Audi A6 (C7) - ABS / Parking Brake / Additional faults...
JohnnyFiama
C?ID=288500
Hi Everyone
I love my Audi A6 (C7) but recently it has become expensive to run :(
...not entirely its fault, a few months ago we were involved in a hit and run (no, we weren't doing the running) and soon after it required new injector seals (completly unrelated). Earlier this evening I was happily driving along the mortorway with cruise control enabled, and then all of a sudden the dash illuminated with faults and cruise control disengaged.
Friday,20,December,2019,21:25:00:28420
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: <<REDACTED>>   License Plate: <<REDACTED>>
Mileage: 134136km-83348mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 56 5F
          62 69 72
VIN: <<REDACTED>>   Mileage: 134136km-83348miles
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X37 0005
   Revision: 53X37---
   Coding: 12254012053601020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: A600A5CAD988897F7D-80F2
          U1113 00 [047] - -
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
                    Engine speed: 1776.50 /min
                    Normed load value: 1.6 %
                    Vehicle speed: 117 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 14 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.740 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 104
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 122.82 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [047] - -
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
                    Engine speed: 1777.50 /min
                    Intake air temperature: 15 °C
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [047] - -
          [Data bus on board diagnostic interface -J533please read DTC]
                    Mileage: 132463 km
                    Date: 2019.10.30
                    Time: 08:38:03
                    Engine speed: 885.00 /min
                    Normed load value: 35.7 %
                    Coolant temperature: 8 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 13.460 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0003
   Revision: --H10---    Serial number: 0000000570
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: AC1457E2C764B32FAB-80F8
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 27A68701E465E180FB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: B620758A0928F9FFCD-80E2
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Ldm_ApbFailureState]
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:24
                    VzRef: 75
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 72
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: B2
0607 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 19
                    Mileage: 132664 km
                    Date: 2019.11.11
                    Time: 13:49:16
                    VzRef: 3D
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2B
                    Uz: B4
0632 - Tire Pressure Warning
          C102D 00 [008] - -
                    Fault Frequency: 29
                    Reset counter: 34
                    Mileage: 133145 km
                    Date: 2019.11.24
                    Time: 14:24:30
                    VzRef: 47
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2F
                    Uz: B1
0362 - Front Right Wheel Speed Sensor
          C101B 07 [137] - Mechanical Failure
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
                    VzRef: 83
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 36
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: C2
                    Uz: B3
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01B93006000000000000
   VCID: F6A0B58A41A8B9FF0D-80A2
   Serial number: 2311000302789014
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:11:40
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0064
   Serial number: 23011200041183
   Coding: 3622000820
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: A404BFC2AFB47B6F63-80F0
0027 - Motor for Defroster Flap
          B1090 07 [008] - Mechanical Failure
                    Reset counter: 19
                    Mileage: 132642 km
                    Date: 2019.11.10
                    Time: 09:49:44
                    Voltage terminal 30: 13.34 V
                    Outside air temperature: 2.0 °C
                    Interior temperature: 0.82 °C
                    Defroster flap motor-Act.val.: 11282
                    Defroster flap motor-Specified value: 11235
                    Defroster flap motor-Stop open: 11276
                    Defroster flap motor-Stop closed: 10000
0275 - Development code 1
          B2F01 00 [008] - -
          [PTC–Zusatzheizung dauerhaft leistungsreduziert Entwicklungscode 2]
                    Fault Frequency: 79
                    Reset counter: 47
                    Mileage: 132463 km
                    Date: 2019.10.29
                    Time: 18:53:54
                    Voltage terminal 30: 13.86 V
                    Outside air temperature: 5.0 °C
                    Energy management heat output control status: not active
                    Electric auxiliary air heater: stage: 1
   Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0111
   Revision: 20012002    Serial number: 00000001204559
   Coding: 2600A01041349FE00181008300001D0C4F9DE70827090101000004602100
   VCID: F5A2B2865CAEB2E704-80A0
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 111217  0051
   Serial number:         120109160917
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20038639
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 19 01 2012  00000772
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: 2F08CD06000000000001
