So first time posting here, as I usually do all my research and fix most problems without the need of additional questions.
However, this is a tough one, as for right now I'm out of ideas, and the only option seems the dealer, which I don't want to take just yet.
Issue is with ACC/Braking Guard Not Available message.
Its been a while since I had this problem, did a scan, and the fault code is ( that I think its related to the problem ) :
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:21
Outside air temperature: 26.5 °C
Voltage terminal 15: 14.0 V
Control Module temperature: 36.0 °C
Now, the system is made of.....windshield camera ( behind the rearview mirror ), image processing module ( under passenger side carpet ), and optical cable, that connects the camera to the processing module.
First step, and most obvious, purchased a new cable. replaced it......no change. bummer.
Second step.....I figured it might be the camera, maybe the output optical cable plug was messed up, so I purchased a used one, but know to be working ( even thou when accessing the camera module with vcds, no errors )…….and surprise, no result, same exact error.
So last step, for same considerations, I purchased a used processing module, also known to be working, and......still nothing.
The same exact error returns.
I'm not sure where to look next.
I even verified the new cable with a multimeter, just to make sure, and its good.
Any ideas would be appreciated.
Are any of the electric wires that connect to the processing module, somehow connected or related to the optical cable? like if a wire to be broken or something, and this way the information from the camera is not processed anymore, yet giving me the "Signal Failure" message for the optical cable?
Does anyone have the wiring diagram for this module?
Like I said, any ideas would be appreciated.
thanks.
Here's the full scan.
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:21
thanks.
Saturday,21,December,2019,16:18:16:54977
VCDS Version: 19.6.2.0 (x64)
VIN: WAUSGAFC6CN006997 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUSGAFC6CN006997 Mileage: 163085km-101336miles
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH05 0007
Revision: --H05---
Coding: 1A2A0034056600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003008
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 275DCC525E3BD577C6-8072
6143 - Fan 2 Control Circuit
P0693 00 [039] - Short to GND
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:19
Engine speed: 716.00 /min
Normed load value: 12.2 %
Coolant temperature: 54 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.913 V
Engine speed: actual: 704 /min
MAF_ENVD: 119.83529 mg/stroke
Coolant temperature (unfiltered): 54.75 °C
Engine: operating status: IS
Engine load: 12.109375 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1100
Part No SW: 4G0 927 158 E HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
Shop #: WSC 46139 001 1048576
ASAM Dataset: EV_TCMAL551211 002018
VCID: 306F270E6BF592CF17-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Coding: 44A70F0222E5F0404B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR
Component: BCM2 2.0 H24 0217
Coding: 0D8A2000000000000000
VCID: 79F9DA2AF00F9387E0-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000094647005
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0056
Serial number: 11051100040057
Coding: 6603207A1C
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 285FCF6E5325DA0FCF-807C
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000001058945
Coding: 0D072015473E9FE081000884A0003820CF9CD308A2090125800308453B00
VCID: 2C57337E4FDDF62F2B-8078
Component: WWS57X 110505 H35 0051
Serial number: 110506135617
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11430731
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 06 05 2011 00000205
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0G7C06
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0006120718
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001104181278
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001104181257
Subsystem 8 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA102275000000263945
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 9E6884A5000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001104042341
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001104042624
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000006
VCID: 2D513E7A74C7FF273C-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901108400698
Coding: 302904
Shop #: WSC 42399 444 11057
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 39791A2AB88F5387A0-806C
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 67DD8C529EBB157706-8032
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:13
Control Module temperature: 32 °C
Voltage terminal 15: 14.022 V
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D800151B%
Coding: 303145313131303030324A55304C34473853
VCID: 336528029AE3A9D76A-8066
Serial number: 6940000Y150001FH9M0.
Serial number: 3575HRB40690HM78694
Serial number: 3585HRB40590HM7670D.
Serial number: 3515JRB405P0H4DUB8S1
Serial number: 3525JRB40550H4DUL0DC
Serial number: 3554VRB405D0GR363OKZ
Serial number: 3564VRB405D0GR368OK+
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KE5001ZB
Coding: 0000FC
VCID: 377D1C12869B45F756-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 18 03 2011 B0011307
Part No SW: 4G8 920 981 M HW: 4G8 920 981 M
Component: TBenUsaAccNv H34 0312
Revision: 19100074 Serial number: 658290411593023
Coding: 0BCF01064F03D705020100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 3D710E3AACA76FA78C-8068
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000150630
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650421594
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 12051100040260
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 2F6D247276CB8D370E-807A
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006094323
Coding: C0581B008F002001000001010101102030303232203232
VCID: 387F1F2E8B854A8F5F-806C
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200VMDN0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D513E7A7CC7FF273C-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000007
VCID: 2F6D2472BECB8D370E-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F19.04.1100H010003CD20089ÿ
Subsystem 4 - Serial number: D20089ÿ
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F57225E00628002000003
Shop #: WSC 02312 785 00200
VCID: 3F8D7432AEAB7DB79E-806A
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0013074818
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B2D0665F9A0DF61-8066
Revision: 00002001 Serial number: 0149037178
Coding: 0126063A20FAF48583B00AC0020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000032298
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1204354-
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00000267442
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA121266000014398465
00510 - Motor for Wind Deflector (V252)
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:16
Part No SW: 4G0 035 465 A HW: 4G0 035 465
Component: BO G3 C7 H07 0130
Revision: 05S00000 Serial number: 0012390
VCID: 2345D842220339579A-8076
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 02003110002204
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F57225E00628002000002
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000073661
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5B35664D29E81FD9-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110513-0004-097
Coding: 1223A6601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57337E47DDF62F2B-8078
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H51 0112
Revision: AB001007 Serial number: 156E+0B7506883
Coding: 020007010000000001
VCID: 2149D24A381F2B4788-8074
Part No SW: 4G0 035 746 B HW: 4G0 035 746
Component: H-BNT-NA H48 0549
Revision: -------- Serial number: 031EW0B7505793
Coding: 090200040003EDFF7D168F2E00000003100001000000000000
VCID: 2643C1565131CC7FFD-8072
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300RN2Q
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Serial number: 90349KEA00089
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:18
Text: DUA009,Front,M,0,0,6
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:21
Bin. Bits: 00000000 00000000
Bin. Bits: 00000010 00000000
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F17224000628002000002
VCID: 428B7DC6DD59105FF1-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F0VL
Coding: 1020013
VCID: 2541C65AEC37C767F4-8070
Part No SW: 4G8 959 107 E HW: 4G8 959 107 A
Component: HDSG-Modul H12 0036
Revision: 12012001 Serial number: 105100083
Coding: 0A3205C100
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 377D1C128E9B45F756-8062
Component: TSG HR H03 0210
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 HW: 4G8 919 604
Component: HeadUpDisplay 025 0042
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 70EFE70EAB75D2CF57-8024
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40032878
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 3169220A60FF9BC718-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001108100464
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C1865A64B7076734-8030
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040181407117
Coding: 038198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2541C65A2437C767F4-8070
Reset counter: 50
Mileage: 163085 km
Date: 2019.12.21
Time: 16:10:21
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FEDE472B64BCD374E-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 07:19)--------------------------
