VW Crafter - Huge Loss of Power - EGR Shut Off
Lightboy
C?ID=382313
ME - James
MY VAN - VW - Crafter - 2011 - 2E - TDI 5-Cyl. 88-163 Hp Panel Van (LT3 / 2006 > 2016)
MY POST - Hey guys, so have read all i can, esp Jacks guide, so here goes.
I have a serious loss of power on my self build camper and this is my first post and
first use of a system like Ross Tech VCDS, before i had a sub £20 ($20) OBDII scanner
so please go easy on me.
So for the last month the van have thrown code P2196 - O2 Sensor, which as it seemed
all fine i have just been clearing and driving on and ignoring the check engine light.
Mainly because people get telling me its likely the DPF not clearing because of short
runs but as my van is a camper its mainly only ever making long trips of 100+ miles.
So then, last week the engine goes limp, i thought actual limp mode but now i am not
so sure, got engine light and flashing coil light (which i know is just another check
engine. Meaning i did not get a flashing red exclamation light.
OBDii scanner read: P2BAC, P2BAB, P202B, P0123, P2100.
Took to garage (emergency find) and they fitted a new EGR after saying it was faulty,
not sure i trust that now. It was very clean and seemed to flick around, should have
kept the old but was stressed and was not thinking properly.
Left there as had to get van home, got towed and cleared the codes.
Now just from running stationary this is the scan i get, (see bellow) but after i drive it,
still like its in limp mode but with no lights for a few miles, i get all those codes again.
---------- AFTER IDLE ENGINE SCAN ----------
Tuesday,17,December,2019,15:20:52:64379
VIN: WV1ZZZ2EZB6******   License Plate: MT60***
Mileage: 178000   Repair Order: 001
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2EZB6
Address 91: LT3 Engine        Labels: Redir Fail!
   Part No SW: 076 906 022 P    HW: 076 906 022 G
   Component: R5 2,5L EDC A0A0SG  7730
   Coding: 0003032
   Shop #: WSC 80093 222 71269
   VCID: 2019E796C6CC54B7E97-8074
No Faults Found
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0J1023775
   VCID: 6D87CEA2419E49DF121-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F78642C58EE11FCA1-8000
Address 95: LT3 ESP
   Part No SW: 9069022800    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_36946.rod (*)
   VCID: 04518B067E94A897EDF-8050
Address 96: LT3 Instruments
   Part No SW: 9069026400    HW: 9069012000
   ASAM Dataset: 32 787
   ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F0FA036AD76F9C5-802E
909C - Alarm Horn (H12): No or incorrect basic setting
            Test Complete - Active/Stored
Address B4: LT3 Central Elec.
   Part No SW: 9064420700    HW: 9065453801
   ASAM Dataset: 33 772
   ROD: CRFT_EZE_33_772.rod (*)
Address C1: LT3 Battery Mgmt        Labels:
   VCID: 55F78642CC0EE11FCA1-FFFE
End----------(Elapsed Time: 01:36, VBatt start/end: 12.9V/12.8V)-----------
---------- SCAN COMPLETE ----------
So here is the scan after i run it stationary for a while.
---------- RUNNING SCAN ----------
Wednesday,18,December,2019,09:53:08:64379
   Revision: 24H37---    Serial number: VWXDZ0J1023775
   Coding: 0003032
000261 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0105 - 001 - Malfunction - Intermittent
                    Fault Status: 00100001
                    Load: 0.0 %
                    Voltage: 12.62 V
                    Torque: 90.0 Nm
                    Temperature: 49.5°C
                    Bin. Bits: 00010000
008235 - Control Circuit for Reductant Tank Heating
               P202B - 000 - Short to GND
                    Voltage: 12.31 V
                    Temperature: 6.3°C
                    Temperature: 7.2°C
                    Voltage: 0.750 V
                    Voltage: 0.000 V
009304 - Diesel Particulate Filter
               P2458 - 000 - Regeneration Duration - MIL ON
                    Fault Status: 11100000
                    RPM: 735 /min
                    Pressure: 5 mbar
                    Hex Value: 0xFF00
                    Temperature: 78.0°C
                    (no units): 25.5
                    Mileage: 270 km
Address 95: LT3 ESP
   ASAM Dataset: 21 3
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 0655910E48A89A87F3B-8052
End----------(Elapsed Time: 01:21, VBatt start/end: 13.2V/12.8V)-----------
QUESTIONS and IDEAS
So firstly i am thinking O2 Lambda Sensor, but does anyone know the module to measure it and
what the values should be?
