Golf 7 2016 LOW to HIGH rear camera upgrade... what a mess!
darkchina811
ITALY
C?ID=333184
based on this autoscan I found here some time ago I decided to upgrade my RVC, so I bought the very same part number 5Q0 980 556 B
https://forums.ross-tech.com/showthread.php?22426-Golf-MK7-5-OEM-Towbar-Hitch
(this was a mistake, I did not research further and I did not consider the possibility that the guy also retrofitted it, since he has a "non calibrated" error... at least that's what I am assuming now...)
I bought the bare camera and replaced it into my swinging emblem. it took some drill and Dremel, as the mounting holes did not align perfectly with the bracket. VW does not endorse this, they treat the RVC together with the emblem as a whole assembly. I also had to run the CAN BUS line towards the 5F but it wasn't bad, I also took the chance to carry on forward the GPS antenna cable which was coiled up in the trunk behind the carpet.
anyways. camera came from an Audi car so I get in touch with a friend who has the other tool to load parameters, and we immediately notice there is no file for Golf with that camera. damn... let's load the file for a Passat.
file is loaded, we play a little with the coding and we manage to clear out all errors but calibration. alright, let's pull out the VAS6350 board and ODIS (offline)...
no way. calibration does not go through, actually the procedure runs very quickly and suddenly END OF TEST shows on the screen, DTC of course stays. my friend says there is something wrong, he did several HIGH RVCs on Audi cars and calibration was never a problem.
we start moving the board around, trying different codings, tryings different parameters, like Passat Variant instead of Limo. nope, calibration still doesn't finish correctly.
I start googling and digging harder and I end up on a german forum that has an endless thread about these RVC cameras. they mainly talk about Passat, and apparently this 556 B camera is a bitch, better to have a "no index" version, but you cannot flash this back because there is no file.
anyways, the sad discovery is that Golf is supposed to have a 5Q0 980 568 A (or B) camera. and again B is a bitch but there is a file available for the A index. reading further (with google translator) I learn that gateway and parking module versions are very important for making this retrofit a success. only some specific versions will happily talk to the camera.
now I have a 568 B camera coming, which I found really cheap online, I'll keep you guys updated. the plan is to flash it back to A index and load parameters, which are available for Golf. then try calibration again.
I would appreciate if in the meanwhile anybody had some insight about coding and stuff. I saw @hadez16 very active on the german forum, hopefully he'll see this and chime in.
@downtime already shared some knowledge, I reached out to him cause I was suprised to see a 556 camera in his stock autoscan, while ETKA says that part number should belong to Audi only.
darkchina811
ITALY
C?ID=333184
small update: 5Q0 980 556 was superseded by A index, then B. ETKA says they are only compatible with Audi but they are also mounted on other cars, like downtime's Tiguan. it's the same as the Golf, the catalog sees the whole assembly "trunk lid handle with camera" or "emblem badge with camera" so the part number becomes another.
I assume the very same for the 568 A/B camera.
Spacewalker
Poland
C?ID=159607
I use that camera and all is working over a year
Component: RVC Compact H12 0231
Coding: 0184420142002017000040
darkchina811
ITALY
C?ID=333184
can you post a full autoscan so I see coding for other modules as well? also, what file did you use for parameters to load with the other tool?
IWMTom
C?ID=313572
When I was looking into this issue myself (I retrofitted the same camera and couldn't calibrate it) I found a thread on this very forum where someone else was having the same issue and they eventually solved it by having a retrofit shop calibrate it using extra domino boards placed on a stand vertically.
Worth looking into.
stefan147
Greece
C?ID=361962
Same problem here. Only difference is that the Leon was never offered with the HIGH camera and this maybe adds extra complexity. Right now I have Octavia parameters but ODIS reads the camera as part of the Area View system and asks for VAS72something which is the Area View board for calibration. This happens if I let ODIS to auto scan or if I manually set the model to Octavia.
