2010 Passat DSG problems P1820, P1815, P0868
TheSchwartz
C?ID=227535
I recently purchased a 2010 Passat with a little over 100k. When I went to look at the car the owner told me that it was running well but occasionally suffered from a harsh shift. The purchase price was absolutely unbelievable, $1000! Knowing it was worth more than that in parts I threw my money at her and ran.
I have owned the car for a couple of weeks now and I can attest to the harsh shifting, along with an occasional fight over getting it into reverse. So, after some reading and a scan that revealed a P0868 code, I decided to re-calibrate the DSG using the guide at Ross-Tech. This here is where the real problems begin. After the calibration I took the car for the prescribed test drive. What follows is my experience on that drive and the subsequent drives.
Test drive:
Car fights to go into reverse, whines and shifts hard, barely gets out of parking space
Shifts into 1st normally in D, shifts normally into second.
At first stop the car shifts back into 1st.
Pulling away the car shifts from 1st to 2nd and then the gear position indicator on the dash panel disappears!
Coming to a stop the car shifts back into 1st and will not shift no matter what I try.
I limp the car around the block in 1st and finally park it and turn it off.
Second and subsequent drives:
Car fights to go into reverse and whines, sometimes not going into reverse at all and the indicator light either flashes (uncommon) or disappears (very common).
Shifts into 1st with a clunk and almost always with a whine, but only on the first time getting into 1st
Shifting into 2nd there is a slipping and a chatter and will slip and/or chatter if you apply heavy throttle especially at low speed
Shifting into 3rd comes with a clunk but other than that seems to perform fine in 3rd, no chatter or slip
Shifting into 4th mild slipping and/or chatter again worse under load at low speeds
5th and 6th seem to perform well but its difficult to tell because the car is moving fairly quickly to load the gear up (there are no hills in New Orleans to really load the gear up)
I have ordered the fluid and filter to do a DSG fluid change and will perform that maintenance asap. The first scan with the P0868 code will be below as well as the scan after the calibration that came with code P1820 and P1815. I am currently debating testing and changing the solenoids associated with those codes. Any advise on the matter is greatly appreciated.
FIRST SCAN
 Chassis Type: AN-VW46 (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
          77
VIN: WVWJK7AN0AE05XXXX   Mileage: 168850km-104918miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    6987
   Revision: AAH08---    Serial number: VWZCZ000000000
   Coding: 0404010A1C070160
   Shop #: WSC 05095 444 14819
   VCID: 6C81C2E31A8F6E8705F-8038
006439 - Relay for Aux Coolant Pump (J496)
               P1927 - 000 - Open Circuit
                    Mileage: 168059 km
                    Date: 2014.04.15
                    Time: 08:52:60
                    Temperature: 90.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1010.0 mbar
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Fault Frequency: 12
                    Mileage: 168822 km
                    Date: 2014.07.06
                    Time: 09:53:31
                    RPM: 1433 /min
                    Load: 22.0 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
   Part No SW: 02E 300 051 P    HW: 02E 927 770 AM
   Component: GSG DSG AG6     531 1979
   Revision: 06253104    Serial number: 00001506252006
   Shop #: WSC 04940 001 00001
   VCID: 2019E6D3A6C77AE7E97-8074
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 168446 km
                    Date: 2014.06.26
                    Time: 13:21:60
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795656837
   Coding: 0000380
   Shop #: WSC 05311 000 08193
   VCID: 629DACDBE84B28F7BF3-8036
   Part No SW: 1K0 820 047 JT    HW: 1K0 820 047 JT
   Component: Climatic PQ35   143 1515
   Revision: 00143034    Serial number: 00000000000000
   VCID: 7F5B05AF7BF9E51FB0D-802A
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
   Revision: 00H54000    Serial number: 00000003332387
   Coding: 15848F0340041000470000000F00000000285D435C000120000000000000
   Shop #: WSC 05124 067 57207
   VCID: 3333199F0731F17F045-8066
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 310809 006  0208
