RS5 electrical fault, loss of power steering (B8.5)
Ape Factory
C?ID=321067
Hi, had a fluke accident last night where I accidentally caught an aftermarket relay wiring harness on the corner of something and it yanked the wire out of the connector as I was trying to locate it. The wire in question was the main hot wire and it touched the windshield wiper control module, causing a spark. Happened so fast but I knew I'd done some damage and it was stupid of me not to disconnect the battery.
Anyway...I'm great at fixing many things but anything electronic is not my best area.
I do have a full scan. The primary issue is the power steering is dead. No assist and the dash has lit up like a Christmas tree.
I'll be attempting to move the car into a more opportune spot so I can check all the fuses (cheap stuff first!). Looking over the electrical FSM, I cannot tell if there's a relay for the active steering control module.
I have a lot of codes as a result of all of this. Ignore the error with the seat and the radio, I've had those forever and a day. Changed the coding on the radio to enable it to use my phone as a wifi hotspot with other supporting hardware.
As I said, I'll start with the fuses but after that, I'm not sure where to even begin. Will most likely clear the codes, disconnect the battery and go from there. And thanks for helping out, greatly appreciated.
Here's the scan:
Monday,28,October,2019,01:13:50:27520
VIN: WUAC6AFR6DA902467   License Plate:
Mileage: 101180km-62870mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C
VIN: WUAC6AFR6DA902467   Mileage: 101180km-62870miles
17-Instruments -- Status: Malfunction 1010
1B-Active Steering -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l JHM.9 /  H04 0005
   Revision: NAH04---
   Coding: 1A25003225C6080D3000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
   ROD: EV_ECM42FSI0118T2907560F.rod
   VCID: 3FDBBD3337FB04FFF0D-806A
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Coolant temperature: 25 ∞C
                    Intake air temperature: 25 ∞C
                    Voltage terminal 30: 11.449 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
4531 - Fan 1 Control Circuit
          P0691 00 [032] - Short to GND
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:14
                    Engine speed: 1409.00 /min
                    Normed load value: 68.6 %
                    Coolant temperature: 26 ∞C
                    Intake air temperature: 23 ∞C
                    Voltage terminal 30: 13.970 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
5612 - Steering Effort Control Module
          U0130 00 [039] - No Communications
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Voltage terminal 30: 11.591 V
                    AFS dm: 0.0 kg/h
4729 - Steering Effort Control Module
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
   Part No SW: 8T0 927 156 H    HW: 0B5 927 156 J
   Component: 0B5 42 FSINAR H01 0005
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ROD: EV_TCMDL501021.rod
   VCID: 42DDB4C7440969179F3-8016
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 302D1A
   VCID: 45D7AFDB55A75E2FBA1-8010
03110 - Active Steering Control Module (J792)
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0011
                    Hex Value: 0x858E
                    Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x000F
                    Hex Value: 0x508E
                    Hex Value: 0x0000
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:10:37
                    Hex Value: 0x0000
                    Hex Value: 0x02A2
                    Hex Value: 0x000C
                    Hex Value: 0x468E
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Coding: 0D804000000000000000
   VCID: 045172DF1E1DA727EDF-8050
   Serial number: 2313000016339008
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000051213831
   Coding: 00037025002C00000000
   Shop #: WSC 06342 000 00000
   Revision: C1000000    Serial number: 01200220130492
   Coding: 4802200000
   VCID: 392FD32B295F2ACFCE9-806C
                    Fault Status: 01100101
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:55:42
                    Fault Status: 00100011
                    Fault Frequency: 11
                    Reset counter: 147
                    Mileage: 100634 km
                    Date: 2019.10.14
                    Time: 14:40:05
                    Voltage: 14.10 V
                    Temperature: 35.0∞C
                    Temperature: 39.0∞C
                    Count: 25000
                    Count: 10984
                    Bin. Bits: 01000000
                    Bin. Bits: 10001011
                    Time: 54.00 s
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000554864301
   Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
   Shop #: WSC 92630 444 123950
   VCID: 7AAD0C276CD9E1D7873-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150213  H15 0080
   Serial number: SWF13020150148
   Coding: 00FD11
   Serial number: 21004112
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000502130647
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4SYJ02
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 7C48C296000000000001
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:14
03124 - Terminal 30 - 3
                    Fault Status: 00101011
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 00:25:52
00926 - Terminal 30
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 00:40:33
