H0 907 379 T
Component: ESP PREMIUM H10 0665
Coding: D2FDAB004BBFD500E300
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_005_AU64.rod
VCID: 43D34488CB17F0932E0-8016
0679 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Net_QSP_02_QSP_Ist_Moment]
Reset counter: 147
Mileage: 63311 km
Date: 2021.02.05
Time: 12:18:32
VzRef: 00
Bit Info 1: C0
Bit Info 2: 47
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2C
F-Type: 2E
Uz: 8B
Part No SW: 4H0 907 064 GB HW: 4H0 907 064 GB
Component: BCM2 2.0 H37 0572
Coding: 05B76F4E000000000000
VCID: 6FBBD838B79F24F39A8-803A
Serial number: 2315000205035014
00955 - Key 1
Reset counter: 138
Mileage: 63232 km
Date: 2020.11.22
Time: 12:11:39
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000173893788
Coding: 0038320000047201000001010101112131313333283333
VCID: 343117549E39472BA7A-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 N HW: 4H0 820 043 N
Component: Klima 2 Zonen H20 0210
Coding: 68210028340000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2B030C28438718D3F60-807E
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Fault Frequency: 42
Reset counter: 124
Mileage: 63228 km
Date: 2020.11.20
Time: 11:13:05
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 EB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0367
Revision: 19020001 Serial number: 00001222803601
Coding: 0105001440349FF0F90140C7A0001800009DC30A2F0802018000089461001700004000240B0000
VCID: 6C81CF348689DFEBBFA-8038
Subsystem 1 - Part No SW: 4H2 955 119 D HW: 4H2 955 119 A
Component: WWS641 150721 H38 0100
Serial number: 150820100204
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61007004
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 09 12 2015 00001008
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121533000015502792
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: B8A98CD7000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2313E4082BD7D0934E0-8076
Revision: -------- Serial number: 003P1007MC8Z
Coding: 30333045313430303038554A305234483053
VCID: 3B233C68B3E78853660-806E
Serial number: 3575HRB405F3NJ3CC1AA
Serial number: 3585HRB40693LPS8BHE7
Serial number: 3515JRB405B3K5RQH1P0
Serial number: 3525JRB405D3K5RQOPBK
Serial number: 3554VRB401I5558AG8RL
Serial number: 3564VRB401I5558AHPGT
Revision: -------- Serial number: 01335OL9000HZ
Coding: 000034
VCID: 372B20588F4FAC33828-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Serial number: 13 10 2015 G0030828
Part No SW: 4H0 920 811 G HW: 4H0 920 811 G
Component: TBenGB----NV- H53 0803
Revision: 38081206 Serial number: 658051115592019
Coding: 33A70802BB412600010100
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 2809F324527133CB1B2-807C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 P HW: 4H0 919 204 P
Component: Analoguhr D4 H05 0225
Serial number: 2151023000832
Part No SW: 4H0 907 468 AG HW: 4H0 907 468 AC
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002070256
Coding: C0ED07480C
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: 76B5ED5CC845153B59E-8022
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 52326042511911111755
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 15304001630021200410
U140B 00 [008] - -
[Powermanagement active]
Fault Frequency: 49
Reset counter: 154
Mileage: 62788 km
Date: 2020.07.18
Time: 14:46:57
Voltage terminal 30: 11.2 V
Voltage terminal 15: 0.0 V
Control Module temperature: 23 ∞C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 1
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 090100
VCID: 3A2D396CBC5DB15B7D6-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 001411150001000
0283 - Oil Pressure and Temperature Sensor
C1004 FE [008] - Oil Temp implausible Correlation with Sensor 2
Reset counter: 60
Mileage: 63311 km
Date: 2021.02.05
Time: 12:18:32
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000087831
Coding: 01010101000000000001000102
VCID: 6491A7146E5997ABF7A-8030
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008004
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B1838779F64F3DA8-807A
C10C8 00 [008] - -
Reset counter: 141
Mileage: 63278 km
Date: 2021.01.16
Time: 11:44:39
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000173893786
Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7100SYCX
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3829236482D1A34B8B2-806C
Part No SW: 4H0 959 793 S HW: 4H0 959 793 H
