Saturday,06,February,2021,13:55:43:05172
VCDS Version: 20.12.0.1 HEX-NET CB: 0.4529.4
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69
VIN
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI H22 1990
Revision: B5H22---
Coding: 011D001204741D083000
Shop #: WSC 00028 028 00031
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026ET_002_VW48.rod
VCID: 004C5D4C9B17378402-8054
17156 - Databus
Mileage: 167519 km
Date: 2020.12.27
Time: 14:59:38
Engine RPM: 914.50 /min
Normed load value: 31.0 %
Coolant temperature: 14 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.140 V
Unlearning counter according OBD: 10
Drivetrain coordinator: brake fault status-Bits 0-7: 1
Drivetrain coordinator: brake function status-Bits 0-7: 5
Acceleration: 0.000 m/s²
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4905
Revision: 06253104 Serial number: TFK01601270726
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ250021.rod
VCID: 1D7204380CA5FA6C09-8048
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60626000002023
Coding: 0FEC6A8F34230B6C077D060341C949F0562CD0E0608292F11862F078C202
VCID: 7AB82FA4FDCB6D544C-802E
4214 - Auto-Hold Switch
C10CE 29 [008] - Signal Implausible
[AVH switch was pressed longer than 10 s]
Reset counter: 83
Mileage: 164174 km
Date: 2019.12.31
Time: 17:35:29
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0396252460
Coding: 000F0F0F03
ROD: EV_KessyHellaMQBAB.rod
VCID: 393AF0A8B84DA64C05-806C
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Reset counter: 183
Mileage: 155933 km
Date: 2019.11.11
Time: 08:09:13
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104202100011015500000101802
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6D9214F8BC85CAECD9-8038
Air quality sensor:
Humidity sensor: exterior:
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[PTC-Reduzierung durch BCM]
Reset counter: 154
Mileage: 167550 km
Date: 2020.12.28
Time: 15:42:40
Voltage terminal 30: 14.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
Auxiliary heater: in stages-Act.val.: 3
Auxiliary heater: in stages-Target value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
Reset counter: 182
Mileage: 167596 km
Date: 2020.12.29
Time: 08:33:35
Voltage terminal 30: 14.3 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 865823021600VE
Coding: 00031A46C2C102FF4BE44004001407081880000000000000000000000000
Shop #: WSC 00028 028 00202
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 034652408A012C9C1F-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160129 042 0607
Serial number: 160209143555
Component: RLHS 037 0059
Serial number: S3Y16M02D26H00M35S34
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 19 12 2015 10000221
Humidity sensor: interior:
U1400 00 [008] - -
137217 - Outside temperature sensor
B103F 1B [136] - Resistance Too High
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 74
Mileage: 161575 km
Date: 2019.12.14
Time: 10:48:35
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391604400099
Coding: 0071051911
VCID: 44C4915CCF8FEBA466-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 3200670A59FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424C19C9F2F5B24D6-8060
2102 - Databus
[FAULT_ESP_CONTROL_FAIL]
Reset counter: 153
Mileage: 167519 km
Date: 2020.12.27
Time: 14:59:38
Control Module temperature: 3 °C
Voltage terminal 15: 11.0 V
0928 - Databus
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Reset counter: 153
Mileage: 167519 km
Date: 2020.12.27
Time: 14:59:38
1074 - Databus
[FAULT_TIMEOUT_ESP_33]
Reset counter: 182
Mileage: 167990 km
Date: 2021.01.15
Time: 10:59:44
Control Module temperature: 2 °C
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FAULT_VBAT_BUSMON_LOW]
Fault Frequency: 26
Reset counter: 180
Mileage: 165710 km
Date: 2020.02.03
Time: 10:01:56
Control Module temperature: 8 °C
Voltage terminal 15: 10.9 V
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STP2NMPN8
Coding: 98CCC000000000005C5400CC000800000065
Shop #: WSC 00028 028 00002
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F4EDEB0E6E9487C7B-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 902 16
Serial number: 3576U0000005EA54291F
Subsystem 2 - Part No SW: ----------- HW: 454 001 102 16
Serial number: 3586U00000011D542912
Subsystem 3 - Part No SW: ----------- HW: 454 802 701 16
Serial number: 3516RA4A2B7090000009
Subsystem 4 - Part No SW: ----------- HW: 454 802 701 16
Serial number: 3526RE6A9B709000000N
Subsystem 5 - Part No SW: ----------- HW: 454 802 306 15
Serial number: 3556VBD4D4707000000N
Part No SW: 3Q0 953 521 DJ HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF034034 Serial number: 20160221400749
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 7BB62AA0F2F1545C57-802E
Address 17: Instruments
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 19021610802625
Coding: 030300345F087300FB0002581C0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79BA30A8F8CD664C45-802C
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000401190066082
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7528939303
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000026009015
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA0888A0BD2E0CFD-8024
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000188511446
Coding: 00350B20D000020000001000
VCID: 47DE8650FEB9C0BC83-8012
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000003062428
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000625870
Coding: 01000010005000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D32E4B8AC659A6C29-8068
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000188173438
Coding: 00350120D000020000001000
VCID: 46C08B54F9B3D9B478-8012
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003104131
Coding: 090000
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 183
Mileage: 168053 km
Date: 2021.01.18
Time: 05:53:11
65579 - Motors for Central Locking
B122B 11 [008] - Short to Ground
Reset counter: 183
Mileage: 168053 km
Date: 2021.01.18
Time: 05:53:11
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 03DA000009010000
VCID: 75A23C98D4D5022C21-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 C HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683B0GB021128
Coding: 02840201FF00000051110001000808001F0100E401200000DF
VCID: 1C74093C17BFF364FE-8048
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU3052HB
Subsystem 2 - Part No SW: V03 959 806 NB HW: -----------
Component: ECE 2021 --- 0189
Compact disc data bank:
Component: Gracenote2 --- 1012
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0395848524
Coding: 0100000202000000
VCID: 3B36EAA0B271945C17-806E
656906 - Bulb for Left Turn Signal on Trailer
C10F7 15 [009] - Open or Short to Plus
Reset counter: 72
Mileage: 165740 km
Date: 2020.07.16
Time: 15:10:01
End----------(Elapsed Time: 02:04, VBatt start/end: 12.4V/12.0V)-----------