                    Reset counter: 148
                    Mileage: 101183 km
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:45
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 00333E
   VCID: 323DE407F429D9970F3-8066
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.26 V
                    Hex Value: 0x00BE
                    Lateral Accel.: 0.00 m/s^2
01316 - ABS Control Module
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.39 V
                    Hex Value: 0x00C0
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.26 V
                    Hex Value: 0x0084
   Serial number: 003KJD91EW3S
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD9CE77C39B157573-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000CJ7S
   Serial number: 6334MSME780331656
   Serial number: 6344MSME78406157C
   Serial number: 6352QSME62282B44G
   Serial number: 6362QSME5F2C5372T
   Serial number: 63732SME712B0F585
   Serial number: 63832SME542B2F444
12660736 - Steering Effort Control Module
          U0130 00 [009] - No Communications
          [Active Steering Control Unit no communication]
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130219001040
   Coding: 00003E
   VCID: 51FF8B8B91EF828F169-8004
   Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
   Revision: 00300000    Serial number: UVA266K2E
   Coding: 83BF0100AF03D705020000
   VCID: 3D27C73B3D7716EFE21-8068
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:08
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z13204008E
   Coding: 80E3031600
   VCID: 4CC19AFF76CDAF6765F-8018
   Serial number: 1367620003
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 148
                    Mileage: 100600 km
                    Date: 2019.10.12
                    Time: 19:37:01
                    Fault Frequency: 24
                    Reset counter: 148
                    Mileage: 100626 km
                    Date: 2019.10.13
                    Time: 03:01:32
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 7
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:01
                    Bin. Bits:    00000
                    Voltage: 11.60 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 01:04:10
                    Bin. Bits:    10000
                    Voltage: 11.70 V
                    Count: 9
                    Bin. Bits:    10000
                    Time: 5.30 s
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
Address 1B: Active Steering
   Component: 4 Wheel Drive H14 0100
   Serial number: 001302130001758
   VCID: 2F3BED73E79BF47F60D-807A
0226 - Steering Effort Control Module
          U0130 00 [137] - No Communications
          [Steuerger‰t f¸r aktive Lenkung keine Kommunikation DTC_CAN_STEER_CTL_NO_COM]
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [137] - -
          [ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000051211560
   Coding: 001B7B25002C00000000
   Shop #: WSC 11251 001 1048576
03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:55:42
   Component: SWA Master    H04 0060
   Serial number: 0192285845
   Coding: 010211
   Shop #: WSC 06324 000 00000
   Component: SWA Slave  H04 0060
   Serial number: 0192294703
   Coding: 000102
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F57897B801E5B7C3B-8002
Address 44: Steering Assist
   Revision: 00002001    Serial number: 0301332569
   Coding: 0106069A00FAC10581B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000634856
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104645000002650945
   Revision: 00005001    Serial number: 94813011143102
   VCID: 2D07F77BED17866F521-8078
   Component: TSG BF        H09 0304
   VCID: 55F77F9BA507EEAFCA1-8000
   Revision: --------    Serial number: 20000000227161
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D62F12D533C7317-806C
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:10:37
                    Voltage terminal 30: 11.6 V
                    Internal Fault ID: 188
                    Network management state: normal
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: static
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156B50D7693479
   Coding: 020007010000000001
   VCID: 25170F5BB5E7BE2F9A1-8070
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 1040
   Revision: --------    Serial number: 204BT0D7561283
   Coding: 150200020306A9EF75028B4E00000403140000000000000002
   VCID: 3FDBBD33377B04FFF0D-806A
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Serial number: A130BX0D2659970
   Serial number: 00000001419689
   Component: CD-Database  4949
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:56:12
                    Text: DUA130,Front,M,0,0,6
00384 - Optical Databus
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 01:03:45
                    Voltage: 11.80 V
   Revision: --H07---    Serial number: 525PA8-J2Z91FG
   Coding: 1021008
   VCID: 3829D62F1E5533C7317-806C
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                        Term 15 On
                        Reverse OFF
                    Count: 3
End----(Elapsed Time: 02:00, VBatt start/end: 11.4V/11.7V. VIgn 11.7V)-----
Ape Factory
C?ID=321067
All the fuses look intact on the driver's and passenger's side. Leaning towards a Can Bus module being blown and preventing connection to the active steering module (J792). Cannot connect to it with the VCDS. Most of the fault priorities are either 4 or 6.
