Differential Oil Pressure and Temperature Sensor
Phil200tdi
Hi
I've recently bought a 2016 Audi S8 4.0T which is Stock. I'm entirely new to VAG/Audi.
I have a MIL on the dash for Rear Sport Differential Fault. Upon reading the codes it looks like it may be electrical failure in one of the diff oil pressure sensors (Black and Brown plugs). I'm keen to know which it is / Part number. I've run some logs and one (IDE02035-ENG98502) is registering 0.5Bar Pressure engine off and IDE02036-ENG98502 is 0.0 Bar - both have 5V. I've sprayed contact cleaner into the plugs (more in hope than anticipation)... I cant get a response from the module to run pressure tests etc in Basic Settings. I gather that I shouldn't replace more than one at a time and that they need coding to the car...
Any advice on diagnosis and repair would be appreciated:
Saturday,13,February,2021,16:56:24:08840
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WAUZZZ4H1GN014646   License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 15 16 17 19 1B 22 30 34 36 3B 42 44
          46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 A9 BA
VIN: WAUZZZ4H1GN014646   Mileage: 63962km-39744miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (------CTFA)       Labels:. 079-907-560-CFS2.clb
   Part No SW: 4H0 907 557 C    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0004
   Revision: NCH63---
   Coding: 022A00326526010B3800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114H0907557C 001005
   ROD: EV_ECM40TFS0114H0907557C.rod
   VCID: 30391B446AA17B0BC32-8064
   Part No SW: 4H1 927 158 CE    HW: 0BK 927 156 AD
   Component: 0BK 40TFSIRdW H19 1004
   Revision: --H19---
   VCID: 75B7EA50D5431E23504-8020
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: D2FDAB004BBFD500E300
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 43D34488CB17F0932E0-8016
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Net_QSP_02_QSP_Ist_Moment]
                    Reset counter: 147
                    Mileage: 63311 km
                    Date: 2021.02.05
                    Time: 12:18:32
                    VzRef: 00
                    Bit Info 1: C0
                    Bit Info 2: 47
                    Bit Info 3: A2
                    Bit Info 4: 00
                    F-Path: 2C
                    F-Type: 2E
                    Uz: 8B
   Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
   Component: BCM2 2.0      H37 0572
   Coding: 05B76F4E000000000000
   VCID: 6FBBD838B79F24F39A8-803A
   Serial number: 2315000205035014
00955 - Key 1
                    Reset counter: 138
                    Mileage: 63232 km
                    Date: 2020.11.22
                    Time: 12:11:39
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000173893788
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 343117549E39472BA7A-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 2 Zonen H20 0210
   Coding: 68210028340000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B030C28438718D3F60-807E
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
                    Fault Frequency: 42
                    Reset counter: 124
                    Mileage: 63228 km
                    Date: 2020.11.20
                    Time: 11:13:05
   Part No SW: 4H0 907 063 EB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0367
   Revision: 19020001    Serial number: 00001222803601
   Coding: 0105001440349FF0F90140C7A0001800009DC30A2F0802018000089461001700004000240B0000
   VCID: 6C81CF348689DFEBBFA-8038
   Subsystem 1 - Part No SW: 4H2 955 119 D    HW: 4H2 955 119 A
   Component: WWS641 150721  H38 0100
   Serial number:         150820100204
   Coding: 0045F7
   Serial number: 61007004
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 09 12 2015  00001008
   Component: EVLS-SG  H08 0300
   Serial number: WA121533000015502792
   Coding: 020300
   Serial number: B8A98CD7000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2313E4082BD7D0934E0-8076
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007MC8Z
   Coding: 30333045313430303038554A305234483053
   VCID: 3B233C68B3E78853660-806E
   Serial number: 3575HRB405F3NJ3CC1AA
   Serial number: 3585HRB40693LPS8BHE7
   Serial number: 3515JRB405B3K5RQH1P0
   Serial number: 3525JRB405D3K5RQOPBK
   Serial number: 3554VRB401I5558AG8RL
   Serial number: 3564VRB401I5558AHPGT
   Revision: --------    Serial number: 01335OL9000HZ
   Coding: 000034
   VCID: 372B20588F4FAC33828-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 13 10 2015  G0030828
   Part No SW: 4H0 920 811 G    HW: 4H0 920 811 G
   Component: TBenGB----NV- H53 0803
   Revision: 38081206    Serial number: 658051115592019
   Coding: 33A70802BB412600010100
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 2809F324527133CB1B2-807C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2151023000832
   Part No SW: 4H0 907 468 AG    HW: 4H0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002070256
   Coding: C0ED07480C
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 76B5ED5CC845153B59E-8022
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 52326042511911111755
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 15304001630021200410
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 49
                    Reset counter: 154
                    Mileage: 62788 km
                    Date: 2020.07.18
                    Time: 14:46:57
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 23 ∞C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 090100
   VCID: 3A2D396CBC5DB15B7D6-806E
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 001411150001000
0283 - Oil Pressure and Temperature Sensor
          C1004 FE [008] - Oil Temp implausible Correlation with Sensor 2
                    Reset counter: 60
                    Mileage: 63311 km
                    Date: 2021.02.05
                    Time: 12:18:32
