Hi, need some help with redoce this module, someone has played with coding of the car, nothing on hardware is changed, but ABS module says incorrect coding, tried some coding- only 1 code is accepted till now , but the error is the same.
Car is 2012 VW PAssat B7 diesel, I attach full scan and the PR code sticker picture, please if someone can help with recding.Regards.
Wednesday,21,October,2020,11:00:28:40809
VCDS Version: 20.4.2.0
VIN: WVWZZZ3CZDE056537 License Plate:
Mileage: 251650km-156368mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62
65 72
VIN: WVWZZZ3CZDE056537 Mileage: 251650km-156368miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PA HW: 03L 907 309 AE
Component: R4 2.0l TDI H27 9978
Revision: 41H27--- Serial number: 00000000000000
Coding: 001D0012042401080000
Shop #: WSC 00066 210 12345
ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
ROD: EV_ECM20TDI01103L906018E_VW36.rod
VCID: 78F4F58EC34C22462B-802C
4515 - Radiator Fan (V7)
P1950 00 [032] - Movement Restricted / Jammed
Mileage: 251380 km
Date: 2020.10.17
Time: 18:20:08
Coolant temperature: 73 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.440 V
Unlearning counter according OBD: 38
Air mass: specified value: 737.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 55.3 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside air temperature: 17.5 °C
Coolant fan 2: activation: 0.00 %
Coolant fan 1: activation: 60.00 %
Fuel temperature: 41.8 °C
4519 - Radiator Fan 2 (V177)
P1951 00 [032] - Movement Restricted / Jammed
Fault Frequency: 9
Mileage: 251377 km
Date: 2020.10.17
Time: 18:17:18
Engine speed: 1862.50 /min
Normed load value: 49.4 %
Vehicle speed: 94 km/h
Coolant temperature: 67 °C
Intake air temperature: 26 °C
Voltage terminal 30: 13.320 V
Air mass: specified value: 473.7 mg/stroke
Coolant temperature at radiator outlet: actual value: 64.4 °C
Outside air temperature: 19.0 °C
Coolant fan 1: activation: 37.44 %
Fuel temperature: 37.0 °C
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [109] - Electrical Fault
Mileage: 251397 km
Date: 2020.10.18
Time: 09:32:53
Engine speed: 119.50 /min
Coolant temperature: 15 °C
Intake air temperature: 13 °C
Voltage terminal 30: 10.220 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
Electric auxiliary heater: relay activation-Bits 0-7: 0
Preheat time: 800 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 112
Glow cycles above temperature threshold-Bits 0-7: 5
Glow cycles above temperature threshold-Bits 0-7: 76
Glow cycles below temperature threshold-Bits 0-7: 2
Glow cycles below temperature threshold-Bits 0-7: 110
Outside air temperature: 12.5 °C
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3521
Revision: 05551213 Serial number: 00001207302127
Shop #: WSC 05311 000 00000
VCID: 244CF1FEE74496A657-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AF HW: 3AA 614 109 AF
Component: J104 C2 450M V439 0024
Revision: --H07--- Serial number: 00000006189853
Coding: 0002480
Shop #: WSC 00046 000 00000
VCID: 71E2C8AA6836730EEC-8024
Reset counter: 57
Mileage: 251657 km
Date: 2015.03.14
Time: 10:55:18
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
Reset counter: 57
Mileage: 251657 km
Date: 2015.03.14
Time: 10:55:18
Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
Shop #: WSC 00015 115 00000
VCID: 74ECC1BEDF24462607-8020
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Reset counter: 96
Mileage: 251428 km
Date: 2020.10.18
Time: 10:04:10
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 95
Mileage: 251377 km
Date: 2020.10.17
Time: 18:17:23
B10A4 15 [009] - Open or Short to Plus
Fault Frequency: 44
Reset counter: 57
Mileage: 251246 km
Date: 2020.10.15
Time: 11:13:13
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 G HW: 3AA 937 087 G
Component: BCM PQ47 H 421 0465
Revision: BB421001
Coding: 0008000000000000009800801400816403510088426D81606480C7200041
VCID: 3E782396A9E8DC7621-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 25111 10 0603
