2012 Tiguan ECU Error 31 coding rejected
mtmservices1
C?ID=250478
Hi! We've got a Volkswagen Tiguan 2012 5N chassis code. We have a new genuine engine ECU that has been hardware coded from factory and we are trying to attempt the long coding (soft coding). We have retrieved the original long code from the original ECU however when this is entered it comes up with Error 31 coding rejected. Can anyone advise/assist?
Monday,25,November,2019,13:08:12:53838
VCDS Version: 14.10.2.0
Data version: 20150311
Dealer/Shop Name: matt
VIN:    License Plate: ML61UMT
Mileage: 172340km-107087mi   Repair Order:
Chassis Type: XX (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 4C 52 53 56 61
          62 72 77
VIN: XXXXXXXXXXXXXXXXX   Mileage: 172340km-107087miles
2E-Media Player 3 -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9981
   Revision: 41H28---    Serial number: XXXXXXXXXXXXXX
   Coding: 00000000000000000000
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_ECM20TDI01103L906018E 003014
   ROD: EV_ECM20TDI01103L906018E.rod
   VCID: 2C50A5EF47D97941E27-8079
10 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Time: 00:00:00
4814 - System Voltage
          P0562 00 [036] - Too Low
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:00:24
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Time: 00:00:00
5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [167] - Open Circuit
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:00:19
10095 - Engine Control Unit Incorrectly Coded
          P0610 00 [167] - -
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:00:16
5040 - Fuel Injector #1 (N30)
          P0263 00 [167] - Contribution/Balance Fault
                    Time: 00:00:00
5042 - Fuel Injector #3 (N32)
          P0269 00 [167] - Contribution/Balance Fault
                    Time: 00:00:00
5045 - Fuel Injector #4 (N33)
          P0272 00 [167] - Contribution/Balance Fault
                    Time: 00:00:00
5041 - Fuel Injector #2 (N31)
          P0266 00 [167] - Contribution/Balance Fault
                    Time: 00:00:00
10529 - Engine Control Module Incorrectly Coded
          P1612 00 [167] - -
                    Time: 00:00:00
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AH    HW: 5N0 614 109 AH
   Component: J104   C6 450M VDE7 0003
   Revision: --H07---    Serial number: 00000005024844
   Coding: 0040254
   Shop #: WSC 01324 020 00200
   VCID: 71EE749B687B54A9911-8024
                    Fault Frequency: 54
                    Reset counter: 231
                    Mileage: 172341 km
                    Date: 2014.04.07
                    Time: 00:00:46
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.50 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
00532 - Supply Voltage B+
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:22:09
                    Hex Value: 0x0000
                    Voltage: 7.50 V
                    Bin. Bits: 00011110
                    Count: 115
                    Hex Value: 0x0000
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:22:09
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004003
   VCID: 7F0AA2A3E62F32D9175-802A
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 231
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:09:05
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 48180A3B8025F1C0400800C0340081E44B510088436D81606480C7000041
   VCID: 3E749FA7A9A5FBD15C3-806B
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 14111  013 0203
   Coding: 009795
   Component: RLS 241111 05  54  0403
   Coding: 02304D
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:14:36
                        Term 15 On
                    Voltage: 8.30 V
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:20:49
                        Term 15 On
                    Voltage: 8.15 V
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:19:44
                        Term 15 On
                    Voltage: 8.60 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 61
                    Reset counter: 231
                    Mileage: 166252 km
                    Date: 2014.01.11
                    Time: 16:27:32
                        Term 15 On
                    Voltage: 12.35 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261132600129
   Coding: 149203
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 4480ED4FCF4991010A7-8011
13635840 - Supply voltage
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:31
          U1400 00 [008] - -
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:31
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__207 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0PPTBDLI
   Coding: 0012343
   VCID: 4C90C56F2F195941C27-8019
   Subsystem 1 - Serial number: 6332MTS624123111
   Subsystem 2 - Serial number: 6342MTS635533101
   Subsystem 3 - Serial number: 6351HTS675F21AKJ
   Subsystem 4 - Serial number: 6361HTS6RA4LV9KJ
                    Reset counter: 15
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:19:45
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111119100505
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79FE4CBBF80B1CE9291-802C
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:21:08
