Hi Guys!
Hopefully somebody may be able to offer some insight.
We have retrofitted a VW Transporter T6.1 with the Newer LED Lights from Halogen. We had to install Resistors to eliminate one of the errors on the Dashboard which worked. Like the VW Transporter T6 we also need to do coding in 09 Central Electrics. As most will know, at the moment there is no coding just 1800 lines of Adaptations.
As this is a bit out of my area I thought I would offer it up to the forum...
This is the vehicle we are working on - WV1ZZZ7HZLH007686
VCDS Scan
09 Central Electrics ADMAP
This is a vehicle that came from Factory with Rear LEDs already installed - WV2ZZZ7HZMH026527
VCDS Scan
Hopefully somebody might be able to help!
Thanks,
VCDS Scan
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZLH007686 Mileage: 10953km-6805miles
Address 01: Engine (J623-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SA HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9697
Revision: 23301001
Coding: 002540144364050900000000000000000000000000000000
Shop #: WSC 00012 790 00059
ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
ROD: EV_ECM20TDI03004L906056QF_004.rod
VCID: 7EB00FA6E1E2247470-802A
Readiness: N/A
Part No SW: 0BT 300 046 N HW: 0GC 927 711 H
Component: GSG DQ500 H06 3107
Revision: 00H06V10
ROD: EV_TCMDQ500021_VN46.rod
VCID: 41CAB45AD09C9B8C4D-8014
Part No SW: 7LA 614 517 A HW: 7LA 614 517
Component: ESC_high H01 0700
Serial number: 08507007190903
Coding: 305524524847EE8C0C5A24AC126C7706392720B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3D32C8AAAC64FF6C29-8068
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 B HW: 7LA 907 426 B
Component: AC Manuell H01 0502
Coding: A03110000810000001000800504001050000000000000000800000000000
Shop #: WSC 00012 790 00037
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
VCID: 42C8BB56D59A809454-8016
Rear A/C control head:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0935
Serial number: 01101928200886
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
VCID: 74A42D8EDFAE7E2416-8020
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S2Y19M10D07H03M35S09
Coding: 02B8EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000033023287
Coding: 1F000F
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000033027380
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY192350DW1
Serial number: 00000000000031642369
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319277
Coding: 0451051811
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000.rod
VCID: 50EC811E0BF66204D2-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200670201FF8748949C815580508700000000000000000004
Shop #: WSC 00012 790 00162
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: 43C6BE52CA80899C5F-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 013 0506
Revision: --------
Coding: 8800C00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F4EF2A2E6E82D7C7B-802A
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 941 HW: 7LA 920 941
Component: KOMBI 204 6750
Coding: 27A40A082480260001882A011401000000200000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 7DB208AAECE43F6C69-8028
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 27091910802015
Coding: 030100044F05730001100018100F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70AC219EABB64204F2-8024
Generator:
Component: 4-01-09-01-04
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440066297191682
Coding: 2C1D00
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 773433010019100906BD
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
VCID: 45C2A04AC4B4B7AC71-8010
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3G0 035 869 B HW: 3G0 035 869 B
Component: MU-E-D-ER 715 0740
Serial number: 27091900021189
Coding: 066401003C00000041110101008000001F0000C60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 2B16F6F2421061DC87-807E
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000908NVKE3
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW27.rod
VCID: 014A745A901C5B8C0D-8054
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Mileage: 10520 km
Date: 2020.11.27
Time: 13:58:12
Voltage terminal 30: 13.3 V
2566 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS-Antenna - Interruption]
Reset counter: 38
Voltage terminal 30: 12.4 V
1644276 - Backup Battery
B1916 F4 [009] - Service Life Critical
Mileage: 10729 km
Date: 2020.12.23
Time: 12:30:48
IDE00001-ENG130235-Production mode-Entry_control not_active
IDE00001-ENG115730-Production mode-Exterior lighting not_active
IDE00001-ENG112304-Production mode-Heckwischer not_active
IDE00001-ENG98647-Production mode-Interior lights not_active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not_active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1 not_active
IDE00001-ENG130232-Production mode-Window_reversing_threshold not_active
IDE00002-Transport mode active
IDE00820-Activating and deactivating all development messages not active
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking DELAY
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln not active
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global not active
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn not active
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln not active
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn normal
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung not active
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte not active
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl not active
IDE02332-Deactivate production mode 0
IDE02488-Anti-theft system interior monitoring 100%
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen not active
IDE02711-ENG112304-Rear wiper-Heckwischer Keine_Spannungsanforderung
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf not active
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck not active
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1 5 s
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2 3 s
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik 7 s
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall 7 s
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW not active
IDE02711-ENG148996-Rear wiper-rear_window_wiper not installed
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck not active
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck 0 ms
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front not installed
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI not active
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung not active
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default not active
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel not enabled
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen not active
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus not active
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer not installed
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung not installed
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung not installed
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe NOT-DEFINED
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum 0%
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer 0%
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn 0%
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil not installed
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI not installed
IDE02957-ENG114629-Ambient lighting-Footwell lighting not installed
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung not installed
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung not installed
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung not installed
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel not installed
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel not installed
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset 0.5 °
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit 50.0 %/s
IDE03638-ENG149111-Stationary cornering lamp-bei_Rueckwaertsfahrt both sides
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur 100.0 °C
IDE03638-ENG149114-Stationary cornering lamp-Obere_Geschwindigkeitsschwelle 40.0 km/h
IDE03638-ENG149117-Stationary cornering lamp-obere_Grenztemperatur 95.0 °C
IDE03638-ENG149116-Stationary cornering lamp-Oberer_Lenkradwinkel 120 °
IDE03638-ENG149113-Stationary cornering lamp-Untere_Geschwindigkeitsschwelle 0.0 km/h
IDE03638-ENG149118-Stationary cornering lamp-untere_Grenztemperatur 80.0 °C
IDE03638-ENG149115-Stationary cornering lamp-Unterer_Lenkradwinkel 80 °
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift ECE_R119
IDE03638-ENG149112-Stationary cornering lamp-Zeitwert_Einschaltzeit_Abbiegelicht 15 min
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s
IDE04927-MAS01535-Window heater-Rear window defogger not installed
IDE04927-MAS01564-Window heater-Front windshield heater installed
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung 35.0 °C
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung 35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung 600 s
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert 320 s
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH active
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH active
IDE05144-Read parameter address 00 00 00
IDE05145-Light configuration 0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 3A 00 20 14 00 64 1F 09 3E 0D 0F 80 06 00 80 09 44 00 21 14 00 64 1F 0A 3E 0E 0F 80 07 00 80 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin 0
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin 0
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin puddle light
IDE05822-Anti-theft alarm system vehicle inclination sensor 100%
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A 78 01 14 0A 33 E1 33 0C FF 00 00 01 BB B6 06 00 0F 1E 00 85 0F 39 F7 63 23 A5 42 57 9B 25 44 3D 3A 69 58 95 2C 0A A5 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0E F3 42 97 1B 05 34 3F 3A 69 58 93 08 0A A5 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 0A A5 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 64 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 0A A5 05 61 06 03 17 0C 11 18 87 02 23 33 69 23 65 42 57 9B 25 24 0C FA 0A 35 95 2C 0A A5 21 03 00 02 02 02 02 02 02 B1 51 12 2B 5E
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung zeitgesteuert
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats not connected
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN not installed
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 0 s
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1 0%
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2 0%
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3 0%
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4 0%
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5 0%
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6 0%
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit 0 min
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 0.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 0.00 °C
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit 0 min
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 0.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 0.00 °C
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit 0 min
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 0.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 0.00 °C
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI Keine_Spannungsanforderung
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO Keine_Spannungsanforderung
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten active
IDE06096-ENG98648-Interior lights-Interior lighting Keine_Spannungsanforderung
IDE06425-Dynamometer mode: functional not active
IDE08786-MAS10528-Assistance light functions-Rain light sensor Rain light sensor
IDE08786-MAS10545-Assistance light functions-Humidity sensor not installed
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP present
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung 0 ms
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen active
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor not installed
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit 0 °
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC 0 °
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0 not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1 not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10 not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11 not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12 not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13 not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14 not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15 not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16 not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17 not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18 not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19 not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2 not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20 not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21 not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22 not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23 not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24 not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25 not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26 not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27 not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28 not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29 not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3 not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30 not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31 not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32 not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33 not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34 not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4 not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5 not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6 not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7 not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8 not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9 not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand 0_Ohm
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit 0 °
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC 0 °
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0 not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1 not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10 not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11 not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12 not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13 not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14 not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15 not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16 not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17 not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18 not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19 not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2 not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20 not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21 not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22 not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23 not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24 not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25 not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26 not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27 not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28 not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29 not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3 not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30 not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31 not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32 not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33 not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34 not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4 not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5 not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6 not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7 not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8 not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9 not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand 0_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs not active
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit 30 min
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose not active
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein not active
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0
IDE11944-MAS10510-Keyless access and start authorization-Kessy not installed
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR not active
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber not active
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit not active
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit not active
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen not active
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen active
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung active
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system not installed
MAS01490-IDE08581-Energy management-Recuperation active
MAS01490-MAS12921-Energy management-Predictive energy management not active
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement active
MAS01490-ENG98636-Energy management-Hybrid No
MAS01490-ENG142037-Energy management-Zweitbatterie not installed
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 2000 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 00 32
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 4000 lx
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway not active
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain active
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity NOT-DEFINED
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF active
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 4300 mV
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 6000 lx
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 1400 mV
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status not active
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC 00 00 00
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC First_dtc
ENG148492-MAS01577-Anti-theft protection-Parking heater not installed
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn not active
ENG148492-ENG115864-Anti-theft protection-Alarmsignal frequency_modulated
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system active
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn sounder_installed
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham No
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor installed
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI not active
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger not active
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung immidiat_driver_door_contact_thatcham
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus not active
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor Yes
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl 10_Alarme
ENG148492-ENG142008-Anti-theft protection-tilt_sensor Yes
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm 2_sekunden_verzoegerung
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger separte
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen 3
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type H7
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze 350 km/h
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze 350 km/h
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag Daytime running lamps
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich active
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren in_Betrieb_lassen
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht not active
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht active
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich not active
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten not active
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO not active
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht not active
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge active
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal No
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion not active
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit 255 km/h
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA active
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion not active
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion not active
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection Discrete signal current
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light Yes
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light Yes
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL Yes
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos. Yes
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6 No
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung Energy management
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung Energy management
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht active
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten Low beam
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus manual
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis Driver_door
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv not active
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach active
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig in 0 and SL position
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer Faktor fuer x5 Minuten
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH Keine_Spannungsanforderung
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp Keine_Spannungsanforderung
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung 116
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung 72
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker true
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht integriert_in_Suchbeleuchtung
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus Enabled
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert active
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit 10 seconds
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht Yes
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module not installed
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam Keine_Spannungsanforderung
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO Menuesteuerung_Zeit_aktivieren
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome 10 seconds
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung active
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert One-sided
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt active
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit 24 s
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6 No
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp Keine_Spannungsanforderung
ENG148494-MAS10534-Background lighting-Input medium: search illumination HMI
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM 0.04 s
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM 0.04 s
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM 0.04 s
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM 0.08 s
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM 0.08 s
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM 0.08 s
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen 1.1 s
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen 0.0 s
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe not active
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten not_active
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung active
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert 100%
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl Fotosensor_Kombi
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung always_active