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000087831
   Coding: 01010101000000000001000102
   VCID: 6491A7146E5997ABF7A-8030
   Coding: 008004
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B1838779F64F3DA8-807A
          C10C8 00 [008] - -
                    Reset counter: 141
                    Mileage: 63278 km
                    Date: 2021.01.16
                    Time: 11:44:39
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000173893786
   Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7100SYCX
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3829236482D1A34B8B2-806C
   Part No SW: 4H0 959 793 S    HW: 4H0 959 793 H
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000169516801
   Coding: 011F12005E01628202083002
   VCID: 49CF56A0E9BB2AC3E4C-801C
   Component: RCevo         H53 0202
   Revision: 00000001    Serial number: 0000357871
   Coding: 011000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D396CBCDDB15B7D6-806E
   Revision: 00002001    Serial number: 0375426233
   Coding: 011B0E2280B93881F330C784080316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2015000000000858207
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93656570
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000017775
   Coding: 030000
   VCID: 1C61DFF416A9EF6B8FA-8048
   Part No SW: 4H0 959 792 H    HW: 4H0 959 792 H
   Component: TSG BF        H06 0280
   Revision: --------    Serial number: 0000169526549
   VCID: 3D273270AD738663584-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001658939
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0702307D9316E3E84-8078
   Coding: 02F60A2022130200
   VCID: 343117549EB9472BA7A-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
13706000 - Databus
          [Empfangener Fehlerwert im Signal Kamera_FDD_Eigenblend_Guete: CAN Message Kamera_Status]
                    Reset counter: 140
                    Mileage: 63278 km
                    Date: 2021.01.16
                    Time: 11:42:57
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109KZ0F2519303
   Coding: 010103010000000001
   VCID: 2B030C28430718D3F60-807E
   Part No SW: 4H0 035 654 A    HW: 4H0 035 670 T
   Component: H-BNT-EU      H49 0947
   Revision: --------    Serial number: 449L40F7530651
   Coding: 03010100020BF1EF45908B1E00000003000001000000000000
   VCID: 2411E7142ED9D7AB37A-8070
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDFBP000N5
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000207707
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 E    HW: 4H0 959 795 E
   Component: TSG HL        H06 0280
   Revision: --------    Serial number: 0000165852599
   Coding: 010F12004000628202083002
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0130192
   Coding: 020F000101000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 331500731
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBD838B71F24F39A8-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000199122
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393A4086BD790930E0-8036
   Component: TSG HR        H06 0280
   Revision: --------    Serial number: 0000165852598
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN150908  0053
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C010F3446891FEBFFA-8078
   Component: DPC-SG        H27 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
0204 - Camera Interference
          C1104 00 [008] - -
          [SPI_No_connection_to_PPC]
                    Reset counter: 140
                    Mileage: 63278 km
                    Date: 2021.01.16
                    Time: 11:42:57
                    Outside temperature: -47.5 ∞C
                    Voltage terminal 15: 14.2 V
                    Control Module temperature: 19.0 ∞C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00024009088501
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00024179125001
   Coding: 272FF2
   Component: RGS-VL        H14 0080
   Coding: 00060000031F030000030800424CD8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1E4061AB7203CCC-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D114C64AD491BB56-8066
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 151022201922
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006127701
   ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:03, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
Monday,08,March,2021,16:29:15:08840
                Address 22: AWD       Labels: 4H0-907-163.clb
Control Module Part Number: 4H0 907 163 B    HW: 4H0 907 163 A
  Component and/or Version: 4 Wheel Drive H17 0200
           Software Coding:
            Work Shop Code:
              ASAM Dataset: EV_AllWheelDiffeQSPFR 003026 (AU64)
          C1004 FE [136] - Oil Temp implausible Correlation with Sensor 2
                    Reset counter: 20
                    Mileage: 64048 km
                    Date: 2021.02.26
                    Time: 16:49:54
0262 - Oil Pressure and Temperature Sensor
          C1004 01 [137] - Electrical Failure
                    Reset counter: 20
                    Mileage: 64048 km
                    Date: 2021.03.06
                    Time: 15:40:44
0315 - Oil Pressure and Temperature Sensor
          C1004 FC [008] - Short between Oil Temp. 1 and Temp. 2
                    Reset counter: 60
                    Mileage: 64061 km
                    Date: 2021.03.06
                    Time: 15:54:43
Phil200tdi
I have found only one other example of someone approaching this:
and this excellent guide:
D4 rear diff sensors.pdf
But just want to know the correct part number and how to do the readaption process..
I may be better to just bite the bullet and go to Audi Stealership.
Eric
HC800000
It's complaining about the temperature part, why are you looking at oil pressures?
Show us a measuring values map with the car at ambient temp, it should look like this:
;SW:8K0-907-163-B   HW:8K0-907-163-A ---  AWD
