2007 VW Passat ABS Module/Park Break Module
Mechanic09
Guyton, GA, USA
C?ID=409550
I have a 2007 VW Passat that was setting. I just rebuilt the Engine and I have having difficulty with the ABS Module. Can the module just lose its information by just setting. I have another module I pulled off another car and it has the same part number. Can I use this ABS module and get the car to accept it. I just dont have the long coding for the module. The speedometer is also not working. Also is there a place to get the wiring diagrams for this car as well. Not sure I inserted the auto scan correctly. Thank You.
Thursday,02,July,2020,16:08:29:24649
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
VIN: WVWEK73C77P002442   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
          65 72
VIN: WVWEK73C77P002442   Mileage: 249930km-155299miles
03-ABS Brakes -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 25428 444 57477
   VCID: 303915096625571BE3B-8064
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
                    Fault Status: 01101000
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:03
                    RPM: 837 /min
                    Load: 28.2 %
                    Temperature: 93.0°C
                    Temperature: 62.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.335 V
049448 - No Communications with Parking Brake Control Module
               U0128 - 008 -
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:03
                    RPM: 837 /min
                    Load: 28.2 %
                    Temperature: 93.0°C
                    Temperature: 62.0°C
                    Voltage: 13.335 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal - MIL ON
                    Fault Status: 11100010
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 12:30:51
                    RPM: 1718 /min
                    Load: 11.4 %
                    Temperature: 92.0°C
                    Temperature: 47.0°C
                    Voltage: 13.462 V
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
                    Mileage: 249937 km
                    Date: 2020.06.28
                    Time: 12:06:32
                    RPM: 1976 /min
                    Load: 35.3 %
                    Temperature: 92.0°C
                    Temperature: 47.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
Readiness: 0000 0100
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 005985C99605079B53B-8054
01316 - ABS Control Module
Address 03: ABS Brakes
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 678BBE55936BD0A3F21-8032
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Status: 00110000
                    Fault Frequency: 22
                    Reset counter: 57
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:12
                    Fault Frequency: 23
                    Reset counter: 17
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:12
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000005593787
   Coding: F5848F0340041A00470A00000F00000000285D435C0000
   Shop #: WSC 00028 028 00001
   VCID: 372B2E15834B8023A21-8062
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 00028
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F1024501
   VCID: 2A0D076140F92DCB2DF-807E
                    Reset counter: 17
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 16:04:34
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P7WP26R
   Coding: 0012366
   VCID: 2E050B717C1141EBF17-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 000000000309W0
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0F0A7529Jÿ†63
   Subsystem 5 - Serial number: A7529Jÿ†6342MSME0E5800234ÿ†63
   Subsystem 6 - Serial number: 800234ÿ†6351HTS6OLLAPOK2Rÿ†63
   Subsystem 7 - Serial number: APOK2Rÿ†6361HTS6OLLMS4C3Gÿ†63
   Subsystem 8 - Serial number: MS4C3Gÿ†63727TS6TLLQEJA3Gÿ†63
   Subsystem 9 - Serial number: QEJA3Gÿ†63827TS6OLLIKRT2-ÿ
   Subsystem 10 - Serial number: IKRT2-ÿ
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507P
   Coding: 0002111
   Component: E0221           006 0080
   Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 25428 444 85788
   VCID: 2313EA4527D3FC836E9-8076
                    Fault Frequency: 13
                    Reset counter: 16
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:25
                    Fault Frequency: 13
                    Reset counter: 16
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:25
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C0651108E2
   Coding: 3FFD0F04D31002
   VCID: 211FE04D3DCFEE937C5-8074
                    Reset counter: 10
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 11:42:37