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__01T VW10 HI   1916
   Revision: 20013000    Serial number: 003E1PJDN9XB
   Coding: 0012628
   VCID: 42DD4C5B488B48F79F3-8016
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 00000000004H10
   Subsystem 3 - Serial number: 0023.06.090000100000850062ÿ†63
   Subsystem 4 - Serial number: 850062ÿ†6332MTS662122649 ÿ†63
   Subsystem 5 - Serial number: 22649 ÿ†6342MTS679972369 ÿ†63
   Subsystem 6 - Serial number: 72369 ÿ†6351HTS6BBHP09KJ ÿ†63
   Subsystem 7 - Serial number: P09KJ ÿ†6361HTS69BDV09KJ ÿ†63
   Subsystem 8 - Serial number: V09KJ ÿ†63727TS68QS019KR ÿ†63
   Subsystem 9 - Serial number: 019KR ÿ†63827TS6RPS019KJ ÿ
   Subsystem 10 - Serial number: 019KJ ÿ
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CN
   Coding: 0001711
   Shop #: WSC 05314 000 00000
   VCID: 74B1DA8342BFB647DDF-8020
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6   H05 0022
   Coding: 00000226
   Part No SW: 3C0 920 972 E    HW: 3C0 920 972 E
   Component: KOMBI         H02 0206
   Coding: 260F00
   Shop #: WSC 05314 115 00000
   VCID: 2809FEF3C27782A7A17-807C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P0992905F6
   Coding: FD807F07001602001002
   VCID: 2A0D04FBD0FBB0B7B73-807E
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 11:00:44
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T0C0G02
   Coding: 0000002
   VCID: 75B7E78749C5AF4FEA1-8020
   Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 77129 444 25107
   VCID: 78A9EEB35ED7D227F17-802C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 50
                    Mileage: 168670 km
                    Date: 2014.07.02
                    Time: 10:39:05
02861 - Electronic Steering Column Lock Check Sum Error
                    Fault Frequency: 15
                    Reset counter: 68
                    Mileage: 165154 km
                    Date: 2014.03.28
                    Time: 10:00:45
   Part No SW: 1K0 959 701 AR    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1501
   Revision: 72009005    Serial number: 00000509098923
   Coding: 0001205
   Shop #: WSC 05311 000 00000
   VCID: 7EA5F8AB7CF3EC17BBB-802A
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.148 0703
   Revision: 1AH03256    Serial number: 00092230120102
   Coding: 0000258
   VCID: 3A2D34BB205B0037C73-806E
00750 - Warning Lamp
                    Fault Status: 00101100
                    Reset counter: 69
                    Mileage: 168566 km
                    Date: 2014.06.29
                    Time: 21:35:44
                    (no units): 4.0
                    Voltage: 11.90 V
   Component:    KSG PQ46 RDK 052 0412
   Coding: 13910F8001862E521004141FF08A0F0E085801
   Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1501
   Revision: 72009005    Serial number: 00000902998918
   Coding: 0001204
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000034936
   Coding: 0000057
   VCID: 2C0102E3DA0FAE8745F-8078
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0034
   Revision: -----19S    Serial number: VWZ4Z7J1119975
   Coding: 0500040004
   VCID: 619FA3D7E14D33EFA69-8034
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 32
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:43:59
                    Reset counter: 208
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:44:07
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 12:08:05
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0308
   Revision: 42004101    Serial number: 00000001076882
   Coding: 0001168
   VCID: 72BDDC9B38ABB877CF3-8026
   Component:    RDK              0453
   Coding: 0100101
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0308
   Revision: 42004101    Serial number: 00000001023304
   Coding: 0001168
   VCID: 73B3D99F47B1B17FC45-8026
Address 77: Telephone
End----(Elapsed Time: 01:46, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
SECOND SCAN
          77
VIN: WVWJK7AN0AE05XXXX   Mileage: 168870km-104930miles
                    Mileage: 168059 km
                    Date: 2014.04.15
                    Time: 08:52:60
                    Temperature: 90.0°C
                    Temperature: 51.0°C
                    Fault Frequency: 12
                    Mileage: 168822 km
                    Date: 2014.07.06
                    Time: 09:53:31
                    RPM: 1433 /min
                    Load: 22.0 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -
