Hi
I have a question ... everything is installed and working, but I have one fault. do I need a camera module because I heard that I don't need it CAN communication
Sunday,06,December,2020,22:34:21:18224
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WAUZZZ4G5FN062480 License Plate:
Mileage: 200138km-124359mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F 62
6C 6D 72 AC
VIN: WAUZZZ4G5FN062480 Mileage: 200138km-124359miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FR HW: 04L 907 309
Component: R4 2,0L EDC H23 0745
Revision: 85H23---
Coding: 12194012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FR 002003
ROD: EV_ECM20TDI01104L906021FR_002.rod
VCID: 7AADF6B21C5B2ADB3D7-802E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 06A09E41600579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDB47A647F9CFF34A9-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 03B9704E000000000000
VCID: 7AADF6B21CDB2ADB3D7-802E
Serial number: 3215000002866005
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Serial number: 28011500042277
Coding: 34220978290000
VCID: 629DAED294CBC21B057-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000988120602
Coding: 0105001440349F604401408000001800CF9D87082F08020100000894E100140200400024030000
VCID: 71BFD19E41AD69838CD-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 141212 H37 0080
Serial number: 141215124157
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23684529
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 27 01 2015 00000066
Serial number: AA280D87000000000001
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P10031ZYG
Coding: 30333130313630323639554A305234473053
VCID: 3B2333B653E1D3D3661-806E
Serial number: 3575HRB40552RDNQ81O+
Serial number: 3585HRB400I50SE478G8
Serial number: 3515JRB405J350J870Q
Serial number: 3525JRB404V34BHEFHBV
Serial number: 3554VRB406734GNGNP31
Serial number: 3564VRB404P3504GJP1L
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OAE000RZ
Coding: 000015
VCID: 3B2333B65361D3D3661-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 16 12 2014 E0057271
Part No SW: 4G8 920 987 R HW: 4G8 920 987 R
Component: TDieGb H14 0225
Revision: 11001108 Serial number: 658140616596056
Coding: 33AD12000B412600010000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 48C95C7A1237884BFB3-801C
Part No SW: 4G0 907 468 AE HW: 4G0 907 468 AC
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001715362
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 73B3DB963B315B937E1-8026
Serial number: 1841145603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 1410220000000000063D
5807 - Rear View Camera System Control Module
U104C 00 [008] - No communication
Reset counter: 170
Mileage: 200138 km
Date: 2020.12.06
Time: 22:31:15
Voltage terminal 30: 11.9 V
Voltage terminal 15: 0.0 V
Control Module temperature: 18 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 130
Mileage: 200138 km
Date: 2020.12.06
Time: 22:31:52
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CA1F0AA16EF14EB2FB-8028
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 02021500040553
Coding: 22
VCID: 3D273DAE4DF5DDE3585-8068
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720FE9FD
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33331B967BB11B93BE1-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16015C01620002080002
VCID: 47CB5F461FA98733F29-8012
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0014616893
Coding: 101000010001
Shop #: WSC 60091 001 1048576
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 392F29BE59DDE1C374D-806C
Revision: 00002001 Serial number: 0359573835
Coding: 013B0622A0B930D4C320090400010F470000000000000000000000000000
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H03 0004
Serial number: 0000FST00041HK600000
Coding: 901E00
Subsystem 4 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H03 0004
Serial number: 0000FST00043CWF00000
Coding: 801E00
Component: TSG BF H03 0507
Coding: 011F16015E01620002080002
VCID: 46D5524218A39E3B09F-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001343815
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070DEE9D954D63E85-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FE02102A600200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Left LED Headlamp Power Output Stage 1:
Coding: E01E00
Right LED Headlamp Power Output Stage 1:
Coding: E01E00
Part No SW: 4G1 035 021 P HW: 4G1 035 021 D
Component: MU-H-LND-EU 052 1425
Serial number: A733I0G7510545
Coding: 017502010000000013111101000A00122F0006E7F1700100DF
VCID: 270BFFC6BF696733129-8072
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY8061YE
Multimedia system control head:
Subsystem 3 - Part No SW: 4G2 919 710 F HW: 4G2 919 710 F
Component: E380 BDT C7 H20 0250
Serial number: 90349NJF000K3
Compact disc data bank:
Component: Gracenote2 --- 1013
6678 - Digital sound System control module
U106A 00 [009] - No Communication
[Control module for sound system: no communication]
Reset counter: 130
Mileage: 200138 km
Date: 2020.12.06
Time: 22:26:35
Voltage terminal 30: 12.1 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
Coding: 010F14004001620002080002
VCID: 49CF597E09BD7143E4D-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002007000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78A9ECBA225738CB4B3-802C
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 016500820
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 3635228268C30EBB99F-8062
Component: TSG HR H03 0507
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143630398
ROD: EV_RDCMA00100.rod
End----(Elapsed Time: 01:54, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