                    Reset counter: 10
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 11:42:37
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TQJK505
   VCID: 6D87CC7DB197FAF388D-8038
                    Fault Frequency: 24
                    Reset counter: 17
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:34
   Part No SW: 3C0 959 433 AA    HW: 3C0 959 433 AA
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 25428 444 101307
   VCID: 698FB86D857FE6D3E45-803C
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 15
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 11:16:05
02827 - Wake-Up request via ESP
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 10
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:45
            008 - Implausible Signal
                    Reset counter: 10
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 11:16:05
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D070C7D71173AF3C8D-8078
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1123
   Revision: 11006001    Serial number: 00000021368520
   Coding: 0001463
   VCID: 3C213139BA6DA37B4F3-8068
01034 - Electric Window Thermal Protection Active; Driver
                    Fault Frequency: 117
                    Reset counter: 52
                    Mileage: 249937 km
                    Date: 2020.06.28
                    Time: 19:12:31
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 33331A0597336C039E9-8066
00625 - Vehicle Speed Signal
                    Mileage: 9920 km
                    Temperature: 68.0°C
                    Voltage: 13.30 V
                    Voltage: 13.10 V
   Component:    KSG PQ46 RDK 051 0218
   Coding: 13910F8001862E521004141FF08A8F0E085800
   Shop #: WSC 25018 444 58921
                    Reset counter: 17
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 16:04:34
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1123
   Revision: 11007001    Serial number: 00000033368923
   Coding: 0001462
   VCID: 3D273C3DA177AA7378D-8068
01035 - Electric Window Thermal Protection Active; Passenger
                    Fault Frequency: 118
                    Reset counter: 52
                    Mileage: 249937 km
                    Date: 2020.06.28
                    Time: 19:12:31
Address 53: Parking Brake
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       165 0035
   Revision: 00165000    Serial number: VWZ5Z7F2075876
   Coding: 0040401
   VCID: 2411E95922DDFBBB173-8070
                    Fault Status: 01111011
                    Reset counter: 16
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 11:15:55
   Component: J388   TUER-SG HL   1109
   Revision: 12005001    Serial number: 00000000067904
   Coding: 0001168
   VCID: 3E253B31AC71B16B617-806A
01036 - Electric Window Thermal Protection Active; Rear Left
                    Fault Frequency: 178
                    Reset counter: 52
                    Mileage: 249937 km
                    Date: 2020.06.28
                    Time: 19:16:23
   Component:    RDK              0420
   Coding: 0100101
                    Fault Status: 01111000
                    Reset counter: 10
                    Mileage: 249937 km
                    Date: 2020.06.26
                    Time: 10:52:59
   Component: J389   TUER-SG HR   1109
   Revision: 12005001    Serial number: 00000000018436
   Coding: 0001168
   VCID: 3FDB4635AB7BB8636A1-806A
01037 - Electric Window Thermal Protection Active; Rear Right
                    Fault Frequency: 179
                    Reset counter: 52
                    Mileage: 249937 km
                    Date: 2020.06.28
                    Time: 19:17:20
End----------(Elapsed Time: 02:14, VBatt start/end: 13.7V/13.7V)-----------
ABS is completely off-line. You'll need to figure out why. Check fuses first.
The instrument cluster likely gets vehicle speed data from the ABS module in this car, rather than from a dedicated vehicle speed sensor.
Also please see: Where do I get a Wiring Diagram.
Mechanic09
Guyton, GA, USA
C?ID=409550
I have already checked the power, grounds and ABS sensors and other wiring. I just plugged in a ABS module that I picked up used and when i plugged it in on my scan tool it was providing information that the other ABS module would not. Would I be able to reprogram a used module to the car. I just dont have the long coding to try and reprogram. Thanks for the info.
Jef
HQ
Provided this other ABS module is a correct part number for the vehicle, then yes, we can provide the info you need to code it and the Basic Settings. Post a fresh Auto-Scan with the talking ABS and we'll go from there.