                    Mileage: 168871 km
                    Date: 2014.07.08
                    Time: 13:38:42
                    RPM: 2098 /min
                    Load: 16.1 %
                    Temperature: 81.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1020.0 mbar
18228 - Pressure Control Valve 2
            P1820 - 008 - Short to Plus - Intermittent
                    Reset counter: 39
                    Mileage: 168856 km
                    Date: 2014.07.08
                    Time: 11:00:58
18223 - Pressure Control Valve 1
            P1815 - 008 - Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 168871 km
                    Date: 2014.07.08
                    Time: 13:38:23
   Coding: 0000380
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012628
   Coding: 0001711
   Coding: 00000226
   Coding: 260F00
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 11:00:44
   Coding: 0000002
                    Reset counter: 50
                    Mileage: 168670 km
                    Date: 2014.07.02
                    Time: 10:39:05
                    Fault Frequency: 15
                    Reset counter: 68
                    Mileage: 165154 km
                    Date: 2014.03.28
                    Time: 10:00:45
   Coding: 0001205
   Coding: 0000258
                    Reset counter: 69
                    Mileage: 168566 km
                    Date: 2014.06.29
                    Time: 21:35:44
                    (no units): 4.0
                    Voltage: 11.90 V
   Coding: 0001204
   Coding: 0000057
   Coding: 0500040004
                    Fault Status: 00101011
                    Reset counter: 33
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:43:59
                    Reset counter: 208
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:44:07
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 12:08:05
   Coding: 0001168
   Component:    RDK              0453
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:44, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
DrPeter
16.4905° S, 151.7375° W
If the vehicle has the above fault code, the factory Guided Fault Finding test plan states the following:
17252 - Transm. press. adaptation at limit stop
Possible malfunction cause:
- Transm. faulty.
(then the test plan continues)....
Replace the Dual-clutch transmission (DSG).
=> Repair manual 6-speed twin-clutch transmission 02E Rep.Gr.34.
Personally, I would drain the DSG fluid, remove the filter and mechatronics and perform visual inspection to see if there is any indication of damage, sludge or other concerns before ever replacing the transmission.
You may be able to "testing and changing the solenoids" and replace the DSG fluid and filter and not have any issues. I would say if the internals look good, then it maybe worth a try.
I have an Audi A3 with over 200k miles on the original DSG, so they can last, but if it did fail, I would seriously consider a manual swap. ;)
We recommend to use the Official Factory Repair Information when attempting repair and diagnoses on these vehicles.
Hope this helps,
drpeter
Gone But Not Forgotten
Did you document the safety and SMOG failure with NHTSA/EPA for failing useful life or as certified yet and required replacement under warranty at dealer for free or reimbursed?
Were you dumb enough to consider buying a new one yet? ........... :rolleyes:
Posting the actual VIN might be more helpful than you realize?
JPPSG yet the entire thread?
Component: GSG DSG AG6 531 1979 <<<<<<<<<<<<<<<<<<<<<< I often wonder why this doesn't match the certificate, do you?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=25131&flag=1
Don't forget to cross your part numbers and CVN for more FOD fun, well did you on page 152 and page 54 of other type certificate for ORVR used?
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=25129&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=25130&flag=1
TheSchwartz
C?ID=227535
please elaborate on
"Don't forget to cross your part numbers and CVN for more FOD fun, well did you on page 152 and page 54 of other type certificate for ORVR used?"
and
"Did you document the safety and SMOG failure with NHTSA/EPA for failing useful life or as certified yet and required replacement under warranty at dealer for free or reimbursed?"
as well as your statement on certificate matching, as I am very intrigued by all of these statements.
