2016 tiguan NAR to euro tail lights
vaskoto1
Bulgaria
C?ID=67648
hi guys. i have some trouble...
customer came to me with a tiguan 2016, imported from america. naturally with american taillights. turn signal and brake light are one. me, personally, i like this a lot, but here it's not allowed... so i have to convert it to euro tail lights with amber turn signals. i found out that in the connector there are swithced positions of turn signal, and nothing is connected to actual brake light. actually turn signal is connected to brake light bulb. i swithced them over and added a cable for the brake light. everything is in place now. signal for the brake light i got from the connector of the hitch, which is not used-there is no hitch module attached. and now i can not tell the bcm to separate the brake lights from the turn lights, and use the actuall brake light with the side marker light back, instead of using dialed down turn signal to complete the side marker...
i really hope you understood my sloppy description...
here is the autoscan of the vehicle:
Wednesday,18,March,2020,12:37:54:50573
VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
VIN: WVGBV7AX9GW581063   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 4F 52 53
          55 5F 62 72 75
VIN: WVGBV7AX9GW581063   Mileage: 51910km-32255miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 1335
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0160
   VCID: 025D8D2CE80349C7DF1-8056
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 074B9C38C3216CEF88F-8052
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD3B 0021
   Revision: --H07---    Serial number: 00000009090795
   Coding: 0005161
   VCID: 78A9EFC4BEDF1317F15-802C
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0390428734
   Coding: 030C0C
   VCID: 372B2CF8FFC1DC6F38F-8062
133124 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Ausfall mBSG3-Botschaft - kein Signal/Kommunikation]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:47
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
          [Weckleitung vom Steuergerät für Zugang- und Startberechtigung Unterbrechung/Kurzschluss nach Masse]
                    Reset counter: 99
   Part No SW: 561 907 426 G    HW: 561 907 426 G
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1F1BE4587731842FD0F-804A
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 12:13:37
   Part No SW: 5K0 937 086 AB    HW: 5K0 937 086 AB
   Component: BCM PQ35 M    122 0183
   Revision: BJ122001
   Coding: EF1A0A1B80232EC4018800C114000D4448F50006566D8DB0E4840000A040
   VCID: 74B1DBF4AEB77777DDD-8020
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 081215  24  0664
   Coding: 009795
   Component: RLS 090116 05  54  0403
   Coding: 02304D
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 59
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 12:02:53
                    Voltage: 12.25 V
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 59
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 12:02:53
                    Voltage: 12.25 V
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAP095SU3
   Coding: 0012341
   VCID: 7DA7FED091FD363FA23-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000RML1
   Subsystem 3 - Serial number: 0029.10.150000300000630130ÿ†63
   Subsystem 4 - Serial number: 630130ÿ†6332MTS687933515Bÿ†63
   Subsystem 5 - Serial number: 33515Bÿ†6342MTS615433515+ÿ†63
   Subsystem 6 - Serial number: 33515+ÿ†6351HTS6AQQP1EKJLÿ†63
   Subsystem 7 - Serial number: P1EKJLÿ†6361HTS6F8D53EKJLÿ†63
   Subsystem 8 - Serial number: 53EKJLÿ†63727TS6M4735EKRIÿ†63
   Subsystem 9 - Serial number: 35EKRIÿ†63827TS6R3735EKRNÿ
   Subsystem 10 - Serial number: 35EKRNÿ
   Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20160107201427
   Coding: 110A140000
   VCID: 78A9EFC4B25F1317F15-802C
   Serial number: 0939434
   Coding: 820000
   Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
   Component: KOMBI         H04 1008
   Coding: 211F010000
   VCID: 3D273ED0DDFDF63FE23-8068
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:47
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Komfortsysteme: keine Kommunikation]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:49
   Part No SW: 7N0 907 530 BB    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1663
   Revision:   H55       Serial number: 181215F1003573
   Coding: 356032
   VCID: 71BFD2E0D1A5425F36B-8024
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00023.11.15
   Coding: 0001
   VCID: 52FD7D6C746319472F1-8006
   Component: IMMO          H04 1008
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC58CFCF3B187771-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 15000263943009
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313F12E011A5025F76B-8064
          U1111 00 [008] - -
          [Timeout Message mBSG_Kombi]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:47
