VW Passat B7 2012 ABS code not correct Help needed
Ekremsky
Bulgaria
C?ID=110228
Hi, need some help with redoce this module, someone has played with coding of the car, nothing on hardware is changed, but ABS module says incorrect coding, tried some coding- only 1 code is accepted till now , but the error is the same.
Car is 2012 VW PAssat B7 diesel, I attach full scan and the PR code sticker picture, please if someone can help with recding.Regards.
Wednesday,21,October,2020,11:00:28:40809
VCDS Version: 20.4.2.0
VIN: WVWZZZ3CZDE056537   License Plate:
Mileage: 251650km-156368mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62
          65 72
VIN: WVWZZZ3CZDE056537   Mileage: 251650km-156368miles
   Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H27 9978
   Revision: 41H27---    Serial number: 00000000000000
   Coding: 001D0012042401080000
   Shop #: WSC 00066 210 12345
   ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
   ROD: EV_ECM20TDI01103L906018E_VW36.rod
   VCID: 78F4F58EC34C22462B-802C
4515 - Radiator Fan (V7)
          P1950 00 [032] - Movement Restricted / Jammed
                    Mileage: 251380 km
                    Date: 2020.10.17
                    Time: 18:20:08
                    Engine speed: 0.00 /min
                    Coolant temperature: 73 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.440 V
                    Air mass: specified value: 737.0 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 55.3 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 17.5 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 60.00 %
                    Fuel temperature: 41.8 °C
4519 - Radiator Fan 2 (V177)
          P1951 00 [032] - Movement Restricted / Jammed
                    Fault Frequency: 9
                    Mileage: 251377 km
                    Date: 2020.10.17
                    Time: 18:17:18
                    Engine speed: 1862.50 /min
                    Normed load value: 49.4 %
                    Vehicle speed: 94 km/h
                    Coolant temperature: 67 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.320 V
                    Air mass: specified value: 473.7 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 64.4 °C
                    Outside air temperature: 19.0 °C
                    Coolant fan 1: activation: 37.44 %
                    Fuel temperature: 37.0 °C
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [109] - Electrical Fault
                    Mileage: 251397 km
                    Date: 2020.10.18
                    Time: 09:32:53
                    Engine speed: 119.50 /min
                    Coolant temperature: 15 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 10.220 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 800 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 112
                    Glow cycles above temperature threshold-Bits 0-7: 5
                    Glow cycles above temperature threshold-Bits 0-7: 76
                    Glow cycles below temperature threshold-Bits 0-7: 2
                    Glow cycles below temperature threshold-Bits 0-7: 110
                    Outside air temperature: 12.5 °C
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3521
   Revision: 05551213    Serial number: 00001207302127
   Shop #: WSC 05311 000 00000
   VCID: 244CF1FEE74496A657-8070
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V439 0024
   Revision: --H07---    Serial number: 00000006189853
   Coding: 0002480
   Shop #: WSC 00046 000 00000
   VCID: 71E2C8AA6836730EEC-8024
                    Reset counter: 57
                    Mileage: 251657 km
                    Date: 2015.03.14
                    Time: 10:55:18
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 57
                    Mileage: 251657 km
                    Date: 2015.03.14
                    Time: 10:55:18
   Part No SW: 3AA 907 044 AF    HW: 3AA 907 044 AF
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004803
   Shop #: WSC 00015 115 00000
   VCID: 74ECC1BEDF24462607-8020
9474161 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 96
                    Mileage: 251428 km
                    Date: 2020.10.18
                    Time: 10:04:10
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 95
                    Mileage: 251377 km
                    Date: 2020.10.17
                    Time: 18:17:23
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Fault Frequency: 44
                    Reset counter: 57
                    Mileage: 251246 km
                    Date: 2020.10.15
                    Time: 11:13:13
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
   Component: BCM PQ47 H    421 0465
   Revision: BB421001
   Coding: 0008000000000000009800801400816403510088426D81606480C7200041
   VCID: 3E782396A9E8DC7621-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 25111  10  0603
   Coding: 00B795
   Component: RLS 170912 05  54  0403
   Coding: 0230ED
   Component: J234__108 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PK3BT2Z
   Coding: 0012344
   VCID: 7CFCE99E3F740E664F-8028
   Subsystem 1 - Serial number: 6332MTS613752521