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor 0.1
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert 6.00%
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck not active
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei 0 cm
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich 0 cm
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite not active
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis not active
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck not active
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF not active
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung 0.0 s
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung 0.0 s
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1 installed
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2 not installed
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3 installed
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4 not installed
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control Halogen
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset not active
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert 0 ms
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent not installed
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung present
ENG248411-ENG248631-Front doors-cockpittaster2_funktion active
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung active
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen active
ENG248411-ENG248768-Front doors-NFZ_Schliessung active
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne No
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum not installed
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion No
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug No
ENG248444-ENG248691-Global-Funktion_SAFE Yes
ENG248444-ENG248774-Global-pa_eKiSi No
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite Yes
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv No
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv No
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck installed
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck Federsteller
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck Klappe
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid installed
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid not installed
ENG141645-MAS00213-HW_Verbau-Insufficient coolant installed
ENG141645-MAS00214-HW_Verbau-Brake pad wear installed
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch installed
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor installed
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter Open
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15 active
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN horn_via_LIN
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit not installed
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0 0 lx
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1 8 lx
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2 200 lx
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3 300 lx
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4 500 lx
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0 16
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1 16
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2 100
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3 100
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4 100
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0 0 lx
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1 8 lx
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2 220 lx
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3 300 lx
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4 500 lx
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0 6
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1 6
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2 100
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3 100
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4 100
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0 0
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1 10
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2 100
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3 150
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4 220
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5 253
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0 3.00%
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1 3.00%
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2 11.00%
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3 40.00%
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4 82.00%
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5 100.00%
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0 0 lx
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1 8 lx
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2 50 lx
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3 500 lx
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0 100
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1 100
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2 100
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3 100
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0 0.00%
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1 50.00%
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2 100.00%
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0 0.00%
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1 50.00%
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2 100.00%
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0 0 lx
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1 8 lx
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2 50 lx
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3 500 lx
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0 100
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1 100
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2 100
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3 100
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0 0 lx
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1 8 lx
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2 50 lx
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3 500 lx
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0 6
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1 6
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2 100
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3 100
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0 0.00%
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1 50.00%
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2 100.00%
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0 0.00%
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1 50.00%
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2 100.00%
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0 0 ms
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1 100 ms
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10 1000 ms
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2 200 ms
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3 300 ms
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4 400 ms
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5 500 ms
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6 600 ms
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7 700 ms
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8 800 ms
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9 900 ms
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0 100.00%
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1 78.00%
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10 0.00%
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2 59.00%
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3 44.00%
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4 33.00%
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5 24.00%
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6 17.00%
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7 12.00%
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8 7.00%
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9 3.00%
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0 0
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1 50
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2 100
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3 200
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4 253
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0 0 lx
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1 50 lx
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2 100 lx
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3 200
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4 500
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0 0 ms
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1 100 ms
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10 1000 ms
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2 200 ms
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3 300 ms
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4 400 ms
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5 500 ms
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6 600 ms
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7 700 ms
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8 800 ms
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9 900 ms
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0 0.00%
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1 3.00%
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10 100.00%
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2 7.00%
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3 12.00%
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4 17.00%
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5 24.00%
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6 33.00%
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7 44.00%
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8 59.00%
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9 78.00%
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0 0.00%
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1 6.00%
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2 16.00%
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3 30.00%
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4 60.00%
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5 100.00%
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0 10
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1 10
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2 100
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3 150
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4 220
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5 253
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0 0 ms
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1 2000 ms
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2 3000 ms
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3 4000 ms
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4 5100 ms
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0 1.00%
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1 5
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2 15
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3 40
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4 100
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren not active
ENG248447-ENG115658-Inszenierung CHoLHo-x0 0 ms
ENG248447-ENG101574-Inszenierung CHoLHo-X1 200 ms
ENG248447-ENG115664-Inszenierung CHoLHo-x10 2000 ms
ENG248447-ENG248838-Inszenierung CHoLHo-x11 200 ms
ENG248447-ENG248839-Inszenierung CHoLHo-x12 400 ms
ENG248447-ENG248840-Inszenierung CHoLHo-x13 600 ms
ENG248447-ENG248841-Inszenierung CHoLHo-x14 800 ms
ENG248447-ENG248842-Inszenierung CHoLHo-x15 1000 ms
ENG248447-ENG99557-Inszenierung CHoLHo-X2 400 ms
ENG248447-ENG102140-Inszenierung CHoLHo-X3 600 ms
ENG248447-ENG102936-Inszenierung CHoLHo-X4 800 ms
ENG248447-ENG103548-Inszenierung CHoLHo-X5 1000 ms
ENG248447-ENG113992-Inszenierung CHoLHo-X6 1200 ms
ENG248447-ENG115661-Inszenierung CHoLHo-x7 1400 ms
ENG248447-ENG115662-Inszenierung CHoLHo-x8 1600 ms
ENG248447-ENG115663-Inszenierung CHoLHo-x9 1800 ms
ENG248447-ENG115659-Inszenierung CHoLHo-y0 0.00%
ENG248447-ENG99777-Inszenierung CHoLHo-Y1 3.00%
ENG248447-ENG115668-Inszenierung CHoLHo-y10 100.00%
ENG248447-ENG136987-Inszenierung CHoLHo-Y11 3.00%
ENG248447-ENG136988-Inszenierung CHoLHo-Y12 7.00%
ENG248447-ENG136989-Inszenierung CHoLHo-Y13 12.00%
ENG248447-ENG136990-Inszenierung CHoLHo-Y14 17.00%
ENG248447-ENG136991-Inszenierung CHoLHo-Y15 24.00%
ENG248447-ENG100480-Inszenierung CHoLHo-Y2 7.00%
ENG248447-ENG100773-Inszenierung CHoLHo-Y3 12.00%
ENG248447-ENG100631-Inszenierung CHoLHo-Y4 17.00%
ENG248447-ENG102174-Inszenierung CHoLHo-Y5 24.00%
ENG248447-ENG113993-Inszenierung CHoLHo-Y6 33.00%
ENG248447-ENG115665-Inszenierung CHoLHo-y7 44.00%
ENG248447-ENG115666-Inszenierung CHoLHo-y8 59.00%
ENG248447-ENG115667-Inszenierung CHoLHo-y9 78.00%
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters LSS ohne Elektronik
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal LIN-Signal
ENG148608-ENG155105-Lenkradhebel-FAS-Taster not installed
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung FL tastend
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung MFL-Bedienung
ENG148608-ENG149001-Lenkradhebel-heated_mirror installed with mirror switch
ENG148608-ENG149004-Lenkradhebel-speed_limiter not installed
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL Direct
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter CAN
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30 installed
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0 100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0 0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0 maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0 maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0 maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0 0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0 0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0 20
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0 52
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0 Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0 Blinken_links_Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0 not_activ
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0 not_activ
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0 not_activ
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0 not_activ
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0 not_activ
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0 not_activ
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0 not_activ
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0 Blinkleuchten
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11 100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11 0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11 maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11 maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11 maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11 0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11 0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11 99
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11 0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11 Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11 Warnblink_taster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11 not_activ
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11 not_activ
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11 not_activ
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11 not_activ
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11 not_activ
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11 not_activ
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11 not_activ
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11 LED_Kleinleistung_mit erhoehter_Nennspannung_ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12 100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12 0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12 maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12 maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12 maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12 0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12 0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12 34
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12 56
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12 Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12 Nebel_licht_links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12 Abbiegelicht_links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12 not_activ
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12 not_activ
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12 not_activ
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12 not_activ
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12 not_activ
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12 not_activ
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12 allgemeineScheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13 100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13 0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13 maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13 maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13 maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13 0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13 0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13 35
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13 66
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13 Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13 Nebellichtrechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13 Abbiegelicht_rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13 not_activ
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13 not_activ
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13 not_activ
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13 not_activ
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13 not_activ
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13 not_activ
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13 allgemeineScheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15 127
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15 0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15 maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15 maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15 maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15 0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15 0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15 90
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15 0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15 Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15 Safe_LED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15 not_activ
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15 not_activ
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15 not_activ
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15 not_activ
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15 not_activ
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15 not_activ
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15 not_activ
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16 100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16 0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16 maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16 maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16 maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16 0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16 0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16 23
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16 57
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16 Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16 Blinken_links_Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16 not_activ
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16 not_activ
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16 not_activ
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16 not_activ
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16 not_activ
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16 not_activ
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16 not_activ
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16 allgemeineGluehlampe6W:auchH6W
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17 100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17 0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17 maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17 maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17 maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17 0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17 0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17 25
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17 67
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17 Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17 Blinken_rechts_Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17 not_activ
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17 not_activ
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17 not_activ
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17 not_activ
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17 not_activ
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17 not_activ
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17 not_activ
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17 allgemeineGluehlampe6W:auchH6W
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18 100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18 0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18 maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18 maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18 maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18 0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18 0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18 22
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18 8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18 Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18 Blinken_links_Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18 not_activ
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18 not_activ
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18 not_activ
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18 not_activ
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18 not_activ
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18 not_activ
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18 not_activ
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18 Blinkleuchten
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19 100
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19 0
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19 maximize
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19 maximize
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19 maximize
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19 0
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19 0
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19 24
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19 24
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19 Always
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19 Blinken_rechts_Hellphase
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19 not_activ
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19 not_activ
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19 not_activ
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19 not_activ
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19 not_activ
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19 not_activ
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19 not_activ