                    ELV State: 0A
                    Information Clamps: 88 08
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 6D
12665089 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Timeout Message mZKE_4]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:48
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6D
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010287783
   Coding: 0004B4
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A2D35CCCCD3C107C71-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009689169
   Coding: 000490
68098 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN KSG]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:48
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN BSG]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:48
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.286 1401
   Revision: 1BH04841    Serial number: 00153380092801
   Coding: 0000258
   VCID: 41DF4220AD8592DF86B-8014
   Component: EZE_2         H55 1663
   Coding: 050B0500
   VCID: 6FBBD498C79154AF20F-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0601
   Revision: 15100010    Serial number: 0010113629
   Coding: 0004B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 3B2330C8C3E9F80FDC7-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009693542
   Coding: 000490
          U1111 00 [008] - -
          [Front CAN KSG]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:48
          U1111 00 [008] - -
          [Front CAN BSG]
                    Reset counter: 99
                    Mileage: 51916 km
                    Date: 2020.03.18
                    Time: 10:53:48
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000001017851
   Coding: 0026156
   VCID: 38292FC4FE5FD317315-806C
   Component: AFS-ECU       H05 0111
   Coding: 041A00010B000400
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2S3727060
   Coding: 02130602FF00000051220001001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 629DADAC04C3E9C7BF1-8036
   Subsystem 1 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS aerial - open circuit]
                    Fault Frequency: 83
                    Reset counter: 98
                    Mileage: 46555 km
                    Date: 2020.01.25
                    Time: 00:13:35
                    Voltage terminal 30: 12.3 V
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140546
   Coding: 02130602C24232107F1606020000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471BB748EF7D7777DD-8040
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.1V)-----------
BCM PQ35.. Those are a PITA. You might have to get something that can edit the EEPROM.
vaskoto1
Bulgaria
C?ID=67648
vcds isn't capable of doing this?
No, it isn't.
Uwe may be correct here but the 5N2 (Facelifted 5N chassis) does have NAR documentation for Byte 18:
AD,Lighting: VW Tiguan (5N2/VW316) North American Region (NAR) with Halogen
AE,Lighting: VW Tiguan (5N2/VW316) North American Region (NAR) with Xenon​
That doesn't help you because you aren't using NAR settings however both HEX AA and AB are marked (RoW) with Unknown lights. I would try both and get back to us with the results. If I was to guess I'd start with AB because of the Xenon lamps and AA is more likely IMO to be Halogen.
If both are accepted do make sure ALL outside lights work properly. Sometimes a rear fog lamp/reverse light can swap functions with a RF DRL and similar when you have wrong Byte 18 in conjunction with wrong-market wiring.
vaskoto1
Bulgaria
C?ID=67648
it turned out to be way more complicated than i ever thought...
apparently the turn signal bulb has three functions on itself. turn signal, brake light and, dimmed-rear park light. NAR vehicles has also separate side-marker, which is one totally separate little bulb on the side.
so first task is to separate brake light from a turn signal.
yup, uwe is right, as always-eeprom had to be rewritten.
second challenge was to wire BCM with the separate left and right brake lights. connectors A (black) pin 26 and C (brown) 4. pins are present in the BCM (thank god for that!) but not wired in the harness. so after wiring the pins with the actual taillights comes the third task. getting the brake light to dim in order to achieve dual function-
brake/parking light. otherwise there are parking lights only on the tailgate. not nice... side marker is restricted in it's own confinement cell and doesn't affect the overall parking light. the whole thing goes blank, with small red light on the side and lights up only with brake light.
it was fun, so to say...
a guy, friend of a friend of the customer came and we had long lasting sex with this BCM... but in the end it all clicked into place.
if i may suggest-if there is even slightest possibility to make all this using vcds it will be priceless!
murphy is an SOB... he said that if your shoes are comfortable, so they must be ugly...
facts of life...