   Subsystem 2 - Serial number: 6342MTS651512531
   Subsystem 3 - Serial number: 6351HTS6HAV4BBKR
   Subsystem 4 - Serial number: 6361HTS63BJLDBKJ
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 251254 km
                    Date: 2015.03.08
                    Time: 18:15:30
00589 - Airbag Igniter 1; Passenger Side (N131)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:15
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110904101597
   Coding: 1192250100
   Shop #: WSC 00046 123 12345
   VCID: 72E0C7A6A530481615-8026
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Coding: 161F00
   VCID: 336E02A29AAA011EDE-8066
   Part No SW: 7N0 907 530 AE    HW: 7N0 907 530 AE
   Component: J533  Gateway H46 1633
   Revision:   H46       Serial number: 010912F1003683
   Coding: 462006
   Shop #: WSC 05314 123 12345
   VCID: 73EEC2A2D22A411E1E-8026
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         045 0400
   Revision: 00045000    Serial number: VWZCZ000000000
   VCID: 76E8FBB60158543639-8022
   Revision: A1001003    Serial number: 7663431889
   Coding: 020100
   Shop #: WSC 05314 000 00000
   VCID: 2A501FC6456040D66D-807E
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003657468
   Coding: 0210B7
   Shop #: WSC 00028 028 00022
   VCID: 356A3CBA94DE1F2EF0-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003119396
   Coding: 010290
66561 - Motor for mirror fold-in
          B11F6 01 [009] - Electrical Failure
                    Reset counter: 54
                    Mileage: 251287 km
                    Date: 2020.10.16
                    Time: 12:33:05
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 1002
   Revision: 1AH03734    Serial number: 00112590205901
   Coding: 0000258
   Shop #: WSC 00028 028 00001
   VCID: 3C7C299E7FF4CE660F-8068
   Component:    KSG PQ47 ELV 045 0634
   Coding: 0191020052830E76340494157C085FCE105801
   Shop #: WSC 05311 123 12345
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 52
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:14
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 52
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:14
                    Reset counter: 52
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:14
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AE
   Component: EZE_2         H46 1633
   Coding: 00000008
   VCID: 6FE6CED2BE0265FEFA-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0001931724
   Coding: 0200B6
   Shop #: WSC 05311 115 12345
   VCID: 36683BB689D81436F9-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001860781
   Coding: 000290
   Revision:   H19       Serial number: 00000000443441
   Coding: 0022167
   VCID: 36683BB641D81436F9-8062
   Part No SW: 1K0 035 180 AD    HW: 1K0 035 180 AD
   Component: Radio Prem-8  H04 0013
   Revision: -----12S    Serial number: VWZ4Z7K1169001
   Coding: 0100040004
   VCID: 62C0B7E67DD0D89665-8036
02633 - Antenna for Satellite Tuner
                    Reset counter: 52
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:14
                    Reset counter: 52
                    Mileage: 251246 km
                    Date: 2015.03.08
                    Time: 11:13:14
                    Reset counter: 53
                    Mileage: 251265 km
                    Date: 2015.03.09
                    Time: 08:09:60
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 57
                    Mileage: 251657 km
                    Date: 2015.03.14
                    Time: 10:59:34
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AE
   Component: Batt.regelung H46 1633
   Coding: 030F1859
   VCID: 71E2C8AAA836730EEC-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900156894
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000154042
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
8402177 - System Switched Off
          C106D 00 [009] - -
                    Reset counter: 45
                    Mileage: 250801 km
                    Date: 2020.09.15
                    Time: 19:39:27
End-------------------------(Elapsed Time: 03:17)--------------------------
adfow_uk
C?ID=136053
Not sure if effecting the coding but notice the dates faukts logged in ABS shows 2015, ECM faults are 2020. Might help might not
Ekremsky
Bulgaria
C?ID=110228
Yes, I saw that, but no matter I delete the errors, the same is coming back, cannot find coding, tried many codes from the net,but error stays , the old Passat is very easy is PR codes, in VCDS is also help, but here only TPMS on off function...
NEtech
Denmark
C?ID=56995
Is the steering wheel in the right (wrong) side of the car?
PR-Code show L0R
Ekremsky
Bulgaria
C?ID=110228
Hi, yes there is a PR code on the back near the spare tyre compartment, car is converted from RHD to LHD , but customer says there was no error in the ABS after converting, in another service they messed up coding.
Here is the PR code attached.
Regards
free image hosting
Ekremsky
Bulgaria
C?ID=110228
problem solved
Ekremsky
Bulgaria
C?ID=110228
Hi , I did the coding with Odis online via SVM coding, new coding was 7091. I hope it will help others.
BR