Cleared codes, disconnected battery, no change. Car starts and runs fine. Was able to "muscle" it out of the garage and into a better position so I could open the driver's door fully and pull fuses.
I have the FSM electrical schematic but trying to figure out which applies to the RS5 is numbing to say the least.
Ape Factory
C?ID=321067
Looked at all the fuses in the trunk, no luck. Have the ECU pulled and now checking the fuses underneath. Next step, the power steering fuse underneath the dash.
Ape Factory
C?ID=321067
Checked the relay under the dash which I believe is the power steering relay and it's working. Tested for operation and resistance.
Ape Factory
C?ID=321067
I buttoned everything back up and still had faults. Shockingly, the power steering came back and it feels like I'm getting both dynamic and normal steering. Strange.
I still have steering faults, adaptive headlight faults, active differential faults and stability control faults on the dash and through the VCDS. I've tried clearing the faults in the individual modules.
I am unable to connect to the active steering control module. I'll do another scan and post it as some of the items from the first scan have gone away.
How can I tell if it's the CAN bus control module or the active steering module itself without physically checking the pins at the CAN bus?
DrPeter
16.4905° S, 151.7375° W
Use VCDS to go in to the [19-Gateway] controller, then use the [Meas.Blocks-08] and have a look at the Group [125 to 129] for the CAN-Data bus Powertrain (Communication).
Everything that is installed and that is communicating should have a value of [1]. If any of these controllers have a [0], that is an indication the controller is not communication. A value that is flashing between [0] and [1], would indicate there is partial but corrupt communications.
You can also perform the [Gateway Installation List] on the Auto-Scan to see if the Gateway controller reports either [Status: Malfunction 0010] or [Status: OK 0000]. If you see the [Status: Cannot be reached 1100], then you can confirm this with the measuring value blocks groups aforementioned.
If you need more information, please post a New Auto-Scan, that way we can see the status of the vehicle now.
Hope this helps,
drpeter
Ape Factory
C?ID=321067
Definitely helps. I've been driving around and the car seems just fine minus the dash light show. The steering seems to have both dynamic and normal. Here's the new scan.
          52 53 56 5F 6C
   Revision: NAH04---
          U1113 00 [039] - -
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    AFS dm: 0.0 kg/h
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:14
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    AFS dm: 0.0 kg/h
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
   Revision: --H01---
   Coding: 302D1A
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0011
                    Hex Value: 0x858E
                    Hex Value: 0x0000
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x000F
                    Hex Value: 0x508E
                    Hex Value: 0x0000
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:10:37
                    Hex Value: 0x0000
                    Hex Value: 0x02A2
                    Hex Value: 0x000C
                    Hex Value: 0x468E
                    Hex Value: 0x0000
   Coding: 4802200000
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:55:42
                    Fault Frequency: 11
                    Reset counter: 147
                    Mileage: 100634 km
                    Date: 2019.10.14
                    Time: 14:40:05
                    Voltage: 14.10 V
                    Temperature: 35.0∞C
                    Temperature: 39.0∞C
                    Count: 25000
                    Count: 10984
                    Bin. Bits: 01000000
                    Bin. Bits: 10001011
                    Time: 54.00 s
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:14
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 00:25:52
00926 - Terminal 30
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 00:40:33
                    Reset counter: 148
                    Mileage: 101183 km
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:45
   Coding: 00333E
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.26 V
                    Hex Value: 0x00BE
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.39 V
                    Hex Value: 0x00C0
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Temperature: 19.0∞C
                    Voltage: 11.26 V
                    Hex Value: 0x0084
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
   Coding: 00003E
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:08
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
   Coding: 80E3031600
                    Reset counter: 148
                    Mileage: 100600 km
                    Date: 2019.10.12
                    Time: 19:37:01
                    Fault Frequency: 24
                    Reset counter: 148
                    Mileage: 100626 km
                    Date: 2019.10.13
                    Time: 03:01:32
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 7
                    Reset counter: 108
                    Mileage: 101183 km
                    Date: 2019.10.27
                    Time: 20:10:01
                    Bin. Bits:    00000
                    Voltage: 11.60 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 01:04:10
                    Bin. Bits:    10000
                    Voltage: 11.70 V
                    Count: 9
                    Bin. Bits:    10000
                    Time: 5.30 s
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:38
          U1017 00 [137] - -
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:55:42
   Coding: 010211
   Coding: 000102
          U1113 00 [009] - -
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:10:37
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 78
                    Mileage: 100575 km
                    Date: 2019.10.12
                    Time: 13:56:12
                    Reset counter: 148
                    Mileage: 101183 km
                    Date: 2019.10.28
                    Time: 01:03:45
                    Voltage: 11.80 V
   Coding: 1021008
                    Reset counter: 108
                    Mileage: 101182 km
                    Date: 2019.10.28
                    Time: 01:09:39
                        Term 15 On
                        Reverse OFF
                    Count: 3
Ape Factory
C?ID=321067
Ran through the gateway controller measuring blocks. Most of the data was actually in the 150+ range. Is there a way to get a list of what all the measuring blocks are for my make/model? Assuming they change based on that criteria.
