Various issues
mogsy
C?ID=271117
On my 2010 B8 estate several faults seemed to appear at the same time, need to press the clutch pedal twice to start the car, the gear recommendation display has disappeared (it is turned on) and the handbrake does not automatically release any more ,don't have hill assist, the handbrake works normally otherwise,the only 'solid' fault showing in VCDS is clutch position sensor, occasionally says fault in electronic parking brake.Could the sensor cause all these faults? I know the EPB and clutch sensor are linked together.
I checked the EPB with vcds and the handbrake locked on and could not be released with dis saying alternately parking brake fault and parked on too steep an incline, next morning the epb was normal, tried it again with the hand brake off and could not apply parking brake with same messages, again went back to normal after I left the car for a while, is this a feature of vcds or the car, is it normal?
We'll need you to post a full unedited VCDS Auto-Scan so we can see how your B8 is equipped and the details of the fault codes.
mogsy
C?ID=271117
 Sunday,16,February,2020,14:12:01:04690
VCDS Version: 19.6.2.2
VIN: WAUZZZ8K6BA044909   License Plate:
Mileage: 203330km-126343mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K6BA044909   Mileage: 203330km-126343miles
Address 01: Engine (J623-CAHA)       Labels:. 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 NP    HW: 03L 906 019 AL
   Component: R4 2,0L EDC   X29 9098
   Revision: 25X29---
   Coding: 12194012232503080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI03L906022NP A02009
   ROD: EV_ECM20TDI03L906022NP.rod
   VCID: 000FEE2D9B11514FA5-8054
4640 - Engine Oil Temp. Sensor (G8)
          P0197 00 [039] - Signal too Low
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:03:38
                    Engine speed: 830.50 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.360 V
                    Fl Sys dvol Fl Cons All Tot: 0.75 l/h
                    Engine oil temperature: 82.6 °C
                    Oil warning threshold: 35.856 mm
                    Control Module temperature: 28.4 °C
                    Oil fill level: 120.000 mm
                    Ambient temperature: 9.0 °C
                    Fuel temperature: 23.8 °C
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
          U1010 00 [039] - -
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:03:36
                    Engine speed: 830.00 /min
                    Normed load value: 31.8 %
                    Voltage terminal 30: 14.380 V
                    Accelerator position: 0.00 %
                    Accelerator pedal: sensor voltage 1: 752.8 mV
                    Accelerator pedal: sensor voltage 2: 376.0 mV
                    Accelerator pedal: switch positions-Bits 0-7: 8
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 65
                    Limiting torque: 159.3 Nm
   Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
   Component: ESP8 front    H04 0030
   Coding: 160504
   Shop #: WSC 06335 000 00000
   VCID: 7EF390D5E9E527BFD7-802A
   Part No SW: 8K0 907 064 CN    HW: 8K0 907 064 CN
   Component: BCM2 2.0      H04 0430
   Coding: 033200
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0510000049477006
   Serial number: 0210000171060006
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0180
   Revision: D0000000    Serial number: 01010920101301
   Coding: 34340000
   VCID: 76E388F5C1D56FFF8F-8022
01273 - Fresh Air Blower (V2)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 134
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:03:36
                    Temperature: 14.0°C
                    Voltage: 14.50 V
                    Current: 0.000 A
                    Voltage: 14.40 V
   Part No SW: 8K0 907 063 K    HW: 8K0 907 063 K
   Component: BCM1 1.0      H29 0392
   Revision: 06029001    Serial number: 00000000771685
   Coding: 690040B10034A7010001000000005F5F001D060806000141000000
   VCID: 377D45F1865FD6F754-8062
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 300810  H05 0070
   Serial number: SWF10080305641
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11041693
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001208101353
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941025000352
   Coding: 100203
   VCID: 489F360DFBA1A90F2D-801C
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0K4FTY
   Coding: 30363435363030303030554A3052384B3053
   VCID: 4487223DCF898D6FC1-8010
   Serial number: 6334MSME5622366FI
   Serial number: 6344MSME570348067
   Serial number: 6352QSME3A6F2C30S
   Serial number: 6362QSME026E1E24L
   Serial number: 63732SME6B6D42288
   Serial number: 63832SME75712600S
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90319JHK0001Y
   Coding: 000017
   VCID: 3D7157D9A463FCA78E-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 D    HW: 8K0 920 981 D
   Component: KOMBIINSTR.   H23 0258
   Revision: 00000000    Serial number: EJD59XV8A
   Coding: 2F04100002002600010000
   Shop #: WSC 31938 002 1048576
   VCID: 346772FD97293DEF71-8060
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10815020D
   Coding: 00CF07
   VCID: 0305E12182074A57B8-8056
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650374230
   Serial number: 10244000578021200181
   Part No SW: 8K0 959 793 N    HW: 8K0 959 793 N
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000107269220
   Coding: 011002204001410001
   VCID: 4B950901EAD7421700-801E
   Revision: 00002001    Serial number: 0134091803
   Coding: 013B062220B904408020023680000000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 134
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:03:40
   Part No SW: 8K0 959 792 N    HW: 8K0 959 792 N
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000107123379
   VCID: 4A9B0C05E5AD5B1F3B-801E
   Revision: 00000003    Serial number: 00000000723919
03182 - Clutch Position Sensor (G476)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 134
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:05:38
                    Voltage: 14.70 V
                    Count: 51
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H51 0051
   Revision: AB001007    Serial number: 469I30A7564425
   Coding: 010003020100000001
   VCID: 5EB3F0554925C7BFF7-800A
   Part No SW: 8T2 035 652 H    HW: 8T2 035 652 D
   Component: B-BN-EU       H60 0175
   Revision: --------    Serial number: 305AP0B7520619
   Coding: 01010100000681ED01000B0E000000030000
   Shop #: WSC 06325 000 00000
   VCID: 3B7559C1BA77F297B0-806E
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0084
   Serial number: 9465HX0A0027745
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000616971
                    Reset counter: 134
                    Mileage: 203330 km
                    Date: 2020.02.16
                    Time: 14:03:39
                    Voltage: 14.70 V
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000107571146
   Coding: 010002204001210001
   VCID: 45813F39CCB3B467D6-8010
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000107571143
End-------------------------(Elapsed Time: 03:22)--------------------------
I would start by checking the clutch position sensor circuit.
mogsy
C?ID=271117
Checked out the cost of a g476 sensor(it's part of the master cylinder) comes out as £170, considering the car also shows unidentified fault with the parking brake module, decided to buy a second user module at £20 thinking that I might change the switch at £300 inc labour which might not cure the fault, if the module does cure it £280 saving.
I did look at the parking brake in vcds and block 005 in measuring blocks did show clutch switch as working under interlock (providing thats the correct item) so gave me a bit of confidence to try the module 1st.
