03 Avant bulb out messages
Deerhurst
Oregon, USA
C?ID=373717
No fault codes outside it being unhappy with the S2 cats.
When the lights are on and the right blinker is active the right rear tail brake filament turns on and off about every 7 blinks at a reduced intensity. After the the blinker is cancelled a bulb out message is thrown.
The bulb holder is new, bulbs are new, CECM has been replaced with "working condition" used module which acts similarly as the old unit. Cannot find an issue in the wiring by basic diagnostics.
Car does have a Curt trailer light controller that has not caused issues in the past.
Deerhurst
Oregon, USA
C?ID=373717
Even though there are no fault codes we'll still need to see a full unedited VCDS Auto-Scan
I'll see what I can do later this evening.
What would the scan tell you that error messages won't?
Full system wide scan or just a scan of that module?
Everything; the whole car please. Even in 2003, cars were already a computer network on wheels.
nazdaq100
London, United Kingdom
C?ID=314050
As mentioned above by petroldave if you can please post a full auto scan. Once you carry out a full auto scan
You can walk your way to Local C/primary drive > RossTech > scans> open the file. Copy all the information CTRL + A> CTRL + C = clicking a # above in this typo CTRL + V from a full auto scan we can learn and tell you more about the car. Also advise you an appropriate ideal solution for your vehicle. Alternatively please click on the link below on how to post an Auto Scan
https://youtu.be/AK1lK5DRNcg
Deerhurst
Oregon, USA
C?ID=373717
These things really are an awesome super computer on wheels. Im not a noobie on computer stuff, just VCDS. Managed to bumble my way though adaptation and coding of the Central Electronics module that I changed out. Trailer light controller was removed tonight. Its a car. If I need to tow Im using a body on frame vehicle like the one parked next to it which is 34 years old a not a computer on wheels. It hardly knows how to pulse an injector.
The controller was tied into a Green/Black wire that is missing on my chiltons wiring diagrams. It was rather crudely spliced in. Its been cleaned up, soldered and shrink wrapped. What is that wire on the right rear tail light assembly?
I do have an aftermarket head unit that sits on CANBUS and sends info to the dash. I do have an aftermarket amp and subs that have completely replaced the OEM amp/sub box. Otherwise the car should be stock.
I couldnt find info on a 01311 code. Its a new one I havnt seen before. The S2 O2 "codes" have gone away (battery recently disconnected for the CECM swap) as has my sticky rear door lock code, for now. No CEL for the cats.
Not comfortable with having my VIN floating around. If anyone from Ross-Tech needs licensing confirmation, please ask and Ill PM.
Current VCDS log: Please excuse formatting.
Friday,21,February,2020,19:23:39:31460
VIN: <SNIP>   License Plate:
Mileage: 238180km-147998mi   Repair Order:
          67 69 75 76 77
VIN: <SNIP>   Mileage: 238180km-147998miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 E    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0003
   Coding: 0016711
   Shop #: WSC 63351 000 00000
   VCID: 372B2BF2E35A2AFF38F-5160
Readiness: 0110 1101
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 04495
   Shop #: WSC 26097
   VCID: 2615F6B631F0A377939-51CE
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A0D028625E88717B71-5160
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00011
   VCID: 34311CFEF72CC1E71DD-4B1E
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   VCID: 372B2BF2E35A2AFF38F-5184
   Part No: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 02042
   Shop #: WSC 63351
   VCID: 3C2134DEDF7C09A7D5D-4B1E
   Part No: 8E0 920 950 PX
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 03200
   Shop #: WSC 56747
   VCID: 0E45AE16B940CB374B9-5184
   WAUVT68E03A203983     AUZ6Z0B0268300
01311 - Information Data Bus
            80-00 - Single-Wire Operation
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0203
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BFD5EAC88EB4CF36B-4B3C
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: 6B83C782EA925E1F0C7-513C
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 12138
   Shop #: WSC 63351
   VCID: 72BDDAE6CDB88FD7CF1-4B1E
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0002
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
   Part No: 4Z7 907 357
   Component: dynamische LWR       D08
   Coding: 00060
   Shop #: WSC 63351
   VCID: 04518C3EE73CB167EDD-4B5C
End----(Elapsed Time: 05:16, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
One of the CAN buses connected to the instrument cluster is in backup mode, where data can only flow through a single wire rather that the differential signal on a twisted pair. I think it's the one that connects to the radio, but I'm not 100% certain of that. Anyway, it may be an artifact of the aftermarket HU.
Nah, we know it's legit. In some cases the VIN is needed to build a coding or look stuff up, but that's not the case here.
As for the bulb out message, I'm stumped. I'd expect to see something in the scan about that.
Deerhurst
Oregon, USA
C?ID=373717
I'm thinking head unit is the cause of that too. It havnt popped up till now and I've had the head unit in there for a while. I bet a cold boot could fix that.
I'm super stumped and getting pretty annoyed at the bulb out. As soon as the lights are cycled the message goes away. I do have a rear fog out which doesn't throw a code until I physically remove the bulb. Probably lost the vacuum on the bulb.
Here is a YouTube of what the bulb does. It's subtile but it turns on and off the brake filament at a reduced intensity. Super unprofessional video but it was originally made for a buddy to see what it is doing.
https://youtu.be/uphfuKQeLqQ
Deerhurst
Oregon, USA
C?ID=373717
So, attempt #4 to post. Every time I try to edit a post it gets deleted. I select the text area and the page reloads and deleted my post. Each post is getting shorter and shorter due to level of aggravation of having to do it all over again.
