Octavia Mk2 FL headlight voltage low
Fatbloke
Scotland
Hi All
My headlights on the Octavia are dim. I tried different bulbs, higher wattage bulbs and LED bulbs. The LED bulbs are slightly better but the lights are still dim. They used to be good but I had an accident and a new headlight unit and seemingly some electrical/electronic control unit for the headlights was replaced. They have been dim since then.
I checked the voltage at the headlight bulb power plug and it shows 11.7v. This seems a bit low.
How can you adjust the headlight voltage?
Fatbloke
Scotland
Not sure, assume full charge but will check it.
So that was with engine not running?
Check with key on, engine off, and check battery voltage in that condition.
Then check it again with engine running, and check battery voltage in that condition.
Some voltage drop through the wiring and the BCM is inevitable, but the question is: How much voltage drop much do you have?
Fatbloke
Scotland
Thanks Uwe. I checked it today. Battery was 12.2v with engine off. 11.5v at headlight.
Checked with engine running, 14v at tickover and 13v at headlight so seems voltage is not the issue.
Where do I check or adjust it via VCDS? Anything else I can check?
That sounds like a normal/reasonable amount of voltage drop, and not the BCM actively reducing the voltage to the lights, so I rather doubt there's anything you can adjust to make them brighter.
DV52
C?ID=194404
fatbloke (me too!!): have I missed your response to Uwe's request below?
Please post an Auto-Scan for context.
I'm a firm believer in the adage "a picture is worth a thousand words", but in this forum an autoscan speaks volumes about both the car and its associated issues because it enables the rest of the forum community to understand the installed equipment - which defines the context (as Uwe says) for the problem to be solved!!
Fatbloke
Scotland
I have taken new scans. Before and after errors cleared. I still need to replace alarm siren battery.
Sunday,28,June,2020,10:40:09:62090
VCDS Version: 20.4.1.0 (x64)
VIN: TMBEH21Z8A2   License Plate:
Mileage: 152750km-94914mi   Repair Order: 28062020-1
Chassis Type: 1Z-SK35 (1K0)
VIN: TMBEH21Z8A2   Mileage: 152750km-94914miles
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RD    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000SG  5751
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 00642 210 45725
   VCID: 78FE6A4C0B21C14633-802C
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 163B601C09290003681306E890220082340800
   Shop #: WSC 73430 790 00999
   VCID: 78FE6A4CCB21C14633-802C
02214 - Tire Pressure Warning
                    Reset counter: 201
                    Mileage: 151405 km
                    Date: 2014.04.10
                    Time: 15:29:32
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 52528
                    Count: 65024
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 03040DA08AE7929E16-8056
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8560800440040000
   Shop #: WSC 20014 576 89718
   VCID: 326A98646DDDEB16CD-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 16120  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
01134 - Alarm Horn (H12)
                    Reset counter: 107
                    Mileage: 138925 km
                    Date: 2012.12.14
                    Time: 13:34:32
                        Term 15 On
                    Voltage: 12.30 V
                        Term 50 Off
                    Fault Status: 01100010
                    Reset counter: 184
                    Mileage: 140481 km
                    Date: 2013.03.19
                    Time: 07:48:26
                        Term 15 Off
                    Voltage: 14.45 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 193
                    Mileage: 152040 km
                    Date: 2014.06.11
                    Time: 10:35:10
                        Term 15 On
                    Voltage: 11.70 V
                        Term 50 Off
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2HS0W%
   Coding: 0020788
   VCID: 3D70BB586483246E20-8068
   Subsystem 1 - Serial number: 6332MSME4C602D7CR
   Subsystem 2 - Serial number: 6342MSME4E634629K
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 03040DA042E7929E16-8056
   Part No SW: 1Z0 920 943 J    HW: 1Z0 920 943 J
   Component: KOMBI         H05 0305
   Coding: 410B00
   Shop #: WSC 73430 031 00999
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 408EC2ACDB7149864B-8014
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K09C190630
   Coding: E9807F06000202001303
   VCID: 69D83F08408B68CEBC-803C
                    Fault Status: 00101011
                    Fault Frequency: 34
                    Reset counter: 224
                    Mileage: 150369 km
   Component: IMMO          H05 0305
   VCID: 6ADA40048D8D63D6B5-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 489EDA8C3B4171C683-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 31689768A8DBD00EB4-8064
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479CD9B0365F7EBE8A-8012
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8180238
   Coding: 050004000001
   VCID: 3560A3789CB3FC2EE8-8060
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326A9864ADDDEB16CD-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33649D6052C7E21EC6-8066
End-------------------------(Elapsed Time: 01:56)--------------------------
   Coding: 0001072
   Revision: 00H30001
   Revision: 00005001
   Coding: 0000000002
   Revision: 00103 AG
   Coding: 00D7B7
                    Reset counter: 184
                    Mileage: 152750 km
                    Date: 2014.11.19
                    Time: 10:44:22
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 184
                    Mileage: 152750 km
                    Date: 2014.11.19
                    Time: 10:44:22
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 Off
   Coding: 0020788
   Coding: 0000034
   Coding: 410B00
   Coding: 0000756
   Revision: 00H17000
   Coding: 0000756
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 01:47)--------------------------
OK, so that BCM does have "Headlight Dimming (Life Time Extension)" in Byte 19 of its coding. It is already set to 13.6V, which is the maximum. You might try setting it to "Inactive" to see if that changes anything.
