Soot mass jumping causing frequent regens.
Humbucker
England
C?ID=403224
Hello all,
I have a 2015 2.0 Passat GT Estate with just over 92,000 miles. The car runs great but lately its regening every 40 miles.
The soot mass drops after regen and it jumped from 6.51g to 23.28g in 1 mile causing it to regen again.
I have just bought a Hex-V2 from Gendan UK and have registered it just now and have completed a scan.
I know about the Air con as it has a very small leak thats getting repaired shortly, the TPMs:- had a slow puncture fixed today.
From the scan what parts are required to sort out the frequent regens.
Also whats the fault:-8531970 - Quiescent Current U1406 00 [008] - Too High
Many Thanks.
The scan is with the engine running.
Saturday,27,June,2020,15:51:01:50295
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZFE468976   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F BB BC
VIN: WVWZZZ3CZFE468976   Mileage: 149322km-92784miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1147
   Revision: B5H21---
   Coding: 01190012034505083000
   Shop #: WSC 05311 115 00315
   ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
   ROD: EV_ECM20TDI01104L906026AS_VW48.rod
   VCID: 7BA3F2C7F36927A3069-802E
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
5158 - Diesel Particulate Filter; Differential Pressure Sensor
          P2456 00 [096] - Intermittent
19226 - Particulate Trap Bank 1
          P2002 00 [096] - Efficiency Below Threshold
                    Mileage: 148570 km
                    Date: 2020.05.16
                    Time: 10:27:03
                    Engine speed: 1791.50 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 88 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 93 °C
                    Voltage terminal 30: 14.340 V
                    Unlearning counter according OBD: 22
                    Exhaust mass flow of low-pressure EGR: calculated: 3.021
                    Differential pressure ratio: low-pressure EGR: 50.1 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: -7.1 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: -4.2 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 50.18 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 53.32 %
9764 - Exhaust Pressure Sensor 1
          P0470 00 [032] - Malfunction
5253 - Diesel Particle Filter; Differential Pressure Sensor
          P2452 00 [032] - Elect. Malfunction
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60425000000003
   Coding: 0FEC928F34260B740780060741C949F0492CD0E0608292F11460F078C002
   VCID: 7EA5FBD3E07B328B217-802A
16388 - TPMS Display
          C1146 F0 [008] - Not Available
                    Reset counter: 242
                    Mileage: 146766 km
                    Date: 2020.01.16
                    Time: 16:53:31
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 3
                    Mileage: 147889 km
                    Date: 2020.03.21
                    Time: 10:00:26
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0524
   Revision: 00023000    Serial number: 0360369354
   Coding: 000F0F0603
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 77ABEEF7CF4103C3621-8022
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Revision: 00001K10
   Coding: 12120104202100012015500000101802
   Shop #: WSC 00015 115 00001
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6D87CC9FBD1DB91388D-8038
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [008] - Too Low
                    Reset counter: 251
                    Mileage: 148276 km
                    Date: 2020.04.22
                    Time: 14:23:43
                    Outside air temperature: 21.5 °C
                    Engine speed: 900 /min
                    Temperature after evaporator: 26.0 °C
                    System run time-Engine running time: 3 s
                    System run time-Terminal 15 on: 6 s
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580502150601
   Coding: 03010A46C24102FF0B844084B11407281880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA7FCDFED7D299338D-8028
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150126  043 0607
   Serial number:         150130021803
   Component: RLHS  037 0059
   Serial number: S5Y15M02D18H03M01S54
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 02 12 2014  00000555
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150200LZJ
   Serial number: 00000000000061573929
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 25
                    Mileage: 147211 km
                    Date: 2020.02.10
                    Time: 09:27:01
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391504009743
   Coding: 0071051001
   Shop #: WSC 05311 115 00095
   VCID: 40D9452BDA0F847B13B-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 2A40608110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33331AE79BB92FE39E9-8066
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P1LQLLH
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015F802F91854D735C5-8054
   Belt Pretensioner left:
   Serial number: 3G2857705C0041P00014
   Coding: 80000A
   Belt Pretensioner right:
   Serial number: 3G2857706C0038P00156
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 000 302 15
   Serial number: 3576U0000000DB052310
   Subsystem 4 - Part No SW: -----------    HW: 454 000 302 15
   Serial number: 3586U0000004CA052313
   Subsystem 5 - Part No SW: -----------    HW: 454 801 502 15
   Serial number: 3516R5CA20F060000006
   Subsystem 6 - Part No SW: -----------    HW: 454 801 702 15
   Serial number: 3526RAA20D5050000002
   Subsystem 7 - Part No SW: -----------    HW: 454 800 102 15
   Serial number: 3556V5C73CC05000000K
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150212400228
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273CDFADFDE99378D-8068
   Part No SW: 3G0 920 951     HW: 3G0 920 951
   Component: KOMBI         308 4311
   Coding: 27A409102F80260001886A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6491A9BB6ED7F85BD73-8030
   Revision: --------    Serial number: 08021510800989
   Coding: 030300044F087300EF00025C080F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDDFE3A42366EB55F-8026
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000178070085054
   Coding: 2CFFFF
   Serial number: 8928485703
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 2801201500010207
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 228
                    Reset counter: 27
                    Mileage: 146284 km
                    Date: 2019.12.22
                    Time: 00:43:01
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Serial number: 15000013555013
   Coding: 0000000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD0EFA1255DF3AC5-8024
   Serial number: 080215BB718916
   Coding: 003F0A20D001028000001000
   VCID: 42DD4F23D403966B05F-8016
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00315
   VCID: 43D34A27CB199F630E9-8016
   Serial number: 310115BAU19825
   Coding: 003F0020D001028000001000
   VCID: 41DF402FD1058D731C5-8014
   Coding: 03DE000009000000
   Shop #: WSC 05311 000 00001
   VCID: 75B7E4FFD54D71D370D-8020
   Part No SW: 3Q0 035 874     HW: 3Q0 035 874
   Component: MU-S-ND-ER    H10 0138
   Serial number: VWZAZ2R8523334
   Coding: 02840201FF00000011111201000808001F0100C601200100CC
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6FBBD697B7114B03BA1-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H42 1017
   Serial number: VWZ8Z9RD8011WC
   Subsystem 2 - Part No SW: 3G0 919 866 E    HW: -----------
   Component: ECE 2015  --- 0335
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 280115BAR1323C
   Coding: 000E00200101028000001000
   VCID: 44D1493BCE17985B373-8010
   Component: TSG HBFS      020 0028
   Serial number: 280115BAR11842
End----------(Elapsed Time: 02:02, VBatt start/end: 14.5V/14.4V)-----------
Looks like you have some wonkiness with the pressure sensors.
First thing to do: Check the tubes between the sensors and the exhaust for integrity (no leaks) and verify that they are not blocked.
PS: Got you Verified, moving this to Car Repair Support.
It means current draw from the battery is higher than expected when everything is (ostensibly) shut down.
Humbucker
England
C?ID=403224
Cheers for the reply,
I think this might be due to the Tracker fitted.
Thanks again
Humbucker
England
C?ID=403224
Thanks Uwe for the verified,
Will look at the pressure sensors when I locate them, more pipes and sensor than my B5 passat.
If I end up replacing the pressure sensors is it just a straight swop or do i have to recalibrate the new ones.
Thanks again.
There's usually a calibration involved for the differential pressure sensor at least. But you shouldn't throw parts at the car until you've done the basic checks I recommended previously.
Humbucker
England
C?ID=403224
Update
I managed to have a look at the car when the rain stopped (Northern England been raining for over a week)
I also have done some reserch into this fault and some had the same issue after a cambelt change, and mine had one a few weeks ago.
I have removed the the pressure sensors and blew down the pipes that go to the DPF with little to no resistance down either.
I have checked for any split pipes as far as i can see.
I blew into both pressure sensors.
Checked the resistance on all 3 pins and both senors measure the same across two sets of pins pin 1 - 2 : Pins 1 to 3 : Pins 2 to 3
I replaced the sensors and the soot mass has stopped jumping.
Before it jumped from 50% sootmass to 100% sootmas after 1 mile
Now its not jumping but will see how it goes on and feed back after a few weeks.
Dont Know why it seems ok at the moment, may be blowing has disturbed some contamination.
I have seen a few people with the same fault but no one has said what they did to cure the fault.
Lubo1980
Slovakia
C?ID=339979
Hi,
I have the same problem with soot mas calculated jumping, I also replaced the sensors and the soot mass calculated has not stopped jumping :-(
When you checked the resistance on all pins - what values have you measured ?
Thank you.