Quick unprofessional clip of what the bulb does while the blinker is on. It's subtle. Gotta run into town tomorrow so I'll try to get a VCDS log with an active bulb out on the dash.
I un-deleted post #8 for your. The following two appear to be duplicates. I have no idea what you are doing that's causing them to get deleted. What kind of device are you using to post here?
Deerhurst
Oregon, USA
C?ID=373717
Thanks man. I'm on mobile using Firefox Mobile.
Deerhurst
Oregon, USA
C?ID=373717
Round 2 after a trip into town and 2 light out warning. For some reason it cuts off the front running light filament. All the warning go away once the lights have been turned off and back on. All lights light normally until the blinker is used. This is a different reaction to the old module which turned off the rear parking lamp.
Could not find anything in the Wiki for the 00985 code. I dont believe the 01498 is a bulb or fuse issue as the light works fine. Everything works fine until the right blinker is used with the lights on. Currently the wiring in the headlight is not modified. That is not the side with the damaged headlight clip.
Saturday,22,February,2020,10:09:54:31460
Mileage: 238200km-148010mi   Repair Order:
          67 69 75 76 77
VIN: <SNIP>  Mileage: 238200km-148010miles
   Coding: 0016711
Readiness: 0000 1001
   Coding: 04495
   Shop #: WSC 26097
   Coding: 00000
   Shop #: WSC 63351
   Coding: 00011
01498 - Bulb for Parking Lamps; Right (M3)
            57-00 - Electric Circuit Failure
00985 - Right Tail Light (M2)
   Coding: 0010607
   Coding: 02042
   Shop #: WSC 63351
   Coding: 03200
   Shop #: WSC 56747
   Coding: 00002
   Shop #: WSC 63351
   Coding: 00001
   Coding: 12138
   Shop #: WSC 63351
01561 - Rear left door
            59-00 - Can't Unlock
   Coding: 00060
   Shop #: WSC 63351
End----(Elapsed Time: 05:18, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Have you checked the condition of the ground(s) for the right tail light assembly?
And the condition of the bulb sockets themselves?
Deerhurst
Oregon, USA
C?ID=373717
Rear bulb holder is brand new and was replaced with the original again last night with no change in symptoms. Didn't like the weather seal on the new one. Wouldn't stay in the track.
The rear ground must be fine because if I add a ground it throws codes. Gets very unhappy if I pull a new ground.
Deerhurst
Oregon, USA
C?ID=373717
The last 2 scans were with the old holder, not the new one.
Deerhurst
Oregon, USA
C?ID=373717
Sorry for the crazy multi post. I don't trust my abilities to hit the edit button on mobile.
I did notice it turned off the right front parking filament when I was pulling the log.
The rear fog still doesn't illuminate but no faults. 11.55v (subs pulling and engine not running) at the socket. Message on dash thrown when the bulb is removed. New bulb, same result. This is the left side though.
Bulb also doesn't illuminate when using TEST in VCDS.
Edit (not on mobile!): I found a setting I missed in Adaptation. The intensity. It was set to 24% for sedan which is why it appeared that the bulb did not go out. Changed that back to 0 and we are back at square 1 everything is exactly the same as the original module. Taillight blinks over so many blinker cycles.
Deerhurst
Oregon, USA
C?ID=373717
Found 2 burnt contacts on the right front parking light. Replaced the bulb and bulb holder with spares. Got a right parking light message. Right front parking light is out.
Also noticed that the parking filament in the right front bulb is lighting opposite to the blinker. It dims when the blinker goes bright and goes bright when the blinker dims.
Rear bulb still goes on and off at it's 7 blink interval.
That's a sure sign of demonic possession! ;)
Seriously now, I cannot imagine why overlaying an extra ground wire would make it unhappy. That makes no sense to me at all.
Deerhurst
Oregon, USA
C?ID=373717
Dude! I'm not ruling out possession at this time! Hahaha!
Found a possible rubbed wire in the headlight between the two hot leads to the yellow bulb up there. Patched it to test and it did the same thing.
Update, decided to pull the power off the battery. left it for 5-10 minutes, and came back with VCDS and cleared the low power faults. Gotta drive it to clear the ABS steering angle low power fault. Gotta do that anyways tonight. Havnt checked for the bulb shenanigans.
I'm afraid to check for an issue because it'll just be back!
When would you say it's time to take it to someone else?
I'd rather not spend an arm and a leg on it but it's driving me insane!
redneckG33K
Canada
C?ID=253336
I don't meant to derail anybodies thought process but for the sake of other people reading this thread.....
I had a curt trailer wiring controller wired to my Audi A3 MY2008. It worked great at first, but within a year or so I had a never ending stream of bulb out messages, or actual blown bulbs in the car. I chalked it up to an Audi being an Audi. (Electrical gremlins galore) . I had no suspicion of the trailer wiring module as it seemed to work trouble free for a considerable amount of time. Then our vehicle circumstances changed at home and Audi became wifes daily driver, and I started removing the mods on the car. The curt trailer wiring module went along with a couple other things. My bulb errors have decrease 90%. I still blow a taillight bulb every once in a while, but at more 'normal' frequency as compared to other vehicles I've owned. In my opinion.
