2015 Audi S3 Mechatronic problem? Possibly
Railroader
C?ID=247142
I have a 2015 Audi S3, I ran a scan on the transmission and some codes popped up, the codes auto clear when the car is turned off and come back once started and go through the gears, car seems to run and drive fine, car has a DQ250 DSG Apr stage 3 TCU tune, engine has a big turbo with supporting mods and runs on e85, transmission malfunction does no come on, it has 2x once when i did a 1/4 pull it came on at the end of the run and once at the end of a 3rd,4th,5th gear pull, any information on possible causes would be much appreciated
               Address 02: Auto Trans       Labels: 0D9-927-770.CLB
Control Module Part Number: 0D9 300 012     HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6A MQB  H53 4903
           Software Coding: 0014
            Work Shop Code: WSC 04742 780 00200
              ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                       ROD: EV_TCMDQ250021.rod
                      VCID: 53A53B173A8271D774-8006
8 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
Sunday,18,August,2019,11:03:30:30521
VCDS Version: 19.6.1.0 (x64)
VIN: WAUFFGFFXF1077035   License Plate:
                Address 02: Auto Trans       Labels: 0D9-927-770.clb
9 Faults Found:
21153 - Gear 1
21154 - Gear 2
21155 - Gear 3
21156 - Gear 4
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21158 - Gear 6
          P073B 00 [002] - Not Selectable
Address 02: DTCs cleared
Address 02: DTCs clearedSunday,18,August,2019,12:24:44:30521
12 Faults Found:
21153 - Gear 1
21154 - Gear 2
21155 - Gear 3
21156 - Gear 4
21157 - Gear 5
21158 - Gear 6
21159 - Gear R
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10909 - Cooling Oil Valve
Monday,19,August,2019,08:22:48:30521
Mileage: 66396km-41256mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 6C A9 BB BC
VIN: WAUFFGFFXF1077035   Mileage: 66396km-41256miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0602
   Revision: --H13---
   Coding: 0A1D00322426000E3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 489F1C7BF3C4C20F11-801C
Readiness: 1010 0100
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4903
   Revision: 03253104    Serial number: TFK01409241359
   Shop #: WSC 04742 780 00200
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 62734000003093
   Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   Revision: 00021000    Serial number: 0349814246
   Coding: 030C0C
   VCID: 3A7B76B3BD28A09F97-806E
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000470162
   Coding: 03000014010000000000000000001400
   VCID: 33655B979A4251D754-8066
   Serial number: FA988357000000000001
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011428800483
   Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AFBB6B3FDA8609FD7-802E
   Component: WWS371 141004  042 0585
   Serial number:         141021125002
   Coding: 0A47F7
   Serial number: 23336452
   Coding: 00006C
   Serial number: 08 08 2014  00001063
   Serial number: 00000000000060812115
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0000754G00000
   Coding: 101F00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331428205581
   Coding: 0030150011
   VCID: 428B0E53D5F8E85FCF-8016
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       220914038
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 4189015FD0FEF347D6-8014
   Serial number: 003GCR00VDBR
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 479D1F47FEDACD7718-8012
   Belt Pretensioner left:
   Serial number: 34178311B22101440278
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B22101470632
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400018PTT0L
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 310 14
   Serial number: 357000000005C289611G
   Subsystem 5 - Part No SW: -----------    HW: 480 002 310 14
   Serial number: 35800000000613896118
   Subsystem 6 - Part No SW: -----------    HW: 480 401 610 14
   Serial number: 3510002C918166B572C5
   Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
   Serial number: 3520002C718166B2B12.
   Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3550002B5175A8E081ED
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3560002B5175A8E2D1FM
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 18101404400027
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 0A1BE673AD48701FC7-805E
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4291
   Coding: 0BED181B3B8857050201EA001800000000000000
   VCID: 4C97206BE7BC2E2F35-8018
   Revision: --------    Serial number: 01101410802775
   Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EB9E93A5D818DF9F-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 17 10 2014  C0047695
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00004.09.14
   Coding: 0001
   VCID: 46831243F9D0D47FE3-8012
   Revision: 00000000    Serial number: 14000292251003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467588B9F4C56EF4D-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0348367775
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 387F6CBB8324B28F61-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0348774456
   Coding: 030211
   Serial number: 14101402090927
   Coding: 005D1F205C00048000000002
   VCID: 408F045BDBF4FA4FD9-8014
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8102
   VCID: 377D6F878E3ABDF768-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900SSR%
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   Serial number: 14101403111564
   Coding: 005D17205E00048000000002
   VCID: 3F8D07A7A60A85B7A0-806A
   Component: AFS-ECU       H01 0091
   Coding: 012200003F200400
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302J0EB005348
   Coding: 017301020000000021220002041A00102F000225010001043E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201YBT
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000002091400030299
   Compact Disc Database:
   Component: Gracenote  --- 3006
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 306F549B6B546ACF29-8064
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140920201090
   VCID: 7DF1BDAFEC8657A7F2-8028
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 15101406071203
   Coding: 004D17204000048000000002
   Component: TSG HBFS      020 0025
   Serial number: 15101406071201
End-------------------------(Elapsed Time: 05:40)--------------------------
Some of these TCUs have really wonky diagnostic stacks. Try un-checking "Use Aggressive Mode" in VCDS and see if those faults still show up. My guess is that they won't, and if so, I wouldn't worry about 'em.
Railroader
C?ID=247142
ok ill try that, just to mention that when i perform the scan with my eurodyne cable which has capability to do the adaptations and some coding, no codes pop up. Thanks
Gone But Not Forgotten
Sounds like a loose ground or problem cooler valve shorting the bus.
Railroader
C?ID=247142
What do you mean cooler valve shorting bus, I'm gonna be replacing the thermostat housing and pulling the injectors this weekend so I'll go over all the connections when I have everything torn apart
