2014 2.0 TSI VW CC DSG / FULL OVERHAUL / IDLE PROBLEM / PARK POSITION DOES NOT WORK
CCSLEEPER
C?ID=391753
Saturday,22,February,2020,12:05:30:43263
VIN: WVWBP7AN1EE501643   License Plate:
Mileage: 178240km-110753mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 53
          55 56 62 65 72 75 77
VIN: WVWBP7AN1EE501643   Mileage: 178240km-110753miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 06J 906 027 GP    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 5696
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 16448 032 526344
   VCID: 7F5B04081BF7F30FB0F-802A
8 Faults Found:
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - MIL ON
                    Fault Status: 11100000
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 955 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.954 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 000 - Signal Too Low - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 955 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 12.954 V
005497 - Throttle Actuator (J338)
               P1579 - 000 - Adaptation Not Started
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 970 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 12.954 V
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:46:04
                    RPM: 1035 /min
                    Load: 31.4 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.208 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:46:06
                    RPM: 1002 /min
                    Load: 30.6 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.208 V
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 000 - Implausible Signal
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:59:10
                    Load: 0.0 %
                    Temperature: 81.0∞C
                    Temperature: 45.0∞C
                    Voltage: 12.065 V
001378 - System Voltage
               P0562 - 000 - Too Low
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:44:50
                    Load: 0.0 %
                    Temperature: 15.0∞C
                    Temperature: 16.0∞C
                    Voltage: 8.636 V
012372 - Starter Will Not Turn
               P3054 - 000 - Jammed or Electrical Malfunction - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:56:13
                    Load: 0.0 %
                    Temperature: 16.0∞C
                    Temperature: 16.0∞C
                    Voltage: 6.223 V
Readiness: 1110 1101
   Part No SW: 02E 300 062 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 4007
   Revision: 05651213    Serial number: 00001304060223
   Shop #: WSC 05311 000 00000
   VCID: 1577C6A0098B195F0A3-8040
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V48E 0030
   Revision: --H07---    Serial number: 00000007050014
   Coding: 0004495
   VCID: 7BA3F0180FEFEF2F9C7-802E
03366 - Vacuum Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 6
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:48:47
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 8.00 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
00532 - Supply Voltage B+
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:50:43
                    Hex Value: 0x0000
                    Voltage: 7.75 V
                    Bin. Bits: 00011111
                    Count: 115
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:59:25
                    Hex Value: 0x0000
                    Voltage: 10.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 BH    HW: 3AA 907 044 BH
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0714019048
   Shop #: WSC 00015 115 00000
   VCID: 77ABEC283F47CB4FF8F-8022
          B10AB F0 [009] - Too Low
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:57
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 00080000000000000098028194000BC020550B0840200D20E484402400C0
   Shop #: WSC 05311 123 12345
   VCID: 49CF5AD019B38DBF5EB-801C
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 240413  010 0604
   Serial number: 240413
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M05D21H20M07S09S4
   Coding: 0228DD
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:53:31
                        Term 15 On
                    Voltage: 7.55 V
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:53:29
                        Term 15 On
                    Voltage: 7.55 V
Address 10: Park/Steer Assist
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__517 VW10 HI   2318
   Revision: 27019000    Serial number: 003N5P8JUF21
   Coding: 0012599
   VCID: 005987F466098CF7C95-8054
   Subsystem 1 - Part No: 3C8 959 339 A
   Component: BF-Gewichtsens. 003 0001
   Subsystem 2 - Serial number: 0000000000CU2N
   Subsystem 3 - Serial number: 0015.03.130000300000850023ˇÜ63
   Subsystem 4 - Serial number: 850023ˇÜ6332MTS624961183 ˇÜ63
   Subsystem 5 - Serial number: 61183 ˇÜ6342MTS611191173 ˇÜ63
   Subsystem 6 - Serial number: 91173 ˇÜ6351HTS69S8NRBKJ ˇÜ63
   Subsystem 7 - Serial number: NRBKJ ˇÜ6361HTS6HVA9RBKR ˇÜ63
   Subsystem 8 - Serial number: 9RBKR ˇÜ63727TS6J5IORBKR ˇÜ63
   Subsystem 9 - Serial number: ORBKR ˇÜ63827TS64G9ORBKJ ˇ
   Subsystem 10 - Serial number: ORBKJ ˇ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Frequency: 6
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:03
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:02
