2001 Audi C5 A6 allroad, 6MT, APB
213,000 miles
Purchased 2009 at 90,000 miles in Orlando, drove home to New Mexico highlands (7400’—high and dry).
Most work done by indy Audi shop (Hans Wittler), but increasingly self-maintained.
July 2019, replaced notoriously self-destructing viscous fan (and pulley) with JHM, electrical fan kit, wiring issues prompted me to install in-dash manual switch.
Very few miles in 2020.
Recent issues:
Recently notified that MVD wants a vehicle inspection by January 15, 2021, even though registration is good until 2022. So my plan was to delete trouble codes, drive in to town for groceries, and see what emission codes are currently popping up, and how long they take to pop up after being cleared—22 December 2020.
Started with an auto-scan, which didn’t show any of the typical emissions codes, but some other issues, including the HVAC problem described above. Strange and unexpected since I’ve done no emissions related work on the car in many months.
Went to OBD and selected Clear DTCs. I don’t use VCDS often enough to have a smooth workflow engrained, but the result of deleting trouble codes didn’t seem right. So I began another scan. This is when the program and the car froze.
I can only assume that, in my haste, I interrupted a process I shouldn’t have.
Jumped in my wife’s Tacoma, and went shopping before the day was entirely lost.
Current Status:
I’m hoping that experienced eyes can discern possible next steps to be taken. I’m fond of this car... when it’s running. I’d like to restore that condition.
Thank you!
still crazy...
Attached below:
EARLIEST SCAN WHEN FIRST ACQUIRED VCDS
213,000 miles
Recent issues:
- Intermittent emissions failures for several years (eg. P0442 code EVAC small leak)—main reason I bought a cheap PC and VCDS.
- 6MT reverse freezing up, and 1st gear difficult once the car is warmed up, worse in cold weather (winter lows, 10-20˚F), began 10 months ago.
- Last trip to town (70 miles RT), driver’s side HVAC was intermittently blowing cold air on me a couple of times during ambient winter temperatures.
Current Status:
- VCDS alert reads, "Car is NOT ISO/OBC-II Compatible! If this car is a VW/Audi/Sat/Skoda Try SELECT -> Individual Controllers". The controllers are not available.
- Ignition, lights, most functions are unavailable; Seats are immobile;
- From my limited understanding of VCDS, the car is stuck in some stage of a scan;
- When I attach USB interface, key on, the interface blinks BLUE.
Thank you!
still crazy...
Attached below:
- Earliest scan recorded with VCDS (2 November, 2018);
- Most recent scan recorded before 22 December, 2020 (3 August 2019);
- Scan immediately prior to freezing, 22 December, 2020;
- Photo of dashboard lights in current condition.
Friday,02,November,2018,16:24:37:63562
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WAUYP64B11N074459 License Plate: KRY949
Mileage: 205734 Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551
Component: 2.7l V6/5VT G 0002
Coding: 06712
Shop #: WSC 02325
VCID: 55F782B71C1ED20F9D3-513C
WAUYP64B11N074459 AUZ7Z0Y1627312
8 Faults Found:
16826 - EVAP Emission Control Sys
P0442 - 35-10 - Small Leak - Intermittent
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-10 - Efficiency Below Threshold - Intermittent
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-10 - Efficiency Below Threshold - Intermittent
17863 - Exhaust Gas Temp Sensor 1 (G235)
P1455 - 35-10 - Implausible Signal - Intermittent
17930 - Camshaft Adjustment; Bank 2
P1522 - 35-10 - Malfunction - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-00 - Insufficient Flow
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-00 - Insufficient Flow
17977 - Cruise Control Switch (E45)
P1569 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D47
Coding: 06395
Shop #: WSC 02325
VCID: 094F9EC78026C6EFC9B-513C
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
VCID: 2D070A57540EBACF053-4AE0
Address 08: Auto HVAC Labels:
Part No: 4B0 820 043 L
