No response from controller
bobst1100
Hi everyone. I have a 2016 Audi A7 US spec car. I recently ran an auto scan (see below) and for some reason, when I go to the Electronic Tabs 1&2, I cannot communicate with the controllers. It says "No response from controller". 2 of the controllers I want to explore are the Radio, and Navigation. Just an FYI, I don't think I ever tried to address these modules before. Also As for the Malfunctions listed, I had a run in with a deer. I believe the damage to the headlight and radar dome are causing these codes.
I'm using a USB connector interface. Does anyone offer any suggestions ?
Thursday,28,November,2019,10:57:07:62608
VIN: WAUWGAFC3GN0XXXX   License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAUWGAFC3GN015096   Mileage: 122742km-76268miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0004
   Revision: --H10---
   Coding: 1A2A00340566010D3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
   ROD: EV_ECM30TFS0214G2907551A_002.rod
   VCID: 290F0049C9766B4FBE9-807C
23044 - Valve for Fuel Metering (N290)
          P0089 00 [096] - Implausible Signal
15077 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
                    Mileage: 114938 km
                    Date: 2019.11.08
                    Time: 10:17:28
                    Engine speed: 1606.00 /min
                    Coolant temperature: 36 °C
                    Intake air temperature: 22 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 14.179 V
                    Unlearning counter according OBD: 6
                    Ignition angle of current cylinder: actual value: 7.88 °
                    Throttle valve angle: 5.186 °
                    Charge press.: average: 0.279 bar
                    Secondary air system: status: cancelled
                    Engine torque: 35.21875 Nm
                    Ambient air pressure: 0.926 bar
                    Accelerator position: 0.00 %
   Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1002
   Revision: --H19---
   VCID: 79AF100979561BCF8E9-802C
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 44A7964B22E569D21B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDBBE1127F2F5FFF0D-806A
   Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0560
   Coding: 0DAA6F4E000000000000
   VCID: 7EA5031560F83CF7BBB-802A
   Serial number: 3215000045223013
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23031500040411
   Coding: 668331B84D0000
   VCID: 63935261EBDAF11FB45-8036
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00001033397502
   Coding: 01050011043C9FE2C100488780007800CF9CC208AE0802218000089C710015020060002D0B0000
   VCID: 76B51B3548C874B7E3B-8022
   Component: WWS57X 150307  H37 0080
   Serial number:         150310091155
   Coding: 0045F7
   Serial number: 23819186
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 10 03 2015  00001897
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01E5BD9A
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA120407000012221144
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: B2A01AC800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 52
                    Mileage: 119555 km
                    Date: 2019.11.20
                    Time: 17:36:12
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Status: 00101100
                    Reset counter: 59
                    Mileage: 122639 km
                    Date: 2019.11.25
                    Time: 15:00:49
   Component: ACC3          H21 0053
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
10240 - Sensor for Automatic Distance Control
          [FAULT_BLR_BLK8_31]
                    Fault Frequency: 39
                    Reset counter: 57
                    Mileage: 111743 km
                    Date: 2019.11.03
                    Time: 09:37:26
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 14.598 V
                    Velocity_vehicle_reference: 34.12 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MAR_SLOW_MISALIGNMENT]
                    Reset counter: 57
                    Mileage: 122009 km
                    Date: 2019.11.23
                    Time: 12:07:01
                    Control Module temperature: 9 °C
                    Voltage terminal 15: 14.360 V
                    Velocity_vehicle_reference: 32.85 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.04 m/s²
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MAR_FAST_MISALIGNMENT]
                    Reset counter: 57
                    Mileage: 120653 km
                    Date: 2019.11.22
                    Time: 11:21:05
                    Control Module temperature: -2 °C
                    Voltage terminal 15: 14.352 V
                    Velocity_vehicle_reference: 33.29 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MAR_PRE_MISALIGNMENT]
                    Fault Frequency: 46
                    Reset counter: 57
                    Mileage: 120088 km
                    Date: 2019.11.21
                    Time: 15:25:15
                    Control Module temperature: 4 °C
                    Voltage terminal 15: 14.492 V
                    Velocity_vehicle_reference: 36.82 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.02 m/s²
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G000212BZ
   Coding: 303331333131303134354A55304C34473853
   VCID: 3431E13D1EB426A71DF-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y150001BE5H0L
   Serial number: 3575HRB405134BKO18K4
   Serial number: 3585HRB406933RVKE11N
   Serial number: 3515JRB406736270O0HI
   Serial number: 3525JRB4053346844GOO
