VW CC CHECK ENGINE 005703 P1647 '08
dd1
C?ID=826
hi everyone, i have a vw CC 2008 with a fault codes, engine control module, p1647. the epc light comes on. no other lights or issues. the transmission has a fault code NO COMM. CRUISE CONTROL - FRONT SENSOR. I had looked and this car does not have adaptive cruise control, no extra plugs and no brackets, regular cruise control yes. i diagnosed the gateway and there also do not have anything there strange, the engine control module, i read the coding and nothing strange. i will post the the car's reading, the logs. maybe someone else can help me. i had checked the abs and air bag no fault codes. the owner doesnt have much info about the car.
dd1
C?ID=826
here is the link
[Link removed. No links to that den of snakes please]
i can not post the logs here, because this is not the laptop with the VCDS. I had it on a different site and i have copied the link so that you guys can see the logs from there. my apologies.
dd1
C?ID=826
ok, here is the VIN 515072, no repairs have done on it by me, the owner of the car doesnt have much info, under the hood looks ok, original, abs. starts and drives ok. battery ok since it starts fine every time. i can not post the logs here since this laptop was not used to read the car. but i managed to link of the post where i had it previously.
Please post an Auto-Scan.
dd1
C?ID=826
is there a way to download it from the computer? i have it here but can not download it as a doc.
It's just a text file. Copy the file from one compute to another using any means you wish, such as a USB memory stick, or a network share. Once you have the file, open it with Notepad, then copy & paste the contents here.
dd1
C?ID=826
thank you
Thursday,13,February,2020,15:56:44:50448
VCDS Version: 19.6.2.2  HEX-NET CB: 0.4508.4
VIN: WVWHP7AN0CE515072   License Plate: DAVESCC
Mileage: 209190km-129984mi   Repair Order: DAVID
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 62
          65 72 77
VIN: WVWHP7AN0CE515072   Mileage: 209190km-129984miles
   Part No SW: 06J 997 029 J    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2    1514
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 55490 001 1048576
   VCID: 3E30C0BF69B2A5BF97-806A
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Fault Status: 11100000
                    RPM: 820 /min
                    Load: 22.3 %
                    Temperature: 54.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
               P0300 - 000 -
                    RPM: 757 /min
                    Load: 23.9 %
                    Temperature: 76.0°C
                    Temperature: 36.0°C
                    Voltage: 13.589 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected
                    RPM: 757 /min
                    Load: 23.9 %
                    Temperature: 76.0°C
                    Temperature: 36.0°C
                    Voltage: 13.589 V
004874 - Cylinder Disabling
               P130A - 000 -  - MIL ON
                    RPM: 766 /min
                    Load: 22.3 %
                    Temperature: 78.0°C
                    Temperature: 37.0°C
                    Voltage: 13.970 V
Readiness: 1010 1101
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3522
   Revision: 05351113    Serial number: 00001104091082
   Shop #: WSC 44551 111 44551
   VCID: 25020FD3EC241667F6-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Reset counter: 40
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:35
   Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
   Component: J104   C2 450M V4B8 0005
   Revision: --H07---    Serial number: 00000004166737
   Coding: 0000399
   Shop #: WSC 05311 000 00000
   VCID: 373ED59B468894F754-8062
   Part No SW: 5K0 907 044 FS    HW: 5K0 907 044 FS
   Component: Climatronic   H17 1011
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00015 115 00000
   VCID: 014A7B4390CC1A47AA-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000009802259400840440517C8840600D605C8060200040
   VCID: 393AD3A3B09C8287A2-806C
   Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 08031  10  0603
   Coding: 00B795
   Component: RLS 050511 05  54  0403
   Coding: 0330ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 184
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:56
                        Term 15 On
                    Voltage: 14.05 V
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__30S VW10 HI   1918
   Revision: 22014000    Serial number: 003JZP7BLHEN
   Coding: 0012371
   VCID: 4BD6996B2A00001700-801E
   Subsystem 1 - Part No: 3C8 959 339 A
   Component: BF-Gewichtsens. 003 0001
   Subsystem 2 - Serial number: 000000000032PR
   Subsystem 3 - Serial number: 0029.03.110000300000650033ÿ†63
   Subsystem 4 - Serial number: 650033ÿ†6332MTS614820961 ÿ†63
   Subsystem 5 - Serial number: 20961 ÿ†6342MTS660810931 ÿ†63
   Subsystem 6 - Serial number: 10931 ÿ†6351HTS6JQGT0AKJ ÿ†63