;Component:4 Wheel Drive H15 0100, Coding:
;EV_AllWheelDiffeQSPCAN,003019,EV_AllWheelDiffeQSPCAN.rod
;Wednesday,24,February,2021,15:49:17:18206
;VCDS Version: Beta 21.2.0 (x64)  Data version: 20210219 DS325.0
;VCID: 2F3819D1E7993D93221-807A
Group,Description,Actual
IDE00018,Voltage terminal 15,14.06, V
IDE00019,Voltage terminal 30,14.06, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,0.00, /min
IDE00031,Torque transmitting function,0.0,
IDE00086,Accelerator pedal position,0.0, %
IDE00100,Engine torque,0,
IDE00102,Control Module temperature,18, °C
IDE00323,Security Access: Number of invalid keys,1,
IDE00326,Steering wheel angle,819.0, °
IDE00544,Factor torque,Factor 1,
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01589,Status ABS brakes,OFF,
IDE01591,EDL status,OFF,
IDE01592,ESP status,iO,
IDE01759,Audi drive select,Dynamic,
IDE01964,Activating and deactivating function block,not active,
IDE02031,Oil pressure and oil temperature sensor supply voltage,5.0, V
IDE02032,Oil pressure and oil temperature sensor supply voltage 2,5.0, V
IDE02033,Oil pressure and oil temperature sensor temperature,8, °C
IDE02034,Oil pressure and oil temperature sensor temperature 2,8, °C
IDE02035-ENG98502,Oil pressure and oil temperature pressure-Data,0.00, bar
IDE02036-ENG98502,Oil pressure and oil temperature pressure 2-Data,0.00, bar
IDE02037,Thermal load of left clutch,0.0, %
IDE02038,Thermal load of right clutch,0.0, %
IDE02039,Thermal load of all-wheel drive pump,0.0, %
IDE02040,Torque distribution,0, Nm
IDE02041-ENG28496,Torque distribution: reserve-Torque,0, Nm
IDE02042,Torque distribution: specified value,0, Nm
IDE02043,Pump for all-wheel drive: current,0.00, A
IDE02044,Pump for all-wheel drive: voltage,2.97, V
IDE02045,Clutch valve for all-wheel drive: status,Open,
IDE02046,Clutch valve 2 for all-wheel drive: status,Open,
IDE02047,Clutch 1 performance loss,16380, J
IDE02048,Clutch 2 performance loss,16380, J
IDE02049,Trailer detected,not detected,
IDE02203,Pump for all-wheel drive: status,not activated,
IDE02204,Audi drive select: Status,OK,
IDE02209,Speed signal: qualification,Qualified,
IDE02210,Brake pressure: qualification,Qualified,
IDE02211-ENG101675,Brake pressure-ESP Brake pressure,0, bar
IDE02212,ESP intervention: left front,OFF,
IDE02213,ESP intervention: right front,OFF,
IDE02214,ESP intervention: left rear,OFF,
IDE02215,ESP intervention: right rear,OFF,
IDE02216,Steering angle sensor: basic setting,calibrated,
IDE02217,Steering angle sensor: qualification,Qualified,
IDE02218,Steering angle sensor: qualification 2,Qualified,
IDE02220,Accelerator position: qualification,Qualified,
IDE02221,Engine torque: qualification,Qualified,
IDE02222,Driver brakes: qualification,Qualified,
IDE02223,Engine speed: qualification,Qualified,
IDE02224,Active assisted steering angle,0.0,
IDE02225,Active assisted steering angle: sign,Positive,
IDE02238,Rotation rate sensor 1: status,0,
IDE02239,Rotation rate sensor 1,-0.17500, °/s
IDE02240,Lateral acceleration sensor 1: status,0,
IDE02241,Lateral acceleration sensor 1,0.00970, g
IDE02242,Rotation rate sensor 2: status,0,
IDE02243,Rotation rate sensor 2,-0.12500, °/s
IDE02244,Lateral acceleration sensor 2: status,0,
IDE02245,Lateral acceleration sensor 2,0.00919, g
IDE02382-ENG103788,Left coefficient of friction class-classification gradient left,15,
IDE02382-ENG101483,Left coefficient of friction class-classification offset left,02,
IDE02383,Dynamic steering,Not coded,
IDE02683-ENG101733,Right coefficient of friction class-classification gradient right,16,
IDE02683-ENG102449,Right coefficient of friction class-classification offset right,02,
IDE02684-ENG99767,Serial number pressure sensor 1-PARAM FP_SN,18230,
IDE02685-ENG99767,Serial number pressure sensor 2-PARAM FP_SN,28505,
IDE03008,Stop process prevented,Stop release,
IDE03010-MAS01866,Number of prevented stop processes-System test,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Measuring value not available,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE05122-ENG101666,Status of oil pressure and oil temperature sensor-PARAM State FP,Fingerprint OK,
IDE05123-ENG101666,Status of oil pressure and oil temperature sensor 2-PARAM State FP,Fingerprint OK,
ENG100038,CPU Load,63.5, %
ENG105749,Dashboard ECU timeout,Kombi OK,
ENG105752,Data set ID,50,
ENG105753-ENG101799,Dataset build date and time-Param to DOP,28.07.2011 09:49,
ENG105754-ENG101799,Dataset build user-Param to DOP,VF6D7WE,
ENG105914,driver braking intervention,kein Bremsen,
ENG105976-ENG98502,DTS1 direct Pressure-Data,180,
ENG105977-ENG98502,DTS2 direct Pressure-Data,1020,
ENG105978-ENG98502,DTS2_ATIC Pressure-Data,672,
ENG106030,ECU delivery state,0,
ENG106208,engine control unit timeout,Motor SG OK,
ENG106306,ESP control ECU timeout,ESP SG OK,
ENG106559-ENG103564,Fingerprint sensor 1 date-Uint16 Param,15123,
ENG106560-ENG103564,Fingerprint sensor 2 date-Uint16 Param,15133,
ENG111016-ENG111015,FP-Statistik-FP KL15 Cycle Counter,182,
ENG111016-ENG111003,FP-Statistik-FP1_Sensor_1Error_Counter,1,
ENG111016-ENG111004,FP-Statistik-FP1_Sensor_1Error_Counter_History,2,
ENG111016-ENG111005,FP-Statistik-FP1_Sensor_2Error_Counter,0,
ENG111016-ENG111006,FP-Statistik-FP1_Sensor_2Error_Counter_History,0,
ENG111016-ENG111007,FP-Statistik-FP1_Sensor_3Error_Counter,0,
ENG111016-ENG111008,FP-Statistik-FP1_Sensor_3Error_Counter_History,0,
ENG111016-ENG111009,FP-Statistik-FP2_Sensor_1Error_Counter,1,
ENG111016-ENG111010,FP-Statistik-FP2_Sensor_1Error_Counter_History,0,
ENG111016-ENG111011,FP-Statistik-FP2_Sensor_2Error_Counter,0,
ENG111016-ENG111012,FP-Statistik-FP2_Sensor_2Error_Counter_History,0,
ENG111016-ENG111013,FP-Statistik-FP2_Sensor_3Error_Counter,0,
ENG111016-ENG111014,FP-Statistik-FP2_Sensor_3Error_Counter_History,0,
ENG98593,Gateway,Gateway OK,
ENG106770,Gearbox-ECU timeout,Getriebe SG OK,
ENG107692,motor pump voltage terminal B,2.97, V
ENG107958,overlay torque set value RLR,-1275, Nm
