Hi would it be possible to work out the long coding for the ABS control unit as it was lost during a Instrument cluster swap (forgot to do a Autoscan first)
Regards Tony
Regards Tony
Tuesday,20,January,2015,14:19:30:43311
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: VSSZZZ6JZAR025220 License Plate: FY59BVH
Mileage: 120380km-74800mi Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR025220 Mileage: 120380km-74800miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BF HW: 03L 906 023 S
Component: 1,6l R4 CR td H13 8811
Revision: --H13--- Serial number: 00000000000000
Coding: 00114036000500080000
ASAM Dataset: EV_ECM16TDI02103L906023BF 003008
ROD: EV_ECM16TDI02103L906023BD_VW25.rod
VCID: 6BDFF21C822CDF79AA9-803E
6260 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Mileage: 120709 km
Date: 2012.05.10
Time: 00:00:16
6068 - No Communication with Instrument Cluster
U0155 00 [032] - -
Mileage: 120709 km
Date: 2012.05.10
Time: 00:00:43
7278 - No Communication with Instrument Cluster
U0155 00 [032] - -
Mileage: 120709 km
Date: 2012.05.10
Time: 00:00:43
7279 - No Communication with Instrument Cluster
U0155 00 [032] - -
Mileage: 120709 km
Date: 2012.05.10
Time: 00:00:43
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AB HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 7EF9CB48ED5E5AD11D7-802B
03306 - Coding Not Valid
Reset counter: 179
Mileage: 120389 km
Date: 2015.01.15
Time: 12:51:31
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1203
Hex Value: 0x1693
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Reset counter: 139
Mileage: 120389 km
Date: 2015.01.15
Time: 12:53:19
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1213
Hex Value: 0x1494
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Reset counter: 179
Mileage: 120389 km
Date: 2015.01.15
Time: 12:51:31
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1203
Hex Value: 0x1693
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000170046-
VCID: 63CF9A3CA2FC9739129-8036
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H08 0029
Revision: BF008001 Serial number: 9955A149091783
Coding: 24882BE88861010001300000660B1EC80000400F608C00002000
Shop #: WSC 69002 210 95077
VCID: 3C7D0140BFC288C1733-8069
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 290609 05 54 0402
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 A HW: 6R0 959 802 A Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0240
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 801 C HW: 6R0 959 801 C
Component: J387__TSG_BT 001 0244
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 HW: 6R0 959 811
Component: J388__TSG_HL 001 0245
Subsystem 5 - Part No SW: 6R0 959 812 HW: 6R0 959 812
Component: J389__TSG_HR 001 0246
Address 10: Park/Steer Assist (J446) Labels: 6J0-919-475.clb
Part No SW: 6J0 919 475 A HW: 6J0 919 475 A
Component: PARKHILFE 4K H07 0007
Revision: -------- Serial number: 80330917112890
Coding: 000002
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
VCID: 346D29609F924081BB3-8061
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA0D H09 0018
Revision: -------- Serial number: 003DW003UADI
Coding: 003044
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 42817FB8D526FE3139F-8017
Serial number: 3496GRB402J9GI4H7R8Z
Serial number: 3506GRB40339F7IGT3NQ
Part No SW: 6J0 920 901 A HW: 6J0 920 901 A
Component: KOMBI X07 0110
Coding: 410A00
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2649C328594E2211357-8073
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0029
Coding: 022300
VCID: 70E5E570A30A3CA19FB-8025
Component: IMMO X07 0110
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10121
Shop #: WSC 06403
VCID: 2E593B08EDBE6A51CD7-807B
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70E5E570630A3CA19FB-8025
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H56 0034
Revision: 0H001001 Serial number: SEZ1Z2I6311757
Coding: 0503040002
VCID: 234FDA3C227CD739529-8076
End-------------------------(Elapsed Time: 02:18)--------------------------
