A3 electrics went mental and car died
Stuartwhite1989
cannot find my old thread i had problem with water in fuse box. cleeaned all up and dried out was fine.driving down road everything went mad oil warning,rev counter dash going mad car shut off. got replacement fuse box still no start
youtube video dash https://youtu.be/4D7W7uy6ET0
car scan. egr is because its unplugged
Thursday,12,December,2019,18:27:39:57077
VCDS Version: 19.6.2.0
VIN: WAUZZZ8P84A056462   License Plate:
Mileage: 237380km-147501mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P84A056462   Mileage: 237380km-147501miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 G    HW: 028 101 136 4
   Component: R4 2,0L EDC 0000SG  5334
   Revision: 12345678    Serial number: AUX7Z0C6FNT0DV
   Coding: 0000072
   Shop #: WSC 01286 386 08256
   VCID: 27560A959633E177C6-8072
16486 - Mass Air Flow Sensor (G70)
            P0102 - 000 - Signal too Low
                    RPM: 147 /min
                    Torque: 190.0 Nm
                    Voltage: 7.98 V
                    Bin. Bits: 00000000
                    Mass Air / Rev.: 850.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 1 1 1
   Part No: 1K0 907 379 D
   Coding: 0055942
   Shop #: WSC 06435 000 00000
   VCID: 336EEEC552EB9DD76A-8066
01312 - Powertrain Data Bus
   Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
   Component: KlimavollautomatH14 0180
   Revision: 138254      Serial number: 8P0820043H
   VCID: 3162E4CDA8F7AFC718-8064
                    Reset counter: 224
                    Voltage: 7.40 V
                    Fault Status: 00101001
                    Reset counter: 218
                    Temperature: -50.0°C
                    Voltage: 8.40 V
                    Load: 9.0 %
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 233
                    Reset counter: 184
                    Mileage: 223600 km
                    Date: 2017.11.11
                    Time: 03:54:00
                    Temperature: 18.5°C
01273 - Fresh Air Blower (V2)
                    Reset counter: 224
                    Mileage: 237118 km
                    Date: 2019.11.27
                    Time: 00:01:56
                    Temperature: 5.0°C
                    Speed: 325.0 km/h
                    (no units): 202.0
                    (no units): 32.0
                    Fault Status: 01101000
                    Reset counter: 184
                    Mileage: 237382 km
                    Date: 2019.12.04
                    Time: 00:11:56
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H27 0401
   Revision: 00000000    Serial number: 00000000119363
   Coding: 01884F00A2141000000000000000000000
   VCID: 3B7EC6E57ABB5597B2-806E
   Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0011602
   VCID: 458AA01D0C7F1367D4-8010
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 009 0030
   Coding: 0000012
   Shop #: WSC 06435 551 00000
   VCID: 3064E1C9A3FDA6CF17-8064
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
   Component: KOMBIINSTR. VDO H25 0080
   Revision: D05         Serial number: 2246CD05000107
   Coding: 0004403
   Shop #: WSC 00783 067 57207
   VCID: 3C7CC5F97FB552AFBB-8068
            007 - Short to Ground
                    Fault Status: 00000011
                    Reset counter: 178
                    Mileage: 237118 km
                    Date: 2019.11.27
                    Time: 00:01:33
            014 - Defective
                    Reset counter: 178
00003 - Control Module
            014 - Defective
                    Mileage: 150981 km
                    Date: 2013.01.21
                    Time: 14:58:48
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0090
   Revision: 08          Serial number: 2400103721A350
   Coding: 3D0F0B42070101
   VCID: 264807919139F87FFD-8072
01304 - Radio
                    Reset counter: 184
                    Mileage: 237382 km
                    Date: 2019.12.04
                    Time: 00:15:39
   Revision: D05         Serial number: AUX7Z0C6FNT0DV
   Shop #: WSC 00762 210 91493
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 3972DCED70876787A0-806C
Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
   Part No: 1K1 909 143 L
   Component: EPS_ZFLS Kl.7       0402
00573 - Steering Torque Sensor (G269)
                    Torque: 0.0 Nm
            012 - Electrical Fault in Circuit - Intermittent - MIL ON
                    Temperature: 9.0°C
                    Voltage: 11.30 V
                    Voltage: 12.40 V
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Mileage: 7360 km
                    Temperature: 14.0°C
                    Voltage: 6.00 V
                    Voltage: 6.00 V
            004 - No Signal/Communication - Intermittent - MIL ON
                    Mileage: 7360 km
                    Temperature: 9.0°C
                    Voltage: 8.20 V
                    Voltage: 12.10 V
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 188800186D288505485AC63000
   Shop #: WSC 00186 785 00200
   VCID: 79F21CED3007A787E0-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH23 0100
   Revision: 00001       Serial number: 10000001041884
   VCID: 70E421C9637DE6CF57-8024
                    Reset counter: 218
                    Mileage: 237082 km
                    Date: 2063.15.31
                    Time: 31:63:63
                    Temperature: 4.0°C
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 218
                    Mileage: 237082 km
                    Date: 2063.15.31
                    Time: 31:63:63
                    Temperature: 4.0°C
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   VCID: 3A70C3E175816C9FA9-806E
Address 56: Radio
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Component: PTC-Element         0404
   Revision: 00600000    Serial number:
   VCID: 2B5EF6A58ADBC51722-807E
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 03: DTCs cleared
Several (but by no means all) modules report really low voltage in their freeeze-frame data. Look for a common voltage supply to those modules. You problem will likely be there.
