Hi Guys
Please help me with Audi A6 4F. Every time after 10 minutes drive ESP light ON and errors related to Battery Regulate module
: 02254 - Interface to Generator and 02479 - Partial Consumer Shut-Off Active.
Steps already done :
1) Fitted 2 known good donor battery with correct coding - still not good
2) Check continuity between alternator D+ and pin 8 Battery Management control unit J644 -all ok
3) Fitted donor J644 control unit - still not good
4) Inspect red connector T17a under scuttle panel -all ok
5) Bypass wire between D+ and J644- still not good
6) Drive with picoscope connect to battery and pin 8 J644- I can not attached print - all ok
7) Customer said that another garage tried with new alternator and was not ok ( Im not sure about this)
8)Alternator is charging all the time
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20200210 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,08,March,2020,15:58:19:31001
VIN: WAUZZZ4FX7N096035 License Plate: WP56OPB(3)
Mileage: 261500km-162488mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
61 62 72
VIN: WAUZZZ4FX7N096035 Mileage: 261500km-162488miles
1E-Media Player 2 -- Status: Malfunction 0010
Self-Diagnosis Log
Page 2
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 HS HW: 03G 906 016 HS
Component: R4 2,0L EDC G000SG 9673
Revision: --H02--- Serial number:
Coding: 0000072
Shop #: WSC 02335 785 00200
VCID: 7BA3F7CB1FE2F14F9C7-802E
006465 - Powertrain Databus
P1941 - 000 - Implausible Message from Controller for Batt. Monitoring
Mileage: 261502 km
Date: 2020.03.08
Time: 15:46:37
RPM: 1533 /min
Speed: 48.0 km/h
Voltage: 13.98 V
Bin. Bits: 00101011
(no units): 1927.0
(no units): 65.0
Readiness: 0 0 1 0 1
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020855
VCID: 6597B1B3896657BF5A3-8030
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Reset counter: 237
Mileage: 261502 km
Date: 2020.03.08
Time: 15:46:38
Hex Value: 0x2F80
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01AB
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100615194
Coding: 0000017
VCID: 6393AFAB8752298FB47-8036
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Self-Diagnosis Log
Page 4
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 769 H HW: 4F0 035 769 B
Component: MMI Cockpit H55 0410
Revision: C61030BE Serial number: AUZ6Z3FBSJ01P3
Coding: 0140002
VCID: 323D1AEF8828F0070F1-8066
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000598676
Subsystem 3 - Serial number: 0128.11.060000000100010747ÿ
Subsystem 4 - Serial number: 010747ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030186634
Coding: 0001044
VCID: 1C61D457FAAC567735D-8048
Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
Component: ILM Fahrer H17 0240
Coding: 0000101
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Self-Diagnosis Log
Page 5
Address 0E: Media Player 1 Labels: Redir Fail!
Coding: 0140002
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0M1E2/
Coding: 0013381
Shop #: WSC 02325 785 00200
VCID: 290FFD83A5FEB3DFBEB-807C
Subsystem 1 - Serial number: 6332CSME153D3108
Subsystem 2 - Serial number: 6342CSME13452314S
Subsystem 3 - Serial number: 6352QSME1B4E2517M
Subsystem 4 - Serial number: 6362QSME1A4132313
Subsystem 5 - Serial number: 63734SME1918056F3
Subsystem 6 - Serial number: 63834SME196E2947B
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063360032
Coding: 0102041
VCID: 6695B6BF74605CA7539-8032
Component: Lenkradmodul H07 0090
Self-Diagnosis Log
Page 6
Part No SW: 4F0 910 900 C HW: 4F0 920 950 R
Component: KOMBIINSTR. M73 H12 0120
Revision: 00400000 Serial number: 58W13VWC6
Coding: 2308448
Shop #: WSC 12345 067 57207
VCID: 2019E0A7D6C47297E95-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300806B260015
Coding: 6CEE53C43B2104
VCID: 270BFBBBB3EA85AFA8F-8072
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3176519
VCID: 1A6DD24FF0982847271-804E
Reset counter: 236
Mileage: 261499 km
Date: 2020.03.08
Time: 15:33:18
Self-Diagnosis Log
Page 7
Address 37: Navigation Labels: Redir Fail!
Coding: 0140002
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0002586
Shop #: WSC 02327 785 00200
VCID: 2C010497AA0CA6F745D-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01026720110000
Coding: 0000251
VCID: 2E050E9F9C10D4E76B9-807A
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 H HW: 4F0 035 223 K
Component: Amp.-ASK-RD H07 0130
Revision: 07S00000
Shop #: WSC 00477 128 02391
VCID: 2313EFABCBD2698FF47-8076
Self-Diagnosis Log
Page 8
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000339943
Coding: 0001104
VCID: 5EE59E5FAC3004679B9-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0002586
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000111
Shop #: WSC 00000 785 00200
Address 56: Radio Labels: Redir Fail!
Coding: 0140002
Self-Diagnosis Log
Page 9
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000105938
Shop #: WSC 26725 123 55366
VCID: 2313EFABC7D2698FF47-8076
Subsystem 1 - Part No: 5K0 915 105 H
Component: von VA0 340517H0B1
Coding: 354B30393135313035482056413033343035313748304231
Shop #: WSC 00000 384 00290
Reset counter: 236
Mileage: 261499 km
Date: 2020.03.08
Time: 15:37:07
Mileage: 261500 km
Date: 2020.03.08
Time: 15:41:41
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002050
Self-Diagnosis Log
Page 10
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002050
End----------(Elapsed Time: 01:32, VBatt start/end: 13.9V/13.9V)-----------
