Audi A4 Tfsi 1.8 petrol 2013
jerzy
C?ID=303197
Can anybody help,I have disabled the stop/start on my car which is o/k. But the engine cuts out when I open drivers door to shut the gate. Thank you in advance.
Monday,17,February,2020,12:27:29:39116
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K7DA222393   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K7DA222393   Mileage: 57570km-35772miles
Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264 A    HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H07 0004
   Revision: --H07---
   Coding: 12030032242501022000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
   ROD: EV_ECM18TFS0218K0906264A.rod
   VCID: 2F381AF68794C0BF60F-807A
15462 - Control Circuit for Coolant Bypass Valve
          P2681 00 [040] - Open Cricuit
                    Fault Frequency: 64
                    Mileage: 57496 km
                    Date: 2020.02.04
                    Time: 13:58:01
                    Engine speed: 1382.00 /min
                    Normed load value: 23.9 %
                    Vehicle speed: 42 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.160 V
                    Engine: operating status: PL
                    Engine temp. management actuator: raw value: 2071
                    Engine temperature management actuator: stop open: 136
                    Engine temperature management actuator: after-run stop: 3950
                    RVC_SP: 128.50 °
                    RVC_AV: 128.91 °
                    RVCPWM: 0.000 %
Readiness: 0000 0001
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K5 927 155 Q    HW: 0AW 927 156 K
   Component: 0AW 18TFSIRdW H05 0001
   Revision: --H05---    Serial number: 0000000684
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 46D65F52082E61F7B39-8012
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 051544
   VCID: 005A894A6A0A8FC7C95-8054
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H12 0633
   Coding: 01B24040000000000000
   VCID: 77A8E2963FC4C87FF8F-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000029141013
   Serial number: 2313000032152004
   Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
   Revision: D0000000    Serial number: 01050320132246
   Coding: 642402C000
   VCID: 392C24AE49501E0FCEB-806C
   Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
   Revision: 03016001    Serial number: 00000564626302
   Coding: 290000308034A7C00081000000001F1F001D460827080201000008004000020000000020000000
   VCID: 73B0D6862BBCA45FC47-8026
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280213  H06 0080
   Serial number: SWF13020280144
   Coding: 00FD11
   Serial number: 21060597
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000103130458
   Serial number: D6184896000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD98U90L
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 34713 001 1048576
   VCID: 48CA516A023A7787415-801C
   Serial number: 6334MSME76244B13B
   Serial number: 6344MSME7624377CM
   Serial number: 6352QSME3E290952L
   Serial number: 6362QSME7026336CH
   Serial number: 63732SME4D2C2948A
   Serial number: 63832SME512C57683
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130311000987
   Coding: 000017
   VCID: 4FF87A76E7D4A0BF00F-801A
   Part No SW: 8K0 920 982 C    HW: 8K0 920 982 C
   Component: KOMBIINSTR.   H35 0556
   Revision: 00400000    Serial number: UVM59ZC3E
   Coding: 3386100002012600010000
   VCID: 3432159A6E32E3671DD-8060
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V13227818C
   Coding: 80CF07FF00
   VCID: 48CA516A02BA7787415-801C
   Serial number: 9342140103
   Serial number: 13064000332021200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000054034523
   Coding: 011002204001410001
   VCID: 50FA790AFAEABF47195-8004
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0004246404
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3432159A6EB2E3671DD-8060
   Revision: 00002001    Serial number: 0300466936
   Coding: 013B062220B90000803002368000000F
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 303A198A9A2ADF47795-8064
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000054065080
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001267433
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 382A21AA72DA0707315-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
   Component: Concert3      H05 0470
   Revision: 00000002    Serial number: AUZ5Z6M1866122
   Coding: 0502008201028D00035B071000
   VCID: 41DC4C4E218046CF86B-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000053951009
   Coding: 010002204001210001
   VCID: 46D65F5208AE61F7B39-8012
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000053952091
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005629881
   Coding: 0010320
   VCID: 3D2430BE5178222FE23-8068
End----------(Elapsed Time: 01:37, VBatt start/end: 12.7V/12.5V)-----------
Westbury, UK
Does the engine still stop if you press the Start/Stop switch before opening the door?
jerzy
C?ID=303197
Engine keeps running
Westbury, UK
Sounds like the tweak you've done disables stop/start but the safety interlock that operates when the door is opened is still active - and I've not seen any discussion of this issue on any of the forums I frequent so can't offer any suggestions on resolving it.
Given that it's a safety system it MAY be that there are no adaptation/coding tweaks to override it :confused:
jerzy
C?ID=303197
Thank you for you response.
Westbury, UK
I had a similar problem in our previous house, so just got into the habit of pressing the SS switch just before opening the drivers door, or as we joked "Doors to manual" :D
nazdaq100
London, United Kingdom
C?ID=314050
Deactivation of the automatic engine shutdown with the engine running when the driver's door is opened
The following coding is to be used:
1. Select STG 46 (comfort system)
2. STG Long Coding -> Function 07
3. Byte 11
4. Disable bit 2
5. Byte 15
6. Disable bit 0
7. Disable bit 1
8. Disable bit 2
9. Disable bit 3
10. Select STG 05 (access and start authorization)
11. STG Long Coding -> Function 07
12. Byte 1
13. Disable bit 5
3. Byte 11
4. Disable bit 2
5. Byte 15
6. Disable bit 0
7. Disable bit 1
8. Disable bit 2
9. Disable bit 3
12. Byte 1
13. Disable bit 5
At first, I was skeptical, but looking at the coding info for those two modules in that car, I think it is worth trying.
jerzy
C?ID=303197
thank you, I will have a go.