136194 - Supply voltage
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:20:40
   Part No SW: 5N0 920 982 D    HW: 5N0 920 982 D
   Component: KOMBI         H04 0417
   Coding: 411F01
   VCID: 3566808B949338898D9-8060
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:45
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 221111F2002748
   Coding: 356003
   VCID: 3B7296B3BAB7EEF97BD-806E
                    Reset counter: 15
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:20:45
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4D96C86BD4035049D59-8018
00448 - Haldex Clutch Pump (V181)
                    Reset counter: 40
                    Mileage: 160635 km
                    Date: 2013.10.22
                    Time: 12:57:36
01155 - Clutch
                    Fault Status: 00100011
                    Reset counter: 13
                    Mileage: 171617 km
                    Date: 2014.03.27
                    Time: 19:58:07
   Component: IMMO          H04 0417
   VCID: 6ADC63F78DADA771D0B-803F
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Revision: A1001003    Serial number: 7661368256
   VCID: 295E5CFB402B6C69191-807C
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:19:30
                    Reset counter: 16
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0003833310
   Coding: 0202B4
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 387889BF8381C5E196F-806D
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C
   Component: J389__TSG-HR  007 1504
   Serial number: 00000006259767
   Coding: 000090
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 230
65793 - Supply voltage
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:52
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:20:58
   Part No: 5N0 909 144 N
   Component: EPS_ZFLS Kl. 202    3301
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 3C7095AF7FB9E9C1727-8069
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.1 V
                        PD
                    Temperature: 11.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 4C: Tire Pressure II
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0003837384
   Coding: 0202B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 397E8CBBB88BDCE9691-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C
   Component: J388__TSG-HL  007 1504
   Serial number: 00000006265346
   Coding: 000090
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:52
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:20:41
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000444092
   Coding: 0026167
   VCID: 3566808B5C9338898D9-8060
03200 - Switch for Electric Parking Brake (E538)
                    Reset counter: 7
                    Voltage: 12.30 V
                    Count: 10
                    Hex Value: 0x0863
                    Hex Value: 0x0098
                    Hex Value: 0x1010
                    Reset counter: 231
                    Mileage: 172341 km
                    Date: 2014.04.11
                    Time: 00:21:09
                    Voltage: 8.00 V
                    Count: 48
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3L6697942
   Coding: 0100040004000C
   VCID: 2C50A5EF4FD97941E27-8079
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H43 1623
   Coding: 030F185A
   VCID: 71EE749BA87B54A9911-8024
   Component: J367-BDM  H07 0180
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661379021
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 264457C759354311343-8073
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:20:09
          U1400 00 [008] - -
                    Reset counter: 16
                    Mileage: 172341 km
                    Date: 2019.11.19
                    Time: 00:19:51
End-------------------------(Elapsed Time: 03:39)--------------------------
NZDubNurd
New Zealand
C?ID=230482
Many of the modules are reporting low voltage.
You may have to install some more voltage before it will even attempt to write anything.
If that isn't the issue, you don't really want to brick something with it shutting off half way through, do you?
Five-year old software? Really?
Yes, it appears to be legitimate, but still.. Software updates are free.
You wouldn't happen to have a scan from this car when the old ECU was still in there for comparison purposes, would you?
Lastly: Have you tried setting some different WSC, Importer, and Equipment number values?
mtmservices1
C?ID=250478
We've now updated to latest version. We can replug old ECU back in and get a code scan. In the meantime, how do we know what different WSC/Importer/Equipment number values we should change it to? Thanks for help.
rhinopower
C?ID=58979
How was the new unit matched? If online with odis it would of also restored the soft coding too
WSC etc is changed in the settings option, bottom right on the main vcds page, you can change to any random numbers, it is just some modules done like 001 etc when coding
It is possible the new ecu is newer and different software, so the coding itself may be different, take a picture of each screen from the long coding options, and match the options selected on the new ecu
Spacewalker
C?ID=159607
XXXXXXXXXXXX = IMMO OFF
post autoscan with old ECU