I am unfamiliar with the Calibration data lookup as well
I have not purchased a new one, nor do I intend to unless all other options are exhausted. Currently I am still trying to gather all the information possible to assist me in making an intelligent decision on the correct course of action. I was under the impression that at 105k mi that this vehicle is out of warranty.
the full VIN is WVWJK7AN0AE057532
All of a sudden I feel like Im in school again!
Hey what's this?
What was the date of delivery of your vehicle & into commerce?
Vehicle Identification No.WVWJK7AN0AE057532
Modelpassat sedan
PA
Date of production15.10.2009
Model year2010
Sales type3C25LD
Engine CodeCCTA
Transmission CodeLQY
Emission standard7GBEmission standard ULEV 2
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR)
and siphoning device for fueling
PART NUMBERDESCRIPTIONREMARKMODEL
* 02E 300 051 PX 00X6-speed dual clutch gearboxLQYNot available
Dropped: Jan 1, 2012 (EKZ: L)
Vehicle intelligent genuine part.
Order only with additional instructions.
Super-session
02E 300 053 AX 00N6-speed dual clutch gearbox
06J 990 990 CControl unit for petrol engine06J 906 026 DA
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0HGVehicle class differentiation -3C0-
Trailer hitch1D0Without trailer hitch
airbag4UBAirbag for NAR
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Storage compartment packageQE2Storage compartment
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8XUS comfort equipment
Brake type in rear1KWDisc brakes in rear
batteriesJ0LBattery 340 A (70 Ah)
Brake type, front1ZGDisc brakes in front (Geomet D)
Beverage holders4M9Beverage holders
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DComponent parts set, complying with vehicle type for USA (without California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
General operating permit, alterationsC21Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts7TMDecorative inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running light -- NAR --
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G7tiptronic
Weight category rear axle0YEWeight range 5 installation control only, no requirement forecast
Weight category front axleL03Suspension range 03 installation control only, no requirement forecast
Base engineTQ24-cylinder SI engine 2.0 l unit 06J.B
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG1A6-speed automatic transmission
Cruise control system and speed limiter6Y9without cruise control system
Brackets3P0Without bracket for first aid kit and warning triangle
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without customized installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8BNotchback
Luggage compartment floor covering6SELuggage compartment floor covering in flat needle-punched nonwoven
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR1With compass
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C1Body measures for increased safety requirements
Radiator grille6KARadiator grille
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Load edge protection2P1Plastic loading edge protection
Lumbar support7P7Power-adjustable lumbar support for left front seat
steering wheels2PPLeather-wrapped multi-function steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Center console3I5Center console
Engine cooling8Z6Hot country
Engine specificationsD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Left vanity mirror4SQLeft vanity mirror illuminated with cover and special mirror imprint (NAR)
Right vanity mirror4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WDIntegrated front fog lamps
Hubcaps1NLTrims for alloy wheels
WheelsCA5Alloy wheels 7.5J x 17
Radios8AXRadio Premium 8
Smoker's/non-smoker's package9JFNon-smoker's package (NAR)
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
umbrellaNS0Without umbrella(s)
tireHK1All-season tires 235/45 R17 97H xl (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SLTaillight assemblies with diodes (LED) (for NAR)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFComfort seat in front, left
Front seat, right3SFComfort seat, front right
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN1SSeat trim covers in leatherette
Seat adjustment3PBPower seat on the left, right seat with manual height adjustment
seat heater4A3seat heating for front seats separat controlable
Side lights8F1Side-marker lamps
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B4Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
power outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0PKNameplate set "FSI"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB34Legal requirements for USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Transit coatingNT1Transit coating (type 2)
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Assembly parts for engine (drive bearing)1VGInstallation parts for four-cylinder engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W3Mobile phone interface High (NAR)
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZBBright decorative trims
Additional child seat anchors3B3Child seat anchors
Auxiliary heating system9M0Without auxiliary heater/parking heater
TheSchwartz
C?ID=227535
are you trying to tell me that the vehicle is still under warranty?