Coding: 00B795
Component: RLS 170912 05 54 0403
Coding: 0230ED
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__108 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PK3BT2Z
Coding: 0012344
VCID: 7CFCE99E3F740E664F-8028
Subsystem 1 - Serial number: 6332MTS613752521
Subsystem 2 - Serial number: 6342MTS651512531
Subsystem 3 - Serial number: 6351HTS6HAV4BBKR
Subsystem 4 - Serial number: 6361HTS63BJLDBKJ
008 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 251254 km
Date: 2015.03.08
Time: 18:15:30
007 - Short to Ground - MIL ON
Fault Status: 11100111
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:15
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Revision: FF010040 Serial number: 20110904101597
Coding: 1192250100
Shop #: WSC 00046 123 12345
VCID: 72E0C7A6A530481615-8026
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Coding: 820000
Part No SW: 3AA 920 870 D HW: 3AA 920 870 D
Component: KOMBI H03 0607
Coding: 161F00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 336E02A29AAA011EDE-8066
Part No SW: 7N0 907 530 AE HW: 7N0 907 530 AE
Component: J533 Gateway H46 1633
Revision: H46 Serial number: 010912F1003683
Coding: 462006
Shop #: WSC 05314 123 12345
VCID: 73EEC2A2D22A411E1E-8026
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
VCID: 76E8FBB60158543639-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663431889
Coding: 020100
Shop #: WSC 05314 000 00000
VCID: 2A501FC6456040D66D-807E
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0003657468
Coding: 0210B7
Shop #: WSC 00028 028 00022
VCID: 356A3CBA94DE1F2EF0-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0503
Serial number: 00000003119396
Coding: 010290
66561 - Motor for mirror fold-in
B11F6 01 [009] - Electrical Failure
Reset counter: 54
Mileage: 251287 km
Date: 2020.10.16
Time: 12:33:05
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.309 1002
Revision: 1AH03734 Serial number: 00112590205901
Coding: 0000258
Shop #: WSC 00028 028 00001
VCID: 3C7C299E7FF4CE660F-8068
Component: KSG PQ47 ELV 045 0634
Coding: 0191020052830E76340494157C085FCE105801
Shop #: WSC 05311 123 12345
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
Reset counter: 52
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:14
Reset counter: 52
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:14
01134 - Alarm Horn (H12)
Reset counter: 52
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:14
Part No SW: 7N0 907 532 HW: 7N0 907 530 AE
Component: EZE_2 H46 1633
Coding: 00000008
VCID: 6FE6CED2BE0265FEFA-803A
Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0529
Revision: 14110009 Serial number: 0001931724
Coding: 0200B6
Shop #: WSC 05311 115 12345
VCID: 36683BB689D81436F9-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000001860781
Coding: 000290
Revision: H19 Serial number: 00000000443441
Coding: 0022167
VCID: 36683BB641D81436F9-8062
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0013
Revision: -----12S Serial number: VWZ4Z7K1169001
Coding: 0100040004
VCID: 62C0B7E67DD0D89665-8036
02633 - Antenna for Satellite Tuner
Fault Status: 01101011
Reset counter: 52
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:14
Reset counter: 52
Mileage: 251246 km
Date: 2015.03.08
Time: 11:13:14
Reset counter: 53
Mileage: 251265 km
Date: 2015.03.09
Time: 08:09:60
00875 - Treble Speaker Front Right (R22)
Reset counter: 57
Mileage: 251657 km
Date: 2015.03.14
Time: 10:59:34
Part No SW: 7N0 907 534 HW: 7N0 907 530 AE
Component: Batt.regelung H46 1633
Coding: 030F1859
VCID: 71E2C8AAA836730EEC-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900156894
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000154042
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
8402177 - System Switched Off
C106D 00 [009] - -
Reset counter: 45
Mileage: 250801 km
Date: 2020.09.15
Time: 19:39:27
End-------------------------(Elapsed Time: 03:17)--------------------------