ENG107959,overlay torque set value RUS,-1275, Nm
ENG107960,overlay torque set value RVS,-1275, Nm
ENG108363,QSP Charisma driver select,Comfort,
ENG108364,QSP Charisma status,0,
ENG108365,QSP Charisma switch,0,
ENG108366,QSP ESP Request,keine ESP Anforderung,
ENG108367,QSP Init phase,Initialisierungsphase laeuft,
ENG108368-ENG101799,QSP Intervention-Param to DOP,intervention_temp_disabled,
ENG108369,QSP KD error,kein_KD_Fehler,
ENG108370,QSP state,System_inaktiv,
ENG108371,QSP thermal load,0.0, %
ENG108373,QSP warning lamp,Warnlampe aus,
ENG108992-ENG101799,Software build date and time-Param to DOP,04.02.2011 12:35,
ENG108993-ENG101799,Software build user name-Param to DOP,muehlbau,
ENG108999-ENG104118,Software Version Number: BIOS-Software Version BIOS,0600,
ENG109000-ENG103564,Software Version Number: KR-Uint16 Param,289,
ENG109001,Software Version Number: QSP,01 86,
ENG109002-ENG103564,Software Version Number: RSW-Uint16 Param,369,
ENG109072,State AudiFahrdynamikRegler,QSP_State_Init,
ENG109073,State FCU,Temp_Abschalten,
ENG109078,State KomonentenRegler,Initalize,
ENG109082,state pressure test DBV,not OK,
ENG109113,steering control ECU timeout,SCU OK,
ENG109114,steering sensor timeout,OK,
ENG109371-ENG98502,Temperature output stage-Data,11, °C
ENG109372-ENG98502,Temperature QCU-Data,8, °C
ENG109411-ENG98502,Thermal load ECU-Data,0, %
ENG109525,torque loss,5.4,
ENG109865-ENG101799,Vehicle_Identification_of_Dataset-Param to DOP,B8 A4 HL601 Production V2.1,
ENG109879,Ventil 1 HS Voltage,0.00, V
ENG109880,Ventil 1 LS Voltage,0.00, V
ENG109881,Ventil 2 HS Voltage,0.00, V
ENG109882,Ventil 2 LS Voltage,0.00, V
ENG109990,VPS Voltage,14.06, V
ENG110110-MAS01143,Werkstattcode 2-Device number,0,
ENG110110-MAS01144,Werkstattcode 2-Importer number,0,
ENG110110-MAS01145,Werkstattcode 2-Dealership number,0,
ENG110111-MAS01143,Werkstattcode 3-Device number,0,
ENG110111-MAS01144,Werkstattcode 3-Importer number,0,
ENG110111-MAS01145,Werkstattcode 3-Dealership number,0,
ENG110112-MAS01143,Werkstattcode 4-Device number,0,
ENG110112-MAS01144,Werkstattcode 4-Importer number,0,
ENG110112-MAS01145,Werkstattcode 4-Dealership number,0,
ENG110113-MAS01143,Werkstattcode 5-Device number,0,
ENG110113-MAS01144,Werkstattcode 5-Importer number,0,
ENG110113-MAS01145,Werkstattcode 5-Dealership number,0,
Elapsed Time: 00:12
Phil200tdi
I did think it was the Oil Temp sensor, but when I looked at the measured values the temps were measuring - albeit 1 degree apart.
The pressure wasn't measuring on one.
I'll get the measured values this afternoon - thanks for your help!
Phil200tdi
Duplicate
Phil200tdi
Is this what you mean:
Monday,22,March,2021,16:15:38:08840
Mileage: 64145km-39857mi   Repair Order:
                Address 22: AWD  (4H0 907 163 B)
16:15:35
  IDE00920   Front left wheel speed 0.0 km/h
  IDE00921   Wheel speed: right front 0.0 km/h
  IDE00922   Left rear wheel speed 0.0 km/h
  IDE00923   Right rear wheel speed 0.0 km/h
  IDE01589   Status ABS brakes OFF
  IDE01591   EDL status OFF
  IDE01592   ESP status not active
  IDE01759   Audi drive select Unknown (5)
  IDE02031   Oil pressure and oil temperature sensor supply voltage 5.0 V
  IDE02032   Oil pressure and oil temperature sensor supply voltage 2 5.0 V
  IDE02033   Oil pressure and oil temperature sensor temperature 9 °C
  IDE02034   Oil pressure and oil temperature sensor temperature 2 9 °C
  IDE02035-ENG98502   Oil pressure and oil temperature pressure-Data 0.00 bar
  IDE02036-ENG98502   Oil pressure and oil temperature pressure 2-Data 0.00 bar
  IDE02037   Thermal load of left clutch 0.0 %
  IDE02038   Thermal load of right clutch 0.0 %
  IDE02039   Thermal load of all-wheel drive pump 0.0 %
  IDE02040-ENG28496   Torque distribution-Torque 0 Nm
  IDE02041-ENG28496   Torque distribution: reserve-Torque 0 Nm
  IDE02042-ENG28496   Torque distribution: specified value-Torque 0 Nm
  IDE02043   Pump for all-wheel drive: current 0.00 A
  IDE02044   Pump for all-wheel drive: voltage 1.88 V
  IDE02045   Clutch valve for all-wheel drive: status Open
  IDE02046   Clutch valve 2 for all-wheel drive: status Open
  IDE02047   Clutch 1 performance loss 16380 J
  IDE02048   Clutch 2 performance loss 16380 J
  IDE02049   Trailer detected not detected
  IDE02203   Pump for all-wheel drive: status not activated
  IDE02204   Audi drive select: Status OK
  IDE02209   Speed signal: qualification Qualified
  IDE02210   Brake pressure: qualification Qualified
  IDE02211-ENG101675   Brake pressure-ESP Brake pressure 0 bar
  IDE02212   ESP intervention: left front OFF
  IDE02213   ESP intervention: right front OFF
  IDE02214   ESP intervention: left rear OFF
  IDE02215   ESP intervention: right rear OFF
  IDE02216   Steering angle sensor: basic setting calibrated
  IDE02217   Steering angle sensor: qualification Qualified
  IDE02218   Steering angle sensor: qualification 2 Qualified
  IDE02220   Accelerator position: qualification Qualified
  IDE02221   Engine torque: qualification Qualified
  IDE02222   Driver brakes: qualification Qualified
  IDE02223   Engine speed: qualification Qualified
  IDE02224   Active assisted steering angle 1.7
  IDE02225   Active assisted steering angle: sign Positive
  IDE02238   Rotation rate sensor 1: status 0
  IDE02239   Rotation rate sensor 1 0.01000 °/s
  IDE02240   Lateral acceleration sensor 1: status 0
  IDE02241   Lateral acceleration sensor 1 0.38000 m/s²
  IDE02242   Rotation rate sensor 2: status 0
  IDE02243   Rotation rate sensor 2 -0.02000 °/s
  IDE02244   Lateral acceleration sensor 2: status 0
  IDE02245   Lateral acceleration sensor 2 0.38000 m/s²
  IDE02381   Pressure control valve: test status not OK
  IDE02382-ENG103788   Left coefficient of friction class-classification gradient left 0E
  IDE02382-ENG101483   Left coefficient of friction class-classification offset left 03
  IDE02383   Dynamic steering ESP ADS coding
  IDE02538   Longitude Acceleration Sensor -0.26000 m/s²