I know these codes also say the MAF sensor, so what can be done to test and measure this too?
Also wondering if the short to ground on the reductant tank has the power to thrown the NOX and then
the EGR?
All ideas and help welcomed.
James
Lightboy
C?ID=382313
Could be
How is the DPF and its sensors/wirings?
2458 seems to indicate that the DPF is not particularly happy. Perhaps the filter is clogged/full or G450 (diff. pressure sensor) faulty?
Cheers for the reply :) will look at the DPF values in the VCDS to check (if i can find the group codes to measure the blocks)
SO that code has only happened since i have been running it standing still.
It was not on the original OBDII scan i did and so guessing that its not regenerating based on the incorrect air flow i see in the EGR cutoff.
Essentially it feels like its in limp mode, although no red hazard on the dash, which i assume it does when in official limp mode, only a flashing coil light
and a fixed engine check. (coil light is just a more severe check engine light when flashing)
I was asked to check the DPF but as its very hard to look at from behind the Turbo i opted for removing the sensors at the top and bottom of the DPF.
My assumption is that if the DPF was packed with soot, that either one of these sensors would be dirty but they were both very clean.
As i said the EGR valve was also very clean and i tend to do long runs when i do drive so it gets plenty of opportunity to recycle itself,
and as i said it was not in the original fault codes i read from the OBDii scan tool, done prior to the buying of the Ross Tech System.
The DPF seems to get hot enough for it to recycle but because the lack of power i think it fails to regenerate based on not enough air flow.
Gonna pull out the Lambda and check, and replace the MAP sensor to account for the first code, then pull the nox sensor, letting it run with
clean air, which should open the EGR valve its thats the issues. Have disconected the EGR to see if it ran better but no joy, ran the same, leads me to think
the turbo, although no codes there, or the MAP, due to bad sensor or a leak in the system.
Also thinking the intake manifold?
But question is, do you or anyone know the group codes to know what i am looking at inside the VCDS,
as i dont get group titles due to the MERC VW mash up?
I was told by Ross Tech uk dealer i would have issues but to not get a name label from a module on what i thought was a VW engine in a Merc chassis seems like a bummer. I accept stuff like the ABS or other modules down from the Engine so if anyone can help that would be grand.
Cheers
DrPeter
16.4905° S, 151.7375° W
Hello James,
- For the fault code P0105, I would look at the Measuring Value Block(MVB) group [010] to compare the G71-Manifold Absolute Pressure sensor and the F96-Barometric Pressure sensor with the Key-On and the Engine-Off.
These two values should be the same (+/- 100mbar, typical)
MVB-010, 2 = Ambient Raw Value
MVB-010, 3 = Charge Air Pressure, actual
For the fault code 'P202B-Control Circuit for Reductant Tank Heating: Short to GND', I suggest to check the wiring, connections, etc to the J891-Control Unit for Reducing Agent Heater. This would include checking the two fuses under the drivers seat, SD34 and SD35, both are 15A fuses.
If all of the above are okay, there is an [Output Test] you can perform with VCDS on the ECM to activate the Heater for reducing agent tank.
You will want to have the Key-On and the Engine-Off when running this test.
[Select]
[01-Engine]
[Output Tests - 03]
- Press [Start/Next] to find and activate the heater for reducing agent (In some cases an [Activate] will be displayed)
When the test is running, VCDS will display the status of this test [On/Off] and the Voltage supplied to the heater (must be greater than 1.0V)
The fault code P2458 seems to mean that a regeneration was started but was interrupted for some reason, perhaps due to the P202B fault code.
After the other faults have been corrected/cleared you will want to perform an extended road test to see if the ECM can perform a successful regeneration.
