2009 Audi A3 - ABS Module Coding Lost
DeeKushman
C?ID=190073
VIN: WAUZZZ8P99A008427   License Plate:
Mileage: 105600km-65616mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P99A008427   Mileage: 105600km-65616miles
01-Engine -- Status: Not registered 0011
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0001
09-Cent. Elect. -- Status: Not registered 0001
15-Airbags -- Status: Not registered 0001
16-Steering wheel -- Status: Not registered 0001
17-Instruments -- Status: Not registered 0011
25-Immobilizer -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0011
47-Sound System -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: Not registered 0001
56-Radio -- Status: Not registered 0001
62-Door, Rear Left -- Status: Not registered 0011
72-Door, Rear Right -- Status: Not registered 0011
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 D    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH03---    Serial number: AUX7Z0H5FNJ01D
   Coding: 0103000C18070060
   Shop #: WSC 06314 000 00000
   VCID: 3A7BD9FB75919C5605-806E
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 103641 km
                    Date: 2020.06.07
                    Time: 23:55:58
                    RPM: 764 /min
                    Load: 12.9 %
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition)
                    Mileage: 103989 km
                    Date: 2020.06.16
                    Time: 10:33:33
                    RPM: 2907 /min
                    Load: 96.4 %
                    Speed: 129.0 km/h
                    Temperature: 97.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 1342401249220002C80F02E6922000813800
   Shop #: WSC 13175 003 1048576
   VCID: 76E30DCBC109383621-8022
16352 - Control Module - Electrical Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 64
                    Mileage: 104494 km
                    Date: 2020.06.25
                    Time: 02:23:55
                    Count: 7
                    Count: 3
                    Count: 12288
                    Count: 96
                    Count: 36864
                    Count: 6125
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 67
                    Mileage: 104531 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 100
                    Count: 45056
                    Count: 768
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 64
                    Mileage: 104531 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 143
                    Count: 45056
                    Count: 768
                    Reset counter: 64
                    Mileage: 104494 km
                    Date: 2020.06.25
                    Time: 02:17:30
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 8192
                    Count: 44288
                    Count: 5888
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH08 0100
   Revision: 000400      Serial number: 8P0820043BG
   VCID: 72EB31DB6D6124160D-8026
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008587286
   Coding: 11AC2F81B0141380EF00001C0000000000084E0564010403002800000000
   Shop #: WSC 06314 000 08192
   VCID: 489FB3333B7DFEC683-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303030374A55305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4999B637E87707CE9C-801C
   Serial number: 3572DRB40000765908BW
   Serial number: 3582DRB400007605292I
   Serial number: 35128RB400003DBF016O
   Serial number: 35228RB400003D15FEF%
   Serial number: 35547RB400003CB19E8
   Serial number: 35647RB400003CB1A78X
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0002012
   VCID: 4189AE171847CF8E44-8014
   Component: E0221           H02 0030
   Part No SW: 8P0 920 982 E    HW: 8P0 920 982 E
   Component: KOMBIINSTR. VDO H15 0820
   Revision: D0H15004    Serial number: 2245H004001186
   Coding: 0004408
   VCID: 3B75DCFF7AABA55E1E-806E
            014 - Defective
                    Mileage: 90464 km
                    Date: 2018.11.12
                    Time: 01:13:21
   Component: J533__Gateway   H-- 0202
   Revision:   H--       Serial number: 00000000000000
   Coding: 00000000000002F100
   VCID: 3561CAC75C8F732EE8-8060
                    Reset counter: 17
                    Mileage: 103383 km
                    Date: 2020.06.02
                    Time: 09:25:01
   Revision: D0H15004    Serial number: AUX7Z0H5FNJ01D
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000692
   VCID: 4385A41F025BDD9E56-8016
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.078 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3663CDCB41897836E1-8062
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C9FC637
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802619459
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000692
   VCID: 4487A7030755DAA66F-8010
   Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
   Component: R Concert2+     H02 0270
   Revision: 00H02000    Serial number: AUZ1Z3H8929991
   Coding: 0330211
   VCID: 3F8DA8EF6EB3B97E32-806A
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 428BA11B1D41D4965D-8016
00099 - Rear Right Central Locking (Safe) Motor (V164)
Thank you
i think i will start by trying to correct the coding ..ABS pump was changed by another garage .