  IDE02540   Longitudinal acceleration sensor: status 0
  IDE02683-ENG101733   Right coefficient of friction class-classification gradient right 08
  IDE02683-ENG102449   Right coefficient of friction class-classification offset right 09
  IDE02684-ENG99767   Serial number pressure sensor 1-PARAM FP_SN 18295
  IDE02685-ENG99767   Serial number pressure sensor 2-PARAM FP_SN 19197
  IDE03008   Stop process prevented Stop release
  IDE03010-MAS01866   Number of prevented stop processes-System test 1440
  IDE03127-IDE03008   Prevented stop processes (ring memory)-Stop process prevented System test
  IDE03127-MAS00106   Prevented stop processes (ring memory)-Year 2021
  IDE03127-MAS00107   Prevented stop processes (ring memory)-Month 2
  IDE03127-MAS00108   Prevented stop processes (ring memory)-Day 15
  IDE03127-MAS00109   Prevented stop processes (ring memory)-Hours 15
  IDE03127-MAS00110   Prevented stop processes (ring memory)-Minutes 1
  IDE03127-MAS00111   Prevented stop processes (ring memory)-Seconds 0
  IDE03212   Start/stop conditions Stop release
  IDE03213   Start/stop enable No release by coordinator
  IDE05122-ENG101666   Status of oil pressure and oil temperature sensor-PARAM State FP OK
  IDE05123-ENG101666   Status of oil pressure and oil temperature sensor 2-PARAM State FP OK
  ENG100038   CPU Load 75.6 %
  ENG105749   Dashboard ECU timeout OK
  ENG105752   Data set ID 48
  ENG105753-ENG101799   Dataset build date and time-Param to DOP 14.12.2012 08:41
  ENG105754-ENG101799   Dataset build user-Param to DOP FTWYWBN
  ENG105914   driver braking intervention OFF
  ENG105976-ENG98502   DTS1 direct Pressure-Data 68
  ENG105977-ENG98502   DTS2 direct Pressure-Data 1020
  ENG105978-ENG98502   DTS2_ATIC Pressure-Data 676
  ENG106030   ECU delivery state 0
  ENG106208   engine control unit timeout OK
  ENG106306   ESP control ECU timeout OK
  ENG106316   ESP system state OK
  ENG106559-ENG103564   Fingerprint sensor 1 date-Uint16 Param 15381
  ENG106560-ENG103564   Fingerprint sensor 2 date-Uint16 Param 15381
  ENG111016-ENG111015   FP-Statistik-FP KL15 Cycle Counter 236
  ENG111016-ENG111003   FP-Statistik-FP1_Sensor_1Error_Counter 1
  ENG111016-ENG111004   FP-Statistik-FP1_Sensor_1Error_Counter_History 1
  ENG111016-ENG111005   FP-Statistik-FP1_Sensor_2Error_Counter 0
  ENG111016-ENG111006   FP-Statistik-FP1_Sensor_2Error_Counter_History 0
  ENG111016-ENG111007   FP-Statistik-FP1_Sensor_3Error_Counter 0
  ENG111016-ENG111008   FP-Statistik-FP1_Sensor_3Error_Counter_History 0
  ENG111016-ENG111009   FP-Statistik-FP2_Sensor_1Error_Counter 1
  ENG111016-ENG111010   FP-Statistik-FP2_Sensor_1Error_Counter_History 3
  ENG111016-ENG111011   FP-Statistik-FP2_Sensor_2Error_Counter 0
  ENG111016-ENG111012   FP-Statistik-FP2_Sensor_2Error_Counter_History 1
  ENG111016-ENG111013   FP-Statistik-FP2_Sensor_3Error_Counter 0
  ENG111016-ENG111014   FP-Statistik-FP2_Sensor_3Error_Counter_History 0
  ENG98593   Gateway OK
  ENG106770   Gearbox-ECU timeout OK
  ENG107692   motor pump voltage terminal B 1.88 V
  ENG107958   overlay torque set value RLR -1275 Nm
  ENG107959   overlay torque set value RUS -1275 Nm
  ENG107960   overlay torque set value RVS -1275 Nm
  ENG108363   QSP Charisma driver select Comfort
  ENG108364   QSP Charisma status 0
  ENG108365   QSP Charisma switch 0
  ENG108366   QSP ESP Request ESP-switch-on
  ENG108367   QSP Init phase active
  ENG108368-ENG101799   QSP Intervention-Param to DOP intervention_temp_disabled
  ENG108369   QSP KD error Malfunction
  ENG108370   QSP state not active
  ENG108371   QSP thermal load 0.0 %
  ENG108373   QSP warning lamp Warning_lamp_on_error
  ENG108444-MAS01143   Repair Shop Code 2-Device number 0
  ENG108444-MAS01144   Repair Shop Code 2-Importer number 0
  ENG108444-MAS01145   Repair Shop Code 2-Dealership number 0
  ENG108445-MAS01143   Repair Shop Code 3-Device number 0
  ENG108445-MAS01144   Repair Shop Code 3-Importer number 0
  ENG108445-MAS01145   Repair Shop Code 3-Dealership number 0
  ENG108446-MAS01143   Repair Shop Code 4-Device number 0
  ENG108446-MAS01144   Repair Shop Code 4-Importer number 0
  ENG108446-MAS01145   Repair Shop Code 4-Dealership number 0
  ENG108447-MAS01143   Repair Shop Code 5-Device number 0
  ENG108447-MAS01144   Repair Shop Code 5-Importer number 0
  ENG108447-MAS01145   Repair Shop Code 5-Dealership number 0
  ENG108992-ENG101799   Software build date and time-Param to DOP 10.02.2012 16:42
  ENG108993-ENG101799   Software build user name-Param to DOP mpt_build
  ENG108999-ENG104118   Software Version Number: BIOS-Software Version BIOS 0475
  ENG109000-ENG103564   Software Version Number: KR-Uint16 Param 289
  ENG109001   Software Version Number: QSP 01 86
  ENG109002-ENG103564   Software Version Number: RSW-Uint16 Param 53
  ENG109071   State AFR QSP_State_Init
  ENG109073   State FCU Temp_Shutdown
  ENG109079   State KR Initalize
  ENG109113   steering control ECU timeout OK
  ENG109114   steering sensor timeout OK
  ENG109371-ENG98502   Temperature output stage-Data 21 °C
  ENG109372-ENG98502   Temperature QCU-Data 9 °C
  ENG109411-ENG98502   Thermal load ECU-Data 0 %
  ENG109525   torque loss 8.1
  ENG109865-ENG101799   Vehicle_Identification_of_Dataset-Param to DOP D4 A8 S8 ADS HL601 Production V0.5
  ENG109835   Voltage A clutch valve -N445 0.00 V
  ENG109837   Voltage A clutch valve -N446 0.00 V
  ENG109836   Voltage B clutch valve -N445 0.00 V
  ENG109838   Voltage B clutch valve -N446 0.00 V
  ENG109990   VPS Voltage 11.56 V
Eric
HC800000
Yep, although the formatting is a little off compared to mine. Also update your VCDS :)
In any case, you have a temp correlation DTC between two sensors that read the exact same temp at ambient. I'd try and catch one "in the act" before you start replacing and re-adaptating them at random, because getting in there isn't easy, nor is the re-adaptation trivial from what I've read.
