ABS fault for 2012 Golf R
B5crazy
CNY, USA
C?ID=157415
Below is the full VCDS scan of my car. I've checked the tire pressure when the warning light comes on in my dash and all 4 tires are within 1 psi of each other. Is there a way to zero in on the abs fault to know what part is failing?
Tuesday,17,March,2020,12:24:35:43668
VCDS Version: 19.6.2.2 (x64)
VIN: WVWPF7AJ5CW203125   License Plate:
Mileage: 223110km-138634mi   Repair Order: 031720
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
          56 62 72 77
VIN: WVWPF7AJ5CW203125   Mileage: 223110km-138634miles
Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
   Revision: 5BH20---    Serial number:
   Coding: 0403010A180F0160
   VCID: 346D5E405791FBEF71-8060
Readiness: 0000 0001
   Revision: 00H31001
   Coding: 144B800C492200FD280C01E6921E0041B70000
   VCID: 7BFFB57CFA4FF497F0-802E
02214 - Tire Pressure Warning
                    Reset counter: 147
                    Mileage: 222997 km
                    Date: 2014.08.06
                    Time: 16:05:44
                    Count: 32768
                    Count: 12800
                    Count: 16401
                    Count: 51712
                    Count: 254
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Revision: 00085000    Serial number: 0159214123
   Coding: 030C0C
   VCID: 346D5E409F91FBEF71-8060
   Part No SW: 35D 907 044 B    HW: 35D 907 044 B
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0000001002
   Shop #: WSC 54321 321 54321
   ROD: EV_ACClimaBHBVW411_VW36.rod
   VCID: 2649B408594D997FFF-8072
          B10A4 15 [009] - Open or Short to Plus
                    Fault Frequency: 8
                    Reset counter: 108
                    Mileage: 222923 km
                    Date: 2020.03.14
                    Time: 19:05:29
   Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 6F180A3B90252AC4108800C170000C4449052186574D8DB0E48420248040
   Shop #: WSC 25568 001 1048576
   VCID: 326158586D85F5DF63-8066
   Component: Wischer 21111  26  0512
   Coding: 009795
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA10NL3
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3F87016CA6D728B79C-806A
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002ZD500
   Serial number: 3572MSME2D2B6466ZZZ0
   Serial number: 3582MSME1521064AZZZN
   Serial number: 3512QSME520B660AZZZV
   Serial number: 3522QSME7C156625ZZZ-
   Serial number: 35527SME56674F29ZZZU
   Serial number: 35627SME295E4F29ZZZ.
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111128200980
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DFBBB64EC5BFAA7CE-8028
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Coding: 270F01
   VCID: 38756A7083F91F8F5D-806C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 281111F1000547
   Coding: 350002
   VCID: 3A717078B5F50D9FAB-806E
   Part No SW: 563 tun ere l    HW: 563 tun ere l
   Component: Haldex 4Motion      T303
   Coding: 0000001
   VCID: 1D3B9BE4C41B5AA7AE-8048
   Component: IMMO          H04 0617
   Coding: 000007
   VCID: 6AD180388DD57D1F1B-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000264696002
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E594C2871BDD13F07-807A
   Revision: A1001003    Serial number: 7661353363
   Coding: 020000
   VCID: 2953BF344053B607D2-807C
   Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
   Component: RNS-MID       H61 4366
   Revision: AB001001    Serial number: VWZ6Z7M8099123
   Coding: 00070402000000800000
   Shop #: WSC 12345 123 12345
   VCID: 2A5140384555BD1FDB-807E
   Component: NAR V11  8407
                    Reset counter: 108
                    Mileage: 197272 km
   Coding: 0001204
   VCID: 31635754A883CEC71A-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 251    3201
   Revision: 00H20000
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0005773
   VCID: 2953BF344853B607D2-807C
   Coding: 0001204
   VCID: 32615858AD85F5DF63-8066
   Coding: 1479708
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
                    Reset counter: 108
                    Mileage: 197272 km
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 356B63445CEBE2E746-8060
   Coding: 0001168
   VCID: 3669644841EDE9FF4F-8062
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H13 2902
   Revision: 1B001001    Serial number: 00007661838103
   Coding: 0A00000000000000
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 108
                    Mileage: 223113 km
                    Date: 2020.03.17
                    Time: 12:14:47
          U1014 00 [009] - -
                    Reset counter: 108
                    Mileage: 223113 km
                    Date: 2020.03.17
                    Time: 12:14:49
End-------------------------(Elapsed Time: 03:03)--------------------------
TIA,
Tom
Jef
HQ
Are all 4 tires 100% matching? Same size? Brand? Tread depth? Does it not reset after holding in the TPMS button in the glove box?
