2005 New Beetle 1.8 turbo conv air bag light on
WalterB
C?ID=384032
can the airbag control module be reset from code" 00003 /014 defective" VCDS release 19.6.2
Thursday,09,January,2020,15:46:16:05114
VIN: 3VWCD31Y55M350443   License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
VIN: 3VWCD31Y55M350443   Mileage: 118890km-73874miles
Address 01: Engine        Labels: 06A-906-032-BKF.lbl
   Part No: 06A 906 032 QT
   Component: 1.8l 5VT NB MT      6477
   Coding: 00001
   Shop #: WSC 13813
   VCID: 0059872DB3123CA7C97-513C
   3VWCD31Y55M350443     VWZ5Z0D9188110
Readiness: 0100 1100
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 34311BFDB22A50071DF-5160
   Part No: 6Q0 909 605 AF
   Component: 01 AIRBAG VW71      0609
   Coding: 0012337
   VCID: 7BA3F0C1DFF45F7F9C5-5160
   Subsystem 1 - Part No: 1C0 959 339 B
   Component: BF-Gewichtsens. 006 0006
00003 - Control Module
            014 - Defective
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 F
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11232
   VCID: 2411EBBD07CAC0878DF-4B1E
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D7ED83B22C27397-4B00
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255 C
   Component:  VSG  NBC       ¤
   VCID: 40D9472DF692FCA7897-513C
            014 - Defective
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: 3B2330C19A749F7FDC5-4B00
   Subsystem 1 - Part No: 1Y1959801C
   Component: 6J Tõrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802D
   Component: 6J Tõrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: Tõrsteuer.HL KLO 0005
   Subsystem 4 - Part No: 1Y0959812
   Component: Tõrsteuer.HR KLO 0005
01358 - Internal Central Locking Switch; Driver Side (E150)
End----------(Elapsed Time: 04:03, VBatt start/end: 12.1V/12.1V)-----------
In this airbag module, I don't think so.
WalterB
C?ID=384032
Thank You. if i get a used one can VCDS make it useable on this car?
You would need the exact, correct airbag module for this car. The main part number alone, "6Q0 909 605 AF" is not sufficient to spec a module for these cars. You need index or color code 001, so the full spec would be, "6Q0 909 605 AF /001".
Trouble is most everyone who sells used parts is unaware of this.
If you get the correct part for the car, it should be plug & play (aside from possibly clearing fault codes). If you get the wrong index, there's nothing VCDS can do for you.
WalterB
C?ID=384032
Thank You
the old one is in my lap. the part # is 6Q0 909 605AF The index is" H/S Index : 06 09" other numbers # AE4,220 4381-21,*0037FS1B*,37040101
do you know if i can get one to use for this car with these numbers?
Walt
WalterB
C?ID=384032
the index should have been HW/SW sorry
