2013 Volkswagen tdi blinking glow plug light limited rpms and no power
Tdibros4
Surrey, BC, Canada
C?ID=330170
Car came in not running, checked fault codes. Cleared codes and deactivated transport mode. After car would start after a really long cranking and run poorly. Checked codes again and pin tested the faulting components back to the ecu. wiring tested good. Got a used ecu from the exact make and model (has different part # tho) and had Malone delete the immobilizer. Installed the ecu and it fired right up and initially had no codes in the engine. Took it for a drive, still glow plug light flashing and lack of power with limited rpms
2013 jetta tdi auto scan
Monday,15,July,2019,13:02:54:45192
VCDS Version: 19.6.0.6 (x64)  HEX-NET CB: 0.4505.4
VIN: 3VWWL7AJ0BM044336   License Plate:
Mileage: 136640km-84904mi   Repair Order: 2013 jetta tdi
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWWL7AJ0BM044336   Mileage: 136640km-84904miles
   Part No SW: 03L 997 030 Q    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H13---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 3C34C3CC7FDB2FAF89-8068
15 Faults Found:
008215 - Intake Manifold Flap Position Sensor (Bank 1)
               P2017 - 000 - Short to Plus - MIL ON
                    Fault Status: 11100000
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Voltage: 11.93 V
                    Lambda: 0.0 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
009258 - Exhaust Gas Temperature Sensor; B1 S3
               P242A - 001 - Malfunction - MIL ON
                    Fault Status: 11100001
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Voltage: 11.93 V
                    Temperature: -40.5°C
                    Temperature: 930.0°C
008241 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
               P2031 - 001 - Electrical Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Voltage: 11.93 V
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0544 - 001 - Circuit Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Voltage: 11.93 V
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
               P246E - 001 - Electrical Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Voltage: 11.93 V
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 000 - Signal too High - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Temperature: -90.0°C
                    Temperature: 99.0°C
                    Temperature: 27.9°C
                    Temperature: 25.2°C
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Temperature: 99.0°C
                    Temperature: 27.9°C
                    Temperature: 25.2°C
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:01
                    Temperature: 25.2°C
                    Temperature: 18.0°C
                    Lambda: 89.2 %
                    Lambda: 0.0 %
               P0544 - 000 - Circuit Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:05
                    Voltage: 11.93 V
               P2031 - 000 - Electrical Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:05
                    Voltage: 11.93 V
               P242A - 000 - Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:05
                    Voltage: 11.93 V
               P246E - 000 - Electrical Malfunction - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:05
                    Voltage: 11.93 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:38:20
                    RPM: 989 /min
                    Voltage: 10.87 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 435.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000403 - Fuel Pressure Sensor (G247)
               P0193 - 000 - Short to Plus - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:38:22
                    RPM: 1012 /min
                    Voltage: 13.76 V
                    Inj. Quantity: 4.7 mg/str
                    Temperature: 37.8°C
                    Temperature: 27.0°C
001037 - EGR Temperature Sensor 1
               P040D - 000 - Signal too High - MIL ON
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:42:36
                    (no units): 0.0
                    Temperature: -48.0°C
                    Temperature: -276.0°C
Readiness: 1 10 0 1 1
   Revision: 00H31001
   Coding: B14B400C492200FB8D0E02E492200042211000
   VCID: 7DB20EC8E441E6A7FE-8028
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 36
                    Mileage: 136649 km
                    Date: 2013.11.30
                    Time: 23:36:17
                    Count: 3
                    Count: 2
                    Count: 20736
                    Count: 8193
                    Count: 42752
                    Count: 3328
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001278198
   VCID: 608C57BCB3F32B4FF5-8034
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371307120423
   Coding: 73994B9A08230F0008382000240884C50082502E60000000300000000000
   VCID: 2F2EE4807EADC4373C-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585131121215058
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH00072H95
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0595039
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
03589 - Switch for Driver Side Window Regulator
                    Fault Status: 00101110
                    Reset counter: 76
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM08Y5D1
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3424EBEC9F8BE7EF41-8060
   Serial number: 6940000Y120000LYAK0C
   Coding: 303038
   Serial number: 3572MSME0A64557FZZZ2
   Serial number: 3582MSME6C6D6272ZZZ5
   Serial number: 3516KSME280D201FZZZU
   Serial number: 3526KSME7B553E1FZZZ8
   Serial number: 3566LSME1B0E4D17ZZZ3
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 136649 km
                    Date: 2019.07.12
                    Time: 21:48:12
   Part No SW: 5C6 920 852 A    HW: 5C6 920 852 A
   Component: KOMBI         H06 0705
   Coding: 370E00
   Shop #: WSC 00066 000 00122
   VCID: 291A0A984849AA07E2-807C
13639424 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
          [Steuergerät für Motor: bitte Fehlerspeicher auslesen Kühlmitteltemperatur]
                    Reset counter: 36
                    Mileage: 136649 km
                    Date: 2019.07.15
                    Time: 00:36:49
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70AC27FCA3139BCF65-8024
   Component: IMMO          H06 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9835948DCF611F2B-803E
   Revision: A1001003    Serial number: 7663492811
   Coding: 010100
   VCID: 2A18F594454FA11FEB-807E
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 373EDCE046FD0CF764-8062
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3455789
   Coding: 01000400020006
   VCID: 230618B022657057A8-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663433608
   Coding: 0210040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A38C5D4BDEF119F9B-806E
End----------(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V)-----------
Help please
Tdibros4
Surrey, BC, Canada
C?ID=330170
Oh and rad fans stay running when the car off. is it possible all these things could be corrected by coding the ecu to the car?