*My* next step would be to clear the DTC, then log both temps and pressures:
IDE02033
IDE02034
IDE02035-ENG98502
IDE02036-ENG98502
and maybe as a reference:
ENG109371-ENG98502
ENG109372-ENG98502
during a drive where things get nice and warm, and hopefully the DTC triggers and you can correlate the freeze frame time to a specific location in your logfile once the drive is over.
Best case you'll have a sensor that goes full negative and that will point you with certainty to that sensor OR ITS WIRING :)
Phil200tdi
Thanks.
When I first logged there was a 4 degree discrepancy between the temp sensors. But it tidied itself up again when I saved.
I'm unable to clear the DTC, it immediately pops up again after clearing. Any ideas?
Eric
HC800000
For the measuring values map, you should be doing Applications->Controller Channel Map .
Before it "tidied itself up", which temp sensor was further from ENG109372-ENG98502 Temperature QCU-Data 9 °C ?
If the DTC won't clear, then you can't use the freeze frame time to pinpoint the issue in the log of your test drive, but that does not make it unusable; you just have to look carefully or plot the data.
Since you mentionned it tidied itself, you may also to start the log and just shake things under the car. The dual sender coolant temp sensors on some Mk4 were notorious for failing as you wiggled them.
Phil200tdi
I'll give this a try..
Took it to Audi Oxford this morning as part of a recall. They ran their diagnostics and recommend changing the Control Unit (J492) and both sensors (G437 and G640) at a cost of £1.1k.. The tech did admit that this is the guidance and they don't just replace individual sensors!
Rather try a DIY and save circa £1k
Phil200tdi
Looking at my log it seems one of the Temp sensors is uniform in rising temp where as the other is spiking up/down at certain points:
Sunday​
28​
2021​
Data version: 20210226 DS325.0​
4H0 907 163 B​
ADVMB​
F0​
G022​
G023​
G024​
Marker​
TIME​
TIME​
Loc. IDE02032​
Loc. IDE02033​
Loc. IDE02034​
STAMP​
STAMP​
Oil pressure and oil temperature sensor supply voltage 2​
Oil pressure and oil temperature sensor temperature​
Oil pressure and oil temperature sensor temperature 2​
V​
°C​
°C​
1.34​
1.47​
5​
16​
18​
2.84​
2.97​
5​
16​
18​
4.35​
4.48​
5​
16​
18​
5.84​
5.97​
5​
17​
18​
7.34​
7.47​
5​
18​
18​
8.85​
8.98​
5​
19​
18​
10.34​
10.47​
5​
18​
18​
11.84​
11.97​
5​
19​
18​
13.35​
13.48​
5​
18​
18​
14.85​
14.98​
5​
19​
18​
16.34​
16.47​
5​
18​
18​
17.85​
17.98​
5​
18​
18​
19.35​
19.48​
5​
18​
18​
20.83​
20.93​
5​
19​
18​
22.28​
22.4​
5​
18​
19​
23.73​
23.86​
5​
18​
18​
25.2​
25.34​
5​
19​
19​
26.7​
26.85​
5​
18​
19​
28.17​
28.29​
5​
18​
19​
29.64​
29.76​
5​
18​
19​
31.09​
31.22​
5​
17​
19​
32.57​
32.68​
5​
16​
19​
34​
34.12​
5​
19​
19​
35.45​
35.6​
5​
19​
19​
36.95​
37.1​
5​
19​
19​
38.45​
38.6​
5​
19​
19​
39.95​
40.1​
5​
19​
19​
41.45​
41.6​
5​
18​
19​
42.92​
43.05​
5​
19​
19​
44.39​
44.51​
5​
19​
19​
45.86​
45.98​
5​
19​
19​
47.33​
47.43​
5​
19​
19​
48.78​
48.9​
5​
19​
19​
50.23​
50.36​
5​
19​
20​
51.7​
51.85​
5​
19​
19​
53.2​
53.35​
5​
19​
20​
54.73​
54.86​
5​
19​
20​
56.2​
56.35​
5​
19​
20​
57.7​
57.84​
5​
19​
20​
59.2​
59.35​
5​
19​
20​
60.7​
60.85​
5​
19​
20​
62.2​
62.35​
5​
20​
20​
63.7​
63.85​
5​
19​
20​
65.2​
65.35​
5​
20​
20​
66.7​
66.84​
5​
20​
20​
68.2​
68.35​
5​
20​
20​
69.7​
69.85​
5​
20​
20​
71.2​
71.35​
5​
20​
20​
72.7​
72.85​
5​
20​
20​
74.2​
74.35​
5​
20​
20​
75.7​
75.85​
5​
20​
20​
77.2​
77.35​
5​
20​
20​
78.7​
78.85​
5​
20​
20​
80.2​
80.35​
5​
20​
20​
81.7​
81.85​
5​
20​
20​
83.2​
83.35​
5​
20​
20​
84.7​
84.85​
5​
20​
20​
86.2​
86.35​
5​
20​
20​
87.7​
87.84​
5​
20​
20​
89.2​
89.35​
5​
20​
20​
90.7​
90.85​
5​
20​
20​
92.2​
92.36​
5​
20​
20​
93.7​
