2015 mk7 gti vaq install
dzolotnyuk
C?ID=84713
just finished installing vaq on my 2015 gti 6 speed, some one that has more brain than i do please check my coding for abs
used process of elimination for abs coding
auto scan before
Monday,02,December,2019,17:54:55:45811
VCDS Version: 19.6.2.0
VIN: 3VW5T7AU1FM083139   License Plate:
Mileage: 51446km-31967mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 75 A9
VIN: 3VW5T7AU1FM083139   Mileage: 51446km-31967miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091900322424002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C5CF5B447B9C42F2B-8078
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 50585000001380
   Coding: 01FA6BA13428096F0078020381CC2980D62C9000408194B410430050C008
   Shop #: WSC 12345 123 61029
   VCID: 4796AA18FE1F077726-8012
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Revision: 00001K01
   Coding: 00020004200100000000000000000000
   Shop #: WSC 01383 790 50316
   ROD: EV_ACManueBHBVW37X_003.rod
   VCID: 4688A71CF9151E7FDD-8012
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86580202150473
   Coding: 00000A464041A04969E44000001407201000000000000000000000000000
   Shop #: WSC 00066 790 00226
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4A90932CED0DFA1F39-801E
   Component: WWS    150131  043 0581
   Serial number:         150322085053
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Fault Frequency: 67
                    Reset counter: 216
                    Mileage: 50323 km
                    Date: 2019.10.29
                    Time: 06:24:31
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Fault Frequency: 177
                    Reset counter: 218
                    Mileage: 49929 km
                    Date: 2019.10.19
                    Time: 16:02:25
135432 - Terminal S
          B11A5 11 [008] - Short to Ground
                    Reset counter: 211
                    Mileage: 51366 km
                    Date: 2019.11.29
                    Time: 20:54:57
329480 - Heated Passenger Seat
          B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                    Fault Frequency: 107
                    Reset counter: 212
                    Mileage: 49390 km
                    Date: 2019.10.03
                    Time: 20:27:02
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391503407567
   Coding: 0031051001
   VCID: 3D7AC8F0ACC35DA78C-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 21011503272256
   Coding: 01000200280438
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   VCID: 3874D9E483E1788F5F-806C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01Y36M
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51A28440005BC9C778-8004
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150002JDV70E
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 003 001 15
   Serial number: 357000000002C3E4521F
   Subsystem 3 - Part No SW: -----------    HW: 480 003 001 15
   Serial number: 35800000000469610313
   Subsystem 4 - Part No SW: -----------    HW: 480 400 302 15
   Serial number: 3510002B71901D92C1A1
   Subsystem 5 - Part No SW: -----------    HW: 480 402 901 15
   Serial number: 3520002B11901D91C20T
   Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3550002C719121A4231P
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3560002C519121A193A.
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150221400657
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A70C3ECBDED6A9FA9-806E
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 03BD09022980CF0502887A011000000000000000
   VCID: 6BDE36A88237031762-803E
   Revision: --------    Serial number: 17021510002499
   Coding: 0101000820085900EF00002A080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_011.rod
   VCID: 72E02BCCA51DD2DFA1-8026
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 27150000304150045081
   Coding: 30FFFF
131614 - Differential Lock Control Module
          U1040 00 [008] - No communication
                    Reset counter: 214
                    Mileage: 51383 km
                    Date: 2019.11.30
                    Time: 10:20:29
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
   Serial number: 220215060502PQ
   Coding: 003E03200000040000000000
   VCID: 4084B104DB31304FE7-8014
   Serial number: 00000000000000846111
   Coding: 011000
   Coding: 8102
   VCID: 3776DAD88EFF77F756-8062
   Serial number: 220215060505FA
   Coding: 003E03200C00040000000000
   VCID: 3F86B2F8A6CF4FB79E-806A
   Serial number: 00000000000000433126
   Coding: 091000
   Coding: 021801010B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B01202154073
   Coding: 02730000FF00000021220001001800001F0203040100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64CC5D946FE94C6F23-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5016RJ
0020 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 24
                    Mileage: 49390 km
                    Date: 2019.10.03
                    Time: 20:23:00
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
   VCID: 438EBE08CA272B57FA-8016
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0014
   Serial number: 150118200694
End-------------------------(Elapsed Time: 04:36)--------------------------
auto scan after
Thursday,12,December,2019,20:54:02:45811
Mileage: 51762km-32163mi   Repair Order:
Scan: 01 03 08 09 10 13 15 16 17 19 32 42 44 52 55 5F 75 A9
VIN: 3VW5T7AU1FM083139   Mileage: 51762km-32163miles
   Revision: --H13---
Readiness: 1110 1101
   Coding: 01FA6BA15428096F0078020341CC6880D62A9000408216B410430051C006
   Revision: 00001K01
   Coding: 0031051001
   Occupant Detection:
   Coding: 30305A
   Coding: 0400
   Coding: 30FFFF
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00029.09.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Coding: 011000
   Coding: 8102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 203
                    Mileage: 51762 km
                    Date: 2019.12.09
                    Time: 00:27:03
                    Voltage terminal 30: 12.3 V
End-------------------------(Elapsed Time: 05:51)--------------------------
Best info I'm aware if is the spreadsheet linked in the first post here.