Anyway...everything checked out except for the active steering module which had a value of 0. Can’t connect to it with the VCDS when I try to access that module. Other items like the ABS brakes, which has a 0010 malfunction shows a 1 through the gateway controller measuring block function.
I’m thinking many of the malfunctions are tied into the active steering and I am unable to erase the dtc’s because of that. The backup cam error is strange though as it’s working.
Not sure what my next step should be. Thanks again for the help.
Michel
Ape Factory
C?ID=321067
Full log from this morning.
Tuesday,29,October,2019,06:31:44:27520
VIN: WUAC6AFR6DA902467 License Plate: GATEWAY INSTALL LIST
Gateway Installation List: 8R0 907 468 P
52 53 56 5F 6C
VIN: WUAC6AFR6DA902467 Mileage: 101190km-62876miles
Revision: NAH04---
U1113 00 [047] - -
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:31
Coolant temperature: 74 °C
Intake air temperature: 61 °C
Voltage terminal 30: 11.709 V
AFS dm: 0.0 kg/h
U0130 00 [047] - No Communications
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:32
AFS dm: 0.0 kg/h
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:32
Readiness: 0010 1101
Revision: --H01---
Coding: 302D1A
Reset counter: 109
Mileage: 101191 km
Date: 2019.10.28
Time: 16:16:24
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0011
Hex Value: 0x858B
Hex Value: 0x0000
Reset counter: 109
Mileage: 101191 km
Date: 2019.10.28
Time: 16:16:24
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x000F
Hex Value: 0x508B
Hex Value: 0x0000
Reset counter: 109
Mileage: 101197 km
Date: 2019.10.29
Time: 06:23:57
Hex Value: 0x0000
Hex Value: 0x02A2
Hex Value: 0x000C
Hex Value: 0x4693
Hex Value: 0x0000
Coding: 4802200000
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:27
Fault Status: 01100011
Reset counter: 109
Mileage: 101191 km
Date: 2019.10.28
Time: 16:31:23
Voltage: 14.10 V
Temperature: 30.0°C
Temperature: 31.0°C
Count: 25000
Count: 10988
Bin. Bits: 01000000
Bin. Bits: 10001011
Time: 65.00 s
Coding: 00FD11
Coding: 02005D
H01 0031
H01 0031
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:28
Coding: 00333E
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:28
Temperature: 33.0°C
Voltage: 11.52 V
Hex Value: 0x00BE
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:28
Temperature: 33.0°C
Voltage: 11.52 V
Hex Value: 0x00C0
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:28
Temperature: 33.0°C
Voltage: 11.52 V
Hex Value: 0x0084
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:30
Coding: 00003E
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:29
Coding: 80E3031600
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:28
Bin. Bits: 10111
Voltage: 11.80 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
U1017 00 [137] - -
[ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
Fault Frequency: 6
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:30
[Steuergerät für aktive Lenkung keine Kommunikation DTC_CAN_STEER_CTL_NO_COM]
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:30
0252 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[12V Unterspannung CAN Spannungsdiagnosegrenze DTC_CAN_LOW_VOLTAGE]
Reset counter: 149
Mileage: 101184 km
Date: 2019.10.28
Time: 16:01:14
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:27
Coding: 010211
Coding: 000102
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0012646993
Coding: 010000010001
ROD: EV_RCEPSAU48X_008.rod
VCID: 3431E21F0EBDD7A71DF-8060
3158408 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Botschaftsausfall des SCU-Steuergeräts]
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:30
Write only channel
4208000 - Steering Angle Sensor
B1168 F1 [008] - Synchronization Failed
Reset counter: 149
Mileage: 101184 km
Date: 2019.10.28
Time: 16:01:14
Write only channel
U1113 00 [009] - -
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:30
Voltage terminal 30: 11.8 V
Function light in parking brake button: OFF
Red operating lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:32
Coding: 1021008
Fault Frequency: 6
Reset counter: 109
Mileage: 101184 km
Date: 2019.10.28
Time: 16:00:27
Term 15 On
Reverse OFF
Count: 3
End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Morski
Cheshire UK
C?ID=90186
I think you really need to relook at the fuses and the location of other fuses for the power steering. Audi have done a good job of putting fuses in all sorts of locations. There is some high power fuses next to the jump start terminal in the engine bay, some are under the dash, either side of the dash panels, bottom of the A posts, in the rear and some in the ecu box that i can recall.
