Should I Up date my old cable
Ron
Australia
C?ID=113987
Hi
One of my first posts.
I'm looking for advice as to whether I should or if I need to up date to the latest Ross-Tech cable. My cable is about 10 years old but still works great. Does the new tool do anything the old one cant do?
Thanks in advance and apologise if I posted in the wrong area for my question :rolleyes:.
Cheers
Ron
If/when you buy a 2019 or later vehicle then you will need either a HEX-V2 or HEX-NET cable (VAG changed so much that it no longer possible to make the older cables such as HEX-CAN work with just software/firmware updates).
The newer cables are needed with some modules built from 2016 onwards as they use messages that are longer than the older cables can handle.
The newer cables also scan much faster.
So if your cable works fine with your current vehicle then there's no need to update (but you might like to), but when you change to a newer vehicle then it's quite likely you will benefit from or need a newer cable.
As Dave stated in the post above, it very much depends on what vehicle(s) you're working on. Starting at about MY 2015, there are some Adaptation channels in some infotainment systems that the HEX+CAN won't be able to change. Starting at MY 2016 (RDW) and 2017 (NAR), there are some control modules in some models of cars that the HEX+CAN can't access at all. And last, but not least, MY 2019 and newer cars are not supported with the HEX+CAN at all.
Ron
Australia
C?ID=113987
Hi, Thanks for the advice guys, I use it in my business so it may be a good idea to up date...... better to have it and not need it yet than not having it and needing it :)
RUZDO.O
Podgorica - MNE
C?ID=92103
Does Ross-Tech work to improve: adaptations, coding, basic settings, block measurements, and so on, for cars below 2016?
What I'm asking is that few people will service with a vcds car from 2016 - 2019, when they have a factory warranty.
myounus
Northwest UK
C?ID=321059
Hi Ron
I updated mine and love the V2. VCDS is by far the best tool.
RUZDO.O
Podgorica - MNE
C?ID=92103
The German version of the PCI vcds distributor restricted the use of HEX-CAN with version 17.8.1. Which is the English version of vcds latest for HEX - CAN. Why add a new version of vcds when the new data is not recognized by HEX - CAN.
Huh? Please explain what you mean. There has been nothing that worked before restricted in any new version. Moreover, a distributor simply does not have the ability to do that.
I'm sorry, I still don't see the problem. Here is a scan I just did on a 2018 Tiguan using a HEX+CAN interface and the current (19.6.1) version from the page you linked above:
Sonntag,22,September,2019,10:07:45:40007
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
VCDS Version: PCI 19.6.1.0
Datenstand: 20190821 DS308.0
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: 3VV4B7AX8JM153175   KFZ-Kennzeichen: ANNIE-PCI
Kilometerstand: 4355km   Reparaturauftrag: 19.6.1
Fahrzeugtyp  AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
          52 5F 69 6C 6D 75 A5 BB BC CA
Fahrzeug-Ident.-Nr.: 3VV4B7AX8JM153175   Kilometerstand: 4355km
03-Bremsenelektronik -- Status: Fehler 0010
05-Zugangs-/Startber. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: INTERFACEHARDWARE NICHT KOMPATIBEL
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
69-Anhänger -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
BB-Türelektronik hinten links -- Status: i.O. 0000
BC-Türelektronik hinten rechts -- Status: i.O. 0000
CA-Schiebedachelektronik -- Status: INTERFACEHARDWARE NICHT KOMPATIBEL
Adresse 01: Motorelektronik (J623-DGUA)       Labeldatei:. 06L-907-115-V1.clb
   Teilenummer SW: 5NA 907 115 A    HW: 06L 907 309 B
   Bauteil: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Codierung: 012A00122476010FB4000000000000000000000000000000
   Betriebsnr.: WSC 54483 002 1048576
   ASAM Datensatz: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C7C8ABEB7F7E0AF85-8068
4 Fehlercodes gefunden:
32900 - Steuergeraet defekt
          P2610 00 [032] - interner Zähler für Motorabschaltung
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
23765 - Steuergerät für Informationselektronik 1
          U1054 00 [032] - Keine Kommunikation
          [Neue Funktion! Erweiterte UDS Fehlercode Informationen werden nur von der aktuellen Hardware-Generationen unterstützt.]