On the other hand if I manually set the model to Superb then ODIS reads the camera correctly as J772 and asks for the correct board VAS6430 but calibration still fails although I have the correct measurements for Superb. Maybe I must find a way to flash Superb parameters and try again.
This is a scan before flashing Octavia parameters. Before that half of the screen was showing my licence plate.
Coding: 0184020122002017000040
VCID: 392ED832F9D526E3545-806C
darkchina811
ITALY
C?ID=333184
haha I was looking for a path to a solution, not to introduce other variables which would rather complicate things :)
the 568 B camera is coming anyway, I'll see what happens with that one.
still waiting to hear back from Spacewalker and possibly hadez16 though...
downtime
Finland
C?ID=280813
Spacewalker has Touran? For that the 556 camera works. It can use Tiguan parameters if nothing else is found. Pretty much the same height and angle.
Thinking that should I try to replace the rear camera of our Leon with this one and see if I can calibrate it. Hmm hmmm hmmm
Spacewalker
Poland
C?ID=159607
My car is a wife Golf 7
99% You can not calibrate camera if DATA set is wrong
I did also Passat B8 camera , and yellow line was display so high (almost to the sky) , after proper dataset , yellow line get back to golf level , but camera lost calibrations
So I finally get golf 7 camera and did not touch any calibration or dataaset
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C
VIN: WVWZZZAUZFW205302   Mileage: 41583km-25838miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DE    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7774
   Revision: WAH10---
   Coding: 01190032232405082000
   Shop #: WSC 01342 020 12345
   ASAM Dataset: EV_ECM14TFS01104E906016DE 002006
   ROD: EV_ECM14TFS01104E906016DE_VW37.rod
   VCID: 689C5D0E93DAB40F0F-803C
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 63374000000767
   Coding: 01FA6AA124202971077A060041C52980562494E0608294F300200078C002
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7EB01B56E15E1ABFD5-802A
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00020004200100001000000000000000
   VCID: 3C34D15EB7C2C8AFBB-8068
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011433701787
   Coding: 00000A42C24122730BA44080B10C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 004C65AE9BAA6C4FA7-8054
   Component: WWS    140719  043 0551
   Serial number:         140726190131
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y14M12D10H17M35S39
   Coding: 05A8DD
   Serial number: 000000000ZY143212GFC
   Serial number: 00000000000061173199
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391433514013
   Coding: 0031151001
   Shop #: WSC 19460 666 12345
   VCID: 3D32DC5AACD8C1A78C-8068
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0E3NTY
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41CAA0AAD020A547E8-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 212 14
   Serial number: 35767000000D2B74321S
   Subsystem 2 - Part No SW: -----------    HW: 480 000 412 14
   Serial number: 35867000000B5BE0321X
   Subsystem 3 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3516502A7188FC24917K
   Subsystem 4 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3526502B318B3A71E22A
   Subsystem 5 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3556502A118B3AB393AK
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 05121408490885
   Coding: 0400
   VCID: 75A2047AD46859E784-8020
   Part No SW: 5G1 920 791     HW: 5G1 920 791
   Component: KOMBI         405 2153
   Coding: 07F579002B0000080708FF001400002000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 699A580A88D08D0710-803C
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0002818375
   Coding: 030100042F085700EF000048080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CB4115EF74208AFFB-8028
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002727390084496
   Coding: 28FFFF
   Serial number: 1945735203
   Component: TSG FS        010 0031
   Serial number: 0000206925339
   Coding: 00370220D000040000001000
   VCID: 47DEBEB2FE049B7726-8012
   Serial number: 00000000000004643923
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43C6AAA2CA3CB757FA-8016
   Serial number: 021214BL211212
   Coding: 003700209E00040000801000
   Serial number: 00000000000004670226
   Coding: 090000
   Coding: 029A000001000000
   Part No SW: 5NA 035 042 D    HW: 5NA 035 042
   Component: MU-H-LN-EU    H54 1367
   Serial number: A847K0HS015112
   Coding: 02730001FF00000001110001000808006F0103A401200405FE
   VCID: 3620C37689EE12FF4D-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV1620503
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Shop #: WSC 05311 115 00066
   VCID: 393AC84AB8F0FD87A0-806C
End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
darkchina811
ITALY
C?ID=333184
yes, the friend who helped me had the same theory, calibration is not possible because dataset is wrong. but there is no file for 555 B on Golf. so we used Passat file...
