- Mar 6, 2020
- 4
- 0
- Wilmington, DE, USA
- C?ID=365507
Hey everyone!
So yeah, I messed my car up pretty bad with OBDEleven and got rid of it and purchased Ross-Tech for the support and more advanced system in general. When I factory reset (I know now, stupid) my ABS long coding other things stopped working correctly as well and hoping someone or some of you have a way to get me back to running correctly without these 3 specific dash light I am getting.
1. Error: Electronic Stabilization Control (ESC)
2. Error: Hill Start Assist
3. Front Assist not available
These are the only issues that are creating dash lights. But going through the faults on other modules, I see that there is quite a bit more that I need some help fixing as well. Much appreciated for any support and thank you in advance. I am pretty new to this stuff and loving it, minus the idiotic NEWB mistakes made previously.
- Craig
- Craig
Tuesday,17,March,2020,15:18:44:48820
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4508.4
VIN: 3VW5T7BU2KM265571 License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 2B 32 36 3C 42 44 47 52 5F 75 A9
C0 CA 8107
VIN: 3VW5T7BU2KM265571 Mileage: 20242km-12577miles
05-Acc/Start Auth. -- Status: Not registered 0001
C0-Act. for Ext. Noise -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKFA) Labels: None
Part No SW: 5G0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0005
Revision: --H13---
Coding: 091900122424002F3000
Shop #: WSC 00066 790 00387
ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
ROD: EV_ECM20TFS0205G0906259Q.rod
VCID: 3C3427F3B7D513AFB9-8068
17922 - Databus
U1122 00 [032] - Implausible Message
Mileage: 20084 km
Date: 2020.03.16
Time: 22:28:13
Engine speed: 0.00 /min
Coolant temperature: 95 °C
Intake air temperature: 36 °C
Voltage terminal 30: 12.773 V
ACC variants: ACC
CCS Switch: CCS operating unit
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
ACC variants (coding): CCS
Engine: operating status: ES
Readiness: 0000 0100
Part No SW: 5Q0 614 517 EB HW: 5Q0 614 517 BR
Component: ESC H82 0108
Revision: 00000000 Serial number: 52469000001286
Coding: 70FB6BA150260971457C020760C4A90ED60A90A2400695361043F055D0894B0B0000000012121212B835351919323200
Shop #: WSC 00066 790 00176
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75A2F2D7D47F82E786-8020
0338 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[inlet valve calibration data missing]
Reset counter: 8
Mileage: 19836 km
Date: 2020.03.13
Time: 23:57:20
8277 - Databus
[FCAN: EPS_DSR_Status signal is invalid]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.17
Time: 11:33:20
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0522207389
Coding: 132C1C0623
VCID: 45C24217C41F5267D6-8010
Part No SW: 5GM 907 044 R HW: 5GM 907 044 R
Component: Climatronic H05 2009
Revision: 00001K04
Coding: 01020014200118010004004012111016
ASAM Dataset: EV_ACClimaBHBVW37X 006148
VCID: 53E66C4F3A4BFCD748-8006
Part No SW: 5Q0 937 087 BB HW: 5Q0 937 087 BB
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86414091904FN
Shop #: WSC 00066 790 00244
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CB4E7F3F755D3AFF9-8028
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SAY19M07D18H07M37S11
Coding: 0218DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300120920190C202031
Seat Backrest Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE1483980
Seat Cushion Fan 1 Front Left:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1486561
Seat Backrest Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1500910
Seat Cushion Fan 1 Front Right:
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1500719
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 2B00008119FF440D949C81C500001400000000000000000014
Shop #: WSC 12345 123 61029
VCID: 44C45F13CF256B6FC1-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_ALIGNMENT_NOT_OK]
Reset counter: 8
Mileage: 19836 km
Date: 2020.03.14
Time: 00:23:01
Control Module temperature: 50 °C
Voltage terminal 15: 14.2 V
201219 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CODING2SWAP_GRP_AWV_TYPE]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 23:08:20
Control Module temperature: 42 °C
Voltage terminal 15: 14.4 V
201224 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CODING_NOAWV]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 23:08:20
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 008 0403
Serial number: 003FGM05G0JA
Coding: 8CCCFC00000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0C54B733A7F5E32FC9-8058
Occupant Detection:
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000C7PIM1
Coding: 30344B
Subsystem 2 - Part No SW: ----------- HW: 480 002 607 19
Serial number: 35700000000022B07E3B
Subsystem 3 - Part No SW: ----------- HW: 480 002 607 19
Serial number: 35800000000CC5B07E3.
