hi
i have a 2006 touareg 3.6 V6 and the fuelpump relay make problems. i change the relay already but have still the same problem. follow problem show up. if i make the ignition on relay dont klick and on the pump is no 12V. if i open the relay and make it manually i have 12V on the pump and pump runs. if i hook up the new relay i have the same. so i think it is the trigger wire from the ignition lock. now the question which pin is the trigger line
the relay had the number 404 and had 5 pins
no1 and No 2 goes on the resistor in the relay (Pin 1 color code green/blue thin cable Pin 2 color code red thin cable)
no 3 is 12V power (color code red thick cable)
no 4 is not connected
no 5 is 12V to pump (color code red/black thick cable)
on pin 1 and 3 i have 12V on pin 3 is no power self if i press the relay manually.on pin 5 i have 12V if i press the relay manually.