   Serial number: 3554VRB405D35IMO1P6/
   Serial number: 3564VRB405D35IMOM1I7
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OCH0004R
   Coding: 0004FC
   VCID: 3829D50D025CC2C7317-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 26 02 2015  E0084774
   Part No SW: 4G8 920 986 A    HW: 4G8 920 986 A
   Component: TBenUsaAcc    H08 0043
   Revision: 04001037    Serial number: 658210315596022
   Coding: 0BCF01060F53D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3635DB3508C834B723B-8062
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001769306
   Coding: C0CD073010
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75B71C39554E7FAFEA1-8020
   Serial number: 9312886003
   Voltage stabilizer:
   Serial number: 15011000000000000293
   Revision: AA001002
   Coding: 04018E64747464545425363E00
   VCID: 7CA1091D76E42EE795F-8028
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 22031500040003
   Coding: 20
   VCID: 3E25C31520F8FCF7FBB-806A
   Revision: AA000000    Serial number: 00000138614452
   VCID: 77AB16314FC20DBFF8D-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82097LPN
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: SWA Master    H06 0060
   Serial number: 0359078765
   Coding: 040211
   VCID: 392FD00939D6DBCFCE9-806C
   Component: SWA Slave  H06 0060
   Serial number: 0363651604
   Coding: 040211
733440 - Control Module for Lane-Change Assist
          C1114 F3 [008] - Limited Visibility
                    Reset counter: 50
                    Mileage: 113040 km
                    Date: 2019.11.04
                    Time: 12:13:33
733696 - Control Module 2 for Lane-Change Assist
          C1115 F5 [008] - Limited Visibility
                    Reset counter: 50
                    Mileage: 117990 km
                    Date: 2019.11.17
                    Time: 10:49:20
   Component: TSG FA        H04 0507
   Coding: 011F57035E00628002000413
   VCID: 45D7ACF945AEAF2FBA1-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0014616076
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0364125417
   Coding: 0126063A20BAF08582B00A0402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000282073
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST0007BONT00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120473000012380672
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93466428
   Coding: 011F57035E00628002000402
   VCID: 46D5ABF578A8A437B3B-8012
   Revision: --------    Serial number: 00000001398756
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D07F459FD9E776F521-8078
   Coding: 05FA021122600400
   Coding: E02000
   Coding: E02000
5538320 - Bulb for High Beam Headlamp Right
          B121A 01 [008] - Electrical Failure
                    Reset counter: 52
                    Mileage: 119555 km
                    Date: 2019.11.20
                    Time: 17:36:08
5538322 - Temperature Sensor for Right High Beam
          C1170 01 [008] - Electrical Failure
                    Fault Frequency: 14
                    Reset counter: 54
                    Mileage: 119790 km
                    Date: 2019.11.21
                    Time: 12:03:42
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025     HW: 4G1 035 025
   Component: MU-H-LNS-US   040 0143
   Serial number: A278C0FB011150
   Coding: 01750302FF0A000013220001041A00102F000CE5F1700104FE
   VCID: 5BE36A81D3AAC9DFFC5-800E
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9EY800SZ6
   Multimedia Operating Unit:
   Serial number: 90349OCG0010H
   Component: Gracenote2  --- 3006
   Coding: 010F17024000628002000002
   VCID: 49CFA0C969B64B4F5E9-801C
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0214131
   Coding: 0216000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI.rod
   VCID: 2E05F355F0980C776BB-807A
   Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
   Component: HDSG-Modul    H14 0049
   Revision: 12014001    Serial number: 065501757
   Coding: 0A3305C122
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 46D5ABF57828A437B3B-8012
   Component: DPC-SG        H27 0081
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01F95DC6847E6745F-8078
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270B0671DF625D3FA8D-8072
   Component: BV-SG         H33 0090
   Serial number: 005000621703157
   Coding: 03C1B8180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313FE829E1A6138F769-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323DE725E4A028970F3-8066
End----------(Elapsed Time: 02:22, VBatt start/end: 12.2V/12.2V)-----------
Look at the Installation List (at the top of the Auto-Scan) that shows all the controller that exist in the car, trying to access any other controller won't work as it doesn't exist!
BTW radio and navigation are now both handled by the 5F Infotainment module :thumbs:
bobst1100
Hi PetrolDave,
Thanks for getting back to me and clearing this matter up and also showing me the correct way to include an auto-scan.
The reason I'm looking to explore the Nav. module is because my maps need updating. My dealer wants approx. $600 to install the new activation code and the new North American maps. That just seems wrong. I've been told that I can actually purchase the key code but not sure if I can access where to update the activation code. Any ideas on this?
Can't help you with that - my Skoda map update is just a case of downloading the new maps from either the VW or Skoda website and unzipping it onto an SD card, but my previous Audi required a new DVD every year at a cost of around $300.
bobst1100
I understand. Thanks for your help!
