After some errant changes in module 46, I received the message below on my dash
Some history: Vehicle was purchased in November 2019, as CPO. Original Scan below with HEX+CAN
Since acquisition, I've made several modifications, including lowering springs, and coding changes; needle sweep, easy entry, gear number, comfort window opening, etc, etc. I've also retrofitted European LED tail lights, bought used and coded with VAG CAN PRO Interface by the person I bought the tail lights from. Most of these changes were made with OBDeleven, since the HEX+CAN cable I had did not communicate with some modules.
I noticed in June, that my tailgate was not closing by remote. With OBD eleven, I tried making some changes in module 46, but must have made a mistake, referenced above. The mistake triggered an error code Faults: C103615 - Left rear level control system sensor Open circuit/short circuit to B+ static. I was able to get the coding back to how it was prior to the mistake, and clear the fault. However, the message on the dash appeared, and now I cannot clear it.
Here is a scan from May, prior to the coding mistake
My suspicion is that since the headlights are aiming based on the level control, the level sensor error caused a cascading effect on the headlights, and the system needs to be calibrated. I've since purchased a HEX-V2 cable from Ross-Tech, assuming I could do the headlight calibration, and remedy the message on the dash.
I read the tutorial on the Ross-Tech Wiki about headlight calibration. While attempting to do the calibration with the HEX-V2 cable, the expected drop downs did not appear, but rather the only dropdown that appeared, was to reset all adaptation values. There was also a warning message that popped up saying "Resetting adaptation is not reversible, reparametrization may require dealer tool" Of course I did not reset the adaptation.
Here is the latest scan, with the V2 cable
So now, I'm stuck as to a next step, and how to get rid of the message on the dash. Any assistance would be most appreciated.
Saturday,23,November,2019,09:41:52:57717
VCDS Version: 19.6.2.0 (x64)
VIN: WA19NAF43HA117046 License Plate:
Chassis Type F4-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 36 39 3C 42 44 46 47 52
5F 6C 6D 74 81 82 8B A5 BB BC CA CF D6 D7
VIN: WA19NAF43HA117046 Mileage: 40766km-25330miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 326500322366010E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: 489574D4F3528E0F2F-801C
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 155 J HW: 0CJ 927 156
Component: 0CJ 20TFSINAR H03 0002
Revision: --H03--- Serial number: 0000000897
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU49.rod
VCID: 30653C346BC226CF17-8064
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160349000530
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 H HW: 8W0 907 379 D
Component: ESP9 Premium H09 0719
Coding: 18AA409928A32A9D919E4895208352A2E6259A180214548912044A4567A459
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 4A914EDCED5E7C1F39-801E
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 H HW: 8W0 820 043 H
Component: Klima Zone 3 H32 0082
Coding: 240809085548010D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 3875041483B2FE8F5F-806C
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0003
Serial number: 00000000000001240884
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 9949CA8880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07500363E0691CCD0517511958AE98B9110B3D080000000000000000200016010A69012B025709
VCID: 0201A6FC95EE645FB1-8056
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 161208 043 0813
Serial number: 89435300301634303872
Coding: 5BC7F7
Serial number: 20194793X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 02 07 2016 00547167
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z2I1V02
Coding: 350000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20161116082728 00081
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE128091612010434
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10456755
Subsystem 8 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000162306001
Seat Backrest Fan 1 Front Left:
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DG29000376
Seat Cushion Fan 1 Front Left:
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DG28800757
Seat Backrest Fan 1 Front Right:
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DG28801040
Seat Cushion Fan 1 Front Right:
Subsystem 12 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DG28800770
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 B HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: B4779FF258FFEC09949880A1
