Hi everyone. I have a 2016 Audi A7 US spec car. I recently ran an auto scan (see below) and for some reason, when I go to the Electronic Tabs 1&2, I cannot communicate with the controllers. It says "No response from controller". 2 of the controllers I want to explore are the Radio, and Navigation. Just an FYI, I don't think I ever tried to address these modules before. Also As for the Malfunctions listed, I had a run in with a deer. I believe the damage to the headlight and radar dome are causing these codes.
I'm using a USB connector interface. Does anyone offer any suggestions ?
Thursday,28,November,2019,10:57:07:62608
VIN: WAUWGAFC3GN0XXXX License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
53 55 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAUWGAFC3GN015096 Mileage: 122742km-76268miles
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0004
Revision: --H10---
Coding: 1A2A00340566010D3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
ROD: EV_ECM30TFS0214G2907551A_002.rod
VCID: 290F0049C9766B4FBE9-807C
23044 - Valve for Fuel Metering (N290)
P0089 00 [096] - Implausible Signal
15077 - Idle Control System RPM
P0507 00 [096] - Higher than Expected.
Mileage: 114938 km
Date: 2019.11.08
Time: 10:17:28
Engine speed: 1606.00 /min
Coolant temperature: 36 °C
Intake air temperature: 22 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 14.179 V
Unlearning counter according OBD: 6
Ignition angle of current cylinder: actual value: 7.88 °
Throttle valve angle: 5.186 °
Charge press.: average: 0.279 bar
Secondary air system: status: cancelled
Engine torque: 35.21875 Nm
Ambient air pressure: 0.926 bar
Accelerator position: 0.00 %
Part No SW: 4G0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H19 1002
Revision: --H19---
VCID: 79AF100979561BCF8E9-802C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 44A7964B22E569D21B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDBBE1127F2F5FFF0D-806A
Part No SW: 4H0 907 064 FR HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0560
Coding: 0DAA6F4E000000000000
VCID: 7EA5031560F83CF7BBB-802A
Serial number: 3215000045223013
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 23031500040411
Coding: 668331B84D0000
VCID: 63935261EBDAF11FB45-8036
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001033397502
Coding: 01050011043C9FE2C100488780007800CF9CC208AE0802218000089C710015020060002D0B0000
VCID: 76B51B3548C874B7E3B-8022
Component: WWS57X 150307 H37 0080
Serial number: 150310091155
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23819186
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 10 03 2015 00001897
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01E5BD9A
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA120407000012221144
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: B2A01AC800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 52
Mileage: 119555 km
Date: 2019.11.20
Time: 17:36:12
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Status: 00101100
Reset counter: 59
Mileage: 122639 km
Date: 2019.11.25
Time: 15:00:49
Component: ACC3 H21 0053
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
10240 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FAULT_BLR_BLK8_31]
Fault Frequency: 39
Reset counter: 57
Mileage: 111743 km
Date: 2019.11.03
Time: 09:37:26
Control Module temperature: 6 °C
Voltage terminal 15: 14.598 V
Velocity_vehicle_reference: 34.12 m/s
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
[FAULT_MAR_SLOW_MISALIGNMENT]
Reset counter: 57
Mileage: 122009 km
Date: 2019.11.23
Time: 12:07:01
Control Module temperature: 9 °C
Voltage terminal 15: 14.360 V
Velocity_vehicle_reference: 32.85 m/s
Longitudinal_acceleration_vehicle_reference: 0.04 m/s²
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
[FAULT_MAR_FAST_MISALIGNMENT]
Reset counter: 57
Mileage: 120653 km
Date: 2019.11.22
Time: 11:21:05
Control Module temperature: -2 °C
Voltage terminal 15: 14.352 V
Velocity_vehicle_reference: 33.29 m/s
Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
[FAULT_MAR_PRE_MISALIGNMENT]
Fault Frequency: 46
Reset counter: 57
Mileage: 120088 km
Date: 2019.11.21
Time: 15:25:15
Control Module temperature: 4 °C
Voltage terminal 15: 14.492 V
Velocity_vehicle_reference: 36.82 m/s
Longitudinal_acceleration_vehicle_reference: 0.02 m/s²
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G000212BZ
Coding: 303331333131303134354A55304C34473853
VCID: 3431E13D1EB426A71DF-8060