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19 Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1 100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1 0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1 maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1 maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1 maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1 0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1 0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1 21
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1 62
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1 Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1 Blinken_rechts_Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1 not_activ
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1 not_activ
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1 not_activ
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1 not_activ
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1 not_activ
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1 not_activ
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1 not_activ
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1 Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20 100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20 25
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20 maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20 maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20 maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20 0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20 0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20 43
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20 9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20 Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20 Brake lamp
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20 not_activ
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20 Position lamps
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20 Parklichtlinks
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20 not_activ
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20 not_activ
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20 not_activ
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20 not_activ
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20 Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21 100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21 25
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21 maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21 maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21 maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21 0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21 0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21 45
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21 25
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21 Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21 Brake lamp
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21 not_activ
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21 Position lamps
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21 Parklichtrechts
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21 not_activ
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21 not_activ
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21 not_activ
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21 not_activ
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21 Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22 127
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22 0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22 maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22 maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22 maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22 0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22 0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22 44
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22 41
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22 Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22 Brake lamp
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22 not_activ
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22 not_activ
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22 not_activ
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22 not_activ
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22 not_activ
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22 not_activ
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22 not_activ
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23 25
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23 0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23 maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23 maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23 maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23 0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23 0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23 41
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23 10
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23 Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23 Position lamps
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23 Parklichtlinks
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23 not_activ
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23 not_activ
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23 not_activ
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23 not_activ
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23 not_activ
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23 not_activ
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23 allgemeineGluehlampe27W:auchH15-TFL
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24 25
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24 0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24 maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24 maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24 maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24 0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24 0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24 42
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24 26
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24 Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24 Position lamps
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24 Parklichtrechts
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24 not_activ
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24 not_activ
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24 not_activ
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24 not_activ
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24 not_activ
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24 not_activ
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24 allgemeineGluehlampe27W:auchH15-TFL
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25 127
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25 0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25 maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25 maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25 maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25 0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25 0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25 48
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25 40
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25 Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25 Position lamps
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25 not_activ
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25 not_activ
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25 not_activ
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25 not_activ
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25 not_activ
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25 not_activ
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25 not_activ
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25 allgemeine_LED_ohne_Spannungskomp_mit_Ueberspg_absch
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26 127
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26 0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26 maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26 maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26 maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26 0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26 0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26 51
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26 28
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26 Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26 Nebel_schlusslicht
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26 not_activ
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26 not_activ
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26 not_activ
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26 not_activ
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26 not_activ
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26 not_activ
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26 not_activ
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26 allgemeine_LED_12W
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27 100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27 0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27 maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27 maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27 maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27 0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27 0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27 8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27 0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27 Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27 Dimmung_Klemme_58_xs
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27 not_activ
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27 not_activ
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27 not_activ
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27 not_activ
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27 not_activ
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27 not_activ
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27 not_activ
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28 100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28 0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28 maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28 maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28 maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28 0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28 0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28 52
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28 27
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28 Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28 Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28 not_activ
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28 not_activ
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28 not_activ
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28 not_activ
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28 not_activ
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28 not_activ
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28 not_activ
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28 allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29 100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29 0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29 maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29 maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29 maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29 0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29 0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29 1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29 0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29 Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29 Klemme_30_G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29 not_activ
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29 not_activ
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29 not_activ
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29 not_activ
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29 not_activ
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29 not_activ
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29 not_activ
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29 allgemeine_LED_12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2 0
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2 0
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2 maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2 maximize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2 maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2 0
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2 0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2 0
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2 0
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2 Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2 not_activ
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2 not_activ
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2 not_activ
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2 not_activ
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2 not_activ
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2 not_activ
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2 not_activ
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2 not_activ
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2 not_active
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30 126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30 0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30 maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30 maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30 maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30 0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30 0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30 7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30 0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30 Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30 Interior lighting
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30 not_activ
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30 not_activ
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30 not_activ
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30 not_activ
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30 not_activ
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30 not_activ
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30 not_activ
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30 allgemeine_LED_12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31 100
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31 0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31 maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31 maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31 maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31 0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31 0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31 10
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31 0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31 Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31 Dimmung_Klemme_58_xs
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31 not_activ
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31 not_activ
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31 not_activ
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31 not_activ
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31 not_activ
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31 not_activ
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31 not_activ
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32 0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32 0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32 maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32 maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32 maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32 0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32 0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32 0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32 0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32 Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32 not_activ
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32 not_activ
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32 not_activ
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32 not_activ
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32 not_activ
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32 not_activ
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32 not_activ
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32 not_activ
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32 not_active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33 0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33 0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33 maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33 maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33 maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33 0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33 0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33 0
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33 0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33 Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33 not_activ
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33 not_activ
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33 not_activ
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33 not_activ
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33 not_activ
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33 not_activ
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33 not_activ
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33 not_activ
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33 not_active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34 0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34 0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34 maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34 maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34 maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34 0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34 0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34 0
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34 0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34 Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34 not_activ
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34 not_activ
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34 not_activ
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34 not_activ
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34 not_activ
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34 not_activ
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34 not_activ
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34 not_activ
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34 not_active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3 0
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3 0
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3 maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3 maximize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3 maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3 0
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3 0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3 0
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3 0
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3 Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3 not_activ
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3 not_activ
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3 not_activ
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3 not_activ
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3 not_activ
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3 not_activ
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3 not_activ
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3 not_activ
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3 not_active
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4 100
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4 62
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4 maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4 minimize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4 minimize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4 0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4 0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4 32
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4 58
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4 Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4 Daytime running lamps
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4 not_activ
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4 Standlicht_vorn
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4 Parklichtlinks
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4 Fernlichtlinks
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4 Headlamp flasher
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4 Blinkenlinksaktiv
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4 not_activ
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4 allgemeineGluehlampe27W:auchH15-TFL
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5 100
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5 62
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5 maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5 minimize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5 minimize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5 0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5 0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5 33
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5 68
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5 Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5 Daytime running lamps
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5 not_activ
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5 Standlicht_vorn
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5 Parklichtrechts
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5 Fernlichtrechts
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5 Headlamp flasher
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5 Blinkenrechtsaktiv
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5 not_activ
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5 allgemeineGluehlampe27W:auchH15-TFL
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6 100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6 0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6 maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6 maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6 maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6 0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6 0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6 26
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6 54
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6 Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6 Abblendlichtlinks
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6 not_activ
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6 not_activ
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6 not_activ
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6 not_activ
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6 not_activ
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6 not_activ
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6 not_activ
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6 Low beam
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7 100