PS: Ain't it amazing what we can find when we know exactly what control modules are in a car? ;)
Fatbloke
Scotland
Thanks Uwe. I will check that out.
Fatbloke
Scotland
Car been out of use for a while and battery died. replaced with spare battery and have had a few runs in it.
The lights are still very dim, in fact they seem worse. Like candles.
I have eventually connected up VCDS and found byte 19 and set front and rear to inactive.
The headlights are still very dim.
Please see the scan below.
Saturday,12,December,2020,14:21:10:62090
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
VIN: TMBEH21Z8A2079849   License Plate:
Mileage: 153500km-95380mi   Repair Order: 12122020
VIN: TMBEH21Z8A2079849   Mileage: 153500km-95380miles
   Coding: 0001072
   VCID: 78FE6A4C0B21C1443A-802C
   Revision: 00H30001
   VCID: 78FE6A4CCB21C1443A-802C
                    Reset counter: 247
                    Mileage: 153216 km
                    Date: 2015.02.14
                    Time: 12:32:46
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 51762
   Revision: 00005001
   Coding: 0000000002
   VCID: 03040DA08AE7929C1F-8056
   Revision: 00103 AG
   VCID: 326A98646DDDEB14C4-8066
   Coding: 00D7B7
                    Reset counter: 184
                    Mileage: 152750 km
                    Date: 2014.11.19
                    Time: 10:44:22
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 Off
                    Fault Frequency: 61
                    Reset counter: 0
                    Mileage: 152750 km
                    Date: 2014.11.19
                    Time: 10:44:22
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 252
                    Mileage: 153397 km
                    Date: 2015.04.20
                    Time: 17:41:11
                        Term 15 On
                    Voltage: 9.10 V
                        Term 50 Off
                    Reset counter: 252
                    Mileage: 153397 km
                    Date: 2015.04.21
                    Time: 14:13:06
                        Term 15 On
                    Voltage: 8.70 V
                        Term 50 Off
                    Reset counter: 252
                    Mileage: 153397 km
                    Date: 2015.04.22
                    Time: 14:02:57
                        Term 15 On
                    Voltage: 10.55 V
                        Term 50 Off
                    Reset counter: 252
                    Mileage: 153397 km
                    Date: 2015.04.22
                    Time: 14:06:55
                        Term 15 On
                    Voltage: 8.05 V
                        Term 50 Off
   Coding: 0020788
   VCID: 3D70BB586483246C29-8068
   Coding: 0000034
   VCID: 03040DA042E7929C1F-8056
   Coding: 410B00
   VCID: 408EC2ACDB71498442-8014
   VCID: 69D83F08408B68CCB5-803C
                    Fault Frequency: 14
                    Reset counter: 0
                    Mileage: 152801 km
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: 6ADA40048D8D63D4BC-803E
   Coding: 0000756
   VCID: 489EDA8C3B4171C48A-801C
   Revision: 00H17000
   VCID: 31689768A8DBD00CBD-8064
   Coding: 0000756
   VCID: 479CD9B0365F7EBC83-8012
   VCID: 3560A3789CB3FC2CE1-8060
   Coding: 0000144
   VCID: 326A9864ADDDEB14C4-8066
   Coding: 0000144
   VCID: 33649D6052C7E21CCF-8066
End-------------------------(Elapsed Time: 01:51)--------------------------
Well, if headlights are still very dim, then it's time to try to find the voltage drop using a meter. It could be anywhere between the battery and the ground point(s) for the headlights.
If you're still getting those voltages then the problem isn't voltage or BCM playing games - so IMHO the only thing left to try/change is the bulbs.
Are they original bulbs? I would suggest getting some extra bright (but road legal) bulbs such as Osram Night Breaker or Philips X-treme Vision.
If they're no better then are the headlamps discoloured? - that's not unusual after several years.
If neither of those help, then it's just Halogen bulb brightness IMHO - are you used to HID (Xenon) headlights in another car?
Fatbloke
Scotland
it was fine a while back with 100w halogen in it. I had a bump and one of the light units was replaced along with suspension struts etc and they also had to replace some electrical board for the lights that was welded in. Not quite sure what tha board was.
When I got it back, the lights were very poor with 55w and 100w bulbs in so I put a set of 55w (each) LED bulbs in. They were very slightly brighter.
There is no discolouration in the light units, they both look perfect. I tried several different bulbs and they are all very dim.
I will have a go at testing with the meter.
I had a bump and one of the light units was replaced along with suspension struts etc and they also had to replace some electrical board for the lights that was welded in. Not quite sure what that board was.
That MIGHT explain one light being dimmer/brighter than the other but not both being dim.
What it does raise is the question of headlight aim, are they aimed correctly - not too low?
Note (ignore if you wish) in the UK 100W bulbs are not street legal, nor is ftting LED bulbs into headlamps that are not approved for them (which Octavia headlamps are not).
Since you're already done that I don't expect that will show anything new.
Well, he hasn't really. He's determined that he only has 11.7V at the headlights. He hasn't located the source of the drop. If the battery is at ~14V with the engine running, there's 3V of drop somewhere.
Seems like he has checked the voltage drop - there is 0.7V drop with the engine off and 1V with the engine running :thumbs:
RogerP1952
C?ID=244770
How are you measuring the voltage at the headlights, to the earth connector at the headlight or to the body somewhere else?
I'd also be interested in the voltage across the actual bulb terminals.
  • Agree
