2009 Audi A4 B8, Steering wheel (talk button) issue
otto
IL, United States
C?ID=178462
I have a 2009 A4 B8 non-NAVI. It has worked for several years until now. I am trying to troubleshoot a problem with my steering wheel (talk button). The other multifunction controls on the steering wheel work just fine. The problem is intermittent meaning I can be parked on a fresh start in the morning and hit the talk button and it works normal meaning I can provide a command per the Audi manual. But once I start driving the talk button does not respond once it is pressed and if I would drive to a location put the car in park (still running) and press the talk button it still refuses to work. So here are the general problems;
When I press the steering wheel button (while I am driving) it will not go into voice command mode for dialing etc. It does absolutely nothing.
Incoming calls into my mobile phone (while I am driving) do not always trigger the telephone mode screen to turn on, and/or the call does not go through to the speakers every time. This is an intermittent problem as well.
My phone device is an android running (Android version 9). Bluetooth connection to the car works fine. Attached is a fresh autoscan with no errors, which I have done several times. Is there a way to use VCDS to troubleshoot these issues?
Friday,02,August,2019,11:30:27:24553
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUSF78K39N0xxxxx   License Plate: 080219
Mileage: 122400km-76055mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          65 72 77
VIN: WAUSF78K39N0xxxxx   Mileage: 122400km-76055miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 26142 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: F9BAA47978863B875E-80AC
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0030
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: B6206F45091814FFF3-80E2
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 150500
   Shop #: WSC 02399 823 56573
   VCID: F9BAA47970863B875E-80AC
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0141
   Coding: 090100
   VCID: B3265651126A01D7D4-80E6
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0508000043807010
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000046520008
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0125.08.080763
   Coding: 64002000
   VCID: F2A893552DF048DF1F-80A6
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000208444
   Coding: 26005295063CAF010000080300003D0D0F1C520800010161000000
   VCID: B02C595DE37C3ACFA9-80E4
   Component: WWS 150808  H06 0070
   Serial number: SWFBIE 0000194
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10232262
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000209081197
   Component: UGDO HL US  H04 0060
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD1426P/
   Coding: 303836354230303030304A55304C384B3053
   VCID: C0CC099D5BDCAA4F59-8094
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0800001U8G
   Serial number: 6334MSME3F560157F
   Serial number: 6344MSME3E735127G
   Serial number: 6352QSME7808312CI
   Serial number: 6362QSME47030500/
   Serial number: 63732SME1608503CY
   Serial number: 63832SME7E071B0EB
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315HHN000BG
   Coding: 000016
   VCID: BD327069242EC7A732-80E8
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DR11UX88
   Coding: 831709000300D705020000
   VCID: AD124029F44E572782-80F8
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0094
   Revision: 4GB20042    Serial number: 4200G088038040
   Coding: 000303
   VCID: C6C01F8571F8847F63-8092
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1803C283130808
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020302
   VCID: F8BCA17D4B8C228F21-80AC
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001136122
   Coding: 00581300000000000000
   VCID: F7BEA24146922DF728-80A2
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000007618410
   Coding: 011C03204E00410001
   VCID: C1CA0C9958D6A34756-8094
   Revision: 00002001    Serial number: 0113865630
   Coding: 0106063A007A440402B001
   Component: GTO BF  H06 0040
   Serial number: 00000000000000065345
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: EE90872539C86C3FFB-80BA
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007593984
   VCID: C0CC099D53DCAA4F59-8094
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000199850
   VCID: B12A5C59E87633C7A6-80E4
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000004
   VCID: B424554DD76406EFCD-80E0
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0211
   Revision: 00000004    Serial number: AUZ5Z4H1038695
   Coding: 040200020101850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100223112
   Coding: 010C03204000210001
   VCID: C4C4058D47C4B66F7D-8090
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140786081891
   Coding: 0CD154
   Revision:             Serial number: 0000100223109
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005017358
   Coding: 0010370
   VCID: BB367E71FA3AC9970C-80EE
End----------(Elapsed Time: 01:51, VBatt start/end: 12.5V/12.4V)-----------
The status of the controls on the steering wheel should be visible at Address 16: Steering wheel, Measuring Blocks, likely Group 007 or 008. Look there when it's working, confirm you can see it change, and check it again when it's not working.
otto
IL, United States
C?ID=178462
I ran the measured blocks (006) twice and have inserted the log for a test while the car was parked (ignition running). When the car is parked and ignition off it states that same information because controls cant be used. I then started the car and moved all 4 tested points on the steering wheel. They registered activated until I stopped moving them and that is why the log states not operational.
Monday,05,August,2019,15:14:36:24553
Dealer/Shop Name:
VIN: WAUSF78K39N0XXXXX License Plate:
Address 16: Steering wheel (8K0 953 568 F)
15:14:17 Group 007: Multifunction Steering Wheel III
Not Oper. Multi-Function Button (Left)
Not Oper. Multi-Function Button (Right)
Not Oper. Thumb Button (Left)
Not Oper. Thumb Button (Right)
I still have 3 issues;
While driving incoming calls are not routed to the speakers.
While driving talk button on steering does not engage the voice commands.
While driving outgoing calls from the car unit should engage my phone to dial out. It does not.
I basically have to pick up the phone handset if I wanted to answer a call. BTW, the phone is connected to the car via BlueTooth verified on the radio screen and on the phone. I am just not sure which module controls the function of an incoming call. I guess it could be the radio itself which is a Generation III - Symphony III with no navigation.
I also have considered the clock spring being the issue just because it controls the controls on the steering wheel.
otto
IL, United States
C?ID=178462
Has anybody in the forum given my situation any thought? I am stumped at this point. Can the HEX-NET device even help me at this point?
otto
IL, United States
C?ID=178462
Had to go to the dealership for this problem. They were surprised that there were no error codes. They were told by Audi HQ that the issues with the Bluetooth side are rare and that the 5F module that controls the BT will need replacement. That part is (8T0862336F). I will replace the module myself with a new or used and hopefully, the current codes in the module will transfer over if there are problems. Will post more once I get there. If there are any pointers from the forum, please reply. Thx
3 issues;