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901200501004
   Coding: 090308
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: BD326AA62C1E2AA70C-80E8
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG006GWLR
   Coding: 30323436313330303537554A305234473053
   Serial number: 3575HRB405V124B2BPBA
   Serial number: 3585HRB4061124B2DPBR
   Serial number: 3515JRB40650TQMC6GF/
   Serial number: 3525JRB4053126SE39BT
   Serial number: 3554VRB40510V8BO59FR
   Serial number: 3564VRB40510V8BO21EG
1049350 - Databus
          [CAN: 0x103 ESP_03 error value ESP_VR_Radgeschw]
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
1049605 - Databus
          [CAN: 0x084 ESP_06 error value ESP_v_ref]
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:24
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20120120001292
   Coding: 000035
   VCID: B02C4392E34CD7CF97-80E4
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
   Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
   Component: TDieGb        H79 0416
   Revision: 28460177    Serial number: 658110112596009
   Coding: 33AF10000B012600010000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU57.rod
   VCID: BC3467A2370423AF3B-80E8
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000370316
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: B4244F821F54EBEFF3-80E0
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790741035
   Voltage stabilizer:
   Serial number: 12024000324021200181
6657 - Generator
          U1052 00 [009] - No Communication
                    Reset counter: 228
                    Mileage: 132463 km
                    Date: 2019.10.29
                    Time: 18:52:33
                    Voltage terminal 30: 14.0 V
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 22 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 113
                    Reset counter: 46
                    Mileage: 132463 km
                    Date: 2019.10.29
                    Time: 21:01:45
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 11 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 41
                    Reset counter: 46
                    Mileage: 132463 km
                    Date: 2019.10.30
                    Time: 00:05:00
                    Voltage terminal 30: 12.1 V
                    Control Module temperature: 8 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA32018YCB0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: EB9694FE02EA7417E2-80BE
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16204001620002080002
   VCID: C2C8195A5DE0555F71-8096
   Part No SW: 4G0 909 144 K    HW: 4G0 909 144 G
   Component: RCEPS         H35 0009
   Revision: 00001000    Serial number: 0007299431
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 007007
   ROD: EV_RCEPS_007.rod
   VCID: B12A4696E046DEC798-80E4
3164944 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Fehlerwert "Radgeschwindigkeiten"]
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:24
                    Write only channel
   Revision: 00002001    Serial number: 0168441168
   Coding: 013F062220B9040083200904200104000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011C16204401620002080002
   VCID: C1CA165658E64E4768-8094
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000237851
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AA1851FACD90AD1F59-80FE
459776 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [FC_SIGNAL_ESP_FR_RADGESCHW_ERROR_VALUE]
                    Reset counter: 9
                    Mileage: 134025 km
                    Date: 2019.12.20
                    Time: 19:31:23
                    Voltage terminal 30: 14.1 V
                    Internal Fault ID: 140
                    Vehicle speed: 116 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120118-0002-081
   Coding: 1122A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230AO0C7531095
   Coding: 010003020100000001
   VCID: A306BCDEA2BA7C571A-80F6
   Part No SW: 4G0 035 670 G    HW: 4G0 035 670 A
   Component: H-BNT-EU      H48 0484
   Revision: --------    Serial number: 428A%0C7538863
   Coding: 050101010103E1FD2500AF3E00000003000001000000000000
   VCID: A71EA8CED682907746-80F2
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB9400HEJX
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LAN0003U
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Fault Frequency: 37
                    Reset counter: 9
                    Mileage: 134041 km
                    Date: 2019.12.20
                    Time: 19:42:28
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00001000 00000000
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: C4C41F4247F45B6F43-8090
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000168803394
   Coding: 0109080000000000
   VCID: F1AA869628C69EC7D8-80A4
   Component: TSG HR        H04 0212
End----------(Elapsed Time: 02:00, VBatt start/end: 11.8V/13.9V)-----------
Those tyre pressure faults from Nov are genuine, I had picked up a slow puncture (since repaired).
Not really sure how best to proceed, in terms of identifying the actual point of failure, could it be an ABS sensor? Thoughts and advice appriciated!
myounus
Northwest UK
C?ID=321059
Clear all faults and run a scan again. See what comes back.
Gone But Not Forgotten
Reset counter: 9
Mileage: 134025 km
Date: 2019.12.20
Time: 19:31:23
VzRef: 83
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 01
F-Type: C2
Uz: B3
Doesn't this fault ring a bell for mechanical failure and should not the reluctor trigger wheel in bearing for run out or air gap checked for ABS sensor/winding?
JohnnyFiama
C?ID=288500
Fair comment, actually I have already done this (but haven't taken the car for a spin since).