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7 0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7 maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7 maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7 maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7 0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7 0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7 27
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7 64
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7 Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7 Abblendlichtrechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7 not_activ
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7 not_activ
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7 not_activ
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7 not_activ
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7 not_activ
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7 not_activ
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7 not_activ
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7 Low beam
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8 100
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8 0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8 maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8 maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7 maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8 0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8 0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8 28
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8 55
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8 Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8 Fernlichtlinks
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8 Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8 not_activ
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8 not_activ
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8 not_activ
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8 not_activ
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8 not_activ
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8 not_activ
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8 allgemeineScheinwerfer
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9 100
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9 0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9 maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9 maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9 maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9 0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9 0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9 29
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9 65
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9 Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9 Fernlichtrechts
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9 Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9 not_activ
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9 not_activ
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9 not_activ
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9 not_activ
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9 not_activ
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9 not_activ
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9 allgemeineScheinwerfer
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14 100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14 0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14 maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14 maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14 maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14 0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14 0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14 89
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14 0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14 Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14 Lock_Unlock_LED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14 not_activ
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14 not_activ
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14 not_activ
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14 not_activ
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14 not_activ
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14 not_activ
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14 not_activ
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck) 0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 09 00 2B 18 00 64 08 09 19 00 00 00 00 00 00 0D 19 00 2D 18 00 64 08 0A 19 00 00 00 00 00 00 24 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 09 0A 00 29 08 09 19 00 00 00 00 00 00 00 00 00 09 1A 00 2A 08 0A 19 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 1C 00 33 1A 00 7F 00 00 00 00 00 00 00 00 00 09 1B 00 34 19 00 64 00 00 00 00 00 00 00 00 00
ENG148594-Leuchtenkonfiguration (Sonstiges) 29 00 00 63 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 59 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 5A 40 00 7F 00 00 00 00 00 00 00 00 00 0F 39 00 17 02 00 64 00 00 00 00 00 00 00 00 00 0F 43 00 19 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 20 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 20 00 00 07 29 00 7E 00 00 00 00 00 00 00 00 00 24 00 00 0A 26 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG126648-MAS02526-LIN-Mirrormode-Activation not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active
ENG126648-ENG149044-LIN-Mirrormode-LIN4 not active
ENG126648-ENG149045-LIN-Mirrormode-LIN5 not active
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0 0.00%
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1 5.00%
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2 50.00%
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3 75.00%
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4 110.00%
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5 126.50%
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0 0.00%
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1 6.00%
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2 16.00%
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3 30.00%
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4 60.00%
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5 100.00%
ENG122979-MAS00075-Networking-ABS Control Module installed
ENG122979-MAS00798-Networking-Transmission Control Module (TCM) installed
ENG122979-MAS01374-Networking-Trailer not installed
ENG122979-MAS03175-Networking-Extended data bus not installed
ENG122979-MAS09880-Networking-Interval potentiometer installed
ENG122979-MAS09882-Networking-MFA button on BCM not installed
ENG122979-MAS10518-Networking-A/C electronics installed
ENG122979-MAS10570-Networking-Window lift type MQB_window_regulator
ENG122979-ENG149007-Networking-Door LIN installed
ENG122979-ENG252084-Networking-KL30_weckfaehig non_wakable
ENG122979-ENG149008-Networking-Roof LIN installed
ENG122979-ENG149009-Networking-Sounder LIN installed
ENG122979-ENG149010-Networking-Wiper LIN not installed
ENG124714-ENG142044-OCU-DWA_push active
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare active
ENG124714-OCU- installed
ENG124714-ENG142261-OCU-Remote HuF Abbruch 20 km/h
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz 3 Hz
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0 15 s
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1 80 s
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2 15 s
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3 2000 ms
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4 15 s
ENG124714-ENG125657-OCU-Remote_Unlock_Lock Via BAP / Fazit
ENG124714-ENG154722-OCU-RHF_Panikalarm active
ENG141646-MAS00481-Querschnitts_funktionen-BAP active
ENG141646-MAS01065-Querschnitts_funktionen-Brand VW
ENG141646-MAS04194-Querschnitts_funktionen-Driver side Right
ENG141646-MAS10509-Querschnitts_funktionen-Traffic Left
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer installed
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System not active
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent not active
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung active
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung not active
ENG141646-ENG154685-Querschnitts_funktionen-Hupe Sollspannungsanforderung 13.5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben not active
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv not active
ENG141646-ENG148952-Querschnitts_funktionen-P_locked installed
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3 not installed
ENG117297-Reversing_Threshold_Driver_Side_Front 90%
ENG117298-Reversing_Threshold_Passenger_Side_Front 90%
ENG122927-RLS_close_glazing 2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s
ENG122929-RLS_LIN_Communication 4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx
ENG122930-RLS_tunel_gateway_recognize 5 s
ENG122935-RLS_Washer_Front 15 s
ENG122926-RLS_wiper_position_parking 15 s
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system not installed
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA not active
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung 0
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel not active
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit 0 ms
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit 0 ms
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit 0 ms
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit 0 ms
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit 0 ms
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system installed
ENG116588-MAS10520-Sonderfunktionen-Special function 1 not installed
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker SMLS
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2 not enabled
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen active
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus by_convenience_operation_via_remote_control_key
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung not active
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen active
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side not installed
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel active
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf not active
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt not active
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung not active
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig active
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress Standard
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0 0.0 lx
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1 8.0 lx
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2 50.0 lx
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3 80.0 lx
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4 100.0 lx
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0 6
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1 6
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2 20
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3 50
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4 100
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0 0.0 lx
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1 8.0 lx
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2 50.0 lx
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3 80.0 lx
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4 100.0 lx
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0 6
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1 6
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2 20
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3 50
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4 100
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 200 lx
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 400 lx
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 600 lx
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 84
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 166
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 250
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 370
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500
ENG141632-MAS10512-Sunroof-Sunroof module MD1 not installed
ENG141632-MAS10513-Sunroof-Sunroof module MD shade not installed
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen not active
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen not active
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen Open
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule LIN
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1 active
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS mechanisch
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS OBW-Schloss
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs mit TKM
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1 active
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS No
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS No
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs ohne TKM
ENG148611-MAS10548-Verbau Personalisierung-Profile function no key profile
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert not active
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert not active
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert not active
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert not active
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert not active
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar not active
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten 0
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung not active
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management not installed
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys not active
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv not active
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante Schluessel
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0 not active
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1 not active
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2 not active
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3 not active
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4 not active
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5 not active
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6 not active
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7 not active
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1 00 00
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2 00 00
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3 00 00
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4 00 00
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1 00 00
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2 00 00
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3 00 00
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4 00 00
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5 00 00
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6 00 00
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1 00 16 90 19 22 00 00 00 FF FE FF 07 D0 10 10 F6 00 00 32 0B 0F 04 B0 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 05 B8 D8 00 05 86 10 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 EF 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2 A9 69
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1 03 E8 03 52 14 1E EC 01 0B 02 08 00 00 28 32 05 28 02 1E 19 0A 00 0A F4 4B 32 0C 00 05 FB 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 37 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 04 46 0B 10 0E 37 C8 F6 F1 F6 FB 13 12 00 08 14 00 FA 02 41 0A 10 0E 37 64 F6 F1 F6 FB 19 14 05 08 14 19 37 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2 0A CB
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1 33 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 00 05 05 17 70 00 10 00 2A 32 00 60 0A 03 00 19 1E 64 00 00 00 00 00 00 00 00
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2 70 3F
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1 00 12 90 19 02 00 00 00 FF FE FF 07 D0 10 10 F6 00 00 32 0B 0F 04 B0 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 05 B8 D8 00 05 86 10 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 8F 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2 F0 59
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1 03 E8 03 52 14 1E EC 01 0B 02 08 00 00 28 32 05 28 02 1E 19 0A 00 0A F4 4B 32 0C 00 05 FB 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 37 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 04 46 0B 10 0E 37 C8 F6 F1 F6 FB 13 12 00 08 14 00 FA 02 41 0A 10 0E 37 64 F6 F1 F6 FB 19 14 05 08 14 19 37 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2 0A CB
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1 33 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 0E 05 05 17 70 00 10 00 2A 32 00 60 0A 03 00 19 1E 64 00 00 00 00 00 00 00 00
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2 9A B7
ENG124895-Window_Regulator_VW_Settings_Driver_Side F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 19 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 96 96 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 2D 3C 50 00 64 1E 50 06 00 B4 01 00 0A 00 14 00 00
ENG130137-Window_Regulator_VW_Settings_Passenger_Side F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 19 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 32 32 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 2D 3C 50 00 64 1E 50 06 01 1E 01 00 0A 00 14 00 00
ENG148493-ENG115721-Windshield wiper-Frontwischer Sollspannungsanforderung 13.5
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition keine_Abtaupostition
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf active
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition active
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung active
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer active
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer 0 ms
ENG148493-ENG149042-Windshield wiper-rain_sensor_function installed
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren active
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status not active
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant not active
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ Direct
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube not active
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus active
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart nur_Erststart
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube active
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button Rocker sw.
ENG141651-MAS10546-ZV allgemein-Radio freq. 434.42MHz
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function not installed
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen not active
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring not active
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm active
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf not active
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt No
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein not active
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut not active
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung not active
ENG141651-ENG115755-ZV allgemein-Notschließfunktion active
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung all_doors_connected_directly
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung No
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung Globale_Entriegelung
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck active
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln active
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit not active
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR not active
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock adjustable
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren active
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen active
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash not active
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button not installed
ENG141653-MAS10551-ZV Heck-Rear lid lock control Contact control
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type 1 or 2 notch rear actuator
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch Yes
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels active
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster not active
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV not active
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv not active
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen not active
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung digitale_Logik
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel not active
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel active
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen not active
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing active
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening active
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front active
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear No
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen not active
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf active
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen active
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen active
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit 600 s
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus active
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen active
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen active
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen active
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster not active
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global active
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer not active
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien not active
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung not active
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar adjustable
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen active
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen active
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock 2 Motor locks
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door not installed
ENG141652-MAS10567-ZV Türkonfiguration-Four-door No
This is a vehicle that came from Factory with Rear LEDs already installed - WV2ZZZ7HZMH026527
VCDS Scan
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 44 55 5F 6D 75 BB BC BE BF
D6 D7
VIN: WV2ZZZ7HZMH026527 Mileage: 82km-50miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 QF HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9695
Revision: 23301001
Coding: 0025401C4364050800000000000000000000000000000000
Shop #: WSC 00012 790 00070
ASAM Dataset: EV_ECM20TDI03004L906056QF 004004
ROD: EV_ECM20TDI03004L906056QE.rod
VCID: 015F87A2118831A35DD-8054
Readiness: N/A
Part No SW: 0BT 300 046 R HW: 0GC 927 711 H
Component: GSG DQ500 H06 3101
Revision: 00H06V11
ROD: EV_TCMDQ500021_VN46.rod
VCID: 45D753B24520DD83215-8010
Part No SW: 7LA 614 517 A HW: 7LA 614 517
Component: ESC_high H01 0700
Serial number: 08501096200921
Coding: 105524524849E68B085924A6126D6726393720B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3D273B522DF09543795-8068
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 7LA 907 040 E HW: 7LA 907 040 E
Component: Climatronic H01 0602
Coding: 0031100008102100010009005040010500000000000B1101A08000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: N/A
Subsystem 1 - Part No SW: 7LA 907 049 F HW: 7LA 907 049 F
Component: E857 H02 0301
Serial number: 00002300620101735601
No ASAM data for: "EV_AirCondiBHTCVN54XT6PA" (VN46)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 090 C HW: 2Q0 937 090 C
Component: BCM A0 Std+ H11 0943
Serial number: 00102027004677
Shop #: WSC 00012 790 00156
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206.rod
VCID: 323D186EE4AE5A3B947-8066
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SAY20M09D23H18M50S02
Coding: 0018EE
Drivers Door Control Module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000041645853
Coding: 1F0007
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000041669358
Coding: 050007
Subsystem 4 - Part No SW: 2N0 951 173 HW: 2N0 951 173
Component: Sensor, DWA 015 0316