   Subsystem 7 - Serial number: T0AKJ ÿ†6361HTS6J6DDV9KR ÿ†63
   Subsystem 8 - Serial number: DV9KR ÿ†63727TS6AS7CS9KJ ÿ†63
   Subsystem 9 - Serial number: CS9KJ ÿ†63827TS6CBOES9KJ ÿ
   Subsystem 10 - Serial number: ES9KJ ÿ
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20181108200270
   Coding: 7982A10000
   Shop #: WSC 01286 386 08256
   VCID: 095A6363A8FC5207F2-805C
   Serial number: 50000000000000377011
   Coding: E20000
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Reset counter: 184
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:36
227355 - Windshield Wiper/Washer Switch
          B1149 13 [009] - Open Circuit
                    Reset counter: 184
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:36
   Part No SW: 3C8 920 970 Q    HW: 3C8 920 970 Q
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 3A38CCAFBD9A899FAB-806E
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 280411F2001250
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 3424E29797FE7FEF71-8060
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0399
   Shop #: WSC 45397 001 1048576
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669928949
   Coding: 020000
   VCID: 281C06E75B360B0FCD-807C
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H05 0011
   Serial number: VWZAZ2L8446594
   Coding: 040004210400000000011000
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 618A5BC3708CBA47CA-8034
1048669 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 184
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:36
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0501
   Revision: 12110009    Serial number: 0002765889
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   VCID: 6D9237F3BC54EE277E-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000002135095
   Coding: 000490
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.303 1101
   Revision: 1AH03729    Serial number: 00111160229901
   Coding: 0000258
   Shop #: WSC 63240 001 1048576
   VCID: 3B36C9AB7AA0B097B0-806E
   Component:    KSG PQ47 ELV 042 0631
   Coding: 13910F8001862E521204141FF08A0F0E085801
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FAE2DFBBE581C374C-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0501
   Revision: 14110009    Serial number: 0002771698
   Coding: 0004B6
   VCID: 6E9030FFB152153F47-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000002133078
   Coding: 000490
66305 - Switch for Passenger Side Window Regulator
          B11F1 29 [009] - Signal Implausible
                    Reset counter: 184
                    Mileage: 209194 km
                    Date: 2020.02.13
                    Time: 04:00:36
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000327903
   Coding: 0022057
   VCID: 3326E18B52F078D768-8066
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000032537
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 3326E18B9AF078D768-8066
8398081 - Tire Pressure Sensor(s)
          C111A 04 [009] - Internal System Fault
                    Reset counter: 32
                    Mileage: 167198 km
                    Date: 2020.05.18
                    Time: 06:10:53
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
                    Reset counter: 10
                    Mileage: 167021 km
                    Date: 2020.05.11
                    Time: 06:36:47
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669833705
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 628854CF758AA15FD3-8036
End----------(Elapsed Time: 01:30, VBatt start/end: 14.0V/13.8V)-----------
Vehicle Identification No. WVWHP7AN0CE515072
Model Passat CC
PACC
Date of production 11.05.2011
Model year 2011
Sales type 3574LD
Engine Code CBFA
Transmission Code MSX
Emission standard 0GT Emission standard SULEV
Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling
Isn't this under warranty extension for useful life and recall admittedly?
dd1
C?ID=826
no it is not
no it is not
That's a pretty cock sure answer from a guy that has trouble posting a scan?
Are you not aware of SULEV useful life warranty is 15 years or 150k especially when firmware is non existent in public disclosure here?
https://literature.vw.com/calibration_lookup.asp
Have you read your conformity certificate application lately?
Did you fiddle fuck with the conformity configuration attributes?
Reactions: dd1
dd1
C?ID=826
here in california, the official dealers will do everything to avoid the warranties and recalls. i do not even know if the car is a salvage title yet. just need to figure the issue with the fault code. that is it.
SALVAGE TITLE OR NOT HAVE YOU JPPSG THE ENTIRE THREAD DIPSTICK?
https://forums.ross-tech.com/showth...al-Problem-Solver-Guide-quot-JPPSG-quot/page5
ALL ABOARD!
latest
dd1
C?ID=826
anyone else? any ideas how to fix this issue? thank you in advance
Did you try comparing scans of the web to your scan yet & to triangulate data?
