hi i was wondering how to read live actual boost pressure, on the convential scanner or on the mobile app. thanks
Friday,24,April,2020,15:18:38:57428
VCDS Version: 20.4.0.1 HEX-NET CB: 0.4508.4
Dealer/Shop Name: MC Auto Tech
VIN: WVWRF7AJ5CW219303 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
56
VIN: WVWRF7AJ5CW219303 Mileage: 168460km-104676miles
Address 01: Engine (CRZ) Labels:. 06F-907-115-CDL.clb
Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH20--- Serial number:
Coding: 0403010A180F0160
VCID: B4248A9FD7DBBB2656-80E0
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected
Fault Status: 01100001
Mileage: 168423 km
Date: 2014.09.11
Time: 11:25:42
RPM: 795 /min
Load: 19.6 %
Speed: 5.0 km/h
Temperature: 58.0°C
Temperature: 6.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.605 V
Readiness: 0000 0001
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 144B800C49238003280E01E4921C0141B70000
VCID: FBB661A37A05B45ED7-80AE
Fault Status: 00101101
Reset counter: 56
Mileage: 167910 km
Date: 2014.08.17
Time: 21:48:13
Count: 2
Count: 13056
Count: 8193
Count: 42496
Count: 256
Count: 768
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 1
Mileage: 167910 km
Date: 2014.08.17
Time: 21:48:13
Count: 2
Count: 13056
Count: 16401
Count: 42496
Count: 256
Count: 768
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0161200323
Coding: 030C0C
VCID: B4248A9F1FDBBB2656-80E0
1057291 - Antenna for Keyless Entry System; Passenger Side
B1170 13 [008] - Open Circuit
Reset counter: 63
Part No SW: 5K0 907 044 FE HW: 5K0 907 044 FE
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000001002
VCID: F3A649835A55FC1E8F-80A6
Part No SW: 1K0 937 084 G HW: 1K0 937 084 G
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 6F180ABB90252A04108800C170000C444A052186574D8DB0E48420248040
Shop #: WSC 08158 444 99999
VCID: B2288C87EDCFB51644-80E6
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 09121 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA13YLH
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: BFCED5B3269D687EBB-80EA
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002FM600
Serial number: 3572MSME5E312265ZZZV
Serial number: 3582MSME2B012466ZZZQ
Serial number: 3512QSME4E3A6443ZZZ$
Serial number: 3522QSME444D6443ZZZY
Serial number: 35527SME542E7929ZZZS
Serial number: 35627SME0B4C4329ZZZM
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111209100797
Coding: 100A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: FDB26FBB6C11BA6EE9-80A8
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Part No SW: 5K6 920 972 E HW: 5K6 920 972 E
Component: KOMBI H04 0617
Coding: 270F01
VCID: B83CBEAF03B35F467A-80EC
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 081211F1002806
Coding: 350000
VCID: BA38A4A735BF4D568C-80EE
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: C5C2C75B8C4132AEF1-8090
Component: IMMO H04 0617
Coding: 000007
VCID: EA9854E70D9F3DD63C-80BE
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000277746001
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: AE1098F7F1F791F620-80FA
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661486559
Coding: 020000
VCID: A91A6BEBC019F6CEF5-80FC
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H33 0265
Serial number: VWZAZ2L8484783
Coding: 04050001010005000000100A
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: A30679C3AA352C9EBF-80F6
Component: NAR_V2 0002
1048667 - Antenna for Satellite Radio
B10F4 13 [009] - Open Circuit
Reset counter: 22
Mileage: 155581 km
Date: 2017.08.17
Time: 00:25:59
B11CF 53 [009] - Deactivated
Reset counter: 22
Mileage: 155581 km
Date: 2017.08.17
Time: 00:25:58
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: B12A838B28C98E0E3D-80E4
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 251 3201
Revision: 00H20000
Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
Component: KonzernAmp 8K H07 0368
Revision: -------- Serial number: EAA085A0008718
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: A91A6BEBC819F6CEF5-80FC
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: B2288C872DCFB51644-80E6
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 1479708
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
00497 - Sensor for Vehicle Leveling; Rear
Fault Status: 11101010
Reset counter: 53
Mileage: 155581 km
Date: 2017.08.17
Time: 00:25:59
Voltage: 11.79 V
ABS 1
End----(Elapsed Time: 01:09, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