5523 - Motorsteuergerät gesperrt
          P1570 00 [032] - -
7657 - Sekundärlufteinblassystem Bank 1
          P2440 00 [096] - Schaltventil hängt offen
Adresse 02: Getriebe (J217)       Labeldatei: 09G-927-749-V2.clb
   Teilenummer SW: 09G 927 158 Q    HW: 09G 927 158
   Bauteil: AISIN AQ8     206 3379
   Codierung: 0002000100000000000000000000000000000000
   Betriebsnr.: WSC 00066 790 00441
   ASAM Datensatz: EV_TCMAQ450031 001001
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 4182FB4AD0158D47D6-8014
Adresse 03: Bremsenelektronik (J104)       Labeldatei: 5Q0-907-379-IPB-V1.clb
   Teilenummer SW: 5Q0 614 517 CF    HW: 5Q0 614 517 AD
   Bauteil: ESC           H25 0513
   Revision: 00000000    Seriennummer: 50668000000792
   Codierung: 0BFA6BA454251B6FC5780307A2C849D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
   Betriebsnr.: WSC 01383 790 50316
   ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
   VCID: 77F65592CE5103F7A8-8022
1 Fehler gefunden:
16401 - Reifendruckwarnung
          C102D 00 [008] - -
          Sporadisch - bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 109
                    Kilometerstand: 3530 km
                    Datum: 2019.06.29
                    Zeit: 13:17:37
Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5Q0-959-435.clb
   Teilenummer SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Bauteil: VWKESSYMQB    037 0907
   Revision: 00037000    Seriennummer: 0473029683
   Codierung: 132C2C0723
   ASAM Datensatz: EV_KessyHellaMQBAB 004041
   VCID: 3E7880B6A1EBF2BFAB-806A
   Steuergerät für Heckklappenöffnung:
   Subsystem 1 - Teilenummer SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Bauteil: GEB.F.Heckoef  H17 0906
   Seriennummer: >900?82>
Adresse 08: Klima-/Heizungsel. (E87)       Labeldatei:| 3V0-907-044.clb
   Teilenummer SW: 5NN 907 044 K    HW: 5NN 907 044 K
   Bauteil: AC Automat    H35 4401
   Revision: 20K03000    Seriennummer: 00000D00137092
   Codierung: 00020024200118001105010C1211140E
   ASAM Datensatz: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 54ACC21E3F6708EF6D-8000
   Geber für Luftfeuchtigkeit: außen:
   Klimabedienteil hinten:
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
   Teilenummer SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Bauteil: BCM PQ37BOSCH 034 0246
   Revision: --------    Seriennummer: C86410041801FN
   Betriebsnr.: WSC 00066 790 00451
   ASAM Datensatz: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0C1C1A7EA7D7102FF5-8058
   Steuergerät für Wischermotor:
   Subsystem 1 - Teilenummer SW: 5NN 955 119     HW: 5NN 955 119   Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: 326 LL 180316  034 0373
   Seriennummer: 18031522018260
   Codierung: 0E4DDD
   Sensor für Regen- und Lichterkennung:
   Subsystem 2 - Teilenummer SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labeldatei: DRV\5Q0-955-547.CLB
   Bauteil: RLHS  047 0105
   Seriennummer: SBY18M04D09H15M43S34
   Codierung: 00A8DD
   Geber für Luftfeuchtigkeit: innen:
2 Fehlercodes gefunden:
13762560 - Komponentenschutz
          U1114 00 [008] - GFA-Schlüssel
206085 - Funkfernbedienung