Let's start with the fact that this is not a 2008; it's a 2009:
WAUZZZ8P99A008427
I'll fix the thread subject.
The very first that should be done correcting the Gateway Installation List:
[Select]
[19-CAN Gateway]
[Installation List]
- Put a checkmark next to each of the items that says "Not registered" at the top of your scan.
[Save Coding]
Then please cycle the ignition and make another scan.
DeeKushman
C?ID=190073
Thank you I will attempt that and report back
Sorry about the wrong year 🤦*♂️
I appreciate the quick reply
DeeKushman
C?ID=190073
VIN: WAUZZZ8P99A008427   License Plate: ELI
   VCID: 3A7BD9FB75919C561D-806E
                    Mileage: 103641 km
                    Date: 2020.06.07
                    Time: 23:55:58
                    RPM: 764 /min
                    Load: 12.9 %
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Voltage: 13.843 V
                    Mileage: 103989 km
                    Date: 2020.06.16
                    Time: 10:33:33
                    RPM: 2907 /min
                    Load: 96.4 %
                    Speed: 129.0 km/h
                    Temperature: 97.0°C
                    Temperature: 25.0°C
                    Voltage: 13.843 V
   Revision: 00H35001
   VCID: 76E30DCBC109383639-8022
                    Fault Status: 00101110
                    Reset counter: 131
                    Mileage: 105603 km
                    Date: 2020.07.27
                    Time: 22:33:00
                    Count: 7
                    Count: 3
                    Count: 12288
                    Count: 96
                    Count: 35328
                    Reset counter: 131
                    Mileage: 105603 km
                    Date: 2020.07.27
                    Time: 22:20:45
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 100
                    Count: 50432
                    Reset counter: 131
                    Mileage: 105603 km
                    Date: 2020.07.27
                    Time: 22:33:00
                    Count: 7
                    Count: 3
                    Count: 12288
                    Count: 143
                    Count: 35328
                    Reset counter: 131
                    Mileage: 105603 km
                    Date: 2020.07.27
                    Time: 22:20:46
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 8192
                    Count: 50432
   Revision: vollauto    Serial number: ppppnnnn123456
   VCID: 72EB31DB6D61241615-8026
   VCID: 489FB3333B7DFEC69B-801C
   Coding: 00056595
   Shop #: WSC 06314
   VCID: 4999B637E87707CE84-801C
   Coding: 0002012
   VCID: 4189AE171847CF8E5C-8014
   Coding: 0004408
   VCID: 3B75DCFF7AABA55E06-806E
            014 - Defective
                    Mileage: 90464 km
                    Date: 2018.11.12
                    Time: 01:13:21
   Coding: E9807F06100202F100
   VCID: 3561CAC75C8F732EF0-8060
                    Reset counter: 171
                    Mileage: 105603 km
                    Date: 2020.07.27
                    Time: 22:03:29
   Coding: 0000692
   VCID: 4385A41F025BDD9E4E-8016
   VCID: 3663CDCB41897836F9-8062
   Coding: 0000692
   VCID: 4487A7030755DAA677-8010
   Coding: 0330211
   VCID: 3F8DA8EF6EB3B97E2A-806A
   Coding: 0000144
   Coding: 0000144
   VCID: 428BA11B1D41D49645-8016
End-------------------------(Elapsed Time: 01:54)--------------------------
Better.
Now clear all fault codes.
I'll note that your ABS coding is not "lost". MK60EC1 modules revert coding to all zeros when it is "lost'.
What parts have been changed in this car? Is the ABS module correct/appropriate for the car?
DeeKushman
C?ID=190073
Hi again
The pump was changed previously..if it was correct is a mystery at the moment....definitely second hand though.
I’m going to try and find out some more history on what’s happened previously.
Will reset the codes and see what comes up
So this pump seems incompatible maybe ?
NEtech
Denmark
C?ID=56995
Coding in [19-CAN Gateway] is wrong, Byte 8 Bit 0
E9807F06100202F101
