VCDS not showing Haldex on A3?
fibrizo
C?ID=156569
Preach on, brother! :thumbs:
Jason
I tend to agree, but the current A4/Q5 was a bit old and need of a refresh, the A6 was a tad expensive with all the options, and the Touareg was a tad too unreliable. :P
   #22
Props for brand loyalty. :)
FWIW, we're reasonably confident we now understand why your Haldex isn't showing and how to fix that.
fibrizo
C?ID=156569
You don't even know the half of it :P I'm loyal because I spent decent money for this VCDS cable. I had to make sure my next car was compatible so I could keep using it :) hehe. But that's cool that a fix is coming. I'm just surprised that I'm the first to notice.
   #24
fibrizo
C?ID=156569
Ok, so it's semi fixed. You can see that there's 22 AWD, but it's inaccessible to a scan or clicking into the module. I'm resubmitting my DLM files for inst and 22, debug level 1024
Saturday,24,January,2015,12:16:47:06722
VCDS Version: 15.1.1.0 (x64) Super Secret Championship Edition X Zero Alpha
Data version: 20150118
VIN: WAUKFGFF3F1042366   License Plate:
Mileage: 6138km-3813mi   Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 55 5F
          6C A5
VIN: WAUKFGFF3F1042366   Mileage: 6138km-3813miles
Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A1D00324466000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79DEA94711755889-8079
Readiness: 1000 0100
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4513
   Revision: 03252204    Serial number: TFK01406220847
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E1D046101AD97C817-804B
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61534000000547
   Coding: 13FF6A9234240A6E017A030681C929C8562C5080C08194B4F84150588608
   VCID: 46AD8C01F9BDAF087F-8013
   Revision: 00021000    Serial number: 0339427358
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55E8F1BD45DBE80B-806F
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000373158
   Coding: 03000014010000000000000000001400
   VCID: 334BC5D59A2F2AA0C8-8066
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0134
   Serial number: 01011417400970
   Coding: 04151C46C04106FD41C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 79D737FDF8C310F042-802C
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
   Component: WWS371 140705  042 0585
   Serial number:         140709020143
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22835410
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 23 04 2014  00000842
   Serial number: 00000000000030305291
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO30791273
   Coding: 101F00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331419000984
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 42A59011D595932853-8017
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H04 0304
   Serial number: 24051477030515
   Coding: 01241501FE0339
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3851F2F98349C9F8FD-806D
   Serial number: 003GCR00HTCU
   VCID: 47B38105FEB7B60084-8012
   Seat belt tensioner; left:
   Serial number: 34178311A08071440230
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34178312A14071471255
   Coding: 333135
   Seat occupant detection; front passenger side:
   Serial number: 6940000Y1400014P8X00
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 000 507 14
   Serial number: 35700000000E43451014
   Subsystem 5 - Part No SW: -----------    HW: 480 000 507 14
   Serial number: 35800000000BB3451019
   Subsystem 6 - Part No SW: -----------    HW: 480 400 307 14
   Serial number: 3510002B71656B83735+
   Subsystem 7 - Part No SW: -----------    HW: 480 400 307 14
   Serial number: 3520002BB1656B848153
   Subsystem 8 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3550002B31656B858160
   Subsystem 9 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3560002BD1656B82D0CI
   Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02071408490329
   Coding: E818
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 00215A199B19413805-8055
   Part No SW: 8V0 920 971 G    HW: 8V0 920 971 G
   Component: KOMBI         H02 4291
   Coding: 0BC518196F88D7050280E8001800000000000000
   VCID: 41A79F1DD09388304A-8014
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 03071410800466
   Coding: 0101000820085A005B00021C180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_AU37.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 30 06 2014  C0090877
Address 22: AWD
   Revision: 00000000    Serial number: 14000171251003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449C6C99F212D98D1-8061
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0337624190
   Coding: 030211
   ROD: EV_LaneChangAssis.rod
   Lane Change Assistant 2:
   Serial number: 01071404080526
   Coding: 005D1F205C00048000000003
   VCID: 40A19A19DB99813845-8015
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 1102
   ROD: EV_SteerAssisMQB.rod
   Serial number: 22061402090458
   Coding: 005D17205E00048000000003
   VCID: 3FA399E5A667FEC03C-806A
   Component: AFS-ECU       H01 0091
   Coding: 012A000023200400
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
   Component: LED LeiMo li.  H07 7540
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
   Component: LED LeiMo re.  H07 7540
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7040
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7040
   Coding: E00100
   Part No SW: 8V0 035 038     HW: 8V0 035 038
   Component: MU-H-LNS-US   H42 0289
   Serial number: A302G0E7510011
   Coding: 017301020000000021220002041A00102F000125010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 71C70FDDA0B358B0FA-8024
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 SR    HW: -----------
   Component: NAR 2014/2015  --- 0032
   Seat Adjustment Driver Side:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201C10
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000002071400030014
   Door Electronics Rear Left:
   Component: Gracenote  --- 3005
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3041CAD96B3911B8B5-8065
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000194614
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B5BEDF5B27FE2E010-806E
End-------------------------(Elapsed Time: 03:59)--------------------------
   #25
Eric
HC800000
Thank you for the debugs (again). I see the issue, should have a fix next week.
   #26
fibrizo
C?ID=156569
So I dug my car out of 10 inches of snow and ran 15.1.2 and got more errors than before. Module 22 still won't scan and an attempt to directly access gives the no response from controller error. Module 2B (Steering Col lock) also doesn't scan now, but can still be accessed directly.