By the way, the ECM does appear to have a software update.... However, I can not seem to find any documentation to verify this, so I suggest to check this out with the manufacture.
ref:
ECM update - [076-906-022-P], from (7730) to (9022)
We recommend the use of the Official Factory Repair Information when working on these vehicles.
Hope this helps,
drpeter
Lightboy
C?ID=382313
3 great ideas and places to look but sadly to no avail.
So looked at the measuring block you suggested both pressures are the same. Not sure if the group codes are the same in my MERC VW mash up?
Here is the measuring blocks in Engine 01.
(sorry for the format, how do you put scans and logs in there own scroll box?)
Thursday,19,December,2019,09:24:19:64379
Mileage:    Repair Order: 100
                Address 01: Engine  (076 906 022 P)
09:24:02 Group 001
  0 /min  RPM
  0.0 mg/str  Inj. Quantity
  0.0 bar  Pressure
  9.9°C  Temperature
09:24:02 Group 002
  0 /min  RPM
  0.0 %  Load
  00000000  Bin. Bits
  9.9°C  Temperature
09:24:02 Group 003
  0 /min  RPM
  1175.0 mg/str  Mass Air / Rev.
  0.0 mg/str  Mass Air / Rev.
  100.0 %  Load
09:24:32 Group 004
  0 /min  RPM
  0.0 °BTDC  Ign. Timing
  0.0  (no units)
  0.0 bar  Pressure
09:24:32 Group 005
  0 /min  RPM
  1.0  (no units)
  9.9°C  Temperature
09:24:32 Group 006
  0.0 km/h  Speed
  00010000  Bin. Bits
  0.0 km/h  Speed
  00000000  Bin. Bits
09:25:00 Group 007
  10.8°C  Temperature
  9.0°C  Temperature
  12.6°C  Temperature
  9.9°C  Temperature
09:25:00 Group 008
  0 /min  RPM
  90.0 Nm  Torque
  0.0 Nm  Torque
  615.0 Nm  Torque
09:25:00 Group 009
  0 /min  RPM
  -1280.0 Nm  Torque
  615.0 Nm  Torque
  0.0 Nm  Torque
09:25:09 Group 010
  989.4 mbar  Absolute Pres.
  0.0 %  Load
09:25:09 Group 011
  0 /min  RPM
  999.6 mbar  Absolute Pres.
  9.8 %  Load
09:25:09 Group 012
  01010000  Bin. Bits
  1.98 s  Time
  12.31 V  Voltage
  9.9°C  Temperature
09:25:16 Group 013
  0.00 mg/str  Inj. Quantity
09:25:16 Group 014
09:25:16 Group 015
  0 /min  RPM
  -150.0 Nm  Torque
  0.00 l/h  Fuel Consump.
  90.0 Nm  Torque
09:25:46 Group 016
  0.0 %  Lambda
  00000000  Bin. Bits
  0.0  (no units)
  12.31 V  Voltage
09:25:46 Group 017
  0.0  (no units)
  0.00  (no units)
  42.6 l  Tank Cont.
  777 /min  RPM
09:25:46 Group 018
  0 /min  RPM
  10.8°C  Temperature
  0.0  (no units)
  1.0  (no units)
09:26:10 Group 019
  0 /min  RPM
  221.85  (no units)
  448.0 bar  Pressure
  9984.0
09:26:10 Group 021
  0 /min  RPM
  224.0 bar  Pressure
  0.0 bar  Pressure
  4.7 %  Lambda
09:26:10 Group 021
  0 /min  RPM
  224.0 bar  Pressure
  0.0 bar  Pressure
  4.7 %  Lambda
09:26:21 Group 022
  0 /min  RPM
   0001000  Bin. Bits
   0000000  Bin. Bits
   0111000  Bin. Bits
09:26:21 Group 024
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:21 Group 024
