So Ive been having some issues with the car here for some time and have been unsuccessful at figuring it out.
My ABS module intermittency loses the steering angle sensor and sets the 01826 steering angle code.
I know it normally means the rack with the steering sensor needs to be changed, so Ive installed 2 used racks and have put 4 used ABS moudles in the car and the issue stiil exists.
Over the weekend I hooked up VCDS to do an auto scan and came up with numerous errors and codes as well as sporadic communication errors.
Now as soon as I started the car and redid the auto scan, all these error's disappeared.
I am starting to think my issues are due to CAN Bus issues but I'm not sure?
Does anyone have ideas on this one?
Saturday,27,June,2020,13:14:07:33238
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWTL71K89M263079 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWTL71K89M263079 Mileage: 273980km-170243miles
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
1C-Position Sensing -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 8680
Revision: 12H01--- Serial number: VWX7Z0H524I095
Coding: 0050072
Shop #: WSC 84224 299 591528
VCID: 3D273EB08179B38378D-8068
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 273957 km
Time: 06:42:38
RPM: 828 /min
Temperature: 43.2°C
Temperature: 92.7°C
Temperature: 27.0°C
Lambda: 63.1 %
Lambda: 0.0 %
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B400D492700FE880C02E9921D00423000
Shop #: WSC 41669 001 104857
VCID: 7EA5F9BCC0FF689B217-802A
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D78486AB0EEBA3B-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009264211
Coding: 10018E234004100007140000001400000008730B5C000120000000000000
Shop #: WSC 53316 000 1048576
VCID: 323D1D8C48277CFB95F-8066
Component: Wischer 190309 021 0501
Coding: 00038805
Shop #: WSC 53316
8 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
Fault Status: 00111001
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Fault Status: 00101001
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Reset counter: 89
Mileage: 273667 km
Voltage: 12.65 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7I0532598
Coding: 0000102
Shop #: WSC 00066 000 00000
VCID: 33331888B73D75F39E9-8066
00003 - Control Module
Fault Status: 00101110
Reset counter: 6
Mileage: 36521 km
Time: 14:55:18
Reset counter: 45
Mileage: 273357 km
Time: 14:35:11
01304 - Radio
Reset counter: 57
Mileage: 273869 km
Time: 22:06:04
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 2U AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08Y5PW
Coding: 0012885
VCID: 6D87CEF09199E30388D-8038
Subsystem 1 - Serial number: 6332MSME43511211W
Subsystem 2 - Serial number: 6342MSME4454272FF
Subsystem 3 - Serial number: 6351HSME1C0C494FO
Subsystem 4 - Serial number: 6361HSME1B790871C
Subsystem 5 - Serial number: 63727SME1B74466BA
Subsystem 6 - Serial number: 63827SME1B751E617
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000331
VCID: 76B5E19CE4CF20DB797-8022
Component: E0221 002 0010
Part No SW: 1K0 920 874 D HW: 1K0 920 874 D
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I224B0EN
Coding: 0023303
VCID: 2E0509FC5C1F581BF17-807A
Reset counter: 89
Mileage: 273667 km
Time: 00:08:13
Reset counter: 89
Mileage: 273667 km
Time: 00:00:05
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 180209F2001694
Coding: E9807F06001702001002
VCID: 372B2C98A34599D3A21-8062
11 Faults Found:
Fault Status: 00110100
Reset counter: 89
Mileage: 273667 km
Time: 00:08:14
Reset counter: 89
Mileage: 273667 km
Time: 00:08:14
Reset counter: 89
Mileage: 273667 km
Time: 00:00:02
Reset counter: 89
Mileage: 273667 km
Time: 00:00:01
Reset counter: 89
Mileage: 273667 km
Time: 00:00:01
Reset counter: 89
Mileage: 273667 km
Time: 00:00:01
Reset counter: 89
Mileage: 273667 km
Time: 00:00:01
Reset counter: 89
Mileage: 273667 km
Time: 00:00:01
01304 - Radio
Reset counter: 45
Mileage: 273357 km
Time: 14:37:02
Reset counter: 45
Mileage: 273357 km
0 Date: 2000.00.00
Time: 14:37:02
00484 - Vehicle Position Recognition Control Module (J603)
Reset counter: 89
Mileage: 273667 km
Time: 00:00:05
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T413504
Coding: 0000003
VCID: 392F2AA095518FA3545-806C
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000805689208
Coding: 0001205
VCID: 6FBBD4F89B951113BA1-803A
Fault Status: 00100101
Reset counter: 91
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 01101100
Fault Frequency: 54
Reset counter: 61
Mileage: 273357 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0D05EC60F7343B2DF-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 13900F880106281B0904058FB0880F0488FC00
Shop #: WSC 03285 999 14509
VCID: 71BFD2808DA107E3AC5-8024
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08120722582603
Coding: 0001204
Address 56: Radio
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003800031
Coding: 0001168
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003874453
Coding: 0001168
VCID: 77ABEC98E3C559D3621-8022
Address 77: Telephone
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