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130511201262
   Coding: 018A270000
   Shop #: WSC 00015 115 12345
   VCID: 6B83C058730F7FAF0C7-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
136194 - Supply voltage
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Part No SW: 3C8 920 971 E    HW: 3C8 920 971 E
   Component: KOMBI         H04 0811
   Coding: 240F00
   Shop #: WSC 05314 115 12345
   VCID: 2F3B14488797C38F60F-807A
12671232 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuerger‰t f¸r Einparkhilfe: keine Kommunikation]
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.22
                    Time: 00:01:44
          [Supply voltage too low]
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 150513F1000793
   Coding: 461006
   Shop #: WSC 05314 123 12345
   VCID: 7CA1F30406E1E81795D-8028
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:58:54
01304 - Radio
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:58:54
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:48
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:58:54
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:59:26
Address 1C: Position Sensing
   Part No SW: 3AA 959 433 C    HW: 3AA 959 433 C
   Component:    IMMO         042 0407
   VCID: 392F2A1045531D3FCEB-806C
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:56:19
Address 2E: Media Player 3
Address 37: Navigation
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0006993716
   Coding: 0004B7
   Shop #: WSC 05311 115 08193
   VCID: 6D87CE404D1B719F123-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003474663
   Coding: 010490
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.302 1202
   Revision: 1BH04737    Serial number: 00131220337801
   Coding: 0000258
   VCID: 3FDB44085B77330FF0F-806A
   Component:    KSG PQ47 ELV 042 0645
   Coding: 1B910F8001862E521204141FF08A0F0E107802
   Shop #: WSC 05311 000 08193
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:48:47
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FBBD4484797838F20F-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0006986952
   Coding: 0004B6
   Shop #: WSC 05311 115 00000
   VCID: 6E85C94C401D8A872B9-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003451714
   Coding: 010490
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000001027098
   Coding: 0022156
   VCID: 3635212C744DF247239-8062
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:47
                    Voltage: 8.00 V
                    Count: 48
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 071200010B000400
   VCID: 372B2C287FC70B4F38F-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
Address 56: Radio
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000218930
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 3537262065CBF95F2A3-8060
12652544 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:52:57
   Component: OCULowUSA     014 0078
   Serial number: 000003554140500
   Coding: 02640402C2421A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F378B8CB7FC76F247-8006
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 05:58:11
          [supply voltage lower limit exceeded]
                    Reset counter: 40
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:37:06
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.22
                    Time: 00:03:59
   Revision: 1B001001    Serial number: 00007664788291
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
   VCID: 2E05094C809DCA876B9-807A
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:50
          U1400 00 [008] - -
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:50
End----(Elapsed Time: 01:45, VBatt start/end: 11.2V/11.1V. VIgn 11.1V)-----
Saturday,22,February,2020,12:25:28:43263
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 53 55
          56 62 65 72 75 77
2E-Media Player 3 -- Status: Not registered 0001
8 Faults Found:
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 955 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 12.954 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 955 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 12.954 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:45:59
                    RPM: 970 /min
                    Load: 32.9 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 12.954 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:46:04
                    RPM: 1035 /min
                    Load: 31.4 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.208 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:46:06
                    RPM: 1002 /min
                    Load: 30.6 %
                    Temperature: 55.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.208 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 05:59:10
                    Load: 0.0 %
                    Temperature: 81.0∞C
                    Temperature: 45.0∞C
                    Voltage: 12.065 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:44:50
                    Load: 0.0 %
                    Temperature: 15.0∞C
                    Temperature: 16.0∞C
                    Voltage: 8.636 V
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:56:13
                    Load: 0.0 %
                    Temperature: 16.0∞C
                    Temperature: 16.0∞C
                    Voltage: 6.223 V
   Coding: 0004495
