HELLO EVERYONE
IVE BEEN USING VCDS A WHILE NOW BUT HAVE NEVER NEEDED TO ASK ANYTHING AS I HAVE FOUND ALL THE ANSWERS ON THE FORUM UP UNTIL NOW.
HERE IS MY STORY
A FRIEND OF A FRIEND ASKED ME IF I COULD FIX HIS AUDI A8 2004 4.0 TDI WHICH HAD ORIGINALLY JUST STOPPED WORKING (NO IGNITION NO NOTHING REALLY)
HE HAD IT TOWED TO A GARAGE HE NEW WHO HAD THE CAR FOR AROUND 8 MONTHS AND COULD NOT FIND THE FAULT SO STILL NOT WORKING.
HE THEN ASKED ME TO LOOK AT IT WHICH I RELUCTANTLY SAID YES AS I DONT LIKE MESSING WITH A CAR THAT SOMEBODY HAS ALREADY MESSED WITH AND I WISH I HAD STUCK TO THAT.
ANYWAY THE CAR CAME TO ME ON A TOW TRUCK AND WHEN I LOOKED INSIDE THE CAR IT LOOKED LIKE A BOMB HAD GONE OFF THE GARAGE HAD BASICALLY RIPPED HALF THE CAR OUT THERE WAS THINGS MISSING FUSES TAKEN OUT MODALS OPENED AND JUST LEFT IN THE BACK ,IT WAS JUST A MESS.
I GOT IT ALL BACK TOGETHER AND FOUND THE KESSEY WAS AT FAULT .
I EVENTUALLY FOUND A COMPLETE SET (KESSEY STEERING COLUMN CLOCKS AND KEY)AND HEY PRESTO IT FIRED UP.
MY PROBLEM NOW IS ALTHOUGH IT STARTS HARDLY ANYTHING ELSE WORKS AND THE CLOCKS SAY SAFE IN THEM.
MY QUESTION IS HOW DO I CODE OR PAIR THE NEW THINGS IVE PUT IN TO THE ECU'S AS IM HOPING THIS IS MY MAIN PROBLEM.
IVE GOT A AUTOSCAN BUT THE LIST OF PROBLEMS IS RIDICULOUS
HOPEFULLY SOMEBODY CAN HELP ME WITH THIS NIGHTMARE AS IM ON MY LAST NERVE LOL
THANKS TO ANYONE TAKING THE TIME TO READ AND HOPEFULLY HELP ME
HERE IS MY STORY
Tuesday,11,August,2020,11:44:30:45660
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ4E94N004240 License Plate: KENNY
Mileage: 232860km-144692mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1D 1E 25 34 36
37 38 42 46 47 4F 52 53 56 57 61 62 72 76 77
VIN: WAUZZZ4E94N004240 Mileage: 232860km-144692miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 1010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
16-Steering wheel -- Status: Cannot be reached 1100
1D-Driver Ident. -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI G000AGMª0020
Revision: <> Serial number: XXXXXXXXXXXXXX
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 2340681CE267A49E36-8076
17977 - Cruise Control Switch (E45)
P1569 - 001 - Implausible Signal
RPM: 630 /min
Torque: 148.2 Nm
Duty Cycle: 0.4 %
Voltage: 14.29 V
Bin. Bits: 00001111
Torque: 319.8 Nm
Temperature: 84.6°C
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
RPM: 630 /min
Torque: 152.1 Nm
Duty Cycle: 0.4 %
Voltage: 13.98 V
Bin. Bits: 00001111
Bin. Bits: 00000000
Bin. Bits: 00001111
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached
RPM: 630 /min
Torque: 152.1 Nm
Duty Cycle: 88.3 %
Duty Cycle: 20.7 %
Duty Cycle: 0.4 %
Temperature: 84.6°C
18282 - Valve for Torque Support Mount
P1874 - 000 - Short to Plus
RPM: 1722 /min
Torque: 362.7 Nm
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 85.5°C
Readiness: 0 0 X X X
Address 02: Auto Trans
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 00976 000 00000
VCID: 214C6214F87BB68E24-8074
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0C4315829
Coding: 0409600
Shop #: WSC 25445 136 80575
VCID: 58BA0FF0EBA1374613-800C
Component: ELV XXXX
02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted
Fault Frequency: 0
Mileage: 232864 km
Date: 2003.02.27
Time: 00:38:40
00956 - Key 2
Fault Status: 01100010
Fault Frequency: 0
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 01:55:14
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
Reset counter: 61
Date: 2003.01.01
01721 - Sensor for Seat Rear Height Adj. Pass. Seat (G280)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 61
Mileage: 231492 km
Date: 2003.02.27
Time: 00:48:37
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 729 A HW: 4E0 035 729 A
Component: Interfacebox H43 0290
Revision: 00000000 Serial number: 300G9037522503
Coding: 0000000
VCID: 26467108915551B651-8072
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318FP037504655
Subsystem 3 - Serial number: ÿÿ23.06.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
02084 - Component Protection
Fault Status: 00100101
Reset counter: 237
Mileage: 228426 km
Date: 2003.02.27
Time: 16:31:36
Reset counter: 237
Mileage: 228426 km
Date: 2003.02.27
Time: 16:31:36
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000020284
Coding: 1071137
Shop #: WSC 02311 785 00200
VCID: 5ABE15F895AD255625-800E