I read your post four times and I am still confused, how did you make it work? what dataset did you use?
or are you saying that you bought used 556 B camera from a Golf which had it from factory? if so, can you tell me that VIN ?
stefan147
Greece
C?ID=361962
You mean that dataset MUST match with the car in order to get it calibrated? Or just find the dataset which is closest to your car measurements? For example for the Leon I could take the camera off and mount it on Superb height and try to calibrate it. Wouldn't that trick ODIS?
darkchina811
ITALY
C?ID=333184
I got the 568 B camera and easily downgraded to A index with ODIS-E, the flash file is on the erwin flash disc.
the camera has no parameters and I need to meet with my friend again, he's got the other tool. I could do parameters with ODIS if I could find a VIN of a Golf with the camera from the factory. there is no such VIN on the whole internet according to google. damn.
today I also received both calibration boards, RVC and A5 front camera. it was stupid cheap to have them printed on PVC by an online print shop :)
will keep you guys updated...
Spacewalker
Poland
C?ID=159607
Not sure, i not play with "some data"
i play with proper data only
darkchina811
ITALY
C?ID=333184
I reached out to my friend today and installed the 568 A camera into the badge. loaded parameters with the other tool and calibration was successful at first attempt. now I got zero errors so I consider the retrofit complete. I will update the autoscan in the non-broken section.
however I am still curious as how Spacewalker has the 556 B camera on a Golf, and both my friend and I were not able to make it work.
IWMTom
C?ID=313572
Great to hear!
I don't suppose you documented the butchering of your old swinging emblem did you? Would like to try and do this myself as I have the same issue you had.
Is it particularly difficult to swap the camera modules out?
darkchina811
ITALY
C?ID=333184
https://www.drive2.com/l/506405644891324874/
I didn't because somebody else did of course :) here you go, you'll notice how the fixing for the cameras on the rear are different, and that is where you'll need to get creative.
I managed to fix it with one tiny screw only, instead of two, but it's holding pretty well.
I assume the inside of the Golf 7.5 emblem is a little different to accomodate the HIGH camera.
tonight I played a little bit with the coding, because Spacewalker and some other codings were a little different.
I tried different bits and everything is accepted, but I am not sure what they do, some are not documented.
maybe a test drive tomorrow will reveal something.
IWMTom
C?ID=313572
Thanks, that's super useful!
stefan147
Greece
C?ID=361962
So I'm coming back to that since I managed to calibrate the notorious 556B camera on a LEON. I always thought that ODIS can be tricked but it was a matter of countless efforts to actually find the measurements that would trick ODIS and provide realistic camera lines at the same time.
For the record it goes like this:
  • Octavia III hatchback parameters
  • Manual car selection in ODIS, Octavia 2018
  • Select the camera as 6C and not 006C which is the Top View camera (if someone needs help with that PM me)
  • Place the VAS6350 board 1300mm from the rear axle and a bit off center to the left of the camera
  • Begin the calibration procedure by putting the gear selector to R and then giving these measurements:
  • 600mm camera height (that is actual height for a Leon Cupra with stock suspension)
  • 1340mm distance from rear axle (a bit fake in order to trick ODIS)
  • Board height is up to you, in my case it was 10mm since I have the VAS stuck on a cardboard
  • Let the procedure begin the countdown, it should take less than 20"
And there you go!
   Coding: 04030101A2002017000060
   VCID: 392ED832F9D526E374D-806C
I hope this helps someone.