being the power steering its going to be a high ampage one around 40A iirc which is for the motor which you say is working but there may also be another smaller amp fuse for its ecu so have a look on erwin and trace the power feeds for the steering system.
No signal or no communication is either a power issue or a dead module
i would also replace the relay you tested with another one from elsewhere in the car to test as it 'may' be damaged.
Could be a bad twisted CAN set to the module too no?
Did you measure the termination resistor at each end for the 0x1B?
Overlay?
Ape Factory
C?ID=321067
I did that actually. I pulled the ECU, checked all the fuses underneath too. The 2013 RS5 has fuses in different locations and not at all in others compared to say an A5 TDI or something similar. Most of the steering ones are 35A. The relay was fine. It clicked and I measured its resistance. It gets stranger...going to reply to the other reply and then update the thread :)
Ape Factory
C?ID=321067
Overlay?
Not sure what you mean by a bad twisted CAN set? I did not get to the point of measuring resistance in any of the modules. I only tested the one relay underneath the dash related to the power steering. It checked out.
So here's where it gets strange.
I decided to take another swipe at looking everything over and scanning every last module with the VCDS again before work this morning. Spent a good 1.5 hours going through every last issue listed on the VCDS, clearing the DTC's in the modules themselves (not globally) and in what I presume was the correct order based on what the VCDS was implying. Not sure if that's a real thing but it'd reference ECU errors but then say to check the ABS module. So I'd clear those first, then go to the ECU, etc...
I did all of that and really didn't find a smoking gun. I did a full test of the brake system while I was at it. I often cycle everything when bleeding the brakes anyway so I went through the motions.
I then went about checking every last fuse once more. Well ok, just the ones related to the issues. I found nothing. They all looked pristine. No dark marks on the blades, nothing blown. I looked with magnifying glasses just to be sure.
So at this point I'm thinking the used module from Lithuania for 1/4 of the price new looks pretty good...have it shipped express. I decided I'd do one last test and see if the module was actually receiving power. Was planning on doing that this weekend when I had more time as pulling the seat and flooring is time consuming.
Anyway...I headed out to work and about halfway to the highway it dawned on me that none of my dash lights were lit up. I think I was tired enough that I didn't even notice the lack of warning chimes upon startup that'd I'd been experiencing over the past three days. I switched the car into dynamic and the steering instantly became firm. Switched into comfort and it lightened up. ESC is working again, no ABS warnings, no AWD warnings, nothing. Like it never even happened.
I think the car was just pissed at me for doing something beyond stupid and I was being punished for it.
I'm not ready to call it solved. I know full well electrical gremlins can come roaring back. The only thing I can think of is there's a proper sequence to clearing the codes and perhaps, just perhaps, pulling the fuses with the battery still connected triggered a reboot somewhere. Otherwise I'm at a loss to explain my newly found good fortune.
Appreciate those who chimed in. Events like these make me long for carburetors again, LOL.
Ape Factory
C?ID=321067
Checked for codes this morning and nothing. Car functioning as it should! Craziness. If anything, this is making me want to take a deeper dive and really learn how to work with the VCDS. I've been putting it off for too long. It's literally the first "mod" I purchased after buying the Audi.