Serial number: 000000000ZY202350AS5
Serial number: 00000000000048657505
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057320269
Coding: 8379161851
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_VW27.rod
VCID: 58E98AC6A292506B4A3-800C
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200670349FF8748949C815580508700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D34DAA4B14E3B30F1-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AE HW: 2Q0 959 655 AE
Component: VW22Airbag 016 0506
Revision: --------
Coding: 88CCC00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 005982A61A8238AB523-8054
Subsystem 1 - Part No SW: ----------- HW: 442 063 009 20
Serial number: 3577Y51C3272ABB412A8
Subsystem 2 - Part No SW: ----------- HW: 442 063 009 20
Serial number: 3587Y52BF32C43C1B2AL
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 320 A HW: 7LA 920 320 A
Component: KOMBI 502 5175
Coding: 24A400082D800600018862011001000880601F02
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 3537237215C04D03B15-8060
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 41
Mileage: 82 km
Date: 2020.11.11
Time: 08:12:45
16777056 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_SDS_0x46 keine Kommunikation]
Reset counter: 41
Mileage: 82 km
Date: 2020.11.11
Time: 08:12:45
16711685 - Databus
Reset counter: 41
Mileage: 82 km
Date: 2020.11.17
Time: 14:03:59
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 5WA 963 271 A HW: 5WA 963 271 A
Component: STH-VW37x 006 0010
Serial number: 000000000000037
Coding: 3143221854121512DCE519
ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
ROD: EV_AuxilHeateWOSVW38X_VW27.rod
VCID: 4ACD608E6C3E32FBCC7-801E
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 27092011600713
Coding: 030100044F05730001100258100F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74B1DE765E3A140B46B-8020
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440071260204605
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
Serial number: 771972000020092302EE
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0306
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB_VN46.rod
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8E020009200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DF47A25108F1A31DD-8014
Part No SW: 3G5 035 820 B HW: 3G5 035 820
Component: MU-O-ND-EU H56 0781
Serial number: WG8LGM260920000
Coding: 64600008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_SE27.rod
VCID: 2313ED2AAB54C3B36F1-8076
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 7LA 959 107 A HW: 4M0 959 107 C
Component: HDSG-Modul H14 0673
Revision: -------- Serial number: A2-C769-9790-3
Coding: 4100
ASAM Dataset: EV_DeckLidCONTIVN46T 001017
ROD: EV_DeckLidCONTIVN46T.rod
VCID: 44D14EB64E1AE48B36B-8010
Part No SW: 5WA 035 284 B HW: 5WA 035 284 B
Component: OCUGen3High H20 0035
Serial number: 0000000008VINVA
Coding: 06462000196898209005460160402607
ASAM Dataset: EV_OCUGen3High 003005
ROD: EV_OCUGen3High_003_VW38.rod
1078036 - Crash Signal
B1073 15 [008] - Open or Short to Plus
[Airbag line - Interruption/ Short circuit to battery]
Reset counter: 39
Mileage: 9 km
Date: 2020.11.09
Time: 08:33:34
Voltage terminal 30: 11.8 V
1644017 - Online Services
B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
[Functional restriction due to insufficient power budget]
Reset counter: 39
Mileage: 9 km
Date: 2020.11.06
Time: 15:59:35
Voltage terminal 30: 12.6 V
Remaining long term energy budget: 2635 mAh
Remaining short term energy budget: 3 mAh
Wake up cycles counter: 42
Address BB: Door Rear Drv (J1093) Labels: None
Part No SW: 7LA 035 593 A HW: 7LA 035 593 A
Component: SLD_Rx-Unit_d H07 0031
Serial number: 1900747F
Coding: 00
ASAM Dataset: EV_ReceiRearDriveSideHuf 002002
ROD: EV_ReceiRearDriveSideHuf.rod
VCID: 3E253C5E20F68E5B60F-806A
Address BC: Door Rear Pass (J1094) Labels: None
Component: SLD_Rx-Unit_p H07 0031
Serial number: 19007486
Coding: 00
ASAM Dataset: EV_ReceiRearPasseSideHuf 002002
Address BE: Slid. Door Rear Left (J926) Labels:* None
Part No SW: 7LA 959 244 D HW: 7LA 959 244 D
Component: Slidingdoor_d H09 0037
Serial number: 18004962
Coding: 12
ASAM Dataset: EV_SlideDoorDriveHufT6PA 001010
ROD: EV_SlideDoorDriveHufT6PA.rod
VCID: 49CF5F82693839E3C5D-801C
Address BF: Slid. Door Rear Right (J927) Labels:* None
Component: Slidingdoor_p H09 0037
Serial number: 180049F2
Coding: 12
ASAM Dataset: EV_SlideDoorPasseHufT6PA 001010
ROD: EV_SlideDoorPasseHufT6PA.rod
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_SK25.rod
VCID: 619FA722F1C891A33DD-8034
Component: LED1R H08 9002
09 Central Electrics ADMAP
IDE00001-ENG130235-Production mode-Entry_control not_active
IDE00001-ENG115730-Production mode-Exterior lighting not_active
IDE00001-ENG112304-Production mode-Heckwischer not_active
IDE00001-ENG98647-Production mode-Interior lighting not_active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not_active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1 not_active
IDE00001-ENG130232-Production mode-Window_reversing_threshold not_active
IDE00002-Transport mode active
IDE00820-Activating and deactivating all development messages not active
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln not active
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global not active
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn not active
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln not active
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn normal
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung not active
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte not active
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl not active
IDE02332-Deactivate production mode 0
IDE02488-DWA Interior monitoring 100%
IDE02711-ENG149246-Rear Window Wiper-Automatisches_Heckwischen not active
IDE02711-ENG112304-Rear Window Wiper-Heckwischer Keine_Spannungsanforderung
IDE02711-ENG149248-Rear Window Wiper-Heckwischer_Weiterlauf not active
IDE02711-ENG115850-Rear Window Wiper-Komfortwischen_Heck active
IDE02711-ENG149251-Rear Window Wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1 5 s
IDE02711-ENG149252-Rear Window Wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2 3 s
IDE02711-ENG149250-Rear Window Wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik 7 s
IDE02711-ENG149249-Rear Window Wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall 7 s
IDE02711-ENG149245-Rear Window Wiper-Menuesteuerung_Komfortwischen_HW active
IDE02711-ENG148996-Rear Window Wiper-rear_window_wiper DWP_Extraction
IDE02711-ENG149247-Rear Window Wiper-Traenenwischen_Heck not active
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck 1200 ms
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front not installed
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI not active
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung not active
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default not active
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel Enabled
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen not active
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus not active
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer not installed
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung not installed
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung not installed
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe NOT-DEFINED
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum 50%
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer 0%
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn 0%
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil not installed
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI not installed
IDE02957-ENG114629-Ambient lighting-Foot well lighting installed
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung not installed
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung not installed
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung not installed
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel not installed
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.5 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s
IDE03638-ENG149111-static AFS light-bei_Rueckwaertsfahrt both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C
IDE03638-ENG149114-static AFS light-Obere_Geschwindigkeitsschwelle 40.0 km/h
IDE03638-ENG149117-static AFS light-obere_Grenztemperatur 95.0 °C
IDE03638-ENG149116-static AFS light-Oberer_Lenkradwinkel 120 °
IDE03638-ENG149113-static AFS light-Untere_Geschwindigkeitsschwelle 0.0 km/h
IDE03638-ENG149118-static AFS light-untere_Grenztemperatur 80.0 °C
IDE03638-ENG149115-static AFS light-Unterer_Lenkradwinkel 80 °
IDE03638-ENG116674-static AFS light-Vorschrift ECE_R119
IDE03638-ENG149112-static AFS light-Zeitwert_Einschaltzeit_Abbiegelicht 15 min
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s
IDE04927-MAS01535-Window heater-Rear window defogger installed
IDE04927-MAS01564-Window heater-Windshield defogger installed
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung 35.0 °C
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung 35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung 600 s
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert 320 s
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH active
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH active
IDE05144-Read parameter address 00 00 00
IDE05145-Light configuration 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 00 00 46 08 7F 09 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 52 00 5D 46 08 7F 09 00 7F 00 00 00 00 00 00 05 53 00 5E 46 08 7F 0A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 5F 00 64 00 00 00 00 00 00 0A 42 00 23 13 17 64 5F 00 64 00 00 00 00 00 00
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin 0
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin 0
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin puddle light
IDE05822-DWA Vehicle inclination sensor 100%
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A 78 01 14 0A 03 81 33 0C FF 00 00 01 96 A6 03 00 0F 1F 00 86 02 3B C7 E4 2D 85 42 57 9B 25 34 2C 3A 09 45 85 2E 0A A3 02 9F 06 56 00 0F 17 00 84 0C 3B F7 E9 0E F3 42 97 9B 05 34 3F 3A 69 23 03 0A 0A A3 03 44 46 0A 00 0F 1C 00 88 0E 2F E7 E9 2D 65 43 77 9B 05 24 3F 3A 69 47 03 0A 0A A3 04 23 15 4A 16 0A 16 1F 89 0B 28 51 32 0C 61 31 5B 94 05 24 8F FD 57 45 02 14 06 A2 05 97 06 02 17 0C 11 18 86 04 23 33 E8 2D 65 42 57 9B 25 24 0C FA 0A 35 85 2E 0A A3 21 03 00 02 02 02 02 02 02 F1 50 E1 2B 35
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung temperaturgesteuert
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats not connected
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN seat_heater_on_LIN
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1 0%
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2 20%
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3 0%
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4 100%
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5 0%
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6 100%
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit 2 min
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 23.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 22.00 °C
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit 15 min
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.50 °C
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit 15 min
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI Keine_Spannungsanforderung
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO Keine_Spannungsanforderung
IDE06096-ENG149157-Interior lighting-Innenlicht_bei_offenem_Heckdeckel_einschalten active
IDE06096-ENG98648-Interior lighting-Interior light Keine_Spannungsanforderung
IDE06425-Roller test bench mode: functional not active
IDE08786-MAS10528-Assistance light functions-Rain/light sensor Rain/light sensor
IDE08786-MAS10545-Assistance light functions-Humidity sensor not installed
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP present
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung 0 ms
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen active
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor not installed
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit 0 °
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC 0 °
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0 not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1 not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10 not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11 not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12 not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13 not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14 not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15 not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16 not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17 not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18 not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19 not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2 not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20 not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21 not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22 not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23 not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24 not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25 not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26 not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27 not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28 not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29 not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3 not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30 not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31 not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32 not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33 not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34 not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4 not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5 not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6 not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7 not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8 not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9 not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand 0_Ohm
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit 0 °
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC 0 °
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0 not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1 not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10 not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11 not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12 not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13 not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14 not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15 not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16 not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17 not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18 not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19 not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2 not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20 not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21 not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22 not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23 not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24 not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25 not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26 not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27 not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28 not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29 not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3 not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30 not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31 not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32 not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33 not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34 not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4 not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5 not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6 not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7 not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8 not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9 not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand 0_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs not active
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit 30 min
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose not active
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein not active
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0
IDE11944-MAS10510-Keyless access and start authorization-Kessy not installed
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR not active
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber not active
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit not active
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit not active
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen not active
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen active
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung not active
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system not installed
MAS01490-IDE08581-Energy management-Recuperation active
MAS01490-MAS12921-Energy management-Predictive energy management not active
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement active
MAS01490-ENG98636-Energy management-Hybrid No
MAS01490-ENG142037-Energy management-Zweitbatterie not installed
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 0 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 0 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 0 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 0 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 0 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 0 lx
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 00 00
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 0 lx
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway not active
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain not active
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF not active
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 0 mV
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 0 lx
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 0 mV
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 0
MAS16372-Security version number 1
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status not active
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC 00 00 00
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC First_dtc
ENG148492-MAS01577-Anti-theft device-Parking heater not installed
ENG148492-ENG149232-Anti-theft device-Akustischer_Alarm_Signalhorn not active
ENG148492-ENG115864-Anti-theft device-Alarmsignal frequency_modulated
ENG148492-ENG148991-Anti-theft device-anti_theft_alarm_system active
ENG148492-ENG148992-Anti-theft device-anti_theft_alarm_with_simple_horn sounder_installed
ENG148492-ENG148993-Anti-theft device-anti_theft_alarm_without_Thatcham No
ENG148492-ENG148990-Anti-theft device-deactivation_button_anti_theft_alarm_sensor not installed
ENG148492-ENG154590-Anti-theft device-Deaktivierung_DWA_ueber_MMI active
ENG148492-ENG123016-Anti-theft device-Diebstahlschutz_mit_Anhaenger not active
ENG148492-ENG149229-Anti-theft device-DWA_Alarmverzoegerung immidiat_driver_door_contact_thatcham
ENG148492-ENG149230-Anti-theft device-DWA_Camper_Modus not active
ENG148492-ENG148994-Anti-theft device-interior_monitoring_sensor Yes
ENG148492-ENG149231-Anti-theft device-Sirenen_Alarmzahl 10_Alarme
ENG148492-ENG142008-Anti-theft device-tilt_sensor Yes
ENG148492-ENG149228-Anti-theft device-Verzoegerung_Panikalarm 2_sekunden_verzoegerung
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger separte
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen 3
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type H7
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze 350 km/h
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze 350 km/h
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag Daytime running lights
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich not active
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren in_Betrieb_lassen
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht not active
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht active
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich not active
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten not active
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO not active
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht not active
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge active
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal No
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion not active
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit 255 km/h
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA active
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion not active
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion not active
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection Discrete signal current
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light Yes
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light Yes
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL Yes
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos. Yes
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6 No
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung Energy management
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung Energy management
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht active
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten Low beam
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus manual
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis Driver_door
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv not active
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach active
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig in 0 and SL position
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer Faktor fuer x5 Minuten
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH Keine_Spannungsanforderung
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light Keine_Spannungsanforderung
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung 116
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung 72
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker false
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht integriert_in_Suchbeleuchtung
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus Enabled
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert active
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit 10 seconds
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht Yes
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module installed
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam Keine_Spannungsanforderung
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO Menuesteuerung_Zeit_aktivieren
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome 10 seconds
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung active
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert One-sided
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt active
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit 24 s
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6 No
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal Keine_Spannungsanforderung
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck active
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei 124 cm
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich 0 cm
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite not active
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis active
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck active
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF active
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung 1.6 s