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y150001BE5H0L
Serial number: 3575HRB405134BKO18K4
Serial number: 3585HRB406933RVKE11N
Serial number: 3515JRB406736270O0HI
Serial number: 3525JRB4053346844GOO
Serial number: 3554VRB405D35IMO1P6/
Serial number: 3564VRB405D35IMOM1I7
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372OCH0004R
Coding: 0004FC
VCID: 3829D50D025CC2C7317-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 26 02 2015 E0084774
Part No SW: 4G8 920 986 A HW: 4G8 920 986 A
Component: TBenUsaAcc H08 0043
Revision: 04001037 Serial number: 658210315596022
Coding: 0BCF01060F53D705020100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3635DB3508C834B723B-8062
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001769306
Coding: C0CD073010
VCID: 75B71C39554E7FAFEA1-8020
Serial number: 9312886003
Voltage stabilizer:
Serial number: 15011000000000000293
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04018E64747464545425363E00
VCID: 7CA1091D76E42EE795F-8028
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 22031500040003
Coding: 20
VCID: 3E25C31520F8FCF7FBB-806A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000138614452
VCID: 77AB16314FC20DBFF8D-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA82097LPN
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Component: SWA Master H06 0060
Serial number: 0359078765
Coding: 040211
VCID: 392FD00939D6DBCFCE9-806C
Lane Change Assistant 2:
Component: SWA Slave H06 0060
Serial number: 0363651604
Coding: 040211
733440 - Control Module for Lane-Change Assist
C1114 F3 [008] - Limited Visibility
Reset counter: 50
Mileage: 113040 km
Date: 2019.11.04
Time: 12:13:33
733696 - Control Module 2 for Lane-Change Assist
C1115 F5 [008] - Limited Visibility
Reset counter: 50
Mileage: 117990 km
Date: 2019.11.17
Time: 10:49:20
Component: TSG FA H04 0507
Coding: 011F57035E00628002000413
VCID: 45D7ACF945AEAF2FBA1-8010
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0014616076
Coding: 101001010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0364125417
Coding: 0126063A20BAF08582B00A0402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000282073
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST0007BONT00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA120473000012380672
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93466428
Component: TSG BF H03 0507
Coding: 011F57035E00628002000402
VCID: 46D5ABF578A8A437B3B-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001398756
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D07F459FD9E776F521-8078
Component: MxB-ECU 001 0100
Coding: 05FA021122600400
Coding: E02000
Coding: E02000
5538320 - Bulb for High Beam Headlamp Right
B121A 01 [008] - Electrical Failure
Reset counter: 52
Mileage: 119555 km
Date: 2019.11.20
Time: 17:36:08
5538322 - Temperature Sensor for Right High Beam
C1170 01 [008] - Electrical Failure
Fault Frequency: 14
Reset counter: 54
Mileage: 119790 km
Date: 2019.11.21
Time: 12:03:42
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 HW: 4G1 035 025
Component: MU-H-LNS-US 040 0143
Serial number: A278C0FB011150
Coding: 01750302FF0A000013220001041A00102F000CE5F1700104FE
VCID: 5BE36A81D3AAC9DFFC5-800E
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9EY800SZ6
Multimedia Operating Unit:
Serial number: 90349OCG0010H
Compact Disc Database:
Component: Gracenote2 --- 3006
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: 49CFA0C969B64B4F5E9-801C
Part No SW: 4H0 907 428 D HW: 7P6 907 441 F
Component: TopView H07 0330
Revision: 11001001 Serial number: 82330JF0214131
Coding: 0216000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
VCID: 2E05F355F0980C776BB-807A
Part No SW: 4G8 959 107 T HW: 4G8 959 107 J
Component: HDSG-Modul H14 0049
Revision: 12014001 Serial number: 065501757
Coding: 0A3305C122
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 46D5ABF57828A437B3B-8012
Component: TSG HR H03 0507
Component: DPC-SG H27 0081
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C01F95DC6847E6745F-8078
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
VCID: 270B0671DF625D3FA8D-8072
Component: BV-SG H33 0090
Serial number: 005000621703157
Coding: 03C1B8180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313FE829E1A6138F769-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323DE725E4A028970F3-8066
End----------(Elapsed Time: 02:22, VBatt start/end: 12.2V/12.2V)-----------