Please answer the aforementioned questions in last post or maybe you see the self evident answers already?
TheSchwartz
C?ID=227535
I am not the original owner so I am unsure of the date of delivery but I did notice the date listed under that gearbox. The vehicle has 104k on it. Should I be on the phone with a stealership?
Did you JPPSG and look up useful life warranty as described under CARB/EPA and as certified by the OEM?
Did you read the certificates and application and for any inconsistencies as certified or with public ADR filed or that would lead you to believe you have a claim?
Did you do your home work yet or talk to a good lawyer or governing agency?
TheSchwartz
C?ID=227535
I have tried to look up this "useful life warranty" that you speak of but Im getting nowhere quick. The second sentence in your last post makes even less sense to me. As far as I can tell the warranty on my vehicle was for 5 years or 60k from the date of purchase, and even if it was purchased in 2012, the warranty would have expired long ago. Unless you can give me a very good reason to call a lawyer, I will continue to avoid them. Honestly I apprieciate that your trying to help me but I feel like I'm more lost than when I started. As far as the JPPSG is concerned the only thing i can gather is that you need a copy of the build tag, so I have included it in my post.
Im not trying to be annoying, I just dont understand what your trying to tell me.
Did you or are you going to read the entire JPPSG thread yet, all pages?
TheSchwartz
C?ID=227535
I have read the entire thread. I found post #42 particularly interesting, however I fail to see how it would relate to my current problem. I did notice that you wanted to get a copy of the OBD II data so I will also include that here. If there is something I am still failing to see please feel free to point it out. Thanks again for your help.
 Monday,17,February,2020,16:48:04:18846
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWJK7AN0AE057532   License Plate:
Mileage: 168910km-104955mi   Repair Order:
          77
VIN: WVWJK7AN0AE057532   Mileage: 168910km-104955miles
   VCID: 6C81C2E31A8F6E8705D-8038
                    Mileage: 168059 km
                    Date: 2014.04.15
                    Time: 08:52:60
                    Temperature: 90.0°C
                    Temperature: 51.0°C
                    Fault Frequency: 12
                    Mileage: 168822 km
                    Date: 2014.07.06
                    Time: 09:53:31
                    RPM: 1433 /min
                    Load: 22.0 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
               P1624 - 000 -  - Intermittent
                    Mileage: 168871 km
                    Date: 2014.07.08
                    Time: 13:38:42
                    RPM: 2098 /min
                    Load: 16.1 %
                    Temperature: 81.0°C
                    Temperature: 42.0°C
008583 - Bank 1; System too Lean at Idle
               P2187 - 000 -  - Intermittent
                    Mileage: 168878 km
                    Date: 2014.07.09
                    Time: 10:08:59
                    RPM: 883 /min
                    Load: 26.3 %
                    Speed: 3.0 km/h
                    Temperature: 71.0°C
                    Temperature: 25.0°C
   VCID: 2019E6D3A6C77AE7E95-8074
                    Reset counter: 34
                    Mileage: 168856 km
                    Date: 2014.07.08
                    Time: 11:00:58
                    Reset counter: 38
                    Mileage: 168871 km
                    Date: 2014.07.08
                    Time: 13:38:23
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Coding: 0000380
   VCID: 629DACDBE84B28F7BF1-8036
   VCID: 7F5B05AF7BF9E51FB0F-802A
   VCID: 3333199F0731F17F047-8066
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012628
   VCID: 42DD4C5B488B48F79F1-8016
   Coding: 0001711
   VCID: 74B1DA8342BFB647DDD-8020
   Coding: 00000226
   Coding: 260F00
   VCID: 2809FEF3C27782A7A15-807C
   VCID: 2A0D04FBD0FBB0B7B71-807E
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 11:00:44
   Coding: 0000002
   VCID: 75B7E78749C5AF4FEA3-8020
   VCID: 78A9EEB35ED7D227F15-802C
                    Reset counter: 50
                    Mileage: 168670 km
