2012 Touareg V6 bluemotion, Overheating and multible faults
Mpm
Australia
C?ID=400544
Hi guys, I'm new here and looking for some advise,
I got a customers car in the shop which he recently bought, on his way home ( about 400 km ) he said that everything went really good apart from the cruise control not working! but in the last 30 km it started to get warm when going up hills but dropping off really quick going down hill.
I found that the little plastic valve in the valley behind the oil cooler was leaking so we replaced the valve and the little flange pressure tested system and inspect egr cooler and oil cooler for leaks.
it did get a new water pump a couple months ago by a different workshop. I hooked up vcds and found multiple codes and after research it looked like the thermostat in the oil-filter housing could cause all the issues so we replaced that one as well. The car still gets hot going up hills and i checked all wiring and plugs and everything seems to be ok, Is there anything else i might have missed? I attach the autoscan and would really appreciate any advice as its driving me nuts!:banghead:
Thanks
Tuesday,14,July,2020,08:17:32:52812
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Mt.Perry Mechanics
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3C 42 46 52 53 56 5F 62
          6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZCD062215   Mileage: 159223km-98936miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012236601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
   ROD: EV_ECM30TDI_VW52.rod
   VCID: 323D1C2974A3855B95F-8066
7036 - Thermostat for Mapped Engine Cooling (F265)
          P0597 00 [047] - Open Circuit
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:41:25
                    Coolant temperature: 77 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.360 V
                    Coolant temperature at radiator outlet: actual value: 36.8 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 27.0 °C
                    Fuel consumption: 0.00 l/h
                    Fuel temperature: 60.8 °C
                    Engine oil temperature: 72.5 °C
4881 - EGR Valve (N18)
          P1440 00 [175] - Open Circuit
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:41:35
                    Voltage terminal 30: 12.340 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 100.00 %
                    EGR valve: offset closed: 2.40 %
                    High press EGR actuator: actual unconditioned volt val: 0.0 mV
                    EGR valve: offset open: -2.40 %
4900 - EGR Sensor 1
          P0405 00 [175] - Signal too Low
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:41:25
                    High press EGR actuator: actual unconditioned volt val: 0.8 mV
Readiness: 1 2 0 0 1
   Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
   Component: AL1000 AISIN  001 2083
   Coding: 001568
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_TCMAL991031 002112
   ROD: EV_TCMAL991031_002.rod
   VCID: 71BFD325B125FE43AC5-8024
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 411120010EC815
   Coding: 5B6B13C3492A2F55DAF6C89492D7F450F700
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D14AF1DE173BEB373-8010
   Part No SW: 4H0 907 064 BM    HW: 4H0 907 064 BM
   Component: BCM2 2.0      H31 0333
   Coding: 01B60000000000000000
   VCID: 75B7E735C5CDD26370D-8020
   Subsystem 1 - Part No SW: 7P6 959 754 AC    HW: 7P6 959 754 AC
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0512000022756003
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000044891013
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1306
   Coding: 36A6200890
   VCID: 7EA5F819F07B913B217-802A
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 12
                    Reset counter: 84
                    Mileage: 156734 km
                    Date: 2020.06.24
                    Time: 07:06:17
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001303159
   Coding: 6900001181345D010005000300005F5F431D460807000241000000000000
   VCID: 73B3D92DCBB9CC535E9-8026
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    120304  31  0020
   Serial number: 90243401120414184808
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10369636
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 F    HW: 7P6 941 431 F
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001704120562
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                    Fault Status: 00101100
                    Reset counter: 84
                    Mileage: 159216 km
                    Date: 2020.07.14
                    Time: 07:12:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261211500041
   Coding: 508D01
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42DD4CE9C40335DB05F-8016
   Part No SW: 7P6 907 561 A    HW: 7P6 907 561
   Component: ACC3          H17 0230
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContrVW526 001004
   ROD: EV_AdaptCruisContrVW526_001.rod
   VCID: 3A2D3409ACD37D1B5DF-806E
143104 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_DIS_FAIL]
                    Reset counter: 84
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:42:12
                    Voltage terminal 15: 13.208 V
                    Velocity_vehicle_reference: -0.02 m/s
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 38
                    Reset counter: 44
                    Mileage: 159216 km
                    Date: 2020.07.14
                    Time: 07:25:48
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 14.784 V
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00T H05 0025
   Revision: --------    Serial number: 003L0002W0W4
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DF43E5C1052EC31C5-8014
   Serial number: 3575LRB405V1BEPS8OCR
   Serial number: 3585LRB405T1BEPSEGEQ
   Serial number: 3515RRB4063181TU7PL%
   Serial number: 3525RRB4063181TUDHT6
   Serial number: 3555NRB405J184CO3PAM
   Serial number: 3565NRB405J184COK0UZ
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 T
   Revision: --------    Serial number: 90815LDQ0002Y
   Coding: 000C9D
   VCID: 38292E01925F6F0BABB-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0172754
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882 F    HW: 7P6 920 882 F
   Component: Kombi         H14 0253
   Revision: 12240067    Serial number: 658230412592060
   Coding: 3307310066080008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 40D946E1CA0F27CB13B-8014
10485828 - Loudspeaker in Instrument Cluster
          B12E7 01 [009] - Electrical Failure
                    Fault Frequency: 21
                    Reset counter: 44
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:42:12
   Part No SW: 7P6 907 530 D    HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5202