Wow, the ECU has a whole truckload of various electrical malfunctions. All those things didn't fail simultaneously. There's some common source for most (if not all) of this. Get out your wiring diagrams, identify each of the components with a fault code, and look for what they might have in common. My WAG is a bad ground.
Are you sure you've got the correct ECU for the car?
Tdibros4
Surrey, BC, Canada
C?ID=330170
I agree it’s a centralized problem, the components didn’t fail all at once.and I did check the wiring from the components to the ecu and didn’t find anything wrong. Which is why I changed the ecu which did fix a bunch of things. I don’t have a good set of wiring diagrams for this car tho. I have the Bentley that covers up to cbea but not cjaa if anyone has some good engine diagrams for the cjaa and want to share them that would be great. no I’m not sure I have the right ecu. Although when I initially installed it it the car had very little faults. It wasn’t until I started clearing codes in other modules for no communication with the ecu that the faults started popping up in the engine. I’m prepared to get a pass through device to use Odis to work with the ecu. But I’m stuck right now. Is it worth coding the ecu to the car or is more likely I need to find bad wiring, or would a bad cluster cause these symptoms?
I do not think a problem with the instrument cluster could cause those faults in the ECU.
I do not think that "coding the ECU to the car" (which I presume means matching it to the immobilizer) is likely fix them either.
Assuming the ECU is correct for the car, I really think you've got some physical electrical problem that underlies this.
These are my opinions only. They are free of charge and come with a double-your-money-back guarantee if I'm wrong. :)
You may wish to look at: Where do I get a Wiring Diagram?
Gone But Not Forgotten
Looks like a wire is open or crossed on the daisy chain of shared components for EGT/Intake flap or a sensor on chain is wrong or faulty!
Don't dismiss Uwe's FOD too!
Vehicle Identification No. 3VWWL7AJ0BM044336
Model Jetta
JEM
Date of production 05.12.2010
Model year 2011
Sales type 162W9L
Engine Code CJAA
Transmission Code LHD
PART NUMBER ILLUSTRATION DESCRIPTION REMARK MODEL RRP PG QUANTITY
03L 997 030 Q control module-diesel engine
03L 130 118
(9-156) CJAA+PR-7GB+
G0K $1,272.31
Vehicle intelligent genuine part.
Order only with additional instructions.
Also Use
03L 130 118 vibration damper
Tdibros4
Surrey, BC, Canada
C?ID=330170
Thank you very much for your help I really appreciate it
Tdibros4
Surrey, BC, Canada
C?ID=330170
I’m having real problems with the Erwin site I cannot login I have been on the phone with them and they have sent several new logins and none of the work. I have been trying to get set with Erwin for a week now err.
Tdibros4
Surrey, BC, Canada
C?ID=330170
I apologize in advance I’m new to this forum let me know if I’m out of line at anytime
Obviously erWin is not a Ross-Tech product....
But I'm curious: What kind of computer and what browser are you using?
Tdibros4
Surrey, BC, Canada
C?ID=330170
I use VCDS to communicate with the car. The Erwin is a vw site has things like ETKA
I was just trying to get wiring diagrams from vw and ETKA on Erwin. But after all your guys’ help I was able to feel confident I had the right ecu and the coding wasn’t cause the problem I had a friend at a local vw dealer pull diagrams for me and did some more testing I have crossed wires in the engine harness, I have a new engine harness on the way and feel very confident this will solve all or most of my problems. Huge thanks to everybody that contributed