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung 2.0 s
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1 installed
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2 not installed
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3 installed
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4 not installed
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control AFS: Fernlicht ueber AFS
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset not active
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert 0 ms
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent Not Present
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung present
ENG248411-ENG248631-Front doors-cockpittaster2_funktion not active
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung not active
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen not active
ENG248411-ENG248768-Front doors-NFZ_Schliessung not active
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne No
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum not installed
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion Yes
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug No
ENG248444-ENG248691-Global-Funktion_SAFE Yes
ENG248444-ENG248774-Global-pa_eKiSi Yes
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite Yes
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv No
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv No
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck not installed
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck Federsteller
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck Klappe
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid installed
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid installed
ENG141645-MAS00213-HW_Verbau-Insufficient coolant installed
ENG141645-MAS00214-HW_Verbau-Brake pad wear installed
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch installed
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor installed
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter Open
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15 active
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN horn_via_LIN
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit installed
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0 0 lx
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1 8 lx
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2 200 lx
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3 300 lx
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4 500 lx
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0 16
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1 16
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2 100
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3 100
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4 100
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0 0 lx
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1 8 lx
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2 220 lx
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3 300 lx
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4 500 lx
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0 6
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1 6
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2 100
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3 100
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4 100
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0 0
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1 10
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2 100
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3 150
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4 220
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5 253
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0 3.00%
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1 3.00%
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2 11.00%
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3 40.00%
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4 82.00%
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5 100.00%
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0 0 lx
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1 8 lx
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2 50 lx
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3 500 lx
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0 100
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1 100
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2 100
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3 100
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0 0.00%
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1 50.00%
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2 100.00%
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0 0.00%
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1 50.00%
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2 100.00%
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0 0 lx
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1 8 lx
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2 50 lx
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3 500 lx
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0 100
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1 100
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2 100
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3 100
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0 0 lx
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1 8 lx
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2 50 lx
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3 500 lx
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0 6
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1 6
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2 100
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3 100
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0 0.00%
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1 50.00%
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2 100.00%
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0 0.00%
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1 50.00%
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2 100.00%
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0 0 ms
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1 100 ms
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10 1000 ms
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2 200 ms
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3 300 ms
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4 400 ms
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5 500 ms
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6 600 ms
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7 700 ms
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8 800 ms
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9 900 ms
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0 100.00%
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1 78.00%
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10 0.00%
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2 59.00%
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3 44.00%
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4 33.00%
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5 24.00%
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6 17.00%
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7 12.00%
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8 7.00%
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9 3.00%
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0 0
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1 50
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2 100
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3 200
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4 253
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0 0 lx
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1 50 lx
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2 100 lx
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3 200
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4 500
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0 0 ms
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1 100 ms
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10 1000 ms
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2 200 ms
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3 300 ms
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4 400 ms
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5 500 ms
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6 600 ms
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7 700 ms
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8 800 ms
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9 900 ms
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0 0.00%
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1 3.00%
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10 100.00%
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2 7.00%
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3 12.00%
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4 17.00%
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5 24.00%
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6 33.00%
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7 44.00%
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8 59.00%
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9 78.00%
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0 0.00%
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1 6.00%
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2 16.00%
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3 30.00%
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4 60.00%
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5 100.00%
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0 10
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1 10
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2 100
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3 150
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4 220
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5 253
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0 0 ms
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1 2000 ms
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2 3000 ms
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3 4000 ms
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4 5100 ms
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0 1.00%
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1 5
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2 15
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3 40
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4 100
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren not active
ENG248447-ENG115658-Inszenierung CHoLHo-x0 0 ms
ENG248447-ENG101574-Inszenierung CHoLHo-X1 200 ms
ENG248447-ENG115664-Inszenierung CHoLHo-x10 2000 ms
ENG248447-ENG248838-Inszenierung CHoLHo-x11 200 ms
ENG248447-ENG248839-Inszenierung CHoLHo-x12 400 ms
ENG248447-ENG248840-Inszenierung CHoLHo-x13 600 ms
ENG248447-ENG248841-Inszenierung CHoLHo-x14 800 ms
ENG248447-ENG248842-Inszenierung CHoLHo-x15 1000 ms
ENG248447-ENG99557-Inszenierung CHoLHo-X2 400 ms
ENG248447-ENG102140-Inszenierung CHoLHo-X3 600 ms
ENG248447-ENG102936-Inszenierung CHoLHo-X4 800 ms
ENG248447-ENG103548-Inszenierung CHoLHo-X5 1000 ms
ENG248447-ENG113992-Inszenierung CHoLHo-X6 1200 ms
ENG248447-ENG115661-Inszenierung CHoLHo-x7 1400 ms
ENG248447-ENG115662-Inszenierung CHoLHo-x8 1600 ms
ENG248447-ENG115663-Inszenierung CHoLHo-x9 1800 ms
ENG248447-ENG115659-Inszenierung CHoLHo-y0 0.00%
ENG248447-ENG99777-Inszenierung CHoLHo-Y1 3.00%
ENG248447-ENG115668-Inszenierung CHoLHo-y10 100.00%
ENG248447-ENG136987-Inszenierung CHoLHo-Y11 3.00%
ENG248447-ENG136988-Inszenierung CHoLHo-Y12 7.00%
ENG248447-ENG136989-Inszenierung CHoLHo-Y13 12.00%
ENG248447-ENG136990-Inszenierung CHoLHo-Y14 17.00%
ENG248447-ENG136991-Inszenierung CHoLHo-Y15 24.00%
ENG248447-ENG100480-Inszenierung CHoLHo-Y2 7.00%
ENG248447-ENG100773-Inszenierung CHoLHo-Y3 12.00%
ENG248447-ENG100631-Inszenierung CHoLHo-Y4 17.00%
ENG248447-ENG102174-Inszenierung CHoLHo-Y5 24.00%
ENG248447-ENG113993-Inszenierung CHoLHo-Y6 33.00%
ENG248447-ENG115665-Inszenierung CHoLHo-y7 44.00%
ENG248447-ENG115666-Inszenierung CHoLHo-y8 59.00%
ENG248447-ENG115667-Inszenierung CHoLHo-y9 78.00%
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters LSS ohne Elektronik
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal LIN-Signal
ENG148608-ENG155105-Lenkradhebel-FAS-Taster not installed
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung FL tastend
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung MFL-Bedienung
ENG148608-ENG149001-Lenkradhebel-heated_mirror installed with mirror switch
ENG148608-ENG149004-Lenkradhebel-speed_limiter not installed
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL Direct
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter CAN
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30 installed
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0 0
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0 0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0 maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0 maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0 maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0 0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0 0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0 0
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0 0
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0 Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0 not_activ
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0 not_activ
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0 not_activ
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0 not_activ
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0 not_activ
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0 not_activ
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0 not_activ
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0 not_activ
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0 not_active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11 100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11 0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11 maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11 maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11 maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11 0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11 0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11 99
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11 0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11 Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11 Warnblink_taster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11 not_activ
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11 not_activ
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11 not_activ
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11 not_activ
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11 not_activ
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11 not_activ
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11 not_activ
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11 LED_Kleinleistung_mit erhoehter_Nennspannung_ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12 100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12 100
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12 maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12 maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12 maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12 0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12 0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12 34
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12 56
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12 Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12 Nebel_licht_links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12 Abbiegelicht_links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12 intermittierend_Nebellicht
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12 not_activ
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12 not_activ
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12 not_activ
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12 not_activ
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12 not_activ
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12 allgemeineScheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13 100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13 100
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13 maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13 maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13 maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13 0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13 0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13 35
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13 66
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13 Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13 Nebellichtrechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13 Abbiegelicht_rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13 intermittierend_Nebellicht
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13 not_activ
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13 not_activ
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13 not_activ
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13 not_activ
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13 not_activ
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13 allgemeineScheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15 127
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15 0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15 maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15 maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15 maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15 0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15 0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15 90
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15 0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15 Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15 Safe_LED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15 not_activ
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15 not_activ
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15 not_activ
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15 not_activ
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15 not_activ
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15 not_activ
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15 not_activ
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16 100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16 0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16 maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16 maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16 maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16 0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16 0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16 23
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16 57
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16 Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16 Blinken_links_Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16 not_activ
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16 not_activ
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16 not_activ
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16 not_activ
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16 not_activ
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16 not_activ
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16 not_activ
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16 allgemeineGluehlampe6W:auchH6W
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17 100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17 0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17 maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17 maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17 maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17 0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17 0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17 25
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17 67
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17 Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17 Blinken_rechts_Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17 not_activ
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17 not_activ
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17 not_activ
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17 not_activ
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17 not_activ
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17 not_activ
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17 not_activ
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17 allgemeineGluehlampe6W:auchH6W
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18 127
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18 0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18 maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18 maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18 maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18 0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18 0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18 22
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18 8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18 Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18 Blinken_links_Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18 not_activ
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18 not_activ
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18 not_activ
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18 not_activ
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18 not_activ
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18 not_activ
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18 not_activ
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18 LED_Blinkleuchten
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19 127
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19 0
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19 maximize
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19 maximize
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19 maximize
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19 0
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19 0
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19 24
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19 24
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19 Always
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19 Blinken_rechts_Hellphase
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19 not_activ
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19 not_activ
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19 not_activ
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19 not_activ
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19 not_activ
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19 not_activ
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19 not_activ
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19 LED_Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1 0
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1 0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1 maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1 maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1 maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1 0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1 0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1 0
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1 0
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1 Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1 not_activ
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1 not_activ