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 3D7B1500AC90DBA78C-8068
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0104
Serial number: 003UQ000945Y
Coding: BFCCF0C000800000A0000033D24C00000000
Shop #: WSC 25449 002 1048576
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 4D9B45C01C306B271C-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705C0006R00648
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706D0348Q00650
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J160006FAEI06
Subsystem 4 - Part No SW: ----------- HW: 442 060 712 16
Serial number: 3577Y00B120DD051546V
Subsystem 5 - Part No SW: ----------- HW: 442 060 712 16
Serial number: 3587Y00BB209FF91722C
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 612 16
Serial number: 35177002E29E084A259G
Subsystem 7 - Part No SW: ----------- HW: 442 0B0 612 16
Serial number: 35277001229E08482570
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 801 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500BD2235602D1DA
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 801 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BD223560211F1
Part No SW: 4M0 907 129 GS HW: 4M0 907 129 GS
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 0717B7E8BECC4177E6-8052
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 C HW: 8W5 920 890 C
Component: FBenUSA H17 0309
Coding: 08C699C3FC88CF0502A369601800400008000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 438F63F8CA74AD57FA-8016
16777024 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
Reset counter: 221
Mileage: 40569 km
Date: 2019.10.24
Time: 16:55:24
Part No SW: 8W8 907 468 D HW: 8W8 907 468 D
Component: Gateway H30 0308
Revision: 5D010003 Serial number: 0385D298617112
Coding: 03010001000006402907000000590030DCB20007000000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20170107012704 00136
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8845272204
Address 22: AWD (J492) Labels:* None
Part No SW: 8W9 927 755 HW: 0CJ 927 749
Component: B9_DL3_H_SD5 H01 0004
Serial number: 1615118560
Coding: 11040000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
VCID: 0B1F8BD8A2A42517C2-805E
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000236065585
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 76E9CA2CC92648FF8D-8022
Address 39: Right Light
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 36690A2C89A608FF4D-8062
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0057
Serial number: 0000231990735
Coding: 005D1B215E001080000100B2
VCID: 40856CF4DB62B64FE7-8014
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 0D008380008080
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 418369F0D068BF47E8-8014
Address 46: Central Conv.
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA010ABN
Coding: 0194420800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
0517 - Front Right Midrange Speaker
B1063 13 [009] - Open Circuit
Fault Frequency: 8
Reset counter: 192
Mileage: 40551 km
Date: 2019.10.21
Time: 11:10:59
Voltage terminal 30: 11.8 V
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0057
Serial number: 0000236080567
Coding: 005D1B215E001080000100B0
VCID: 3F876F08A69CC9B79E-806A
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 HW: 8W5 035 880
Component: MU-P-LNS-US 033 0918
Serial number: A798A0HB009106
Coding: 019442020000000053220002041A00102F000CE501700904BE
VCID: 7CFDD804F70A12AFFB-8028
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0160
Serial number: TPO00101121600820424
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK110121600020411
Compact Disc Database:
Component: Gracenote2 --- 3011
B11CF 53 [009] - Deactivated
Reset counter: 180
Mileage: 40551 km
Date: 2019.10.21
Time: 12:43:23
Voltage terminal 30: 12.2 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG011435
Coding: 02940202BA0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 346D30249FDA1AEF73-8060
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31133508400000
Coding: 0570
VCID: 3261363C65CE14DF61-8066
Address 74: Chassis Control
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 J HW: 8W1 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170103003834
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3A711E1CBDBEEC9FA9-806E
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W5 919 617 B HW: 8W5 919 617 B
Component: HeadUpDisplay H17 1603
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736.rod
VCID: 479777E8FE4C817726-8012
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 3B7F1B18B284D597B2-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090200000202022023A6AD0000FCB0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0057
Serial number: 0000233623026