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:29 Group 025
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:29 Group 027
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:29 Group 027
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:42 Group 028
  0 /min  RPM
  0.0  (no units)
  0.0 bar  Pressure
09:26:42 Group 030
  0.304 V  Voltage
  0.152 V  Voltage
  00000000  Bin. Bits
  0.0 %  Load
09:26:42 Group 030
  0.304 V  Voltage
  0.152 V  Voltage
  00000000  Bin. Bits
  0.0 %  Load
09:26:54 Group 031
  5B75
09:26:54 Group 033
  0 /min  RPM
  12.0°C  Temperature
  1.00  (no units)
  1.00  (no units)
09:26:54 Group 033
  0 /min  RPM
  12.0°C  Temperature
  1.00  (no units)
  1.00  (no units)
09:27:02 Group 034
  0 /min  RPM
  9.8 %  Load
  -0.8 %  Lambda
  4.7 %  Lambda
09:27:02 Group 036
  0 /min  RPM
  100.0 %  Load
  97.8 %  Lambda
  0.0 %  Lambda
09:27:02 Group 036
  0 /min  RPM
  100.0 %  Load
  97.8 %  Lambda
  0.0 %  Lambda
09:27:15 Group 037
09:27:15 Group 039
  0 /min  RPM
  12.6°C  Temperature
  0.0 %  Lambda
09:27:15 Group 039
  0 /min  RPM
  12.6°C  Temperature
  0.0 %  Lambda
09:27:23 Group 040
  0 /min  RPM
  100.0 %  Load
  100.2 %  Lambda
  0.0 %  Lambda
09:27:23 Group 042
  0.15  (no units)
  1.6 %  Lambda
  3.300 V  Voltage
  25.40  (no units)
09:27:23 Group 042
  0.15  (no units)
  1.6 %  Lambda
  3.300 V  Voltage
  25.40  (no units)
09:27:32 Group 043
  0.0  (no units)
  10.8°C  Temperature
  00000000  Bin. Bits
  0.000 V  Voltage
09:27:32 Group 045
  9.9°C  Temperature
  100.0 %  Load
  0.0 %  Lambda
  0.0 %  Lambda
09:27:32 Group 045
  9.9°C  Temperature
  100.0 %  Load
  0.0 %  Lambda
  0.0 %  Lambda
09:28:02 Group 046
  10.8°C  Temperature
  9.9°C  Temperature
  -0.9°C  Temperature
  00000001  Bin. Bits
09:28:02 Group 047
  89.1°C  Temperature
  -0.9°C  Temperature
  0.0 %  Load
  0.0 %  Lambda
09:28:02 Group 048
  0 /min  RPM
  0 /min  RPM
         1  Bin. Bits
  1270.0 Nm  Torque
09:28:10 Group 049
09:28:10 Group 050
  0 /min  RPM
        10  Bin. Bits
09:28:10 Group 051
  0 /min  RPM
  0 /min  RPM
  1.0  (no units)
  0.0°KW  Idle Stabilization
09:28:17 Group 052
  0 /min  RPM
  0xFF00  Hex Value
  0xFF00  Hex Value
  21.6°C  Temperature
09:28:17 Group 053
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
09:28:17 Group 054
  0.0  (no units)
  0 /min  RPM
09:28:27 Group 055
09:28:27 Group 056
09:28:27 Group 057
  0 /min  RPM
  0.0 km/h  Speed
  0.0 %  Duty Cycle
  0.0 %  Duty Cycle
09:28:54 Group 058
  0 /min  RPM
  0.0 km/h  Speed
  0.0 %  Duty Cycle
  99.6 %  Duty Cycle
09:28:54 Group 059
  0 /min  RPM
  -150.0 Nm  Torque
  39.0 Nm  Torque
  0.0 Nm  Torque
09:28:54 Group 060
  39.0 Nm  Torque
  -42.0 Nm  Torque
  0.0 Nm  Torque
  0.0 %  Lambda