                    Fault Frequency: 6
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:48:47
                    Hex Value: 0x0000
                    Voltage: 8.00 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:50:43
                    Hex Value: 0x0000
                    Voltage: 7.75 V
                    Bin. Bits: 00011111
                    Count: 115
                    Hex Value: 0x0000
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:59:25
                    Hex Value: 0x0000
                    Voltage: 10.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:57
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
            000 - - - MIL ON
                    Fault Frequency: 8
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:03
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:49:02
   Coding: 018A270000
   Coding: E20000
          U1400 00 [008] - -
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Coding: 240F00
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Coding: 461006
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.15
                    Time: 00:16:14
                    Mileage: 178243 km
                    Date: 2014.07.15
                    Time: 00:16:10
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.15
                    Time: 00:16:14
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:56:19
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Coding: 0000258
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2014.07.14
                    Time: 23:48:47
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:48
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:52:57
0036 - Databus
          [CAN TO GPS data]
                    Fault Frequency: 6
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 05:58:11
                    Reset counter: 40
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:37:06
                    Fault Priority: 8
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.22
                    Time: 00:03:59
   ROD: EV_UHVUMI.rod
9457426 - Left audio channel for speech/telephone
          B104F 12 [009] - Short to GND
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.22
                    Time: 00:04:02
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.22
                    Time: 00:04:02
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:50
          U1400 00 [008] - -
                    Reset counter: 182
                    Mileage: 178243 km
                    Date: 2020.02.21
                    Time: 23:48:50
End(Elapsed Time: 01:42, VBatt start/end: 11.4V/10.9V. VIgn 10.9V, udsna)--
I would start by charging this poor car's battery.
Next, I would investigate the throttle position sensor faults.
Welcome to the VCDS forum OP!
After your "full overhaul" did you reconnect the ground strap from battery to chassis and to block?
Did you know that a TV and starter are the highest load devices under hood, beside alternator and that even though you have voltage when you try to crank or adapt a TV, it will draw more current and brown out the circuit being insufficient?
It only takes one strand of copper to show voltage but amperage isn't going to happen on one strand of copper and why the starter cable is finger thick, did you know this?
As Uwe aforementioned, did you charge or get a new battery yet?
JPPSG and RTFB!
CCSLEEPER
C?ID=391753
Yes i have a new battery fully charged. And yes the battery is grounded to the chassis. I have a new throttle body and rewired a wire harness with new wires. i have a new throttle pedal and have checked the connection and the wire coming out of the throttle pedal. Replaced the crankshaft & camshaft sensors.
Did you try an overlay to check redundancy of ground or feed currents?
CCSLEEPER
C?ID=391753
CCSLEEPER
C?ID=391753
No i have not done:
"overlay to check redundancy of ground or feed currents"
My friend who is an electrian suggested that but im totally clueless on the procedure. I appreciate your time Jack & Uwe.
Ive also done a throttle body test on all the connections.
Are you sure enough current is available at ECU?
Have you unplugged all consumers under hood to see if the TV will adapt as specified to isolate?
What are current draw values when attempting a TV adaptation isolated?
CCSLEEPER
C?ID=391753
I should probably mention that i do have another battery in the trunk for the stereo system which is also ground too the chassis.
CCSLEEPER
C?ID=391753
Ive Checked ALL the fuses under the hood & inside the car.
Did you try what I have questioned in prior posts?
CCSLEEPER
C?ID=391753
Im doing everything you suggested right now and checking the stereo system for issues. Ill let you know tomorrow because this could take awhile.
Thanks Again!
CCSLEEPER
C?ID=391753
I downloaded the factor wire diagram from VW and still in the process checking everything.
Side Note:
If I installed a KO4 Turbo would that be a factor down the line?
Is there a way to permanently erase the P2015 & P2004? Due to the fact that i have an HPA Manifold.
Side Note:
These questions would not be a comporting qualified repair and no VCDS can not delete codes in a ECU diagnostic stack.
VCDS can clear fault codes, but if the fault conditions that set those fault codes still exist, then those fault codes will return. VCDS cannot alter the fault detection logic in your ECU.