          B1311 54 [009] - keine Grundeinstellung
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\5Q0-919-294.clb
   Teilenummer SW: 5QA 919 294 B    HW: 5QA 919 294
   Bauteil: PDC 8 KanalH07 0044
   Seriennummer: 000116643R18104
   Codierung: 0471655911
   ASAM Datensatz: EV_EPHVA18AU3700000 009035
   VCID: 4B9ED962E25957173C-801E
Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
   Teilenummer SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Bauteil: ACCCONTIMQB   H02 0233
   Codierung: 320000C958FF8728749C8145304097
   ASAM Datensatz: EV_ACCMRRCONTIVW376 002012
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5Q0-959-655.clb
   Teilenummer SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Bauteil: AirbagVW21    004 0336
   Seriennummer: 003NUM08EVGI
   Codierung: 8CCCFC00000000005000001AC20800000065
   ASAM Datensatz: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 050A2F5A84BD6167AA-8050
   Sitzbelegungserkennung Beifahrerseite:
   Subsystem 1 - Teilenummer SW: 4M0 959 339 B    HW: 4M0 959 339 B
   Bauteil: BF-Gewichtss.  H13 0022
   Seriennummer: IBH000000000008Z10EI
   Codierung: 303352
   Subsystem 2 - Teilenummer SW: -----------    HW: 480 000 903 18
   Bauteil: SideSensor_Df  001 0887
   Seriennummer: 35700000000C27A45D2R
   Codierung: 2D2D2D
   Subsystem 3 - Teilenummer SW: -----------    HW: 480 001 702 18
   Bauteil: SideSensor_Pf  001 0887
   Seriennummer: 35800000000FB6099B2-
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 480 400 303 18
   Bauteil: SideSensor_Dr  000 6149
   Seriennummer: 3510001A328F9E53E5CO
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 480 400 203 18
   Bauteil: SideSensor_Pr  000 6149
   Seriennummer: 35200019F28F9E55A2BU
   Codierung: 2D2D2D
   Subsystem 6 - Teilenummer SW: -----------    HW: 480 402 403 18
   Bauteil: FrontSensor_D  000 6149
   Seriennummer: 3550001A929633C3240Y
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Beifahrerseite:
   Subsystem 7 - Teilenummer SW: -----------    HW: 480 402 403 18
   Bauteil: FrontSensor_P  000 6149
   Seriennummer: 3560001A929633C3A837
   Codierung: 2D2D2D
Adresse 16: Lenkradelektronik (J527)       Labeldatei:| DRV\5Q0-953-549.clb
   Teilenummer SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Bauteil: Lenks. Modul  004 0140
   Revision: --------    Seriennummer: 11021804400118
   Codierung: 0C10
   ASAM Datensatz: EV_SMLSKLOMQB 020002
   VCID: 030E31428A895F5784-8056
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
   Teilenummer SW: 5NA 920 891 B    HW: 5NA 920 891 B
   Bauteil: KOMBI         408 3195
   Codierung: 0BA4041AEF88CF0502886B0B54010000A0000000
   ASAM Datensatz: EV_DashBoardVDDMQBAB 009058
   VCID: 438EF142CA099F57C4-8016
1 Fehler gefunden:
9456681 - Schlüssel
          B104C 29 [008] - unplausibles Signal
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 543 km
                    Datum: 2018.10.24
                    Zeit: 14:17:10
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   518 5323
   Seriennummer: 16031800841058
   Codierung: 030500347F085900FB07225A1E0F00010001070000000000000000000000