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1 not_activ
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1 not_activ
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1 not_activ
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1 not_activ
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1 not_activ
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1 not_activ
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1 not_active
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20 127
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20 0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20 maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20 maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20 maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20 0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20 0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20 43
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20 9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20 Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20 Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20 not_activ
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20 not_activ
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20 not_activ
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20 not_activ
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20 not_activ
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20 not_activ
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20 not_activ
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20 LED Bremsleuchten_mit_Ueberspg_absch
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21 127
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21 0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21 maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21 maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21 maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21 0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21 0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21 45
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21 25
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21 Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21 Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21 not_activ
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21 not_activ
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21 not_activ
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21 not_activ
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21 not_activ
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21 not_activ
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21 not_activ
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21 LED Bremsleuchten_mit_Ueberspg_absch
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22 127
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22 0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22 maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22 maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22 maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22 0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22 0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22 44
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22 41
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22 Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22 Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22 not_activ
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22 not_activ
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22 not_activ
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22 not_activ
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22 not_activ
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22 not_activ
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22 not_activ
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23 127
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23 0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23 maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23 maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23 maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23 0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23 0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23 41
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23 10
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23 Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23 Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23 Parklichtlinks
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23 not_activ
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23 not_activ
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23 not_activ
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23 not_activ
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23 not_activ
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23 not_activ
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23 allgemeine_LED_12W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24 127
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24 0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24 maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24 maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24 maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24 0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24 0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24 42
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24 26
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24 Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24 Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24 Parklichtrechts
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24 not_activ
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24 not_activ
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24 not_activ
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24 not_activ
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24 not_activ
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24 not_activ
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24 allgemeine_LED_12W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25 127
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25 0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25 maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25 maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25 maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25 0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25 0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25 48
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25 40
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25 Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25 Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25 not_activ
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25 not_activ
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25 not_activ
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25 not_activ
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25 not_activ
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25 not_activ
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25 not_activ
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25 allgemeine_LED_ohne_Spannungskomp_mit_Ueberspg_absch
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26 127
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26 0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26 maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26 maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26 maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26 0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26 0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26 51
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26 28
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26 Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26 Nebel_schlusslicht
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26 not_activ
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26 not_activ
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26 not_activ
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26 not_activ
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26 not_activ
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26 not_activ
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26 not_activ
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26 allgemeine_LED_12W
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27 100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27 0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27 maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27 maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27 maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27 0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27 0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27 8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27 0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27 Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27 Dimmung_Klemme_58_xs
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27 not_activ
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27 not_activ
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27 not_activ
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27 not_activ
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27 not_activ
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27 not_activ
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27 not_activ
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28 127
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28 0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28 maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28 maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28 maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28 0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28 0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28 52
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28 11
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28 Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28 Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28 not_activ
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28 not_activ
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28 not_activ
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28 not_activ
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28 not_activ
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28 not_activ
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28 not_activ
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28 allgemeine_LED_12W
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29 100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29 0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29 maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29 maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29 maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29 0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29 0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29 1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29 0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29 Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29 Klemme_30_G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29 not_activ
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29 not_activ
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29 not_activ
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29 not_activ
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29 not_activ
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29 not_activ
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29 not_activ
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29 allgemeine_LED_12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2 127
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2 127
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2 maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2 maximize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2 maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2 0
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2 0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2 0
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2 0
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2 Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2 Versorgung_AFS_bei_LCM
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2 Parking light
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2 Parklichtlinks
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2 Parklichtrechts
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2 not_activ
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2 not_activ
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2 not_activ
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2 not_activ
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2 allgemeineGluehlampe6W:auchH6W
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30 126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30 0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30 maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30 maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30 maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30 0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30 0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30 7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30 0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30 Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30 Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30 not_activ
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30 not_activ
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30 not_activ
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30 not_activ
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30 not_activ
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30 not_activ
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30 not_activ
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30 allgemeine_LED_12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31 100
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31 0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31 maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31 maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31 maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31 0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31 0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31 10
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31 0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31 Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31 Dimmung_Klemme_58_xs
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31 not_activ
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31 not_activ
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31 not_activ
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31 not_activ
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31 not_activ
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31 not_activ
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31 not_activ
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32 0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32 0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32 maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32 maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32 maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32 0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32 0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32 0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32 0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32 Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32 not_activ
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32 not_activ
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32 not_activ
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32 not_activ
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32 not_activ
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32 not_activ
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32 not_activ
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32 not_activ
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32 not_active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33 100
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33 0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33 maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33 maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33 maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33 0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33 0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33 2
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33 0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33 Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33 Footwell light
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33 not_activ
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33 not_activ
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33 not_activ
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33 not_activ
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33 not_activ
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33 not_activ
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33 not_activ
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34 60
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34 0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34 maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34 maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34 maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34 0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34 0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34 2
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34 0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34 Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34 Footwell light
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34 not_activ
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34 not_activ
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34 not_activ
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34 not_activ
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34 not_activ
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34 not_activ
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34 not_activ
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3 0
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3 0
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3 maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3 maximize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3 maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3 0
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3 0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3 0
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3 0
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3 Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3 not_activ
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3 not_activ
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3 not_activ
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3 not_activ
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3 not_activ
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3 not_activ
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3 not_activ
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3 not_activ
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3 not_active
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4 0
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4 0
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4 maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4 maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4 maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4 0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4 0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4 0
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4 0
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4 Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4 not_activ
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4 not_activ
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4 not_activ
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4 not_activ
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4 not_activ
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4 not_activ
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4 not_activ
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4 not_activ
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4 not_active
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5 0
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5 0
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5 maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5 maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5 maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5 0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5 0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5 0
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5 0
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5 Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5 not_activ
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5 not_activ
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5 not_activ
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5 not_activ
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5 not_activ
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5 not_activ
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5 not_activ
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5 not_activ
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5 not_active
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6 127
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6 127
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6 maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6 maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6 maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6 0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6 0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6 93
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6 82
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6 Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6 Versorgung_AFS_bei_LCM
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6 Parking light
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6 Parklichtlinks
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6 not_activ
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6 not_activ
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6 not_activ
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6 not_activ
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6 not_activ
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6 LED_Abblendlicht
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7 127
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7 127
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7 maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7 maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7 maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7 0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7 0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7 94
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7 83
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7 Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7 Versorgung_AFS_bei_LCM
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7 Parking light
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7 Parklichtrechts
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7 not_activ
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7 not_activ
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7 not_activ
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7 not_activ
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7 not_activ