Subsystem 4 - Part No SW: ----------- HW: 480 402 007 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001C2EFE72542348
Subsystem 5 - Part No SW: ----------- HW: 480 401 107 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001A6F08AF88F54T
Subsystem 6 - Part No SW: ----------- HW: 480 400 908 19
Component: FrontSensor_D 005 6149
Serial number: 35500019CF029AA425CI
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 908 19
Component: FrontSensor_P 005 6149
Serial number: 35600019CF029AA407BI
Part No SW: 17A 920 890 A HW: 17A 920 890 A
Component: KOMBI 509 1701
Coding: 01AC091226A0CF05028B772150000008A0000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 2600E59B5959B97FFF-8072
U1014 00 [009] - -
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 22:32:11
1246802 - Interface Module for Vehicle Position/Orientation System
B1306 52 [009] - Not activated
Reset counter: 15
Mileage: 19836 km
Date: 2020.03.14
Time: 00:45:07
16776987 - Databus
[STS_01 keine Kommunikation]
Reset counter: 8
Mileage: 19836 km
Date: 2020.03.13
Time: 23:57:27
16776996 - Databus
[FCW_01 keine Kommunikation]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 22:28:13
16776985 - Databus
[Quersperre_04 keine Kommunikation]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 22:28:13
16777060 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_StartStopReasons_0x39 keine Kommunikation]
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 23:25:02
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 19091900841461
Coding: 0101000830085900FB0002A9080F00000001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E90DDBBB129B13F47-803A
Component: 1-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AD HW: 5G0 959 442 AD Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 29190001323530079236
Coding: 28FFFF
131684 - Actuator for External Sound
U1147 00 [009] - No Communications
[Timeout Knoten 0x64 / C0 - Aktuator für Aussengeräusch]
Fault Frequency: 34
Reset counter: 15
Mileage: 19836 km
Date: 2020.03.13
Time: 23:57:29
Supply voltage: Terminal 30: 14.3 V
Terminal 15: On
131770 - No Communications with Undefined Control Module
U1126 00 [009] - -
[Timeout Knoten 0xBA]
Fault Frequency: 34
Reset counter: 15
Mileage: 19836 km
Date: 2020.03.13
Time: 23:57:29
Terminal 15: On
66304 - Databus
U1124 00 [009] - Additional Installations Detected
[Mehrverbau CAN]
Fault Frequency: 145
Reset counter: 15
Mileage: 19836 km
Date: 2020.03.13
Time: 23:57:29
Terminal 15: On
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000209021016
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 312A06C76097EEC71A-8064
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H55 8043
Serial number: HA1-00022.03.19
Coding: 0005
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52E8694B0551F5DF43-8006
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007SFR34905
Coding: 0010000200000400018280808000000000008101000000F400
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3FCE50FFA6C308B79C-806A
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
Reset counter: 55
Mileage: 19847 km
Date: 2020.03.14
Time: 12:10:27
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H05 0052
Serial number: 00000523342915
Coding: 5000C500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
VCID: 383C3BE383ED3F8F5D-806C
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038915401924
Coding: 003D1B204200028000000000
VCID: 4FEE603F166398376C-801A
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004137416
Coding: 011000
Part No SW: 5QN 909 144 B HW: 5QN 909 144 A
Component: EPS_MQB_ZFLS 507 5082
Coding: 800A0100
ROD: EV_SteerAssisMQB_015.rod
VCID: 51EA664700578EC77A-8004
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5F0 035 456 HW: 5F0 035 456
Component: KonzernAmp12K H03 2109
Revision: -------- Serial number: A1126A00120176
Coding: 0203000002AAAAAA000000000000
ASAM Dataset: EV_AMPCAN12C4PASE 001002
ROD: EV_AMPCAN12C4PASE.rod
VCID: 6288B98B75F1055FD3-8036
0535 - Loudspeaker 2 in Double-Subwoofer
B130D 12 [009] - Short to Plus
Fault Frequency: 11
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 22:05:05
Voltage terminal 30: 14.3 V
0537 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [009] - Open Circuit
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.17
Time: 00:11:10
Voltage terminal 30: 12.5 V
0575 - Double Bass Speaker 1; Front Left
B1345 13 [009] - Open Circuit
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.17
Time: 00:11:10
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46038924501138
Coding: 003F13200E00028000000000
VCID: 4ED07D3B1169913F67-801A
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004124807
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 724 0890
Coding: 09730100AA00000041220003001C08409F0513F40180040002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2E101DBB71A9F13F07-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 254 8130
Serial number: VWZ6ZMW2625810
U1014 00 [009] - -
Reset counter: 15
Mileage: 20084 km
Date: 2020.03.16
Time: 23:26:45
Voltage terminal 30: 14.5 V
Byte_Coding_Condition-byte_0_condition: ERROR
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730102C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 43C65C0FCA2B6C57F8-8016
Part No SW: 5G0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0004
Serial number: 190321202559
Address C0: Act. for Ext. Noise
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00800073710B
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 76A0F5DBC97989FF8F-8022
Address 8107: Antenna
End----------(Elapsed Time: 01:32, VBatt start/end: 14.4V/14.4V)-----------