VCID: 2313EC6F02CA7CBFA37-2586
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655 C
Component: Airbag Front+Kopf 1002
Coding: 00307
Shop #: WSC 02325
VCID: 4FFB70DF3EC2A8DF57F-513C
Address 16: Steering wheel Labels:
Part No: 4B0 907 487 D
VCID: 2D070A57540EBACF053-4FDA
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
Shop #: WSC 05141
VCID: 43D34CEFE28A5CBFC37-5118
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 03843
VCID: 48C95BC3DBAC7FE7165-50F4
01575 - Control Switched Off
35-00 - -
Address 35: Centr. Locks Labels:. 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15917
Shop #: WSC 05164
VCID: 30391323433CD7272E5-4EEA
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01561 - Rear left door
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
VCID: 2C0107536F14B3C712D-4AE0
Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl
Part No: 4B0 919 887 B
Component: Navigation BNO 0001
VCID: 323D192B4D30E537581-4AE0
00-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
VCID: 2615F57B71F88997C49-50AE
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D05
Coding: 00030
Shop #: WSC 02325
VCID: 04518FF3A7049B87BAD-4B5C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 02325
VCID: 1E65DD9B29A851578C9-4B3C
00856 - Radio Antenna
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D05
Coding: 00186
Shop #: WSC 02325
VCID: 025D89EBBD1095B7881-5118
End----------(Elapsed Time: 04:01, VBatt start/end: 12.1V/12.1V)-----------
MOST RECENT SCAN BEFORE 22 December
Saturday,03,August,2019,12:33:54:63562
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
Mileage: 212529 Repair Order:
75 76 77
Coding: 06712
Shop #: WSC 02325
VCID: 55F782B71C1ED20FC9F-513C
17870 - Exhaust Gas Temp Regulation for Bank 2
P1462 - 35-10 - Implausible Signal - Intermittent
Coding: 06395
Shop #: WSC 02325
VCID: 094F9EC78026C6EF9D7-513C
Coding: 00003
VCID: 2D070A57540EBACF51F-4AE0
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
VCID: 2313EC6F02CA7CBFF7B-2586
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
Coding: 00307
Shop #: WSC 02325
VCID: 4FFB70DF3EC2A8DF033-513C
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Component: Lenkradelektronik D02
Coding: 00102
Shop #: WSC 12345
VCID: 2D070A57540EBACF51F-4FDA
Coding: 02264
Shop #: WSC 05141
VCID: 43D34CEFE28A5CBF97B-5118
Coding: 25500
Shop #: WSC 03843
VCID: 48C95BC3DBAC7FE7429-50F4
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Coding: 15917
Shop #: WSC 05164
VCID: 30391323433CD7277A9-4EC8
Coding: 00001
VCID: 2C0107536F14B3C7461-4AE0
VCID: 323D192B4D30E5370CD-4AC2
00-00 - -
Coding: 00102
Shop #: WSC 02325
VCID: 2615F57B71F88997905-50AE
Coding: 00030
Shop #: WSC 02325
VCID: 04518FF3A7049B87EE1-4B5C
Coding: 00115
Shop #: WSC 02325
VCID: 1E65DD9B29A85157D85-4B7A
00-00 - -
Coding: 00186
Shop #: WSC 02325
VCID: 025D89EBBD1095B7DCD-5118
End----(Elapsed Time: 04:05, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
SCAN IMMEDIATELY PRIOR TO FREEZING
Tuesday,22,December,2020,18:34:47:63562
VCDS Version: 20.12.0.1 HEX-V2 CB: 0.4529.4
75 76 77
Coding: 06395
Shop #: WSC 02325
VCID: 094F9EC78026C6E324C-513C
Coding: 00003
VCID: 2D070A57540EBAC3E84-4AE0
Coding: 00160
Shop #: WSC 02325
VCID: 2313EC6F02CA7CB34E0-2586
Coding: 00307
Shop #: WSC 02325
VCID: 4FFB70DF3EC2A8D3BA8-513C
Coding: 00102
Shop #: WSC 12345
VCID: 2D070A57540EBAC3E84-4FDA
Coding: 02264
Shop #: WSC 05141
VCID: 43D34CEFE28A5CB32E0-5118
Coding: 25500
Shop #: WSC 03843
VCID: 48C95BC3DBAC7FEBFB2-50F4
Coding: 15917
Shop #: WSC 05164
VCID: 30391323433CD72BC32-4EEA
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Coding: 00001
VCID: 2C0107536F14B3CBFFA-4AE0
VCID: 323D192B4D30E53BB56-4AC2
00-00 - -
Coding: 00102
Shop #: WSC 02325
VCID: 2615F57B71F8899B29E-50AE
Coding: 00030
Shop #: WSC 02325
VCID: 04518FF3A7049B8B57A-4B5C
Coding: 00115
Shop #: WSC 02325
VCID: 1E65DD9B29A8515B61E-4B5C
00-00 - -
Coding: 00186
Shop #: WSC 02325
VCID: 025D89EBBD1095BB656-5118
End----(Elapsed Time: 04:21, VBatt start/end: 11.6V/10.8V. VIgn 10.7V)-----