   Betriebsnr.: WSC 131071 1023 2097151
   ASAM Datensatz: EV_GatewNF 013023
   ROD: EV_GatewNF.rod
   VCID: 387496AE83CFCC8F61-806C
   Generator:
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 5NN 959 442 A    HW: 5NN 959 442 A
   Bauteil: E221__MFL-TAT  H06 0023
   Seriennummer: 0231821410402383BO2B
   Codierung: 2E0000
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 5QA 915 181 D    HW: 5QA 915 181 D
   Bauteil: J367-BDMHella  H10 9070
   Seriennummer: 5719055700
Adresse 22: Allrad (J492)       Labeldatei:* DRV\0CQ-907-554.clb
   Teilenummer SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Bauteil: Haldex4Motion H52 7084
   Seriennummer: HA1-00022.01.18
   Codierung: 0101
   ASAM Datensatz: EV_AllWheelContrHA1VW37X 004013
   VCID: 4C9CDA7EE757502F35-8018
Adresse 2B: Lenksäulenverrieg. (J764)       Labeldatei:* DRV\5Q0-905-861.clb
   Teilenummer SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Bauteil: ELV-MQBB      H05 0020
   Seriennummer: 18000048647017
   Codierung: 0800000000000000
   ASAM Datensatz: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 336EA1829AA92FD754-8066
Adresse 36: Sitzverst. Fahr. (J810)       Labeldatei:* Keine
   Teilenummer SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Bauteil: Sitzmemory    H09 0023
   Seriennummer: Y0006RC910540
   Codierung: 0010000000000500018280808080000000008101000000F400
   ASAM Datensatz: EV_SeatMemorDriveSide 002022
   VCID: 3D7A87BAACEDE9A7B2-8068
Adresse 3C: Spurwechsel (J1086)       Labeldatei:| DRV\5Q0-907-686.clb
   Teilenummer SW: 5Q0 907 686 C    HW: 5Q0 907 686 C
   Bauteil: HRE_Master    H12 0080
   Seriennummer: 0471437951
   Codierung: 02012103
   ASAM Datensatz: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW37.rod
   Steuergerät 2 für Spurwechselassistent:
   Subsystem 1 - Teilenummer SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Bauteil: HRE_Slave  H12 0080
   Seriennummer: 0471513457
   Codierung: 020121
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
   Teilenummer SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Bauteil: TSG FS        011 0032
   Seriennummer: 5038810100743
   Codierung: 003F1B205200028000000000
   ASAM Datensatz: EV_DCUDriveSideEWMAXCONT 006001
   VCID: 4796E552FE31B37718-8012
Adresse 44: Lenkhilfe (J500)       Labeldatei:| DRV\5Q0-909-143.clb
   Teilenummer SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
   Bauteil: MQB_PP_APA    204 2051
   Revision: 00000000    Seriennummer: 0002329142
   Codierung: 01000011004001
   ASAM Datensatz: EV_SteerAssisVWBSMQBA 009129
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 4084FE4EDB1F844FD9-8014
Adresse 47: Soundsystem (J525)       Labeldatei:| DRV\5Q0-035-456.clb
   Teilenummer SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Bauteil: MIB2_lite_amp H40 0200
   Revision: 00000001    Seriennummer: VWZ8Z1HMD01XC5U
   Codierung: 2200000000AAAAAA000000000000
   ASAM Datensatz: EV_AMPMst12C1Gen2ALPI 001003
   VCID: 2E58B0F6718B023F3B-807A
Adresse 4B: Multifunktionsstg.
Interfacehardware NICHT kompatibel.
Bitte erwerben Sie ein aktuelles Ross-Tech Diagnoseinterface.