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000169516801
Coding: 011F12005E01628202083002
VCID: 49CF56A0E9BB2AC3E4C-801C
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000001 Serial number: 0000357871
Coding: 011000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D396CBCDDB15B7D6-806E
Revision: 00002001 Serial number: 0375426233
Coding: 011B0E2280B93881F330C784080316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H13 0080
Serial number: A2015000000000858207
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93656570
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000017775
Coding: 030000
VCID: 1C61DFF416A9EF6B8FA-8048
Part No SW: 4H0 959 792 H HW: 4H0 959 792 H
Component: TSG BF H06 0280
Revision: -------- Serial number: 0000169526549
VCID: 3D273270AD738663584-8068
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001658939
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0702307D9316E3E84-8078
Component: MxB-ECU 001 0100
Coding: 02F60A2022130200
VCID: 343117549EB9472BA7A-8060
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E00300
Power module 1 for left matrix headlamp:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E00300
Power module 1 for right matrix headlamp:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E00300
13706000 - Databus
[Empfangener Fehlerwert im Signal Kamera_FDD_Eigenblend_Guete: CAN Message Kamera_Status]
Reset counter: 140
Mileage: 63278 km
Date: 2021.01.16
Time: 11:42:57
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109KZ0F2519303
Coding: 010103010000000001
VCID: 2B030C28430718D3F60-807E
Part No SW: 4H0 035 654 A HW: 4H0 035 670 T
Component: H-BNT-EU H49 0947
Revision: -------- Serial number: 449L40F7530651
Coding: 03010100020BF1EF45908B1E00000003000001000000000000
VCID: 2411E7142ED9D7AB37A-8070
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 4H0 919 604 H HW: 4H0 919 604 H
Component: DU8 D4 SV NB H63 0060
Serial number: AUZ8ZDFBP000N5
Subsystem 3 - Part No SW: 4H2 919 600 L HW: 4H2 919 600
Component: E380 BDT D4 H11 0110
Serial number: 00000000207707
Component: CD-Database 6890
Part No SW: 4H0 959 795 E HW: 4H0 959 795 E
Component: TSG HL H06 0280
Revision: -------- Serial number: 0000165852599
Coding: 010F12004000628202083002
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0130192
Coding: 020F000101000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 331500731
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBBD838B71F24F39A8-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000199122
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393A4086BD790930E0-8036
Component: TSG HR H06 0280
Revision: -------- Serial number: 0000165852598
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN150908 0053
ROD: EV_GSM2x3Mono_AU64.rod
VCID: 2C010F3446891FEBFFA-8078
Component: DPC-SG H27 0081
Coding: E0140000
ROD: EV_OnBoardCamerDPC.rod
0204 - Camera Interference
C1104 00 [008] - -
[SPI_No_connection_to_PPC]
Reset counter: 140
Mileage: 63278 km
Date: 2021.01.16
Time: 11:42:57
Outside temperature: -47.5 ∞C
Voltage terminal 15: 14.2 V
Control Module temperature: 19.0 ∞C
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00024009088501
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00024179125001
Coding: 272FF2
Component: RGS-VL H14 0080
Coding: 00060000031F030000030800424CD8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F1E4061AB7203CCC-8064
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D114C64AD491BB56-8066
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 151022201922
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813006127701
ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:03, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
Monday,08,March,2021,16:29:15:08840
Address 22: AWD Labels: 4H0-907-163.clb
Control Module Part Number: 4H0 907 163 B HW: 4H0 907 163 A
Component and/or Version: 4 Wheel Drive H17 0200
Software Coding:
Work Shop Code:
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026 (AU64)
C1004 FE [136] - Oil Temp implausible Correlation with Sensor 2
Reset counter: 20
Mileage: 64048 km
Date: 2021.02.26
Time: 16:49:54
0262 - Oil Pressure and Temperature Sensor
C1004 01 [137] - Electrical Failure
Reset counter: 20
Mileage: 64048 km
Date: 2021.03.06
Time: 15:40:44
0315 - Oil Pressure and Temperature Sensor
C1004 FC [008] - Short between Oil Temp. 1 and Temp. 2
Reset counter: 60
Mileage: 64061 km
Date: 2021.03.06
Time: 15:54:43