                    Date: 2014.07.02
                    Time: 10:39:05
                    Fault Frequency: 15
                    Reset counter: 68
                    Mileage: 165154 km
                    Date: 2014.03.28
                    Time: 10:00:45
   Coding: 0001205
   VCID: 7EA5F8AB7CF3EC17BB9-802A
   Coding: 0000258
   VCID: 3A2D34BB205B0037C71-806E
                    Reset counter: 69
                    Mileage: 168566 km
                    Date: 2014.06.29
                    Time: 21:35:44
                    (no units): 4.0
                    Voltage: 11.90 V
   Coding: 0001204
   Coding: 0000057
   VCID: 2C0102E3DA0FAE8745D-8078
   Coding: 0500040004
   VCID: 619FA3D7E14D33EFA6B-8034
                    Reset counter: 38
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:43:59
                    Reset counter: 208
                    Mileage: 144652 km
                    Date: 2013.01.15
                    Time: 11:44:07
                    Reset counter: 248
                    Mileage: 162326 km
                    Date: 2013.12.01
                    Time: 12:08:05
   Coding: 0001168
   VCID: 72BDDC9B38ABB877CF1-8026
   Component:    RDK              0453
   Coding: 0100101
   Coding: 0001168
   VCID: 73B3D99F47B1B17FC47-8026
End----(Elapsed Time: 01:43, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
 Monday,17,February,2020,16:45:44:18846
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: 1 Fault Found:
P0747 - Pressure Control Solenoid 1: Stuck ON
Let me ask a series of questions & to gain a perspective or what we might ascertain, okay?
Are not the transmission and engine controller, AECD'S and which are responsible for illumination of the MIL or for SMOG fault's and the absolute control devices to maintain the proper controlled remediated GHG output?
How is it possible the controllers can comport for proper operation without a valid ADR or matching CVN as disseminated for free in the public view & if application's or from OEM website & if a DTC exists or are non functional?
Could not one argue that if the firmware levels are not the same as certified & without public disclosure, such as the transmission for example, doesn't this further imply it never comported to begin with & if no ADR exists or recall to prove the service action, would it not be subject to warranty, a safety recall or being repurchase regardless of mileage?
So you are telling me that while having a hard DTC and registered in the OBD2 side of mode 3, that no MIL exists and the firmware is of an unapproved version as disseminated on the conformity application, without ADR and not represented on the OEM's website as required by law, is that right?
Could you please post mode 9 too?
I see you deleted your post where you said there was no MIL why?
Try some Liquid Schwartz yet?
TheSchwartz
C?ID=227535
I removed my post to give myself time to understand exactly what is going on here. I think I’m getting what your saying but I am unsure how to proceed with the information provided.
I will get a mode 9 when I return home
Use the Schwartz!
TheSchwartz
C?ID=227535
I spoke with a service writer at vw today and he provided me with the build date Oct 15, 2009 and the delivery date Mar 17, 2010. Im hoping that the delivery date and the commerce date is the same thing, mostly because he had no idea what I meant by "the date the vehicle was introduced into commerce", I know that feeling.
Number 9
Tuesday,18,February,2020,09:53:13:18846
Type 02 - VIN : WVWJK7AN0AE057532 (Address E8)
Type 04 - Calibration ID : 06J906026DA 6987 (Address E8)
Type 04 - Calibration ID : 02E300051P  1979 (Address E9)
Type 06 - Calibration Verification Number : DF9B96A2 (Address E8)
Type 06 - Calibration Verification Number : 00002236 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 3901
    Ignition cycle count : 14637
         Catalyst monitor bank 1 : 1426 / 3805
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 1098 / 3878
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 12787 / 3901
         AIR monitor : 0 / 0
         EVAP monitor : 2183 / 787
         Secondary O2 Sensor monitor bank 1 : 2312 / 3805
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Additionally, I wanted to note that, sometimes the MIL is on but usually its off.