09:29:03 Group 061
  0 /min  RPM
  9.0°C  Temperature
  63.0 mm  Content
  76.0 mm  Content
09:29:03 Group 062
  0 /min  RPM
  0.0  (no units)
  0.0  (no units)
09:29:03 Group 063
  0 /min  RPM
  0 /min  RPM
  0 /min  RPM
  0 /min  RPM
09:29:10 Group 064
  0 /min  RPM
09:29:10 Group 065
09:29:10 Group 066
09:29:21 Group 067
09:29:21 Group 068
09:29:21 Group 069
  10011101  Bin. Bits
  00000011  Bin. Bits
  10011110  Bin. Bits
  00000011  Bin. Bits
09:29:32 Group 070
  10011110  Bin. Bits
  00000011  Bin. Bits
  1.00  (no units)
09:29:32 Group 071
  11111111  Bin. Bits
  00011111  Bin. Bits
09:29:32 Group 072
  9.28  (no units)
  6.40  (no units)
  0.64  (no units)
09:29:58 Group 076
  16.00  (no units)
  11.20  (no units)
  3.20  (no units)
09:29:58 Group 077
  6.40  (no units)
  0.64  (no units)
  0.00  (no units)
09:29:58 Group 078
09:30:07 Group 079
09:30:07 Group 080
  Please use
  the first row
  for this
  data type
09:30:07 Group 081
  Please use
  the first row
  for this
  data type
09:30:17 Group 082
  0000000000000 00.00.00 78       79  <>
09:30:17 Group 083
09:30:17 Group 084
09:30:28 Group 085
  29540 km  Mileage
  23  Count
  3149  Count
  10568  Count
09:30:28 Group 086
  11110000  Bin. Bits
  10111110  Bin. Bits
  11110100  Bin. Bits
  11111111  Bin. Bits
09:30:28 Group 087
  11111111  Bin. Bits
  11111111  Bin. Bits
  11111111  Bin. Bits
09:30:36 Group 088
09:30:36 Group 089
  10000100  Bin. Bits
  00001110  Bin. Bits
  10100000  Bin. Bits
  00100000  Bin. Bits
09:30:36 Group 090
  0 /min  RPM
  00000000  Bin. Bits
09:30:48 Group 091
  323.85  (no units)
  -326.40  (no units)
  323.85  (no units)
09:30:48 Group 092
09:30:48 Group 093
  00000000  Bin. Bits
  3.97  (no units)
  0.0  (no units)
  0.0  (no units)
09:31:02 Group 094
09:31:02 Group 095
  00000000  Bin. Bits
  00000000  Bin. Bits
  0.0  (no units)
09:31:02 Group 096
  00000000  Bin. Bits
  00000000  Bin. Bits
        00  Bin. Bits
  12.31 V  Voltage
09:31:16 Group 097
  -3 mbar  Pressure
  -3 mbar  Pressure
09:31:16 Group 098
  0 /min  RPM
  12.6°C  Temperature
09:31:16 Group 099
  0 /min  RPM
  12.0°C  Temperature
  6.0°C  Temperature
  12.0°C  Temperature
09:31:27 Group 100
  12.0°C  Temperature
  6.0°C  Temperature
  -3 mbar  Pressure
  -3 mbar  Pressure
09:31:27 Group 101
  0 /min  RPM
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
09:31:27 Group 102
  00000000  Bin. Bits
  00000001  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
09:31:40 Group 103
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
09:31:40 Group 104
  0xFF01  Hex Value
  0xFF10  Hex Value
  00000000  Bin. Bits
  00000000  Bin. Bits
09:31:40 Group 105
  00000000  Bin. Bits
  8.0  (no units)
  12.0°C  Temperature
  0.0  (no units)
09:31:50 Group 106
  34.3 l  Tank Cont.