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:46:07
Temperature: 29.0°C
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:46:07
Bin. Bits: 00011111
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:46:07
Voltage: 14.20 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No HW: 4E0 907 279 J
Component: RLS NO RESPONSE
Coding: 0123001
VCID: 55A406C4FCB30A2E08-8000
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
01024 - Rain Sensor (G213)
Reset counter: 60
Reset counter: 61
01800 - Light Switch (E1)
Reset counter: 100
Mileage: 232866 km
Date: 2003.02.27
Time: 00:00:04
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI G000AGSª0020
Revision: <> Serial number: AUX3Z0C5318600
Coding: 0010773
RPM: 651 /min
Torque: 3.9 Nm
Duty Cycle: 0.4 %
Voltage: 14.21 V
Bin. Bits: 00001111
Bin. Bits: 00000000
Bin. Bits: 00001111
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: 63C0281CA2E7E49E76-8036
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C5012892
Coding: 0000103
Shop #: WSC 12345 001 136936
VCID: 5CB213E09F99DB6637-8008
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 D
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
VCID: 59BC0AF490AB2E4E2C-800C
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0050
Revision: 07 Serial number: 13003036240F7B
Coding: FCFFDBDE2B3504
Shop #: WSC 05311 210 01865
VCID: 65C43604ACD39AAE98-8030
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:47:42
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:47:43
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 01:54:58
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 02:04:12
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H04 0060
Revision: 06000104 Serial number: 23052003163143
VCID: 5EB619E88985C97659-800A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 HW: 4E0 035 111
Component: CD-Changer H43 0220
Serial number: AUZ5ZBC1018111
VCID: 56A601C8E1B5013601-8002
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Fault Frequency: 0
Mileage: 232864 km
Date: 2003.02.27
Time: 00:38:40
00956 - Key 2
Fault Frequency: 0
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 01:55:14
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 67916 260 51396
VCID: 25447604EC535AAE58-8070
Fault Status: 11100100
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 00:39:24
01437 - Control Position not Learned
Fault Status: 11100101
Reset counter: 60
Mileage: 232866 km
Date: 2003.02.27
Time: 00:37:47
00776 - Level Control System Sensor; Left Front (G78)
Fault Status: 11101100
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 01:54:58
01400 - Suspension Level Control
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 01:40:08
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 02:02:39
Component: Sitzmemory FS H06 0060
Coding: 4063342
Reset counter: 61
Date: 2003.01.01
Part No SW: 4E0 910 887 C HW: 4E0 919 887 C
Component: MNS ECE H41 0350
Revision: 00000000 Serial number: 305GP037536473
VCID: 2D548E24B4A362EE90-8078
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000315500023
Coding: 0036032
VCID: 1D345EE4C403926E00-8048
Reset counter: 101
Mileage: 232864 km
Date: 2003.02.27
Time: 00:39:00
Reset counter: 101
Mileage: 232864 km
Date: 2003.02.27
Time: 02:04:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM004 0080
Coding: 0028454
02111 - Motor for Window Regulator
Reset counter: 79
Mileage: 230208 km
Date: 2019.09.22
Time: 15:23:34
00913 - Window Regulator Switch; Front Right Driver (E81)
Reset counter: 98
Mileage: 231040 km
Date: 2019.10.13
Time: 08:27:14
Fault Status: 00101100
Fault Frequency: 14
Reset counter: 99
Mileage: 231344 km
Date: 2019.10.14
Time: 10:13:54
01482 - Motors for Central Locking
Fault Status: 00100111
Reset counter: 100
Mileage: 231488 km
Date: 2003.02.27
Time: 00:45:42
Fault Status: 01101000
Reset counter: 60
Mileage: 231488 km
Date: 2003.02.27
Time: 00:05:36
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040307030112
Coding: 0004345
VCID: 27587C0C965F48BE6A-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
Fault Frequency: 18
Reset counter: 61
Mileage: 231492 km
Date: 2003.02.27
Time: 01:01:34
Fault Frequency: 227
Reset counter: 61
Mileage: 231492 km
Date: 2003.02.27
Time: 01:11:53
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 02:04:19