93.85​
5​
20​
20​
95.2​
95.34​
5​
20​
20​
96.7​
96.84​
5​
20​
20​
98.23​
98.36​
5​
20​
20​
99.7​
99.85​
5​
20​
20​
101.2​
101.34​
5​
20​
20​
102.7​
102.84​
5​
20​
20​
104.2​
104.35​
5​
20​
20​
105.7​
105.85​
5​
20​
20​
107.2​
107.35​
5​
20​
20​
108.7​
108.85​
5​
20​
20​
110.2​
110.35​
5​
20​
20​
111.75​
111.87​
5​
20​
20​
113.23​
113.36​
5​
20​
20​
114.7​
114.85​
5​
20​
20​
116.2​
116.34​
5​
20​
20​
117.7​
117.86​
5​
20​
20​
119.2​
119.34​
5​
20​
20​
120.7​
120.84​
5​
20​
20​
122.19​
122.33​
5​
20​
20​
123.7​
123.84​
5​
20​
20​
125.2​
125.34​
5​
20​
21​
126.7​
126.85​
5​
20​
21​
128.2​
128.35​
5​
20​
20​
129.7​
129.85​
5​
20​
21​
131.19​
131.33​
5​
21​
21​
132.66​
132.79​
5​
20​
21​
134.11​
134.22​
5​
20​
21​
135.54​
135.67​
5​
21​
21​
137​
137.12​
5​
21​
21​
138.41​
138.55​
5​
21​
21​
139.89​
140.01​
5​
21​
21​
141.32​
141.44​
5​
21​
21​
142.78​
142.9​
5​
21​
21​
144.25​
144.36​
5​
21​
21​
145.7​
145.83​
5​
21​
21​
147.16​
147.29​
5​
21​
21​
148.64​
148.76​
5​
21​
21​
150.09​
150.21​
5​
21​
21​
151.58​
151.69​
5​
21​
21​
153.05​
153.19​
5​
21​
21​
154.58​
154.68​
5​
21​
21​
156.05​
156.17​
5​
21​
21​
157.6​
157.73​
5​
21​
21​
159.1​
159.23​
5​
21​
21​
160.6​
160.73​
5​
21​
21​
162.11​
162.25​
5​
21​
21​
163.61​
163.73​
5​
21​
21​
165.1​
165.23​
5​
21​
21​
166.6​
166.73​
5​
21​
21​
168.1​
168.23​
5​
21​
21​
169.58​
169.69​
5​
21​
21​
171.05​
171.17​
5​
21​
21​
172.51​
172.64​
5​
21​
21​
174.02​
174.16​
5​
21​
21​
175.52​
175.66​
5​
21​
22​
177.05​
177.17​
5​
21​
21​
178.55​
178.67​
5​
21​
22​
180.03​
180.16​
5​
21​
22​
181.53​
181.66​
5​
21​
22​
183.02​
183.14​
5​
21​
22​
184.52​
184.64​
5​
21​
22​
185.95​
186.09​
5​
21​
22​
187.45​
187.59​
5​
21​
22​
188.95​
189.09​
5​
21​
22​
190.45​
190.6​
5​
22​
22​
191.95​
192.09​
5​
22​
22​
193.42​
193.54​
5​
22​
22​
194.87​
195​
5​
22​
22​
196.35​
196.48​
5​
22​
22​
197.83​
197.93​
5​
22​
22​
199.25​
199.37​
5​
22​
22​
200.7​
200.85​
5​
22​
22​
202.2​
202.34​
5​
22​
22​
203.7​
203.85​
5​
22​
22​
205.2​
205.34​
5​
22​
22​
206.7​
206.85​
5​
22​
22​
208.17​
208.29​
5​
22​
22​
209.61​
209.73​
5​
22​
22​
211.08​
211.18​
5​
22​
22​
212.53​
212.65​
5​
22​
22​
213.98​
214.11​
5​
22​
22​
215.45​
215.6​
5​
22​
22​
216.94​
217.07​
5​
22​
22​
218.39​
218.5​
5​
22​
22​
219.84​
219.96​
5​
22​
22​
221.32​
221.42​
5​
22​
22​
222.74​
222.86​
5​
22​
22​
224.2​
224.34​
5​
22​
22​
225.69​
225.83​
5​
22​
22​
227.2​
227.35​
5​
22​
22​
228.7​
228.84​
5​
22​
23​
230.2​
230.36​
5​
22​
22​
231.7​
231.85​
5​
22​
23​
233.2​
233.34​
5​
22​
22​
234.69​
234.83​
5​
22​
23​
236.16​
236.28​
5​
22​
23​
237.62​
237.75​
5​
22​
23​
239.1​
239.23​
5​
22​
23​
240.6​
240.73​
5​
22​
23​
242.09​
242.22​
5​
22​
23​
243.6​
243.73​
5​
22​
23​
245.1​
245.24​
5​
22​
23​
246.6​
246.74​
5​
22​
23​
248.12​
248.25​
5​
22​
23​
249.6​
249.73​
5​
22​
23​
251.08​
251.19​
5​
22​
23​
252.53​
252.66​
5​
22​
23​
254.01​
254.14​
5​
22​
23​
255.52​
255.66​
5​
23​
23​
257.01​
257.14​
5​
23​
23​
258.52​
258.66​
5​
22​
23​
260.01​
260.14​
5​
23​
23​
261.48​
261.6​
5​
23​
23​
262.95​
263.1​
5​
23​
23​
264.45​
264.6​
5​
22​
23​
265.95​
266.09​
5​
22​
23​
267.45​
267.59​
5​
23​
23​
268.95​
269.09​
5​
23​
23​
270.42​
270.54​
5​
23​
23​
271.87​
272​
5​
23​
23​
273.35​
273.46​
5​
23​
23​
274.83​
274.93​
5​
23​
23​
276.28​
276.4​
5​
23​
23​
277.73​
277.86​
5​
23​
23​
279.2​
279.34​
5​
23​
23​
280.7​
280.84​
5​
23​
23​
282.2​
282.35​
5​
23​
23​
283.7​
283.84​
5​
23​
23​
285.2​
285.34​
5​
23​
23​
286.67​
286.79​
5​
23​
23​
288.12​
288.25​
5​
23​
23​
289.6​
289.72​
5​
23​
23​
291.07​
291.19​
5​
23​
24​
292.53​
292.65​
5​
23​
23​
293.98​
294.11​
5​
23​
23​
295.45​
295.59​
5​
23​
24​
296.95​
297.09​
5​
23​
24​
298.41​
298.55​
5​
23​
24​
299.86​
299.98​
5​
23​
24​
301.28​