  270 km  Mileage
  1128.0  (no units)
09:31:50 Group 107
  48.0
  45.6
  26.4
09:31:50 Group 108
  78 ml  milliliters
  32.4
  38.4
09:32:03 Group 109
  00000000  Bin. Bits
  00000000  Bin. Bits
  144.0  (no units)
09:32:03 Group 110
  00000000  Bin. Bits
  0.0 km/h  Speed
09:32:03 Group 111
  0 /min  RPM
  0.0 km/h  Speed
  0.00  (no units)
  0.0  (no units)
09:32:13 Group 112
  0.00  (no units)
  1270.0 Nm  Torque
  -1280.0 Nm  Torque
  0.0 Nm  Torque
09:32:13 Group 113
  00000000  Bin. Bits
  0.0  (no units)
  1.0  (no units)
  0.0  (no units)
09:32:13 Group 114
  255.0  (no units)
  255.0  (no units)
  0.00  (no units)
  0.00  (no units)
09:32:23 Group 115
09:32:23 Group 116
  0.0 %  Load
  -0.9°C  Temperature
  192.0  (no units)
  0.0  (no units)
09:32:23 Group 117
  0.0 %  Lambda
  -0.9°C  Temperature
  00010100  Bin. Bits
  7.0  (no units)
09:32:31 Group 118
09:32:31 Group 119
09:32:31 Group 120
  7.1 %  Lambda
  -7.9 %  Lambda
  00000000  Bin. Bits
  4.256 V  Voltage
09:33:09 Group 121
  0.0 %  Lambda
  -11.8 %  Lambda
  00000100  Bin. Bits
  1.216 V  Voltage
09:33:09 Group 122
09:33:09 Group 123
  -3.9 %  Lambda
  3.2 %  Lambda
  00000100  Bin. Bits
  3.952 V  Voltage
09:33:16 Group 124
  -0.8 %  Lambda
  0.0 %  Lambda
  00000000  Bin. Bits
  4.484 V  Voltage
09:33:16 Group 125
  ABS 1
  Instruments 1
09:33:16 Group 126
09:33:23 Group 127
  El.Ign.Lock 1
09:33:23 Group 128
09:33:23 Group 129
09:33:30 Group 130
09:33:30 Group 131
09:33:30 Group 133
09:33:38 Group 133
09:33:38 Group 134
09:33:38 Group 136
09:33:50 Group 133
09:33:50 Group 134
09:33:50 Group 136
09:34:26 Group 137
09:34:26 Group 138
09:34:26 Group 139
09:34:35 Group 140
09:34:35 Group 141
09:34:35 Group 142
09:34:48 Group 143
09:34:48 Group 144
09:34:48 Group 145
09:34:57 Group 146
09:34:57 Group 147
09:34:57 Group 148
09:35:09 Group 149
09:35:09 Group 151
09:35:09 Group 151
09:35:16 Group 152
09:35:16 Group 154
09:35:16 Group 154
09:35:22 Group 155
09:35:22 Group 157
09:35:22 Group 157
09:36:34 Group 166
  0.070°  Angle
  0.043°  Angle
  0.055°  Angle
  0.032°  Angle
09:36:34 Group 167
  0.070°  Angle
09:36:34 Group 168
09:36:40 Group 169
09:36:40 Group 170
  0.00 %
  0.0  (no units)
  0.00 %
  0.0 bar
09:36:40 Group 171
09:36:48 Group 172
  0.0  (no units)
  0.0  (no units)
  10.8°C  Temperature
  66.7 %  Load
09:36:48 Group 173
09:36:48 Group 174
  2.0  (no units)
  0.0  (no units)
  0.000 V  Voltage
  0.000 V  Voltage
09:36:55 Group 175
  0.0  Ohms
  0.000 A  Current
  0.000 A  Current
  6.0°C  Temperature
09:36:55 Group 176
  0 ppm
  0.000 V  Voltage
  0.00  (no units)
  00000000  Bin. Bits
09:36:55 Group 177
  0 ppm
  0.000 V  Voltage
  0.00  (no units)
  00000000  Bin. Bits
09:37:02 Group 178
  2960 km  Mileage
  1.0  (no units)
  00000000  Bin. Bits
09:37:02 Group 179
  255.0 kg  Mass/Weight
09:37:02 Group 180
  0 ppm
09:37:10 Group 181
  0.0 bar
  10.8°C  Temperature
09:37:10 Group 182
  10.7  (no units)
09:37:10 Group 183
  1.02  (no units)
09:37:19 Group 184
09:37:19 Group 185
09:37:19 Group 186
09:37:29 Group 187
09:37:29 Group 188
09:37:29 Group 189
09:38:09 Group 200
  0 ppm
  0 ppm
  0 ppm
  0 ppm
09:38:09 Group 201
  0.00  (no units)
  1.00  (no units)
  0.02  (no units)
  1.00  (no units)
09:38:09 Group 202
  0.00  (no units)