It looks like you've made the appropriate change in Byte 27.
dzolotnyuk
C?ID=84713
Thanks uwe
Quick update just went back to my original abs coding and only changed byte 27 from 50 to 51 coding accepted no faults
DV52
C?ID=194404
dzolotnyuk: I'm not sure about the relative synapse quantities in our individual neural networks, but here's a more -readable form of the comparative long codes values for the hex03 module:
ABS  	Before		         After
Byte	Hex	Binary	        Hex	Binary
0	01	00000001	01	00000001
1	FA	11111010	FA	11111010
2	6B	01101011	6B	01101011
3	A1	10100001	A1	10100001
4	34	00110100	54	01010100
5	28	00101000	28	00101000
6	09	00001001	09	00001001
7	6F	01101111	6F	01101111
8	00	00000000	00	00000000
9	78	01111000	78	01111000
10	02	00000010	02	00000010
11	03	00000011	03	00000011
12	81	10000001	41	01000001
13	CC	11001100	CC	11001100
14	29	00101001	68	01101000
15	80	10000000	80	10000000
16	D6	11010110	D6	11010110
17	2C	00101100	2A	00101010
18	90	10010000	90	10010000
19	00	00000000	00	00000000
20	40	01000000	40	01000000
21	81	10000001	82	10000010
22	94	10010100	16	00010110
23	B4	10110100	B4	10110100
24	10	00010000	10	00010000
25	43	01000011	43	01000011
26	00	00000000	00	00000000
27	50	01010000	51	01010001
28	C0	11000000	C0	11000000
29	08	00001000	06	00000110
As you can see - changes made to a few Bytes!!
Somnus
SLC, USA
C?ID=215931
ABS  	Before		         After
Indeed, that new coding looks like the Bytes related to Front Brake equipment & Rear Brake Equipment have been changed as well.
The coding for your ABS module with as few changes as possible for VAQ would be
01FA6BA13428096F0078020381CC2980D62C9000408194B410430051C008
EDIT: I just saw you already changed your coding around. Disregard :D
dzolotnyuk
C?ID=84713
thank you all if any issues come up i have a lot of references now
here is how i worked out my first coding
01FA6BA13428096F0078020381CC2980D62C9000408194B410430050C008 2015GTI M (MINE)
01FA6BA1342409710077020481CB2980D62C9000408194B400430050C007 2015GTI M
01FA6BA1342009700078020781C42980D62C9000408194B400430050C009 2015GTI M
01FA6BA13426096D007F020981C72980D62C9000408194B400430050C005 2015GTI A
01FA6BA134200971007D020081C52980D62C9000408194B400430050C009 2015GTI A
01FA6BA1342209700079020881C32980D62C9000408194B400430050C009 2015GTI A
01FA6BA134260971007E020581CA2980D62C9000408194B400430050C009 2015GTI A
01FA6BA1542009720077020441CB6880D62A9000408216B600430051C009 2016GTI M PLUS[/B][/B][/B][/B]
01FA6BA154200971007C020941C76880D62A9000408216B6144350D3C089 2016GTI m plus
01FA6BA134222972007A0602C1C32980D62C9400608394F600410030C009 2015 GTIA CANADA
01FA93A15424296F0378070641C36980C92A94C0E08296F7004200B8C208 2015 GOLF R A
01FA93A1542329750780070041C36980C92A94E0E08296F7184250F8C208 2015 GOLF R A
01FA93A1542029740380070741C56980C92A94C0E08296F7004200B8C208 2015 GOLF R A
darkchina811
ITALY
C?ID=333184
what is a differential lock and what benefit does it give to the car?
DarksideDev
C?ID=91860
Hi Everyone
I messaged dzolotnyuk but he has not replied.
Does anyone have any reference material that will help us with the retrofit of the E-Diff?
We have two Audi TT Race Cars that we want to convert from DSG with mechanical LSD to either DSG or Manual with the VAQ Diff
These are the cars - https://www.darksidedevelopments.co.uk/audi-tt-cup-8s-2-0-tfsi-dsg/
They are 2017 CHHC so basically the same as a Mk7 GTI
Any help would be appreciated.
Thanks