B5crazy
CNY, USA
C?ID=157415
All 4 tires are the same and almost brand new with ~ 2K miles on them. The TPMS button does reset the dash light but why is it being triggered in the first place?
If the tires are good, it's possible you have an ABS wheel speed sensor, or encoder ring, or even a wheel bearing that's slightly dodgy.
Did you try adding 10 PSI per tire more for each tire, since we are close to drastic temp changes with spring/winter transition?
B5crazy
CNY, USA
C?ID=157415
Adding 10 psi? I hope you're not serious as this would put the pressure above the rating for the tires. I'm guessing it's a ABS wheel speed sensor but was hoping VCDS could tell me this and which one was bad.
Considering a lower limit is exceeded and sporadically, did you cross check your actual PSI to another gauge for accuracy?
Did you see a statement, I thought I only asked you questions?
By all means did you tear it all down & measure value's of all mechanical components yet?
Did you consider the cost deviations and that when tires are cold they deflate since temperature is also relative?
VCDS can only tell you what the car knows. The car isn't aware of an obvious problem with a wheel speed sensor. However, it would not hurt to log the four wheel speed sensors while driving straight ahead to see if one might be a bit divergent from the others.
I think Uwe has a great idea here.
I would add that do you realize OP that tire PSI raises significantly related to temperature or how a vehicle is being driven in the turns or conditions met, so why dismiss my questions, seriously?
Jef
HQ
Will point out, odds are once you hit about 20km/h, the ABS module will drop communication.... don't panic, ABS modules do this by design.
+1
On my non-VAG car I have a separate TPMS display and even on a fairly gently drive of around 10 miles to the local supermarket the tire pressures increase by around 2-3PSI and the temperatures by around 8 Fahrenheit.
I mean "seriously" wouldn't it be wise to crank up PSI verifying it is relative to humidity and active temperatures or at least verify the settings in the adaption threshold?
You know as per the RTFB before doing a complete disassembly & when we know we are are upon a season change of drastic temperatures?
:popcorn:
B5crazy
CNY, USA
C?ID=157415
I will add that maybe perhaps this is a fault with VCDS. If you look at the logs of the faults carefully you will see that the ABS fault has a date that is 6 years old (2014) whereas the others have the correct date (2020). I've included the ABS fault info and you can go back to my original post to see the other faults.
Revision: 00H31001
Reset counter: 147
Mileage: 222997 km
Date: 2014.08.06
Time: 16:05:44
Count: 32768
Count: 12800
Count: 16401
Count: 51712
Count: 254
The fault date is generated by the module, VCDS merely reports the information supplied by the module - so the date error (if it is an error) is caused by the VW firmware not VCDS.
B5crazy
CNY, USA
C?ID=157415
So the module has its own internal clock and calendar? Since I cleared all the faults in VCDS before this scan I'm surprised that a fault from 2014 was still there as I have cleared the faults several times since 2014.
No, the module doesn't. But it may not have gotten valid time/date data from the rest whatever module does at the time it set that fault code, and some modules don't seem to handle freeze-frame dates gracefully.
Look at the mileage: 222997. Considering the mileage in your scan is 223110, we can deduce that the fault code is fairly recent.
B5crazy
CNY, USA
C?ID=157415
Is it true that VCDS can manually turn on the ABS pump? How would I do this action in VCDS. I'm going to do a brake upgrade and I would like to make sure there is no air left in the pump when I flush the system.
RTFB the proper procedure for a comporting brake job and function of the hydraulic system done safely!
The forum is not a substitute for the RTFB, nor for repairs outside the scope of stock.
If a test procedure existed in outputs in VCDS, that too would be for a stock car, NOT modified.
These statements are for your safety and not to be dismissed or taken lightly.
Did you do this yet because I strongly suggest you study up on system SSP & brake size codification options the controller may or may not support?
I hope you see I'm truly trying to help you!
I don't see an obvious way to do just that in this ABS.
However, Basic Settings in Group 001 should initiate the brake bleeding procedure and I would expect the ABS to give you some helpful prompts in the four MVB fields. Note however that this is generally a two-person job. The car should be on a lift, with one person in the car with the scan tool and operating the pedal, while the other one is opening and closing the bleeder valves as prompted. At least that's how it was done on earlier ABS systems.
And as Jack states, you should definitely refer to proper repair manual for more details.