Oh I'm sorry dealer and SVM.............
Jack, does the PR info for this car show it having had ACC when it was built?
Stand by......
8T2 & 6Y2
PART NUMBERDESCRIPTIONREMARKMODEL
06J 906 027 FDFOD FUCKAROO
AT LEAST AS PUBLICLY DISCLOSED?
Control unit for petrol engineCBFA+PR-0GT+
G0K+G1A
Vehicle intelligent genuine part.
Order only with additional instructions.
HERE
or
HERE
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=24440&flag=1
Vehicle Identification No.WVWHP7AN0CE515072
ModelPassat CC PACC
Date of production11.05.2011
Model year2011
Sales type3574LD
Engine CodeCBFA
Transmission CodeMSX
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0DJVehicle class differentiation -350-
Emission standard0GTEmission standard SULEV
Trailer hitch1D0Without trailer hitch
airbag4UBAirbag for NAR
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Storage compartment packageQE0Without storage compartment package/box
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XCExterior mirrors: power-adjustable
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8FSports equipment
Brake type in rear1KWDisc brakes in rear
batteriesJ0LBattery 340 A (70 Ah)
Brake type, front1ZGDisc brakes in front (Geomet D)
Beverage holders4M9Beverage holders
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0WComponent parts set, complying with vehicle type for California, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ3Chrome package (version 2)
General operating permit, alterationsC08Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAWithout roof insert (standard roof)
Suspension system in rearUA4Rear shock absorption, base version
Suspension system in frontG60Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MDDecorative aluminum inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X0Without park distance control
Electric interface for external useUF8Electric interface for external use
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Headlight activation8K9Separate daytime running light with automatic headlight control and Coming Home feature
Parking brakeUH2Parking brake
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G7tiptronic
Weight category rear axle0YBWeight range 2 installation control only, no requirement forecast
Weight category front axleL11Suspension range 11 installation control only, no requirement forecast
Base engineTQ24-cylinder SI engine 2.0 l unit 06J.B
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG1A6-speed automatic transmission
Cruise control system and speed limiter6Y2Speed limiter
Brackets3P0Without bracket for first aid kit and warning triangle
Rear seats3NNRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without customized installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8CCoupe
Luggage compartment floor covering6SELuggage compartment floor covering in flat needle-punched nonwoven
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Rear head restraints3Q5headrest for seat, rear
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C1Body measures for increased safety requirements
Radiator grille6KJRadiator grille with chrome molding
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Light control systems8G0Without Light Assist
Load edge protection2P1Plastic loading edge protection
Lumbar support7P1Power-adjustable lumbar support in front seats
steering wheels2PPLeather-wrapped multi-function steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Center console3D5Center console
Driver alert systemEM0Without driver alert system
Engine cooling8Z6Hot country
Engine specificationsD2L4-cyl. SI engine 2.0 l/147 kW (16V) turbo FSI, homogeneous base engine: T59/T61/TQ2/TU2/TD6/TN6/TT8
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7T8Navigation system "RNS315" NAR
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WDIntegrated front fog lamps
Hubcaps1NLTrims for alloy wheels
WheelsCB5Alloy wheels 8J x 18
Radios8AYRadio navigation system
Smoker's/non-smoker's package9JFNon-smoker's package (NAR)
Tire pressure monitoring system7K3Tire pressure monitoring system 433 MHz High
tireH04All-weather tires 235/40 R 18 95H (NAR) (polymer coating)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PECCalifornia emission standard
WC6Luxury package CC - USA
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SJRear combination lamp, standard design (NAR)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFComfort seat in front, left
Front seat, right3SFComfort seat, front right
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
seat coversN1SSeat trim covers in leatherette
Seat adjustment3L5Both front seats power-adjustable
seat heater4A3seat heating for front seats separat controlable
Side lights8F1Side-marker lamps
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Horns8Y1Two-tone horn
Control number (no PR family)S0BSales model year does not match production model year
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B4Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
power outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set0PWNameplate set "CC"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements for California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Transit coatingNT1Transit coating (type 2)
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Assembly parts for engine (drive bearing)1VGInstallation parts for four-cylinder engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W7Mobile phone interface (NAR)
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZNBright decorative trims
Additional child seat anchors3B3Child seat anchors
Auxiliary heating system9M0Without auxiliary heater/parking heater
ClocksUP0Analog clock