Friday,20,December,2019,21:44:38:28420
          62 69 72
   Revision: 53X37---
          U1113 00 [039] - -
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:41:33
                    Engine speed: 900.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 82 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.900 V
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    Cruise Control System: specified speed: 0.00 km/h
          U1113 00 [039] - -
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:41:33
          U1113 00 [009] - -
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:41:42
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: B5
   Coding: 3622000820
   Component: WWS57X 111217  H35 0051
   Coding: 0045F7
   Coding: 02512B
   Coding: 090308
1049350 - Databus
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:42:15
   Coding: 000035
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:42:27
   Coding: 00CD077D00
   Voltage stabilizer:
          U1113 00 [009] - -
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:42:37
                    Write only channel
          U1113 00 [009] - -
                    Reset counter: 9
                    Mileage: 134136 km
                    Date: 2019.12.20
                    Time: 21:42:58
                    Voltage terminal 30: 14.2 V
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
End----------(Elapsed Time: 02:23, VBatt start/end: 14.0V/14.0V)-----------
Did you JPPSG yet and measure the wheel speed sensors in VCDS on the test drive yet to compare them via logging?
JohnnyFiama
C?ID=288500
No, however I most certainly will tomorrow. It was late when I got home this evening, incredibly dark and immensly wet! I am unfaimilar with the process you mention and so will need to research what is involved.
JohnnyFiama
C?ID=288500
Yes, I noticed this following the first scan, but it seems to have dissapeared since I cleared down the faults (whereas the dash is still lit up like an xmas tree). But as mentioned I haven't driven the car, so it could easily return next outing.
myounus
Northwest UK
C?ID=321059
The remaining errors are still pointing to wheel speed sensors "Radgeschwindigkeiten". When the Jack speaks we obey!
JohnnyFiama
C?ID=288500
Apologies for the delay, my last post was made at 00:30hrs (GMT).
Speed sensor fault confirmed: Log Output (Google Spreasheets)
Not sure whether the results indicate actual mechanical failure, or a wiring issue, perhaps this isn't possible to know without physical investigation?
Let me see is this right, If you indeed tore the wheel down to investigate with meter/scope, even LED test light & configured to see triggers or ran a simulation reading & from other side or rear with test overlay & even if backward in blocks you could see if it was the sensor, wiring or the hub now huh & or merely using VCDS blocks to cross check it, "right"?
Yeah......... that Jack guy is such an asshole with his leading sometimes cryptic questions, huh?
NostraJackASS Has Spoken & with kind questions!
JohnnyFiama
C?ID=288500
Yeah, I'll admit I am unsure how to interperet this...
...and so I guess the answer must be yes!
JohnnyFiama
C?ID=288500
Good man, thanks!
I intend to investigate further on Monday (I'm home alone), will report back with my finding on visual condition and resistance values.
JohnnyFiama
C?ID=288500
Investigated further today, strange results...
Happily the connectors do not appear to be corroded, slightly grubby on the outside but the insulation is in no way perished.
...but my multimeter really struggled to get a decent reading, auto-ranging meters are great when they work. Oddly though when switching to manual things were even worse, no readings at all:
Naturally I presumed the sensor was faulty and put everything back together, and then I went for a long drive.
This fault had apparently self-cleared, the VCDS sensor output log (I have done several since) seems to confirm that all wheel are rotating at more or less the same rate.
JohnnyFiama
C?ID=288500
So is it fixed?
Yeah, looks like :)
Other unrelated fault codes persist, one 'CAN Gateway' related which has me scratching my head (I do that a fair amount).
Monday,23,December,2019,16:27:03:28420
VIN: WAUZZZ4G9CNXXXXXX   License Plate:
Mileage: 134228km-83405mi   Repair Order:
          62 69 72
VIN: WAUZZZ4G9CNXXXXXX   Mileage: 134228km-83405miles
   Revision: 53X37---
          U1008 00 [047] - -
                    Fault Frequency: 17
                    Mileage: 134216 km
                    Date: 2019.12.23
                    Time: 14:59:38
                    Engine speed: 773.50 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 23 °C
   Coding: 3622000820
   Coding: 0045F7
   Coding: 02512B
   Coding: 090308
   Coding: 000035
   Coding: 00CD077D00
   Voltage stabilizer:
6657 - Generator
                    Reset counter: 12
                    Mileage: 134216 km
                    Date: 2019.12.23
                    Time: 15:14:07
                    Voltage terminal 30: 9.4 V
                    Voltage terminal 15: 9.6 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 12
                    Mileage: 134216 km
                    Date: 2019.12.23
                    Time: 14:59:38
End----------(Elapsed Time: 02:04, VBatt start/end: 13.7V/13.8V)-----------
...but perhaps that should be a new topic! Uwe told me ages ago to investigate the generator fault, however my usual (back street) mechanics were unable to identify a specific issue.
Muchas Gracias for your "encouragement" and expert advice to date.
The fault code in 01-Engine is just a "sympathy" code for the generator fault in the CAN Gateway.
JohnnyFiama
C?ID=288500
I did wonder if that might be the case, thank you for confirming.