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
   Teilenummer SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Bauteil: TSG BFS       011 0032
   Seriennummer: 6038806500458
   Codierung: 003F13205E00028000000000
   ASAM Datensatz: EV_DCUPasseSideEWMAXCONT 006001
   VCID: 4688E856F93BAA7FE3-8012
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-STD2.clb
   Teilenummer SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Bauteil: MU-S-NS-US    851 0867
   Seriennummer:
   Codierung: 027306020000000051220002001808001F0500E401200405C6
   Betriebsnr.: WSC 00066 790 00327
   ASAM Datensatz: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   Anzeige- und Bedienungseinheit 1 für Informationselektronik:
   Subsystem 1 - Teilenummer SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Bauteil: ABT_Std-2_Nav  H52 8130
   Seriennummer: VWZ6ZJV0816064
   Datenträger:
   Subsystem 2 - Teilenummer SW: 3G0 919 866 BP    HW: -----------
   Bauteil: NAR 2018  --- 0715
   Seriennummer: --------------------
1 Fehler gefunden:
0020 - Tuner für Satellitenradio
          B11CF 53 [009] - deaktiviert
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 11
                    Kilometerstand: 653 km
                    Datum: 2019.01.12
                    Zeit: 12:42:39
                    Spannung Klemme 30: 11.9 V
                    SDARS_tuner_status_2-Status Antenne für Satellitenradio: elektrisch i.O.
                    SDARS_tuner_status_2-Kanalauswahl für Satellitenradio: 0
                    SDARS_tuner_status_2-Audio Signal: verfügbar
                    SDARS_tuner_status_2-Antennenstrom: 106 mA
                    SDARS_tuner_status_2-Empfangsqualität: optimum_signal
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 07
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 07
Adresse 69: Anhänger (J345)       Labeldatei:| DRV\5Q0-907-383.clb
   Teilenummer SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Bauteil: Anhaenger     H27 0264
   Revision: 8A001003    Seriennummer: 0446515577
   Codierung: 0200000200000000
   ASAM Datensatz: EV_TrailFunctGener2Hella 001008
   VCID: 4280F446D513965FCF-8016
Adresse 6C: Rückfahrkamera (J928)       Labeldatei:* Keine
   Teilenummer SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Bauteil: Areaview 2    H13 0608
   Seriennummer: C854707JG027208
   Codierung: 01230601A30F20003000400C
   ASAM Datensatz: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 397293AAB8C5D5879E-806C
Adresse 6D: Heckklappe (J605)       Labeldatei:| DRV\5Q0-959-107.clb
   Teilenummer SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Bauteil: HDSG-Modul    H12 0261
   Revision: --------    Seriennummer: A2-C758-8700-0
   Codierung: 0AA8
   ASAM Datensatz: EV_DeckLidCONTIAU736 001014
Adresse 75: Telematik (J949)       Labeldatei:| 5QE-035-285.clb
   Teilenummer SW: 5QE 035 285 A    HW: 5QE 035 285 A
   Bauteil: OCULowMQBUS   009 0570
   Codierung: 02230602C2823A037F1E06020000
   ASAM Datensatz: EV_OCULowMQB 001006
   ROD: EV_OCULowMQB.rod
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3QD 980 654     HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H07 1272
   Seriennummer: 03011841K22321
   Codierung: 0003070601020201002213548150490084000E200120
   ASAM Datensatz: EV_MFKBoschMQBB 001001
   VCID: 0814266EB3AF7C0FD1-805C
Adresse BB: Türelektronik hinten links (J388)       Labeldatei:* Keine
   Teilenummer SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Bauteil: TSG HFS       012 0032
   Seriennummer: 0000306067820
   Codierung: 002011200101028000000000
   ASAM Datensatz: EV_DCURearDriveMAXCONT 006001
   VCID: 4992E36AE82545070E-801C
Adresse BC: Türelektronik hinten rechts (J389)       Labeldatei:* Keine
   Bauteil: TSG HBFS      012 0032
   Seriennummer: 0000305928013
   ASAM Datensatz: EV_DCURearPasseMAXCONT 006001
Adresse CA: Schiebedachelektronik
Ende----------------------------(Dauer: 06:22)-----------------------------
Yes, there are some modules that the old HEX+CAN interfadce is not compatible with, but this is known, and is not some new limitation imposed by the software. These modules never worked with with a HEX+CAN in any version of VCDS.
In addition, I would expect there to be some Adaptation Channels in 09 and 5F that the HEX+CAN cannot change. Same situation; this is due to hardware limitations in the old interface.
