01 TT 225 cluster questions
vwparts
C?ID=76058
hi! n00b here, so please bear with me. been a tech for volvo for a long time, so I know enough to know when i'm up to no good :D
here is an auto scan:
Monday,02,September,2019,21:06:45:51893
VCDS Version: 19.6.1.0 (x64)
Dealer/Shop Name: Rizzo's Repair
Workshop Code: 444 00066 001022
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
   Mileage: 112590km-69960miles
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 T
   Component: 1.8L R4/5VT     G   0003
   Coding: 06710
   Shop #: WSC 01236
   VCID: 428097554E45645FCF-50E6
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V004
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E78E3A53ABD00BFAB-4A82
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 285425FDC839AE0FF1-2554
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 1005
   Coding: 10102
   Shop #: WSC 01236
   VCID: 77F636815507F1F7A8-513C
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 E
   Component: KOMBI+WEGFAHRS. M73 D08
   Coding: 07244
   VCID: 336EC29101FFDDD754-4A9C
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F463E219D7769B780-4A9C
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N7 962 267 A
   Component: Central Lock/Alarm  D04
   Coding: 15900
   Shop #: WSC 01236
   VCID: 3E78E3A53ABD00BFAB-4E78
01366 - Opened Due to Crash Signal
            35-00 - -
Address 37: Navigation        Labels:
   VCID: 55AA5C09ACCBE3E79A-4A9C
   Note: Excessive Comm Errors
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N7 951 177
   Component: Innenraumueberw.    D14
   Coding: 00001
   VCID: 7BFE2AB1692FD597CC-50AC
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 65CA6CC9FFAB73670A-513C
End-------------------------(Elapsed Time: 03:26)--------------------------
what I am chasing here is a gauge issue. seems my coolant and possible fuel gauge steppers are a bit wonky. both gauges appear to be reading "proud" of the centerline after running the output tests. both are about a needles width to the right of the center mark during the test.
i'm not afraid to blow the cluster open and replace the steppers....been there done that with volvo's…
it would appear to me that this car DOES NOT have immobilizer capabilities. in ch 25 (iirc) it wouldn't communicate.
million dollar question (2 actually)
1) good place to get the steppers? I see them as low as 5.00 and as high as 100+. not being cheap, it never works for me....best place to get them.
2) local junk yard has a same vintage TT. I can get the cluster out of that for a cheap price (and will, because murphys law has it I will snap a pointer)
if I were to plug in said mystery cluster, what are the ramifications of doing so? my concern is the mileage may jump, or I could simply let the smoke out. I know mileage (on volvo's) is stored in several other modules so plugging in a cluster can overwrite mileage. I don't want to run that risk, but would like to plug in the used cluster to see if it works (again, I 100% intend on using my original cluster and the used one would be for messing around with)
please and thank you :o
Gone But Not Forgotten
vwparts
C?ID=76058
Hello OP and welcome to the VCDS Forum!
Couldn't you have a data transfer done to preserve mileage or just fix and calibrate the gauge's in adaption?
A new cluster could just be installed and adapted to program miles using RTFB, no?
hi! thanks for the reply. I have used ErWin before, no problem there.
I guess I muddied up my question...
if I plug a used cluster in just to see what it does, will I make a mess in other systems? or, will it render my original cluster useless? not as brave as I was when I was 20 :D
I could send my cluster out for sure....but honestly for stepper motors....it's really not that big of a deal for me to do it. solder in a new display? yea...someone else can do that for me (thankfully my display is fine....for now)
again, i'm a volvo tech of 20+ years now (I know, shoot me) and I know how angry stuff gets swapping out 'nodes' as volvo calls them....I am just not 100% sure on the architecture of VAG products...
This is the VCDS forum for OBD not regular repair area or tweaks area, right?
Repairs here or work procedure steps, should be queried in the RTFB, no?
What makes you think plugging in a cluster will pollute other modules?
Does this happen in Volvo and why It's a POS now made in China?
vwparts
C?ID=76058
hi
I was just asking for some guidance, real world experience. damned if you do, damned if you don't....you ask a question and get flamed....you do something without asking and get flamed, and cause a mess.
a simple "yea, you can plug in a used cluster to test it if you want....it won't do a,b,c" or "dude, DON'T DO IT because....." was all I was looking for. having spent most of my life working with VIDA and Ista, as mentioned in my first post....I know enough about VAG to be dangerous. not fully understanding a system is my issue. all info I have seems to tell me I can test a used cluster, but was just looking for confirmation that's all
hi
Yes you can, no? :p
I do not think anything bad will happen on a car that old. I believe the worst case is that the car won't start, but based on what I see in the Auto-Scan, it looks like this car is pre-immobilizer.
YES.......Won't a new or reman cluster permit miles to be set exactly in adaption and observed on cluster display & before saving in VCDS to be sure you are right?
vwparts
C?ID=76058
perfect guys, thank you.
it would appear that it isn't an immobilizer year, as I can't connect to anything immo related.
Hey are you a Vida eater and Ista grail sipper, you do realize I just ask a lot of questions to be helpful right and if it's a question it is is not a work instruction, you know for liability purposes & is why I don't give advice, but ask a ton of questions to make you realize your own outcome, via run on sentence?
You figured it out though, huh? ;)
IIRC, it was a mid-year "upgrade" (straight to Immo-3) on the TT in 2001.
UPGRADE?
Some might disagree no? :p
Like this?