Tuesday,27,January,2015,18:18:32:06722
VCDS Version: 15.1.2.0 (x64)
Mileage: 6186km-3843mi   Repair Order:
          6C A5
VIN: WAUKFGFF3F1042366   Mileage: 6186km-3843miles
   Revision: --H13---
   VCID: 2C79DEA9471175589F-8079
Readiness: 1110 1101
   VCID: 1E1D046101AD97C801-804B
   VCID: 46AD8C01F9BDAF0869-8013
   Coding: 030C0C
   VCID: 3A55E8F1BD45DBE81D-806F
   VCID: 334BC5D59A2F2AA0DE-8066
   VCID: 79D737FDF8C310F054-802C
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 101F00
   Coding: 0070150011
   VCID: 42A59011D595932845-8017
   VCID: 3851F2F98349C9F8EB-806D
   VCID: 47B38105FEB7B60092-8012
   Coding: 333135
   Coding: 333135
   Coding: 303139
   Coding: E818
   VCID: 00215A199B19413813-8055
   VCID: 41A79F1DD09388305C-8014
Address 22: AWD
   Coding: 030211
   VCID: 40A19A19DB99813853-8015
   Coding: 1102
   VCID: 3FA399E5A667FEC02A-806A
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
   VCID: 71C70FDDA0B358B0EC-8024
   Sound System:
   VCID: 3041CAD96B3911B8A3-8065
   VCID: 3B5BEDF5B27FE2E006-806E
End--------------------(Elapsed Time: 04:31, Deb=1024)---------------------
I get this vague feeling that I'm going to end up pushing you guys all the way to 15.2.0 :P
   #27
You know, if they sold that car with a manual transmission, I'd get us one. For R&D purposes, of course. ;)
NZDubNurd
New Zealand
C?ID=230482
Legitimate business expense :thumbs:
Eric
HC800000
Well, looking at the debugs, we're getting closer :) I think 2B not talking during the autoscan was a fluke, it was due to the gateway not responding at the time. I'm now getting a response from 22, just need to figure out why VCDS doesn't want to proceed further at that point!
   #30
Eric
HC800000
Check you emails please. Debugs appreciated as usual with the new build, working or not! :)
fibrizo
C?ID=156569
Getting closer I think. It seems to read 22 now, but access to 2B has gotten intermittent. Even direct access fails a few times first now before I can get to 2B. Is this a glitch on my end or unlucky? Also oddly the transmission randomly shows faults and no faults every few times I scan. I assume this is nothing to worry about.
Thursday,29,January,2015,12:52:19:06722
VCDS Version: 15.1.3.0 (x64)
Mileage: 6194km-3848mi   Repair Order:
          6C A5
VIN: WAUKFGFF3F1042366   Mileage: 6194km-3848miles
   Revision: --H13---
   VCID: 2C79DEA94711755895-8079
Readiness: 1010 0101
   VCID: 1E1D046101AD97C80B-804B
11 Faults Found:
21153 - Gear 1
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21158 - Gear 6
          P073B 00 [002] - Not Selectable
21159 - Gear R
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10909 - Cooling Oil Valve
   VCID: 46AD8C01F9BDAF0863-8013
   Coding: 030C0C
   VCID: 3A55E8F1BD45DBE817-806F
   VCID: 334BC5D59A2F2AA0D4-8066
   VCID: 79D737FDF8C310F05E-802C
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 101F00
   Coding: 0070150011
   VCID: 42A59011D59593284F-8017
   VCID: 3851F2F98349C9F8E1-806D
   VCID: 47B38105FEB7B60098-8012
   Coding: 333135
   Coding: 333135
   Coding: 303139
   Coding: E818
   VCID: 00215A199B19413819-8055
   VCID: 41A79F1DD093883056-8014
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7081
   Serial number: HA1-00012.06.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   Coding: 030211
   VCID: 40A19A19DB99813859-8015
   Coding: 1102
   VCID: 3FA399E5A667FEC020-806A
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
   VCID: 71C70FDDA0B358B0E6-8024
   Sound System:
   VCID: 3041CAD96B3911B8A9-8065
   VCID: 3B5BEDF5B27FE2E00C-806E
End--------------------(Elapsed Time: 04:29, Deb=1024)---------------------
   #32
Eric
HC800000
Yeah, 22 looks great. I'm wondering if your battery is running low maybe... If you have the time, do a couple scans with the beta, then a couple with the release, and let us know if the 2B issues persist with the release. As far as I can tell it's just the gateway not responding at that point, but I'll take another look at the modifications I did to the micro-CAN code since the release.
   #33
fibrizo
C?ID=156569
Sure I'll try 14.10.0 and see if the issue persists. It seemed to only start on 15.1.2.
   #34
Eric
HC800000
Don't go out in the snow for this. I'm able to reproduce this issue on Andy's GTI through some address faking.
   #35
fibrizo
C?ID=156569
Reproduce the 2B error? I even drove the car around for an extra hour lol to make sure the battery was charged :P
Also I think you guys need a S3 for um... research purposes on the new MQB chassis... I know it's DSG only, but umm I think you guys need "direct access" to the modules :)
On a side note it's cheap to lease a 2.0T A3
   #36
Eric
HC800000
Should be fixed in impending 14.10.1 ; let us know either way!
   #37
fibrizo
C?ID=156569
Rather than keep refreshing/checking, do you know when 14.10.1 will be out so I can know when to give it a whirl?
   #40
fibrizo
C?ID=156569
Might be easier to retrofit your GTI with a Golf R. I hear the new ones have a crazy 70% residual on a 3 year lease.