   Revision: --------    Serial number: 00000000494959
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 392F2B05A9D57603545-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650166587
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 12109001851021200181
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 11
                    Reset counter: 84
                    Mileage: 158782 km
                    Date: 2020.07.10
                    Time: 14:19:19
                    Voltage terminal 30: 12.8 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 30 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 84
                    Mileage: 158782 km
                    Date: 2020.07.10
                    Time: 17:19:47
                    Voltage terminal 30: 12.7 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH04 0110
   Revision: 00H04000    Serial number: 6PZ 010 316-01
   Coding: 0001151
   VCID: 7EA5F819FCFB913B217-802A
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H02 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F21.04.1200H020003C520356ÿ
   Subsystem 4 - Serial number: 520356ÿ
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000126540316
   Coding: 011D0620D001459005080003
   VCID: 43D349EDDB993CD30E9-8016
   Revision: 00002001    Serial number: 0175225875
   Coding: 011A162028B9109480200624030000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO1621672%
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1594499F
   Coding: 191100
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 74
                    Mileage: 158521 km
                    Date: 2020.07.07
                    Time: 12:07:58
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 74
                    Mileage: 158521 km
                    Date: 2020.07.07
                    Time: 12:08:09
01505 - Bulb for Blinkers; Rear Right (M8)
                    Reset counter: 74
                    Mileage: 158521 km
                    Date: 2020.07.07
                    Time: 12:08:09
02739 - Bulb for Tail/Brake Light; Right
                    Reset counter: 74
                    Mileage: 158521 km
                    Date: 2020.07.07
                    Time: 13:10:08
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000126647277
   Coding: 011D0620D001459005080000
   VCID: 3B23310DA3694413469-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1241700718
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3635203998CB997BB97-8062
   Slave 3:
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227D/0C7571890
   Coding: 040005020100000003
   VCID: 2615F07948EBE9FB097-8072
   Part No SW: 7P6 035 764 K    HW: 7P6 035 764
   Component: H-BNT-RW      H45 0934
   Revision: --------    Serial number: 479C/0C7519170
   Coding: 010A01050040C9EF39100B0E00000003F00001010000000000
   VCID: 41DF43E5C1852EC31C5-8014
   Subsystem 1 - Part No: 8R0 060 884 AJ
   Component: ROW 2012  0403
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M78017Z5
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000126779513
   Coding: 011C04200001259005080000
   VCID: 3A2D3409AC537D1B5DF-806E
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D
   Component: TopView       H05 0097
   Revision: 11001001    Serial number: 82330JF0039355
   Coding: 0100000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 41
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:41:29
                    Voltage terminal 30: 12.3 V
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 104200938
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D273F15BDFD4A2378D-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000126628813
   Part No SW: 7P6 907 217 A    HW: 7P6 907 217
   Component: DPC-SG        H24 0033
   Coding: 69020000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 38292E0192DF6F0BABB-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003024991_2023
   Part No SW: 7P6 907 541 A    HW: 7P6 907 541
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526_001.rod
          U1113 00 [009] - -
                    Reset counter: 84
                    Mileage: 158893 km
                    Date: 2020.07.11
                    Time: 14:42:12
                    Voltage terminal 15: 13.492 V
                    Velocity_vehicle_reference: -0.01 m/s
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 A    HW: 7P6 907 107
   Component: BV-SG         H30 0031
   Serial number: 000040191604127
   Coding: 01A098000000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 44
                    Mileage: 159161 km
                    Date: 2020.07.13
                    Time: 16:19:01
                    Outside air temperature: 21.5 °C
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 24.0 °C
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW52.rod
   VCID: 313F132571A5BE43EC5-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW52.rod
End----------(Elapsed Time: 02:19, VBatt start/end: 14.9V/14.9V)-----------
"Thermostat for Mapped Engine Cooling - Open Circuit"
That's pretty self-explanatory, isn't it?
Of course the EGR faults should be fixed as well.
Does your car support a secondary thermostat too and Auxiliary water pump?
Is air bled properly burped?
Mpm
Australia
C?ID=400544
Hi Uwe,
Yeah it is pretty self-explanatory!!! I did replace the the thermostat and checked all wiring and plugs, I was just wondering if anyone came across this issue? all sensors seem to test ok with the test data i could find, Im just wondering if it could be an earth issue in one of the modules as i had that happening before!
thanks anyway!
Mpm
Australia
C?ID=400544
no it hasn't got the secondary thermostat, I thought it had but couldn't find it where there normally are, Yeah i bleed the system twice, using genuine coolant. All i wanted to know was if anyone came across this issue before i pull out ecm's and get them tested! maybe there are some other issues related, he hasn't got cruise control, adaptive cruise,side assist, lane assist, backup cam plays up!!!!
just a little gremlin in it somewhere and i cant find it!!!
Thanks
Hi Uwe,
If the thermostat is good and the wiring is good, then the only thing left is the ECU itself, right?
But since ECUs are quite expensive and a PITA to replace, I would go back and double-check the thermostat and wiring. Maybe sub in a resistor in place of the thermostat and load test the wiring?
Mpm
Australia
C?ID=400544
yeah i have to check the whole lot again! would you have any date and resistance check for the thermostat, I mean i had it happening before that I did get a brand new part which was faulty,
Thanks
Decade box and scroll up watching blocks and DTC resets to establish thresholds?