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7 LED_Abblendlicht
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8 0
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8 0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8 maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8 maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7 maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8 0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8 0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8 0
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8 0
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8 Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8 not_activ
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8 not_activ
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8 not_activ
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8 not_activ
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8 not_activ
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8 not_activ
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8 not_activ
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8 not_activ
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8 not_active
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9 0
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9 0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9 maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9 maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9 maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9 0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9 0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9 0
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9 0
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9 Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9 not_activ
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9 not_activ
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9 not_activ
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9 not_activ
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9 not_activ
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9 not_activ
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9 not_activ
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9 not_activ
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9 not_active
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14 100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14 0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14 maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14 maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14 maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14 0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14 0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14 89
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14 0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14 Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14 Lock_Unlock_LED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14 not_activ
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14 not_activ
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14 not_activ
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14 not_activ
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14 not_activ
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14 not_activ
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14 not_activ
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14 LED_Kleinleistung_ohne_OL_mitUeberspg_absch
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck) 21 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 21 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 27 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 27 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 24 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 1C 00 33 1A 00 7F 00 00 00 00 00 00 00 00 00 20 0B 00 34 19 00 7F 00 00 00 00 00 00 00 00 00
ENG148594-Leuchtenkonfiguration (Sonstiges) 29 00 00 63 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 59 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 5A 40 00 7F 00 00 00 00 00 00 00 00 00 0F 39 00 17 02 00 64 00 00 00 00 00 00 00 00 00 0F 43 00 19 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 20 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 20 00 00 07 29 00 7E 00 00 00 00 00 00 00 00 00 24 00 00 0A 26 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 3C 00 00 00 00 00 00 00 00 00
ENG126648-MAS02526-LIN-Mirrormode-Activation not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active
ENG126648-ENG149044-LIN-Mirrormode-LIN4 not active
ENG126648-ENG149045-LIN-Mirrormode-LIN5 not active
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0 0.00%
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1 5.00%
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2 50.00%
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3 75.00%
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4 110.00%
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5 126.50%
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0 0.00%
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1 6.00%
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2 16.00%
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3 30.00%
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4 60.00%
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5 100.00%
ENG122979-MAS00075-Networking-Brake control module installed
ENG122979-MAS00798-Networking-Transmission Control Module (TCM) installed
ENG122979-MAS01374-Networking-Trailer not installed
ENG122979-MAS03175-Networking-Databus extended not installed
ENG122979-MAS09880-Networking-Interval potentiometer installed
ENG122979-MAS09882-Networking-MFA button on BCM installed
ENG122979-MAS10518-Networking-A/C electronics installed
ENG122979-MAS10570-Networking-Window lift type MQB_window_regulator
ENG122979-ENG149007-Networking-Door LIN installed
ENG122979-ENG252084-Networking-KL30_weckfaehig non_wakable
ENG122979-ENG149008-Networking-Roof LIN installed
ENG122979-ENG149009-Networking-Sounder LIN installed
ENG122979-ENG149010-Networking-Wiper LIN not installed
ENG124714-ENG142044-OCU-DWA_push active
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare active
ENG124714-OCU- installed
ENG124714-ENG142261-OCU-Remote HuF Abbruch 20 km/h
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz 3 Hz
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0 15 s
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1 80 s
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2 15 s
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3 2000 ms
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4 15 s
ENG124714-ENG125657-OCU-Remote_Unlock_Lock Via BAP / Fazit
ENG124714-ENG154722-OCU-RHF_Panikalarm active
ENG141646-MAS00481-Querschnitts_funktionen-BAP active
ENG141646-MAS01065-Querschnitts_funktionen-Brand VW
ENG141646-MAS04194-Querschnitts_funktionen-Driver side Right
ENG141646-MAS10509-Querschnitts_funktionen-Traffic Left
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer installed
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System not active
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent not active
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung active
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung not active
ENG141646-ENG154685-Querschnitts_funktionen-Hupe Sollspannungsanforderung 13.5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben not active
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv not active
ENG141646-ENG148952-Querschnitts_funktionen-P_locked installed
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3 not installed
ENG117297-Reversing_Threshold_Driver_Side_Front 90%
ENG117298-Reversing_Threshold_Passenger_Side_Front 90%
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold 100%
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold 100%
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold 100%
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter 3
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold 100%
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent 10%
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset 1300 ms
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout 1000 ms
ENG179054-ENG179168-RLFS_ZF_TRW-p_t_RsEmergencyReduceCycle 2.0 s
ENG179054-ENG179169-RLFS_ZF_TRW-p_t_RsEmergencyReduceDelay 4.0 s
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay 6 s
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window 15 s
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on 1100
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2 2
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement 30 s
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max 120 s
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on 1800 ms
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step 5 s
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed 5 km/h
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1 20 km/h
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2 4 km/h
ENG122927-RLS_close_glazing 2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s
ENG122929-RLS_LIN_Communication 4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx
ENG122930-RLS_tunel_gateway_recognize 5 s
ENG122935-RLS_Washer_Front 15 s
ENG122926-RLS_wiper_position_parking 15 s
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system not installed
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA active
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung 10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel active
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit 2000 ms
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit 800 ms
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit 10000 ms
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit 30 ms
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit 800 ms
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system installed
ENG148494-MAS10534-Search lights-Input medium: search illumination HMI
ENG148494-ENG142240-Search lights-Daempfung Abdimmen KL 58xd PWM 0.00 s
ENG148494-ENG154582-Search lights-Daempfung_Abdimmen_KL_58xs_PWM 0.00 s
ENG148494-ENG154583-Search lights-Daempfung_Abdimmen_KL_58xt_PWM 0.00 s
ENG148494-ENG154584-Search lights-Daempfung_Aufdimmen_KL_58xd_PWM 0.00 s
ENG148494-ENG154585-Search lights-Daempfung_Aufdimmen_KL_58xt_PWM 0.00 s
ENG148494-ENG179120-Search lights-Daempfung_Aufdimmen_KL58xs_PWM 0.00 s
ENG148494-ENG142242-Search lights-Helligkeit_RLS_Daempfung_Abdimmen 1.1 s
ENG148494-ENG142241-Search lights-Helligkeit_RLS_Daempfung_Aufdimmen 0.0 s
ENG148494-ENG149159-Search lights-KL58_Einschalten_mit_Rampe not active
ENG148494-ENG149160-Search lights-KL58_Verriegelungsausschalten not_active
ENG148494-ENG149161-Search lights-Lichtsensor_wirkt_auf_Suchbeleuchtung active
ENG148494-ENG149162-Search lights-Suchbeleuchtung_Festwert 100%
ENG148494-ENG142234-Search lights-Umgebungs_helligkeit_auswahl Fotosensor_Kombi
ENG148494-ENG130188-Search lights-Warnblinktastersuchbeleuchtung_Aktivierung always_active
ENG148494-ENG130190-Search lights-Warnblinktastersuchbeleuchtung_Faktor 0.1
ENG148494-ENG130189-Search lights-Warnblinktastersuchbeleuchtung_Grundwert 6.00%
ENG116588-MAS10520-Sonderfunktionen-Special function 1 not installed
ENG116588-ENG273845-Sonderfunktionen-Blinkerueberwachung_MFG not installed
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker SMLS
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2 not enabled
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen active
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus by_convenience_operation_via_remote_control_key
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung not active
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen active
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side not installed
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel active
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf not active
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt not active
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung not active
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig active
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress Standard
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0 0.0 lx
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1 8.0 lx
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2 50.0 lx
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3 80.0 lx
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4 100.0 lx
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0 6
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1 6
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2 20
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3 50
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4 100
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0 0.0 lx
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1 8.0 lx
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2 50.0 lx
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3 80.0 lx
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4 100.0 lx
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0 6
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1 6
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2 20
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3 50
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4 100
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 200 lx
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 400 lx
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 600 lx
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 84
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 166
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 250
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 370
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500
ENG141632-MAS10512-Sunroof-Sunroof module MD1 not installed
ENG141632-MAS10513-Sunroof-Sunroof module MD shade not installed
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen not active
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen not active
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen Open
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule LIN
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1 active
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS elektrisch
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS OBWr-Schloss
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs mit TKM
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1 active
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS elektrisch
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS OBWr-Schloss
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs mit TKM
ENG148611-MAS10548-Verbau Personalisierung-Profile function Key profile
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert active
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert active
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert active
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert active
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert active
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar active
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten 7
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung not active
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management installed
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys active
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv active
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante Konto (v. 2.x)
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0 active
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1 active
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2 not active
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3 not active
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4 not active
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5 not active
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6 not active
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7 not active
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1 00 00
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2 00 00
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3 00 00
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4 00 00
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1 00 00
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2 00 00
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3 00 00
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4 00 00
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5 00 00
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6 00 00
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1 00 16 90 19 22 00 00 00 FF FE FF 07 D0 10 10 F6 00 00 32 0B 0F 04 B0 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 05 B8 D8 00 05 86 10 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 EF 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2 A9 69
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1 03 E8 03 52 14 1E EC 01 0B 02 08 00 00 28 32 05 28 02 1E 19 0A 00 0A F4 4B 32 0C 00 05 FB 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 37 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 04 46 0B 10 0E 37 C8 F6 F1 F6 FB 13 12 00 08 14 00 FA 02 41 0A 10 0E 37 64 F6 F1 F6 FB 19 14 05 08 14 19 37 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2 0A CB
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1 33 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 00 05 05 17 70 00 10 00 2A 32 00 60 0A 03 00 19 1E 64 00 00 00 00 00 00 00 00
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2 70 3F
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1 00 12 90 19 02 00 00 00 FF FE FF 07 D0 10 10 F6 00 00 32 0B 0F 04 B0 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 05 B8 D8 00 05 86 10 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 8F 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2 F0 59
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1 03 E8 03 52 14 1E EC 01 0B 02 08 00 00 28 32 05 28 02 1E 19 0A 00 0A F4 4B 32 0C 00 05 FB 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 37 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 04 46 0B 10 0E 37 C8 F6 F1 F6 FB 13 12 00 08 14 00 FA 02 41 0A 10 0E 37 64 F6 F1 F6 FB 19 14 05 08 14 19 37 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2 0A CB
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1 33 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 0E 05 05 17 70 00 10 00 2A 32 00 60 0A 03 00 19 1E 64 00 00 00 00 00 00 00 00
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2 9A B7
ENG124895-Window_Regulator_VW_Settings_Driver_Side F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 19 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 96 96 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 2D 3C 50 00 64 1E 50 06 00 B4 01 00 0A 00 14 00 00
ENG130137-Window_Regulator_VW_Settings_Passenger_Side F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 19 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 32 32 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 2D 3C 50 00 64 1E 50 06 01 1E 01 00 0A 00 14 00 00
ENG148493-ENG115721-Windshield wiper-Frontwischer Sollspannungsanforderung 13.5
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition keine_Abtaupostition
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf active
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition active
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung active
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer active
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer 0 ms
ENG148493-ENG149042-Windshield wiper-rain_sensor_function installed
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren active
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status not active
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant not active
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ Direct
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube not active
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus active
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart nur_Erststart
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube active
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button Rocker sw.
ENG141651-MAS10546-ZV allgemein-Radio freq. 434.42MHz
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function not installed
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen not active
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring active
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm active
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf not active
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt No
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein not active
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut not active
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung active
ENG141651-ENG115755-ZV allgemein-Notschließfunktion active
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung all_doors_connected_directly
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung No
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung Globale_Entriegelung
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck active
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln active
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit not active
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR not active
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock adjustable
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren active
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen active
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash not active
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button via_pin
ENG141653-MAS10551-ZV Heck-Rear lid lock control Contact control
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type 1 or 2 notch rear actuator
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch Yes
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels active
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster not active
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV not active
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv not active
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen not active
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung mit_180_Ohm
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel not active
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel active
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen not active
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing active
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening active
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front active
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear No
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen not active
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf active
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen active
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen active
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit 600 s
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus active
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen active
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen active
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen active
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster not active
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global active
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer not active
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien not active
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung not active
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar adjustable
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen active
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen active
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock 2 Motor locks
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door not installed
ENG141652-MAS10567-ZV Türkonfiguration-Four-door No
ENG141652-ENG273805-ZV Türkonfiguration-schliesszylinderlogik_lbs not active
Hopefully somebody might be able to help!
Thanks,