Stuartwhite1989
The low voltage is where I kept unplugging things 1 by one and tryin to start. Then clearing all codes and doing scan after battery bit low. All this bloody started from a puddle not even a big one.
Stuartwhite1989
I’m going to cut cover off ecu tomo and check there for water in plugs. I keep thinking engine loom as the Rev counter speedo and oil level was going crazy
AIB Wolfgang
Hello
Here is the reason:
Freeze Frame: RPM: 147 /min >> needs up to 300 and
more than 10,5V battery voltage while starting.
Stuartwhite1989
The low voltage is because I had been trying to keep starting and unplugging bits then cranking. I could put a fully charged battery on or jump leads and it still won’t start. It jut cranks and dash beeps
AIB Wolfgang
so it seems there are no electrical failures who blocks the starting.
Now it's necessary to switch looking for mechanical failures.
Stuartwhite1989
The problem is mechanicaly it ran fine. Engine bay got bit wet then the problems started. When I switch the ignition on even with charged battery I get traction control light on permanently steering one and beeps. Only other thing I can think is I washed the car day before it broke down. It was parked for day after then it started and cut out few times like immo. Then it started after I sprayed wd40 into engine fuse box then had all the crazy light on dash in video I posted while driving. Then is cut in and out with power then died.
Westbury, UK
Sounds like a good start would be to thoroughly clean the residue of the WD40 from the fuse box.
Stuartwhite1989
I did mate. Even got another identical fuse box and part number. Still the same. I’ve checked every plug I can just not even attempting to start just crank and beeping dash
Westbury, UK
Stuart - it's kinda hard to suggest things to try when it feels like you're "drip feeding" us with the history of this problem. I suggest that it would help if you could post a "blow by blow" history of how the problem happened (details please) and step-by-step what you've done to try and fix the problem.
Stuartwhite1989
I brought the car from a friend and had gone through 3 steering racks in 4 months. He was sick of it so I brought for cheap run around. Throws torque sensor fault and shuts steering off now and then I just reset it as only to get to and from work. I caught a puddle nearside on way to work as lot of water come off field. Got to work and switched off but engine stayed running untill door opened. Thought ignition barrel. It then wouldn’t switch off when I got home at all so stalled it and left it. Engine fan was coming on all night draining battery. Turns out the seal was gone on fuse box engine bay. I stripped it down cleaned water and corrosion put back together was all good. Washed the car on the Friday and underneath engine as no guards thought I’d clean the crap under. Drove home all fine. Left it there weekend then went to start it started and cut out like it does with wrong key immo kicking in then got the beeping and oil level steering like in the video in first post. I soaked wd40 into fuse box to disperse any water and after 3 attempts it started but all the waning stayed on dash. Driving to my lockup to repair it the rev and speedo up and down engine cut in and out then completely dies. I stripped fuse box dried and tried no joy. Ordered another fuse box same part no still no joy. Unplugged everything 1 at a time tried starting after each still no joy. It just throws traction control light steering fault beeps. Cranky and not even trying to catch where before it would start and stop
Westbury, UK
Thanks - that should help the experts :thumbs:
NZDubNurd
New Zealand
C?ID=230482
Water in the oil level sensor plug can certainly cause the "oil level warning" and the "stop engine now" alarms - ask me how I know ;) The Mrs abandoned the car at the end of our road :D
There's not going to be much anybody can do remotely for this thing - it's going to be a lot of testing and trial and error.
That video could be many things, but it could easily be a power supply issue - a bunch of lights will come up when a module reboots. It could be ignition switch, relays, J519, battery terminals, earths, corroded connections etc. You're going to need a wiring diagram, I'd say ;)
Stuartwhite1989
Would a problem with power steering cause electric fault not to start. I clear faults. I read with snap on solid this time and all that keeps coming back is steering assist faults.
00573 steering torque sensor g269 electric problem in circuit.
01312 power train
00003 control module malfunction
00750 warning lamp trouble codes.
01314 engine control module no signal/ no communication
Stuartwhite1989
In instrument cluster I have 00562 sensor for oil short with ground
00381 data is instrument cluster malfunction