301.41​
5​
23​
24​
302.75​
302.86​
5​
23​
24​
304.19​
304.33​
5​
23​
24​
305.66​
305.79​
5​
23​
24​
307.14​
307.26​
5​
23​
24​
308.62​
308.75​
5​
23​
24​
310.11​
310.23​
5​
23​
24​
311.6​
311.73​
5​
23​
24​
313.09​
313.22​
5​
23​
24​
314.61​
314.73​
5​
20​
24​
316.11​
316.23​
5​
19​
24​
317.6​
317.73​
5​
21​
24​
319.09​
319.22​
5​
21​
24​
320.6​
320.74​
5​
21​
24​
335.64​
335.76​
5​
23​
24​
337.1​
337.23​
5​
23​
24​
338.58​
338.68​
5​
20​
24​
340.01​
340.14​
5​
23​
24​
341.48​
341.61​
5​
24​
24​
342.95​
343.09​
5​
24​
24​
344.45​
344.59​
5​
24​
24​
345.95​
346.09​
5​
24​
24​
347.45​
347.59​
5​
24​
24​
348.92​
349.05​
5​
24​
24​
350.36​
350.48​
5​
24​
24​
351.83​
351.93​
5​
24​
24​
353.28​
353.4​
5​
24​
24​
354.73​
354.86​
5​
24​
24​
356.2​
356.34​
5​
24​
24​
357.7​
357.84​
5​
24​
24​
359.17​
359.29​
5​
24​
24​
360.6​
360.73​
5​
24​
24​
362.07​
362.19​
5​
24​
24​
363.53​
363.65​
5​
24​
24​
365​
365.12​
5​
24​
24​
366.45​
366.59​
5​
24​
24​
367.92​
368.04​
5​
24​
24​
369.36​
369.48​
5​
24​
24​
370.82​
370.93​
5​
24​
24​
372.25​
372.37​
5​
24​
24​
373.7​
373.84​
5​
24​
25​
375.17​
375.29​
5​
24​
24​
376.61​
376.73​
5​
24​
25​
378.07​
378.18​
5​
24​
24​
379.57​
379.69​
5​
24​
24​
381​
381.12​
5​
24​
24​
382.45​
382.59​
5​
24​
24​
383.95​
384.1​
5​
24​
25​
385.45​
385.6​
5​
24​
25​
386.95​
387.09​
5​
24​
24​
388.45​
388.59​
5​
24​
25​
389.95​
390.09​
5​
24​
25​
391.42​
391.54​
5​
24​
25​
392.86​
392.98​
5​
24​
25​
394.32​
394.44​
5​
24​
24​
395.75​
395.87​
5​
24​
25​
397.2​
397.34​
5​
24​
25​
398.67​
398.79​
5​
24​
25​
400.11​
400.23​
5​
24​
25​
401.57​
401.68​
5​
24​
25​
403​
403.12​
5​
24​
25​
404.45​
404.6​
5​
24​
25​
405.95​
406.09​
5​
24​
25​
407.45​
407.6​
5​
22​
25​
408.95​
409.1​
5​
20​
25​
410.45​
410.59​
5​
24​
25​
411.95​
412.09​
5​
20​
25​
Phil200tdi
Is it fair to say that sensor1 is my problem?
Phil200tdi
Audi wanted to replace both sensors and the control unit.. Guess this didn't include any wiring...
Westbury, UK
That's the classic assumption that many people make - if there's a fault then replace something without checking the wiring first, which can be an expensive mistake.
Phil200tdi
Fair point, but if the sensor is consistently reading 5V and continuously reading a temp - rather than N/A or Zero then surely the wiring would be sound. I've done a visual inspection of the wiring as have Audi investigated as part of their diagnosis.
Phil200tdi
Currently the MIL has gone away and allowed me to clear the codes. I'll wait for these to return before doing anything further.
OK, this is a good time to now go to the wiring and wiggle it around, or even pull on it a bit or check where it is fastened ..... if you get a fault then it is potentially the connection or the wiring. Also, when you unplug the connectors, use some dielectric grease on them! You could easily have a bad connection, and..... never say never when it comes to wiring (be sure to look for perforations also). Sounds like it is a "moving target", keep a open diagnostic approach.
Regarding your voltage check, sure its ok..... at that moment!
The dealer is revealing to you that it uses a "parts cannon approach" ie, change everything! That isn't diagnosing the problem. I would take what they say with a grain of salt! Unfortunately, if there isn't much or any profit in it.... they don't do it.
Be patient and think creatively!
  • Agree
BTW, I seem to recall Jeff from RT helping a "user" regarding testing a circuit/wiring : DVOM vs. test light with (incandescent bulb type) If you have a partially severed / broken wire the DVOM will read "normal" values ; while if it is tested with a test light and thus carry a load (bulb), it may not illuminate or be unusually dim. ???