Mechanic09
Guyton, GA, USA
C?ID=409550
Friday,03,July,2020,17:35:27:24649
          65 72
53-Parking Brake -- Status: Malfunction 1010
               U0121 - 008 -  - Intermittent
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:46:03
                    RPM: 844 /min
                    Load: 24.3 %
                    Temperature: 67.0°C
                    Temperature: 35.0°C
                    Voltage: 13.589 V
               U0128 - 008 -  - Intermittent
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:46:03
                    RPM: 844 /min
                    Load: 24.3 %
                    Temperature: 67.0°C
                    Temperature: 35.0°C
                    Voltage: 13.589 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - MIL ON
                    Fault Status: 11100100
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:46:09
                    RPM: 839 /min
                    Load: 24.3 %
                    Temperature: 67.0°C
                    Temperature: 36.0°C
                    Voltage: 13.716 V
               P1653 - 004 -
                    Fault Frequency: 16
                    Load: 0.0 %
                    Temperature: 33.0°C
                    Temperature: 34.0°C
                    Voltage: 7.620 V
Readiness: 0110 0101
   Coding: 0000072
            013 - Check DTC Memory
                    Fault Frequency: 19
                    Reset counter: 0
                    Mileage: 52028 km
                    Date: 2008.08.15
                    Time: 14:26:14
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100006470
   Coding: 0010000
   Shop #: WSC 05100 444 59153
   VCID: 323D1F016829650B95F-8066
7 Faults Found:
                    Fault Frequency: 43
                    Mileage: 249937 km
                    Date: 2020.06.23
                    Time: 16:59:58
00532 - Supply Voltage B+
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:29
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:58
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:58
00716 - Air recirculation Flap Positioning Motor (V113)
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:11:58
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:21:00
                    Voltage: 8.15 V
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 14:23:00
                    Voltage: 8.50 V
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 14:24:00
                    Voltage: 8.45 V
                    Reset counter: 18
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:25:26
   Coding: 0012366
03032 - Supply Voltage for Seat Occupied Recognition Control Module
   Coding: 0002111
01426 - Controls in Steering Wheel (E221)
   Coding: 0007205
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:39
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:39
                    Fault Frequency: 6
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 14:23:39
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:14
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:46:01
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:46:01
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:29
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:47:57
                    Fault Status: 00100111
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:45:40
                    Fault Status: 00111000
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 20:47:58
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 58
   Coding: 0001463
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                    Reset counter: 58
                    Mileage: 9920 km
                    Temperature: 34.0°C
                    Voltage: 13.70 V
                    Voltage: 13.50 V
00003 - Control Module
                    Temperature: 34.0°C
                    Voltage: 4.70 V
                    Voltage: 5.60 V
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:17:17
   Coding: 0001462
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
                    Reset counter: 58
   Revision:   013
   Coding: 0010000
                    Fault Status: 11101101
                    Fault Frequency: 173
                    Reset counter: 18
                    Mileage: 249936 km
                    Date: 2020.07.02
                    Time: 17:33:03
                    Voltage: 13.04 V
                    Count: 236
                    Reset counter: 58
                    Mileage: 249936 km
                    Date: 2020.07.02
                    Time: 15:20:20
                    Voltage: 6.52 V
                    Count: 200
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 18
                    Voltage: 6.42 V
                    Count: 171
            000 - - - MIL ON
                    Reset counter: 18
                    Voltage: 6.42 V
                    Count: 170
   Coding: 0040401
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 14:23:47
                    Reset counter: 18
                    Mileage: 249937 km
                    Date: 2020.07.01
                    Time: 21:09:32
00874 - Treble Speaker Front Left (R20)
                    Reset counter: 18
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:16:14
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 18
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:16:14
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
00667 - Ambient Temperature Signal
                    Reset counter: 58
                    Mileage: 249937 km
                    Date: 2020.07.02
                    Time: 15:20:12
                    Fault Frequency: 255
                    Reset counter: 58
   Coding: 0001168
00935 - Electric Window Motor; Rear Right (V27)
                    Fault Status: 01100101
                    Reset counter: 18
End----------(Elapsed Time: 01:41, VBatt start/end: 13.0V/12.5V)-----------
Jef
HQ
For ABS coding, try 0013755. Then do the Basic Settings for the ABS module:
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3C)_Brake_Electronics
For EPB coding, try 0000013. After you code the EPB module, you will need to do the "Function Test":
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3C)_Parking_Brake#Basic_Setting
Do make sure you follow the rules of the game when playing with the EPB. If your electrical system (battery) is subpar, then you be:
Mechanic09
Guyton, GA, USA
C?ID=409550
Just wanted to give a update. I was able to code the used ABS module and now I have my speedometer working and parking brakes working. I need to actually mount the ABS module on the car. Just had Hernia surgery so it will be a minute before that happens. Thanks for helping.
Jef
HQ
Good to hear. Once you have everything buttoned up, please post a follow up Auto-Scan.