Coding: 000D1B2000001080400000A0
VCID: 428166FCD56EA45FF1-8016
Component: TSG HBFS 009 0057
Serial number: 0000236084500
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 07:30)--------------------------
Thursday,14,May,2020,21:24:19:57717
VCDS Version: 20.4.1.0 (x64)
VIN: WA19NAF43HA117046 Mileage: 48776km-30308miles
Revision: --H15---
ROD: EV_ECM20TFS0208W0906259J.rod
VCID: 489574D4F3528EC683-801C
VCID: 30653C346BC22606BB-8064
VCID: 4A914EDCED5E7CD695-801E
VCID: 3875041483B2FE46F3-806C
Coding: 07500363E0690CCD0517511958AE9CB9110B3D080000000000000000200016010A69012B025709
Shop #: WSC 12345 123 61029
VCID: 0201A6FC95EE64961D-8056
Coding: 5BC7F7
Coding: 02005D
Coding: 350000
Coding: 030000
VCID: 3D7B1500AC90DB6E20-8068
VCID: 4D9B45C01C306BEEB0-8018
Coding: 80000D
Coding: 80000D
Occupant Detection:
VCID: 0717B7E8BECC41BE4A-8052
Coding: 00CF99C3FC88CF0502A36D601800400008000000
VCID: 438F63F8CA74AD9E56-8016
8531970 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 163
Mileage: 48390 km
Date: 2020.04.26
Time: 18:37:58
Total static current-current total quiescent current: 781 mA
Total static current-Total time quiescent current exceeded: 1.0 H
EM_vehicle_state: 00 00
Coding: 11040000
VCID: 0B1F8BD8A2A425DE6E-805E
Coding: 005C1BC00000B4010000010101010000000000000000000000000000000000
VCID: 76E9CA2CC926483621-8022
Revision: --------
Coding: 0EC002
VCID: 36690A2C89A60836E1-8062
VCID: 40856CF4DB62B6864B-8014
VCID: 418369F0D068BF8E44-8014
VCID: 3F876F08A69CC97E32-806A
VCID: 7CFDD804F70A126657-8028
Reset counter: 101
Mileage: 47514 km
Date: 2020.04.01
Time: 15:59:25
Voltage terminal 30: 12.5 V
VCID: 346D30249FDA1A26DF-8060
Coding: 0570
VCID: 3261363C65CE1416CD-8066
VCID: 3A711E1CBDBEEC5605-806E
Coding: 4F01E0
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 479777E8FE4C81BE8A-8012
VCID: 3B7F1B18B284D55E1E-806E
1123600 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 187
Mileage: 47845 km
Date: 2020.04.11
Time: 11:09:39
Control Module temperature: 44 °C
Voltage terminal 15: 14.80 V
1123601 - predictive route data
Reset counter: 184
Mileage: 48439 km
Date: 2020.04.29
Time: 12:36:20
Control Module temperature: 24 °C
VCID: 428166FCD56EA4965D-8016
Address CA: Sunroof
End-------------------------(Elapsed Time: 06:29)--------------------------
Friday,10,July,2020,20:24:50:24586
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Chassis Type: F4-AU49 (8W8)
VIN: WA19NAF43HA117046 Mileage: 51369km-31919miles
Revision: --H15---
VCID: 48C95DC16235FBEBDBB-801C
VCID: 30391521FAA5532BE3B-8064
Coding: 18AA409928A32A9D919E4895208352A2E625DA180214548912044A4567A45B
Shop #: WSC 17873 123 50804
VCID: 4ACD67C97C3909FBCDF-801E
VCID: 38292D0112D58B6BABB-806C
Coding: 07500363E0690CCD0517511958AE9CF9110B3D080000000000000000200016010A69012B025709
VCID: 025D8FE9048911BB45F-8056
Coding: 5BC7F7
Coding: 02005D
Coding: 350000
Coding: 030000
VCID: 3D273C153DF7AE4378D-8068
VCID: 4DC76CD58D571EC3E8D-8018
Coding: 80000D
Coding: 80000D
Occupant Detection:
VCID: 074B9EFD2FAB3493121-8052
VCID: 43D34AED5B13D8B30E9-8016
Coding: 11040000
VCID: 0B43A2CD33C350F3369-805E
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A9ED0152554B6B6BB-802C
VCID: 76B5E33958413D1B797-8022
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Revision: --------
Coding: 0EC002
VCID: 3635233918C17D1BB97-8062
VCID: 40D945E14A05C3AB13B-8014
VCID: 41DF40E5410FCAA31C5-8014
Part No SW: 8W0 907 064 CC HW: 8W0 907 064 C
Component: BCM2 MLBevo 018 0344
Coding: 013400004F9100C0650BA0006E00080233004000010027502F0400000504803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7F5B061D777B7C532A1-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY163232G4G
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000037252209
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0904
Serial number: >1023017
VCID: 3FDB461D37FBBC536A1-806A
VCID: 7CA1F111666D674B0F3-8028
Reset counter: 219
Mileage: 51189 km
Date: 2020.07.04
Time: 12:50:31
VCID: 343119310EBD6F0B873-8060
Coding: 0570
VCID: 323D1F29F4A9613B95F-8066
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 3012160491
Coding: 1051506158
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 4CC161D1764D17CBFF3-8018
VCID: 3A2D37092CD9997B5DF-806E
Coding: 4F01E0
VCID: 47CB5EFD6F2BF493D21-8012
VCID: 3B23320D23E3A073469-806E
VCID: 42DD4FE94409D1BB05F-8016
Part No SW: 4M0 907 594 HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 208000049202
VCID: 73B3DA2D4B3328335E9-8026
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 33331A2D0BB368339E9-8066
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 1675C3B978019D1B997-8042
Component: LED1R H09 0003
End----------(Elapsed Time: 02:32, VBatt start/end: 12.0V/12.1V)-----------