  0.95  (no units)
  18.0°C  Temperature
09:38:17 Group 203
  0.00  (no units)
  0.00  (no units)
  0.0  (no units)
  0 mg/s
09:38:17 Group 204
  1.02  (no units)
09:38:17 Group 205
09:38:24 Group 206
  25.5 l/1000km
09:38:24 Group 207
  10.8°C  Temperature
  0.0 s  Time
  10.8°C  Temperature
  0.0 s  Time
09:38:24 Group 208
  1.0  (no units)
  0.0 s  Time
  0.0 s  Time
  0.0 s  Time
09:38:33 Group 209
  2.0  (no units)
  51.2 s  Time
  102.4 s  Time
  64.0  (no units)
09:38:33 Group 210
  0.00 V  Voltage
09:38:33 Group 210
  0.00 V  Voltage
09:38:48 Group 212
  -1.30  (no units)
09:38:48 Group 213
  0.00 mg/s
  0.00 mg/s
  0.78  (no units)
  0.00  (no units)
09:38:48 Group 214
  -6.0°C  Temperature
  -6.0°C  Temperature
  -6.0°C  Temperature
09:38:58 Group 215
09:38:58 Group 216
09:38:58 Group 217
  0.0
  0.0
  0.0
  0.0
09:39:09 Group 218
  0.0
  0 km  Mileage
  0.0  (no units)
  0.0  (no units)
09:39:09 Group 219
  -276.0°C  Temperature
  0.0 km/h  Speed
  0.0 km/h  Speed
09:39:09 Group 220
  0.0  (no units)
09:39:16 Group 221
  1.22  (no units)
09:39:16 Group 223
  969.0 mbar  Pressure
  969.0 mbar  Pressure
  0.0  (no units)
  0.0  (no units)
09:39:16 Group 224
09:39:21 Group 224
09:39:21 Group 227
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
09:39:21 Group 227
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
09:39:29 Group 227
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
  0.0  (no units)
09:39:29 Group 230
09:39:29 Group 230
09:39:36 Group 230
09:39:36 Group 233
09:39:36 Group 233
09:40:16 Group 246
  979.2 mbar  Absolute Pres.
  0.8 %  Load
09:40:16 Group 247
  121.6 km/h  Speed
  161.3 km/h  Speed
  0.0  (no units)
  0.0 km/h  Speed
09:40:24 Group 248
  235  Count
  65.0  (no units)
  16.0  (no units)
  161.3 km/h  Speed
09:40:24 Group 249
  -150.0 Nm  Torque
  0.0  (no units)
09:40:24 Group 250
  0.0 bar  Absolute Pres.
  0.0 Nm  Torque
  00000001  Bin. Bits
09:40:34 Group 251
  0 /min  RPM
  0 /min  RPM
  2982 /min  RPM
  00001000  Bin. Bits
09:40:34 Group 252
  -150.0 Nm  Torque
  0.0 Nm  Torque
  00000000  Bin. Bits
  00001000  Bin. Bits
09:40:34 Group 253
  0 /min  RPM
  1.0  (no units)
  00000000  Bin. Bits
  0.0  (no units)
09:40:45 Group 254
09:40:45 Group 254
09:40:45 Group 254
Lightboy
C?ID=382313
Other points
Checked the fuses, all seemed fine, although going to double check with a tester.
Reducing tank heater had 2 voltages, box 3 and box 4.
RPM - 0
On/Off - ON
Voltage - 0.825
Voltage 12.24
If it was the heater circuit, why would the NOX sensor not throw a code, if it shut down the EGR?
If i pull the plug on the EGR will it leave it open or closed? Will it let me drive it or will it put it into
limp mode?
Is there a way to force it open with the VCDS ?
Cheers for ya help
Lightboy
C?ID=382313
Not sure if this will help anyone help me but
Thursday,19,December,2019,10:23:55:64379
VCDS Release 19.6.2 (x64): Generic OBD2
Freeze Frame Data for address 7E8
PID02 DTC that caused freeze frame data storage: P2BAC
PID04 Calculated load value: 47.1 %
PID05 Engine coolant temperature: 89 °C
PID0B Intake Manifold Absolute Pressure: 107 kPa abs
PID0C Engine RPM: 1595 /min
PID0D Vehicle speed: 16 km/h
PID0F Intake air temperature: 16 °C
PID10 Mass Air Flow: 32.69 g/s
PID11 Throttle position sensor: 79.2 %
