Hello ,
So I am adding to yet another mess-up of byte 18 , VW jetta mk6 2015 highline cecm , byte 18 was set to 00 on vcds , tried changing the sam to 8C to get rid of bulb out error on led tail lights , DRL's stopped working along with front left , riht error popping up when ignition is ON , Ross tech gave options of 3C , 3D , 3E and 3F to try , I tried changing the same , however none created any change from the current mode which make me suspect if any change is getting pushed to CECM , posting auto scan as below , Experts please help !
Monday,16,November,2020,14:47:53:64981
VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4
VIN: WVWF15168FA5XXXXX License Plate: XXXXXX
Mileage: 54200km-33678mi Repair Order:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
77
VIN: WVWF15168FA5XXXXX Mileage: 54200km-33678miles
Address 01: Engine (J623-CLCB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 TC HW: 03L 907 309 R
Component: R4 2.0l TDI X25 9978
Revision: 42X25--- Serial number: 00000000000000
Coding: 001D0012042500080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906018TC 003005
ROD: EV_ECM20TDI01103L906018TC.rod
VCID: 7EA5FF391078A8AB20F-802A
4481 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Fault Frequency: 8
Mileage: 54064 km
Engine speed: 0.00 /min
Coolant temperature: 54 °C
Intake air temperature: 40 °C
Voltage terminal 30: 12.480 V
Cruise Control System (CCS): switch position-Bits 0-7: 130
Cruise Control System (CCS): status-Bits 0-7: 12
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
Mileage: 54064 km
Cruise Control System (CCS): switch position-Bits 0-7: 194
Cruise Control System (CCS): status-Bits 0-7: 204
Component: GSG DSG AG6 531 4014
Revision: 05653104 Serial number: 00001503230951
Coding: 0000024
Shop #: WSC 02069 000 90108
VCID: 1471BD91027452FBE6B-8040
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A63B40F8092700FB650D02EA90210082A1100010
Shop #: WSC 00047 000 00000
VCID: 04518DD17E14C27B76B-8050
Part No SW: 1K8 907 044 AJ HW: 1K8 907 044 AJ
Component: Climatronic H05 0202
Revision: 00001K02
Coding: 001001A002
Shop #: WSC 00047 000 00056
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 77ABEA1D3F4299E3639-8022
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 26000A3AF82F00D440480080240089EC0574000873A08120E4CC00000040
Shop #: WSC 00066 123 12345
VCID: 76B5E71938C8E0EB78F-8022
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 311014 05 54 0403
Coding: 02300A
8 Faults Found:
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 11
Reset counter: 160
Mileage: 53952 km
Date: 2020.11.14
Time: 21:46:05
Voltage: 12.25 V
00985 - Right Tail Light (M2)
Fault Frequency: 11
Reset counter: 160
Mileage: 53952 km
Date: 2020.11.14
Time: 21:46:03
Voltage: 12.25 V
Fault Status: 00101010
Reset counter: 200
Mileage: 54200 km
Date: 2020.11.16
Time: 10:49:10
Voltage: 11.85 V
01506 - Bulb for Rear Fog; Right (L47)
Reset counter: 160
Mileage: 54203 km
Date: 2020.11.16
Time: 14:40:05
Voltage: 12.35 V
Reset counter: 160
Mileage: 54203 km
Date: 2020.11.16
Time: 14:40:58
Voltage: 12.35 V
Reset counter: 160
Mileage: 54203 km
Date: 2020.11.16
Time: 14:40:58
Voltage: 12.35 V
Reset counter: 160
Mileage: 54203 km
Date: 2020.11.16
Time: 14:40:10
Voltage: 12.35 V
Reset counter: 160
Mileage: 54203 km
Date: 2020.11.16
Time: 14:40:10
Voltage: 12.35 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 A HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0477
Revision: -------- Serial number: 39391506500490
Coding: 0001090011
Shop #: WSC 00047 000 00051
ASAM Dataset: EV_EPHVA18VW364GP00 001006
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 3537201565CEABF3B15-8060
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 014 0613
Serial number: 003JQM064DX/
Coding: 00005047
ROD: EV_AirbaVW10SMEVW360.rod
Serial number: 3572MSME73770C4FZZZ5
Serial number: 3582MSME27770C4FZZZ5
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME17525035ZZZH
Serial number: 3526KSME7B395635ZZZ$
Part No SW: 1K5 953 521 BL HW: 5K0 953 569 AD
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150311100173
Coding: 0892440008
ROD: EV_SMLSNGVOLWS.rod
VCID: 78A9E921325C969B6A3-802C
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 3311422565702344AC1B
Coding: 290000
Part No SW: 5C6 920 874 A HW: 5C6 920 874 A
Component: KOMBI H05 0906
Coding: 171F00
VCID: 2D0708758D9EE333C95-8078
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 250514F1000346
Coding: 351003
VCID: 7EA5FF3910F8A8AB20F-802A
Component: IMMO H05 0906
VCID: 6A8DC3697CF0340BEC7-803E
Address 2E: Media Player 3
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0515
Revision: 12110009 Serial number: 0009312858
Coding: 3416F7
Shop #: WSC 00047 123 00051
VCID: 1C61D5B1E6241ABBAEB-8048
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586150211095945
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
VCID: 392F2C2545564F9355D-806C
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0515
Revision: 14110009 Serial number: 0009316476
Coding: 0417F6
VCID: 1D67D8B5FD3E13B3595-8048
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587150216065906
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 081600000B000200
Shop #: WSC 01383 790 50316
VCID: 372B2A1D7FC259E3A39-8062
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0318
Revision: -----001 Serial number: VWZ6Z2R7429649
Coding: 16000441000006
Shop #: WSC 00081 790 00118
VCID: 46D557D908A8306B28F-8012
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Reset counter: 146
Mileage: 53340 km
Date: 2020.10.28
Time: 09:41:22
Fault Frequency: 13
Reset counter: 197
Mileage: 53340 km
Date: 2020.10.28
Time: 09:41:16
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 D HW: 5N0 035 729 D
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007670215596
Coding: 0A01000080010101
ROD: EV_UHVUMI.rod
VCID: 313F140591A687D3EDD-8064
B104F 13 [024] - Short to GND
Reset counter: 146
Mileage: 53340 km
Date: 2020.10.28
Time: 09:38:56
B104E 13 [024] - Short to GND
Reset counter: 146
Mileage: 53340 km
Date: 2020.10.28
Time: 09:38:56
End----(Elapsed Time: 01:04, VBatt start/end: 12.3V/11.8V. VIgn 11.8V)-----