Reset counter: 60
Mileage: 217900 km
Date: 2017.07.18
Time: 04:57:23
00985 - Right Tail Light (M2)
Fault Frequency: 64
Reset counter: 61
Mileage: 231492 km
Date: 2003.02.27
Time: 00:00:36
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 A HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0140
Revision: PROD_01 Serial number: 00000000205228
Coding: 0000013
VCID: 1B3050FCDA179C5EFE-804E
Fault Frequency: 13
Reset counter: 100
Mileage: 230450 km
Date: 2019.10.06
Time: 08:50:53
Reset counter: 100
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 100
Bin. Bits: 10
02454 - Microphone Unit (in Front Roof Module) (R164)
Fault Frequency: 9
Reset counter: 100
Mileage: 231492 km
Date: 2003.02.27
Time: 00:03:17
Bin. Bits: 00
00456 - Control Module for Access and Start Control (J518)
Reset counter: 100
Mileage: 231492 km
Date: 2003.02.27
Time: 00:30:04
Reset counter: 101
Mileage: 231492 km
Date: 2003.02.27
Time: 00:02:40
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000018260
Coding: 0010101
VCID: 5DB41EE48483D26E40-8008
Reset counter: 101
Mileage: 232864 km
Date: 2003.02.27
Time: 02:04:00
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 00:37:00
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 00:37:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM004 0080
Coding: 0028454
Reset counter: 101
Mileage: 232864 km
Date: 2003.02.27
Time: 02:04:38
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 80093 222 183701
02427 - Brake Disk Rear Right; Not Reached
000 - - - MIL ON
Fault Status: 11110000
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 01:53:44
Voltage: 14.18 V
Count: 13
02426 - Brake Disk Rear Left; Not Reached
000 - - - MIL ON
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 01:53:44
Voltage: 14.18 V
Count: 12
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
000 - - - MIL ON
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 02:05:04
Voltage: 14.29 V
Count: 15
02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached
000 - - - MIL ON
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 02:05:04
Voltage: 14.29 V
Count: 14
02596 - Rear Brake Pads Worn
Reset counter: 61
Mileage: 232864 km
Date: 2003.02.27
Time: 02:05:27
Voltage: 12.84 V
Count: 61
Part No SW: 4E0 910 541 HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0180
Revision: 00000000 Serial number: 304GO037536581
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 HW: 4E0 919 146
Component: TV analog TUNER H12 0140
Revision: 00000041 Serial number: 00000000003292
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000005507
Shop #: WSC 00673 210 83197
VCID: 204A6710F371BF862B-8074
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1407230308
Coding: 344530393135313035412056413031343037323330333038
Shop #: WSC 02313 183 00289
02255 - Voltage Measuring Lead from Vbat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 61
Mileage: 232866 km
Date: 2003.02.27
Time: 02:10:01
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0090
Coding: 0028454
Fault Frequency: 14
Mileage: 231424 km
Date: 2019.10.15
Time: 10:17:20
Fault Status: 00101110
Mileage: 231488 km
Date: 2003.02.27
Time: 02:13:08
Fault Frequency: 9
Mileage: 231488 km
Date: 2003.02.27
Time: 00:41:18
Mileage: 232864 km
Date: 2003.02.27
Time: 00:01:10
Mileage: 232864 km
Date: 2003.02.27
Time: 00:01:10
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0090
Coding: 0028454
Reset counter: 60
Reset counter: 101
Mileage: 232864 km
Date: 2003.02.27
Time: 02:04:40
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0101008
VCID: 60CA2710B3F1FF866B-8034
Reset counter: 100
Mileage: 232866 km
Date: 2003.02.27
Time: 00:00:56
Reset counter: 100
Mileage: 231492 km
Date: 2003.02.27
Time: 00:03:43
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 100
Mileage: 231492 km
Date: 2003.02.27
Time: 00:16:06
00576 - Terminal 15
Reset counter: 100
Mileage: 231492 km
Date: 2003.02.27
Time: 00:17:11
Fault Frequency: 8
Reset counter: 101
Mileage: 232866 km
Date: 2003.02.27
Time: 00:00:46
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 B HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0180
Revision: 00000004 Serial number: T2AUD3080806XP
Coding: 0000004
VCID: 1E3659E8C905897619-804A
End-------------------------(Elapsed Time: 03:33)--------------------------
Address 03: DTCs cleared