CCSLEEPER
C?ID=391753
Friday,28,February,2020,13:21:01:43263
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
          62 65 72 75 77
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 06:39:42
                    RPM: 1009 /min
                    Load: 30.6 %
                    Temperature: 93.0∞C
                    Temperature: 45.0∞C
                    Voltage: 13.462 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 06:39:42
                    RPM: 1016 /min
                    Load: 30.2 %
                    Temperature: 93.0∞C
                    Temperature: 45.0∞C
                    Voltage: 13.462 V
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 06:39:42
                    RPM: 1016 /min
                    Load: 30.2 %
                    Temperature: 93.0∞C
                    Temperature: 45.0∞C
                    Voltage: 13.462 V
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 06:39:48
                    RPM: 1009 /min
                    Load: 30.6 %
                    Temperature: 93.0∞C
                    Temperature: 46.0∞C
                    Voltage: 13.335 V
               P2015 - 000 - Implausible Signal - MIL ON
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 06:39:50
                    RPM: 1040 /min
                    Load: 30.6 %
                    Temperature: 93.0∞C
                    Temperature: 46.0∞C
                    Voltage: 13.462 V
   Component: J104   C2 450M V48F 0030
   Coding: 0004495
                    Fault Frequency: 16
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:12:11
                    Hex Value: 0x0000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Fault Frequency: 14
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:12:12
                    Hex Value: 0x0000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:13
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 183
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 06:40:45
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
            000 - - - MIL ON
                    Fault Frequency: 7
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:14:10
   Coding: 018A270000
   Coding: E20000
   Coding: 240F00
   Coding: 461006
01304 - Radio
                    Reset counter: 183
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:28:24
                    Fault Frequency: 6
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:12:12
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2014.07.20
                    Time: 04:12:16
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:11
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 183
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:12
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:11
                    Reset counter: 183
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:12
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
                    Fault Frequency: 20
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:17
                    Fault Priority: 8
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:21:25
   ROD: EV_UHVUMI.rod
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:11
                    Reset counter: 142
                    Mileage: 178243 km
                    Date: 2020.02.27
                    Time: 04:12:11
End----------(Elapsed Time: 01:40, VBatt start/end: 13.6V/13.7V)-----------
Friday,28,February,2020,13:32:46:43263
          62 65 72 75 77
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:30:35
                    RPM: 995 /min
                    Load: 30.6 %
                    Temperature: 66.0∞C
                    Temperature: 35.0∞C
                    Voltage: 13.970 V
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:30:35
                    RPM: 1010 /min
                    Load: 30.2 %
                    Temperature: 66.0∞C
                    Temperature: 35.0∞C
                    Voltage: 13.970 V
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:30:35
                    RPM: 1010 /min
                    Load: 30.2 %
                    Temperature: 66.0∞C
                    Temperature: 35.0∞C
                    Voltage: 13.970 V
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:30:43
                    RPM: 1008 /min
                    Load: 30.6 %
                    Temperature: 66.0∞C
                    Temperature: 35.0∞C
                    Voltage: 13.970 V
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:30:45
                    RPM: 1025 /min
                    Load: 29.4 %
                    Temperature: 66.0∞C
                    Temperature: 35.0∞C
                    Voltage: 13.843 V
   Coding: 0004495
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:22:23
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:22:24
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0714019048
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   Coding: 018A270000
   Coding: E20000
   Coding: 240F00
   Coding: 461006
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:22:25
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2014.07.21
                    Time: 01:22:29
   Coding: 0004B7
   Slave Driver:
   Coding: 010490
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
   Coding: 0000258
   Coding: 00000008
   Coding: 0004B6
   Slave Passenger:
   Coding: 010490
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:29
                    Fault Priority: 8
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
   ROD: EV_UHVUMI.rod
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
                    Reset counter: 143
                    Mileage: 178243 km
                    Date: 2020.02.28
                    Time: 01:22:24
End----------(Elapsed Time: 01:37, VBatt start/end: 14.2V/13.8V)-----------
Did you perform the service action or TSB for the TV yet OP for wiring issues?
CCSLEEPER
C?ID=391753
If you're talking about the rewiring the 6 wire to the wire harness of the TB. YES i Did.
Are you sure your work is good & did you recheck it and verify voltage and ability to carry current? :rolleyes:
CCSLEEPER
C?ID=391753
If you put it that way i'll check it again.
